CSR2512JT33L0
CSR2512JT33L0
    SEI
    贴片电阻 2512 33mΩ ±5% 2W ±200ppm/℃
CSR2512JT33L0 数据手册
CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Features: • • • • • • 0201 to 1225 sizes available Power ratings to 3W Low inductance – less than 0.2nH typically RoHS compliant and halogen free Non-standard resistance values available 0815, 2010 and 2512 sizes available with narrow terminations (CSRN) Electrical Specifications - CSR Type / Code Power Rating (W) @ 70°C Dielectric Withstanding Voltage (V) CSR0201 0.05 200 CSR0402 CSR0603 CSR0805 CSR1206 0.125 0.125 0.25 0.5 200 200 200 200 CSR1210 0.5 200 CSR2010 CSR2512 1 2 200 200 CSR0830 2 200 CSR1225 3 TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 1% ± 1000 ± 600 ± 300 ± 200 ± 300 ± 200 ± 100 (1) ± 600 ± 400 ± 300 ± 200 ± 100 (1) ± 200 ± 300 ± 200 ± 150 - ± 300 ± 200 ± 150 ± 100 200 2%, 5% 0.1 - 0.147 0.15 - 0.499 0.511 - 1 0.0511 - 1 0.02 - 1 0.02 - 1 0.01 - 1 0.01 - 0.02 0.0205 - 0.0511 0.0523 - 0.0976 0.1 - 1 0.01 - 1 0.01 - 1 0.001 - 0.004 0.0051 - 0.01 0.0102 - 0.348 0.003 - 0.0049 0.0051 - 0.02 0.0205 - 0.0301 0.0332 - 7.87 (1) Contact Stackpole for TCR below 50 mohm Electrical Specifications – CSRN (Narrow Termination) Type / Code Power Rating (W) @ 70°C CSRN2010 1 Dielectric Withstanding Voltage (V) 200 CSRN0815 1 200 CSRN2512(*) (*) AEC-Q200 Qualified 2 200 TCR (ppm/ºC) ± 250 ± 300 ± 150 ± 200 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.01 - 1 0.01 - 0.0196 0.02 - 0.499 0.01 - 1 Electrical Specifications – CSR-HP Type / Code CSR0603…-HP Power Rating (W) @ 70°C Dielectric Withstanding Voltage (V) TCR (ppm/ºC) 200 ± 400 ± 300 ± 200 0.2 Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.051 - 0.1 0.102 - 0.499 0.51 - 1 www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Electrical Specifications – CSR-HP (cont.) Power Rating (W) @ 70°C Type / Code CSR1210…-HP Dielectric Withstanding Voltage (V) TCR (ppm/ºC) 200 ± 600 ± 400 ± 300 ± 200 0.75 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.01 - 0.02 0.0205 - 0.0499 0.051 - 0.091 0.1 - 1 Please refer to the High-Power Resistor Application Note (page 7) for more information on designing and implementing high power resistor types. Mechanical Specifications Type / Code Weight (g) (1000 pieces) CSR0201 0.18 CSR0402 0.7 CSR0603 1.99 CSR0805 5.3 CSR1206 8.82 CSR1210 15.5 CSR2010 27.03 CSR2512 53.08 CSR0830 35.71 Type / Code Weight (g) (1000 pieces) CSRN0815 19.96 CSRN2010 27.03 CSRN2512 53.08 L Body Length 0.024 ± 0.001 0.60 ± 0.03 0.039 ± 0.002 1.00 ± 0.05 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.006 2.00 ± 0.15 0.120 ± 0.006 3.05 ± 0.15 0.122 ± 0.004 3.10 ± 0.10 0.197 ± 0.008 5.00 ± 0.20 0.252 ± 0.008 6.40 ± 0.20 0.079 ± 0.008 2.00 ± 0.20 W Body Width 0.012 ± 0.001 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.006 1.25 ± 0.15 0.061 ± 0.006 1.55 ± 0.15 0.102 ± 0.006 2.60 ± 0.15 0.100 ± 0.008 2.54 ± 0.20 0.126 ± 0.008 3.20 ± 0.20 0.295 ± 0.012 7.50 ± 0.30 T Body Height 0.009 ± 0.002 0.23 ± 0.05 0.013 ± 0.004 0.32 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 0.020 ± 0.006 0.50 ± 0.15 0.024 ± 0.004 0.60 ± 0.10 D1 Top Termination 0.005 ± 0.002 0.12 ± 0.05 0.010 ± 0.004 0.25 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.068 ± 0.006 1.72 ± 0.15 0.075 ± 0.006 1.90 ± 0.15 0.016 ± 0.008 0.40 ± 0.20 D2 Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 0.016 ± 0.010 0.40 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.067 ± 0.006 1.70 ± 0.15 0.075 ± 0.006 1.90 ± 0.15 0.016 ± 0.008 0.40 