Technical Data 4314
Effective August 2017
Supersedes November 2011
SD6030
Low profile shielded drum core power inductors
Applications
Product features
6.0 mm x 6.0 mm x 3.0 mm surface mount
package
Ferrite core material
Shielded drum core reduces EMI
Inductance range from 2.7 µH to 660 µH
Current range from 0.16 A to 4.08 A
Frequency range up to 1 MHz
Notebook, laptop computers
Digital cameras
LED Drivers
TFT LCD Bias supplies
Wireless handsets
Handheld instruments
Gaming consoles
GPS devices
Battery backup/power
Environmental data
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4314
Product specifications
Part Number5
SD6030-2R7-R
SD6030-3R3-R
SD6030-4R2-R
SD6030-5R0-R
SD6030-5R8-R
SD6030-7R8-R
SD6030-100-R
SD6030-120-R
SD6030-150-R
SD6030-180-R
SD6030-220-R
SD6030-270-R
SD6030-330-R
SD6030-360-R
SD6030-440-R
SD6030-520-R
SD6030-680-R
SD6030-820-R
SD6030-101-R
SD6030-121-R
SD6030-151-R
SD6030-181-R
SD6030-221-R
SD6030-271-R
SD6030-331-R
SD6030-391-R
SD6030-471-R
SD6030-561-R
SD6030-681-R
OCL1 µH ± 30%
2.7
3.3
4.1
4.9
5.8
7.8
9.3
11.3
14.1
17.1
20.4
26.0
32.4
34.4
44.0
52.0
65.6
81.6
94.4
110.1
144.5
175.7
210.9
264.2
313.5
373.7
460.0
546.2
659.4
Irms2 (A)
4.08
3.54
3.11
2.81
2.58
2.38
2.15
1.99
1.71
1.65
1.57
1.31
1.26
1.19
1.10
0.99
0.92
0.80
0.76
0.70
0.64
0.55
0.50
0.44
0.38
0.35
0.33
0.30
0.27
Isat3.(A)
2.60
2.40
2.20
1.90
1.80
1.60
1.30
1.20
1.10
1.00
0.90
0.85
0.75
0.70
0.62
0.58
0.52
0.46
0.42
0.40
0.35
0.32
0.30
0.27
0.25
0.22
0.20
0.18
0.16
1) Open Circuit Inductance Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2 Irms: DC current for an approximate DT of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other
heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application.
Typ. DCR mW@ +20 °C
13
18
23
28
33
39
48
56
76
82
90
130
140
157
185
226
263
343
385
517
608
817
1000
1300
1733
2083
2250
2767
3458
Max DCR mW @ +20 °C
18
24
31
38
45
53
65
76
103
110
122
175
189
212
250
305
355
463
520
620
730
980
1200
1560
2080
2500
2700
3320
4150
K-factor4
34
30
27
24
22
19
17
16
14
13
12
11
9.3
8.7
7.9
7.2
6.5
5.9
5.6
5.6
5.0
4.5
4.0
3.6
3.3
3.0
2.8
2.5
2.3
4 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K*L*DI, Bp-p (mT), K:
(K factor from table), L: (Inductance in mH), DI (Peak to peak ripple current in Amps).
5 Part Number Definition: SD6030-xxx-R
SD6030 = Product code and size; -xxx = Inductance value in mH;
R = decimal point; If no R is present, third character equals
number of zeros. -R suffix = RoHS compliant
3 Isat Amps peak for 35% rolloff (@ +25 °C)
Dimensions-mm
Part Marking: xxx = Inductance value in uH. R = decimal point. If no R is present third character = # of zeros, wwlly or wwllyy = Date code, R = Revision level.
Do not route traces or vias underneath the inductor
Packaging information-mm
Parts packaged on 13" diameter reel, 2000 parts per reel.
2
www.eaton.com/electronics
SD6030
Technical Data 4314
Core loss vs Bp-p
500kHz
1MHz
300kHz
1
200kHz
100kHz
C ore Lo ss (W)
0.1
0.01
0.001
0.0001
1
10
100
1000
Bp-p ( mT)
Temperature rise vs total loss
Inductance characteristics
-40°C
+25°C
+85°C
3
SD6030
Technical Data 4314
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4314 BU-SB111167
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD6030-7R8-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+6.814372000+0.88140
