HCM1104-R36-R
HCM1104-R36-R
    EATON(伊顿)
    功率电感 ±20% 30A 360nH 11.10 x 10.00mm 4.00mm 1.2mΩ 1104
HCM1104-R36-R 数据手册
Technical Data 4370 Effective August 2018 Supersedes September 2017 HCM1104 High current power inductors Applications • Voltage Regulator Module (VRM) • Multi-phase regulators • Point-of-Load modules • Desktop and server VRMs and EVRDs • Base station equipment • Notebook and laptop regulators • Battery power systems • Graphics cards • Data networking and storage systems Environmental data Product features • High current carrying capacity • Low core losses • Magnetically shielded, low EMI • Frequency range up to 5 MHz • Inductance range from 0.2 μH to 22 μH • Current range from 5 A to 45 A • 11.5 mm x 10.3 mm footprint surface mount package in a 4.0 mm height • Iron powder core material • Storage temperature range (Component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient + self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1104 High current power inductors  Technical Data 4370 Effective August 2018 Product Specifications OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4,5 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C K-factor6 HCM1104-R20-R 0.20 0.13 32 45 0.63 0.72 411 HCM1104-R36-R 0.36 0.23 30 42 1.04 1.20 269 HCM1104-R45-R 0.45 0.29 29 36 1.07 1.23 219 HCM1104-R56-R 0.56 0.36 25 32 1.56 1.80 230 HCM1104-R90-R 0.90 0.58 22 28 2.17 2.50 236 HCM1104-1R0-R 1.0 0.56 18 28 3.0 3.3 378 HCM1104-1R5-R 1.5 0.84 16 32 3.8 4.2 310 HCM1104-2R2-R 2.2 1.23 12 18 6.0 7.0 253 HCM1104-3R3-R 3.3 1.85 10 16 10.8 11.8 220 HCM1104-4R7-R 4.7 2.63 8.5 15 17 20 175 HCM1104-100-R 10 5.60 7.5 8.5 27 30 116 HCM1104-220-R 22 12.3 5.0 5.5 60 66 92 Part Number 7 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, @ +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, @ Isat, @ +25 °C 3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff @ +25 °C- HCM1104-R20-R to HCM1104-R90-R 5. Isat: Peak current for approximately 30% rolloff @ +25 °C HCM1104-1R0-R to HCM1104-220-R 6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 7. Part Number Definition: HCM1104-xxx-R HCM1104 = Product code and size xxx= inductance value in μH, R= decimal point , If no R is present then last character equals number of zeros -R suffix = RoHS compliant Dimensions (mm) Recommended pad layout Part marking: xxx=inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros. wlyy=date code, R=revision level All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Color: Grey Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics Schematic HCM1104 High current power inductors Technical Data 4370 Effective August 2018  Packaging information (mm) Supplied in tape and reel packaging, 850parts per 13” diameter reel 50.0 50.0 40.0 40.0 Temperature Rise (° C) Temperature Rise (° C) Temperature rise vs. total loss 30.0 HCM1104-R20-R HCM1104-R36-R HCM1104-R45-R HCM1104-R56-R HCM1104-R90-R 20.0 10.0 HCM1104-1R0-R 30.0 HCM1104-1R5-R 20.0 HCM1104-3R3-R/ HCM11044R7-R/HCM1104-220-R 10.0 HCM1104-2R2-R/ HCM1104100-R 0.0 0.0 0.0 0.5 1.0 Total Loss (W) 1.5 2.0 0.0 0.5 1.0 1.5 2.0 Total Loss (W) www.eaton.com/electronics 3 HCM1104 High current power inductors  Technical Data 4370 Effective August 2018 Core loss vs. Bp-p HCM1104-R20-R to HCM1104-R90-R 10,000 1 MHz 500 kHz 300 kHz 200KHz 1000 Core Loss (mW) 100 kHz 50 kH z 25 kH z 100 10 1 0.1 100 1 000 10, 000 B p-p (Gauss) HCM1104-1R0-R to HCM1104-220-R 10,000 1MHz 500 kHz 300 kHz 200 kHz 1000 Core Loss (mW) 100 kHz 50 kH z 25 kH z 100 10 1 0.1 100 1 000 B p-p (Gauss) 4 www.eaton.com/electronics 10, 000 HCM1104 High current power inductors Technical Data 4370 Effective August 2018  Inductance characteristics HCM1104-R36-R HCM1104-R20-R 100% 100% 90% 80% 80% % of OC L % of OC L 90% 70% 70% 60% 60% 50% 50% 40% 40% 0 10 20 30 40 50 60 70 80 90 1 00 0 10 20 30 40 50 I DC (A) HCM1104-R45-R 100% 60 70 80 90 1 00 I DC (A ) HCM1104-R56-R 100% 90% 80% 80% % of OC L % of OC L 90% 70% 70% 60% 60% 50% 50% 40% 40% 0 10 20 30 40 50 60 70 0 80 10 20 I DC (A ) 30 40 I DC (A ) 50 60 70 HCM1104-1R0-R HCM1104-R90-R 100 % 100 % 90% 90% 80% % of OCL % of OC L 80% 70% 60% 70% 60% 50% 50% 40% 0 10 20 30 I DC (A ) 40 50 60 40% 0 5 10 15 20 Idc (A) 25 30 35 www.eaton.com/electronics 40 5 HCM1104 High current power inductors  Technical Data 4370 Effective August 2018 Inductance characteristics HCM1104-1R5-R 9 0% 90% 8 0% 80% 7 0% 70% 6 0% 60% 5 0% 50% 4 0% HCM1104-2R2-R 100% % of OCL % of OCL 100% 40% 0 5 10 15 Idc (A) 20 25 30 0 35 2 4 6 8 10 12 14 16 18 20 22 24 26 28 Idc (A) HCM1104-3R3-R 100% HCM1104-4R7-R 100% 90% 9 0% %of OCL % of OCL 80% 70% 60% 8 0% 7 0% 6 0% 50% 5 0% 40% 0 2 6 4 8 10 12 14 16 18 20 22 4 0% Idc (A) HCM1104-100-R 100% 2 4 8 6 Idc (A) 10 12 14 16 18 HCM1104-220-R 110% 100% 9 0% 90% 8 0% %of OCL %of OCL 0 7 0% 80% 70% 6 0% 60% 5 0% 4 0% 6 50% 0 2 4 6 www.eaton.com/electronics 8 Idc (A) 10 12 14 16 40% 0 2 4 Idc (A) 6 8 10 HCM1104 High current power inductors Technical Data 4370 Effective August 2018  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
HCM1104-R36-R 价格&库存
很抱歉,暂时无法提供与“HCM1104-R36-R”相匹配的价格&库存,您可以联系我们找货
HCM1104-R36-R
    HCM1104-R36-R
    • 850+13.11785850+1.70500
    • 3400+11.848383400+1.54000
    库存:7650
    HCM1104-R36-R
    库存:3400