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Mechanical Specifications – CSRN (Narrow Termination) L Body Length 0.079 ± 0.008 2.00 ± 0.20 0.197 ± 0.008 5.00 ± 0.20 0.250 ± 0.008 6.35 ± 0.20 W Body Width 0.148 ± 0.008 3.75 ± 0.20 0.096 ± 0.006 2.45 ± 0.15 0.124 ± 0.006 3.15 ± 0.15 Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 T Body Height 0.024 ± 0.004 0.60 ± 0.10 0.024 ± 0.006 0.60 ± 0.15 0.024 ± 0.004 0.60 ± 0.10 D1 Top Termination 0.016 ± 0.008 0.40 ± 0.20 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 D2 Unit Bottom Termination 0.016 ± 0.008 inches 0.40 ± 0.20 mm 0.020 ± 0.010 inches 0.50 ± 0.25 mm 0.022 ± 0.010 inches 0.55 ± 0.25 mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Mechanical Specifications – CSR1225 Type / Code Weight (g) (1000 pieces) L W T D1 D2 F Unit 64.88 0.126 ± 0.006 3.20 ± 0.15 0.254 ± 0.006 6.45 ± 0.15 0.035 ± 0.006 0.90 ± 0.15 0.024 ± 0.012 0.60 ± 0.30 0.031 ± 0.010 0.80 ± 0.25 0.090 ± 0.005 2.29 ± 0.13 inches mm CSR1225 Performance Characteristics Test Method Test Specification Typical Test Condition High Temperature Exposure Test MIL-STD-202 Method 108 1% Tol: (± 1% + 0.05Ω) 2%, 5% Tol: (± 1.5% + 0.1Ω) ≤ 0.5% 1000 hours at T = 155°C. Unpowered. Measurement at 24 ± 4 hours after test conclusion. Short Time Overload JIS-C-5201-1 4.13 IEC 60115-1 4.13 ± (0.5% + 0.05Ω) ≤ 0.25% ± (1% + 0.05Ω) For high power rating ≤ 0.5% RCV (rated current) * 2.5 for 5 seconds. 1000 Cycles (-55°C to +125°C) Measurement at 24 ± 4 hours after test conclusion. 30 minuntes maximum ≤ 0.5% dwell time at each temperature extreme. 1 minute maximum transition time. 1000 hours 85°C / 85% RH. Note: Specified ≤ 0.5% conditions: 10% of operating power. Measurement at 24 ± 4 hours after test conclusion. Temperature Cycling JESD22 Method JA-104 1% Tol: (± 0.5% + 0.05Ω) 2%, 5% Tol: (± 1.5% + 0.1Ω) Biased Humidity MIL-STD-202 Method 103 1% Tol: (± 1% + 0.1Ω) 2%, 5% Tol: (± 2% + 0.1Ω) Operational Life MIL-STD-202 Method 108 1% Tol: (± 1% + 0.1Ω) 2%, 5% Tol: (±2% + 0.1Ω) ≤ 0.5% External Visual MIL-STD 883 Method 2009 - Pass Physical Dimensions JESD22 Method JB-100 - Pass MIL-STD 202 Method 215 Marking unsmeared Pass MIL-STD 202 Method 213 1% Tol: (± 0.25% + 0.05Ω) 2%, 5% Tol: (± 1% + 0.05Ω) ≤ 0.5% Resistance to Solvents Mechanical Shock Vibration MIL-STD 202 Method 204 1% Tol: (± 0.5% + 0.05Ω) 2%, 5% Tol: (±1% + 0.05Ω) Resistance to Soldering Heat MIL-STD 202 Method 210 1% Tol: (± 0.5% +0.05Ω) 2%, 5% Tol: (± 1% + 0.05Ω) ESD AEC-Q200-002 -- Solderability J-STD-002 > 95% Coverage Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 Condition D Steady State TA = 125°C at rated power. Measurement at 24 ± 4 hours after test conclusion. Electrical test not required. Inspect device construction, marking and workmanship. Verify physical dimensions to the applicable device detail specification. Note: User(s) and supplier specification, electrical test not required. Note: Aqueous wash chemical - OKEM Clean or equivalent. Do not use banned solvents. Figure 1 of Method 213. Condition C. 5g's for 20 minuntes, 12 cycles each of 3 orientations. Note: Use 8" X 5" PCB 0.031" thick 7 secure points on ≤ 0.5% one long side and 2 secure points at corners of opposite sides. Parts mounted within 2" from any secure point. Test from 10 - 2000Hz. Condition B no pre-heat of samples. Note: Single ≤ 0.5% wave solder - Procedure 2 for SMD. With the electrometer in direct contact with the discharge tip, verify the voltage setting at levels of ± Pass 500V, ± 1kV, ± 2kV, ± 4kV, ± 