RT0603CRB07100KL
RT0603CRB07100KL
    YAGEO(国巨)
    贴片电阻 0603 100KΩ ±0.25% 1/10W ±10ppm/℃
RT0603CRB07100KL 数据手册
DATA SHEET THIN FILM CHIP RESISTORS High precision - high stability RT series 0.05% TO 1%, TCR 5 TO 50 sizes 0201/0402/0603/0805/1206/ 1210/2010/2512 Product specification – May 11, 2015 V.6 RoHS compliant 2 Product specification Chip Resistor Surface Mount SCOPE This specification describes RT series high precision - high stability chip resistors with lead-free terminations made by thin film process. APPLICATIONS  Converters  Printer equipment  Server board  Telecom  Consumer FEATURES  Halogen Free Epoxy RoHS compliant      - Products with lead free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reducing environmentally hazardous wastes High component and equipment reliability Saving of PCB space None forbidden-materials used in products/production RT SERIES 10 0201 to 2512 (RoHS Compliant) ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) RT XXXX F X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512 (2) TOLERANCE W = ±0.05% B = ±0.1% C = ±0.25% D = ±0.5% F = ±1% (3) PACKAGING TYPE R = Paper/PE taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE A = 5 ppm/°C B = 10 ppm/°C C = 15 ppm/°C D = 25 ppm/°C E = 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for order only (Note) Resistance rule of global part number Resistance code rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω O RDERING EXAMPLE The ordering code of a RT0603 chip resistor, TC 50 value 56 Ω with ±0.5% tolerance, supplied in 7-inch tape reel is: RT0603DRE0756RL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 3 10 0201 to 2512 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. For matching traditional types with size codes, please refer to “Comparison table of traditional types and sizes”. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2390 (1) X (2) XX X (4) (3) START TCR (2) PACKING CODE TOL . (4) WITH (1) (ppm/°C) BY SIZE (inch) (3) (%) 2390 XXXX (5) RESISTANCE RANGE L (6) DEFAULT CODE (NOTE) The remaining 4 digits Letter L is system 7 = ±15 47 = 13'' reel 6 = ±0.5 represent the resistance value with default 6 = ±25 0603: 04 = 7'' reel 5 = ±0.25 the last digit indicating code for 4 = ±50 24 = 10'' reel 4 = ±0.1 the multiplier as shown order only (Note) 44 = 13'' reel 3 = ±0.05 in the table of “Last digit of 12NC”. 0805: 01 = 7'' reel 0402: 4.7Ω ≤ R ≤ 240KΩ 41 = 13'' reel 8 = ±10 0402: 07 = 7'' reel 7 = ±1 1206: 11 = 7'' reel 51 = 13'' reel 1210: 12 = 7'' reel 52 = 13'' reel 2010: 15 = 7'' reel 2512: 18 = 7'' reel 0603: 1 Ω ≤ R ≤ 1MΩ 0805: 1Ω ≤ R ≤ 1.5 MΩ Comparison table of traditional types and sizes TF X X X (1) (2) START SIZE WITH CODE TF (4) (3) TCR TOL. (ppm/°C) (%) 3 = 0402 4 = ±10 0 = ±1 2 = 0603 3 = ±15 1 = ±0.5 1 = 0805 1 = ±25 2 = ±0.25 0 = 1206 2 = ±50 3 = ±0.1 5 = 1210 4 = ±0.05 7 = 2010 6 = 2512 1206: 1Ω ≤ R ≤ 1.5 MΩ  Example: 1210: 4.7Ω ≤ R ≤ 1 MΩ 2010: 4.7Ω ≤ R ≤ 1 MΩ TF321 = RT0402, TC50, ±0.5% tolerance 2512: 4.7Ω ≤ R ≤ 1 MΩ Resistance decade (3) Last digit 1 to 9.76 Ω 10 to 97.6 Ω 8 100 to 976 Ω 1 1 to 9.76 kΩ 2 Exceptions to above packing code definitions: 10 to 97.6 kΩ 3 0805 TC50 with 1%, supplied in 13" reel, the packing code is 02. 