8kV. The electrometer reading shall be within ± 10% for voltages from 500V to ≤ 8kV. Electrical test not required. Magnification 50 times. Conditions: SMD: Pass a) Method B, 4 hours @ 155°C dry heat @ 235°C. b) Method B @ 215°C category 3. c) Method D category 3 at 260°C. www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Method Electrical Characterization User Spec Flammability UL-94 Board Flex AEC-Q200-005 Terminal Strength (SMD) Flame Retardance Voltage Proof Test Specification Typical -- Pass No ignition of tissue or scorching Pass of pine board. 1% Tol: (± 1% + 0.05Ω) ≤ 0.5% 2%, 5% Tol: (± 1% + 0.05Ω) AEC-Q200-006 No breakage Pass AEC-Q200-001 No flame Pass JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover Pass Test Condition Parametrically test per lot and sample size requirements, summary to show Min, Max, Mean and Standard Deviation at room as well as Min and Max operating temperatures. V - 0 or V - 1 are acceptable. Electrical test not required. 60 second minimum holding time. 1.42 times Max. Operating Voltage for 1 minute. 0201: 50V; 0402: 100V; 0603: 150V; 0805: 300V 1206, 1210, 2010, 2512, 0830, 1225, 0815: 400V Operating temperature range is -55ºC to +155ºC Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 40 20 155ºC 0 -60 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Recommended Pad Layouts - CSR Type / Code CSR0201 CSR0402 CSR0603 CSR0805 CSR1206 CSR1210 a 0.010 0.25 0.020 0.50 0.031 0.80 0.039 1.00 0.079 2.00 0.079 2.00 Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. b 0.012 0.30 0.020 0.50 0.039 1.00 0.039 1.00 0.045 1.15 0.045 1.15 4 0.016 0.40 0.024 0.60 0.035 0.90 0.053 1.35 0.067 1.70 0.098 2.50 c ± ± ± ± ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Recommended Pad Layouts – CSR (cont.) Type / Code a 0.039 1.00 0.142 3.60 0.193 4.90 0.047 1.20 CSR0830 CSR2010 CSR2512 CSR1225 b 0.071 1.80 0.055 1.40 0.063 1.60 0.079 2.00 0.299 7.60 0.098 2.50 0.126 3.20 0.276 7.00 c ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm inches mm 0.154 3.90 0.098 2.50 0.126 3.20 c ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm Recommended Pad Layouts - CSRN Type / Code a 0.039 1.00 0.142 3.60 0.193 4.90 CSRN0815 CSRN2010 CSRN2512 b 0.071 1.80 0.055 1.40 0.063 1.60 Reel Specifications Size 0201 0402 0603 0805 1206 1210 2010 2512 1225 0815 0830 A 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± B 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± C 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 5 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.374 9.50 0.374 9.50 0.374 9.50 0.374 9.50 0.374 9.50 0.374 9.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.689 17.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± T 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.453 11.50 0.453 11.50 0.453 11.50 0.453 11.50 0.453 11.50 0.453 11.50 0.610 15.50 0.610 15.50 0.610 15.50 0.610 15.50 0.768 19.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Packaging Specifications – Paper Tape Size 0201 0402 0603 0805 1206 1210 A 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.114 2.90 Size 0201 0402 0603 0805 1206 1210 ± ± ± ± ± ± ± ± ± ± ± ± B 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.002 0.05 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± E 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.004 0.10 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± ± ± ± ± F ± ± ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 D0 + + + + + + + + + + + + ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm inches mm inches mm 0.008 0.20 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm inches mm 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm inches mm T 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.017 0.42 0.018 0.45 0.028 0.70 0.033 0.85 0.033 0.85 0.033 0.85 ± ± ± ± ± ± ± ± ± ± ± ± Unit Packaging Specifications – Embossed Plastic Tape Type 2010 2512 1225 0815 0830 A 0.110 2.80 0.133 3.38 0.133 3.38 0.098 2.50 0.098 2.50 ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.217 5.50 0.263 6.68 0.263 6.68 0.175 4.45 0.327 8.30 Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.472 12.00 0.472 12.00 0.472 12.00 0.472 12.00 0.630 16.00 6 ± ± ± ± ± ± ± ± ± ± E 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 0.217 5.50 0.217 5.50 0.307 7.80 ± ± ± ± ± ± ± ± ± ± Unit www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Packaging Specifications – Embossed Plastic Tape (cont.) Type 2010 2512 1225 0815 0830 P0 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± P1 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± P2 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± D0 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.061 1.55 0.061 1.55 0.061 1.55 0.059 1.50 + + + + + + + + + + 0.004, -0 0.10, -0 0.002, -0 0.05, -0 0.002, -0 0.05, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 T 0.039 1.00 0.057 1.45 0.057 1.45 0.047 1.20 0.047 1.20 ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohms at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 mΩ. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series CSR CSRN Description Thick Film Current Sensing Surface Mount Chip Resistor Thick Film Current Sensing Surface Mount Chip Resistor, Narrow Package / Termination Type SMD SMD Standard Series RoHS Compliant YES by means of exemption 7c-I YES by means of exemption 7c-I Lead-Free Termination Composition Lead-Free Lead-Free Effective Date Mfg. Effective Date Code (Std Product Series) (YY/WW) 100% Matte Sn over Ni May-04 04/18 100% Matte Sn over Ni May-04 04/18 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 C S R 1 2 0 6 F T 1 0 L 0 Product Series Code Description CSR Standard Narrow CSRN Terminations Size Code W 0201 0.05 0402 0.13 0603 0.13 0805 0.25 1206 0.5 1210 0.5 2010 1 2512 2 0815 1 0830 2 1225 3 Tolerance Code Tol F 1% G 2% J 5% Code Description 7" Reel Paper Tape T 7" Reel Plastic Tape 7" Reel Paper Tape K 7" Reel Plastic Tape Rev Date: 03/23/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Packaging Size Quantity 0201, 0402 10000 0603, 0805, 1206, 1210 5000 2010, 2512 4000 0815, 0830, 1225 2000 0402 0603, 0805, 1206, 1210 1000 2010, 2512 0815, 0830, 1225 9 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of -3 10 for any value under 0.1 ohm - 14 15 H P Special (*) Code Description -HP High Power (*) Only available for 0603 and 1210 sizes 0.051 ohm = 51L0 0.35 ohm = R350 1 ohm = 1R00 www.seielect.com marketing@seielect.com
CSR2512JT33L0
物料型号: - 系列包括CSR和CSRN,其中CSRN具有较窄的端子。
器件简介: - 这些是厚膜电流检测电阻,适用于多种尺寸(从0201到1225)。 - 它们具有低电感特性,通常小于0.2nH。 - 符合RoHS标准,无卤素。 - 可提供非标准电阻值。
引脚分配: - 根据尺寸不同,引脚分配有所变化,例如CSR0201的引脚尺寸为0.005±0.002英寸。
参数特性: - 包括功率等级(从0.05W到3W)、耐电压(200V)、温度系数(TCR)、欧姆范围和公差。 - 例如,CSR0201的功率等级为0.05W,耐电压为200V,TCR为±1000ppm/C。
功能详解: - 电阻用于电流检测,具有高温暴露、短时过载、温度循环、偏置湿度、操作寿命等性能特性测试。
应用信息: - 适用于需要高功率电阻的应用,如电源管理、电机驱动等。
封装信息: - 提供了详细的机械规格,包括重量、身体长度、宽度、高度和端子尺寸。
其他信息: - 文档还包含了订购指南、环保政策、RoHS合规性、冲突矿产承诺和REACH合规性声明。
CSR2512JT33L0 价格&库存
很抱歉,暂时无法提供与“CSR2512JT33L0”相匹配的价格&库存,您可以联系我们找货