100 to 976 kΩ 4 0603 TC50 with 1%, supplied in 13" reel, the packing code is 03. 1 to 9.76 MΩ 5 2512 TC15, in 7" reel, the packing code is 35. 10 to 97.6 MΩ 6 2010 TC15, in 7" reel, the packing code is 31. O RDERING EXAMPLE The ordering code of a TF221 resistor, TC50, value 56 Ω , with ±0.5% tolerance, supplied in tape of 5,000 units per reel is: 239040465609L or RT0603DRE0756RL. Example: 1Ω 33 kΩ 10 MΩ 9 = 1008 or 108 = 3303 or 333 = 1006 or 106 NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT 4 10 0201 to 2512 (RoHS Compliant) SERIES MARKING RT0201 / RT0402 / RESISTANCE VALUE IS NOT IN E-24 / E96 SERIES No marking Fig. 4 RT0603 E-24 series: exception values 10/11/13/15/20/75 of E-24 series, one short bar under marking letter Fig. 2 Value = 56 kΩ E-96 series: including values 10/11/13/15/20/75 of E-24 series, 3 digits Fig. 3 Value = 12.4 kΩ RT0805 / RT1206 / RT1210 / RT2010 / RT2512 Either resistance in E-24 or E-96: 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 1 Value = 10 kΩ For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION The resistors are constructed out of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive layer. The resistive layer is adjusted to give the approximate required resistance and laser cutting of this resistive layer that achieves tolerance trims the value. The resistive layer is covered with a protective coat and printed with the resistance value. Finally, the two external terminations (matte tin) are added. See fig. 5. OUTLINES For dimension see Table 1 DIMENSION Table 1 For outlines see fig. 5 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RT0201 0.60 ±0.03 0.30 ±0.03 0.23 ±0.03 0.10 ±0.05 0.15 ±0.05 RT0402 1.00 ±0.10 0.50 ±0.05 0.30 ±0.05 0.20 ±0.10 0.25 ±0.10 RT0603 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15 RT0805 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20 0.35 ±0.20 RT1206 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 RT1210 3.10 ±0.10 2.60 ±0.15 0.55 ±0.10 0.50 ±0.20 RT2010 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 RT2512 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.40 ±0.20 0.50 ±0.20 Fig. 5 Chip resistor outlines 0.50 ±0.20 0.50 ±0.20 www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 5 10 0201 to 2512 (RoHS Compliant) ELECTRICAL CHARACTERISTICS Table 2 TYPE RT0201 Operating Temperature Range Power Rating –55 °C to +125 °C 1/20W RT0402 1/16W RT0603 Max. Max. Dielectric T.C.R. Work Overload Withstand (ppm/°C) (1) Vol. Vol. Vol. 25V 50V 1/10W 75V 50V 100V 150V 50V 75V 100V RT0805 ±0.05% ±0.1% ±0.25% ±0.5% ±1.0% ±50 --- 22 ~75K 22 ~75K 22 ~75K 22 ~75K ±25 --- 22~75K 22~75K 22~75K 22~75K ±15 --- --- --- --- --- ±10 --- --- --- --- --- ±5 --- --- --- --- --- ±50 20~12K 4.7~240K 4.7~240K 4.7~240K 4.7~240K ±25 20~12K 4.7~240K 4.7~240K 4.7~240K 4.7~240K ±15 20~12K ±10 20~12K ±5 20~10K ±50 4.7~100K ±25 4.7~100K 20~70k --- --- 20~70k 20~70k --- --- 20~10K 20~10K --- --- 1~1M 1~1M 1~1M 1~1M 1~1M 1~1M 1~1M 1~1M ±15 4.7~100K 4.7~332k 4.7~332k --- --- ±10 4.7~100K 4.7~332k 4.7~332k --- --- ±5 –55 °C to +155 °C 1/8W 150V 300V 200V 1/4W RT1210 1/4W 200V 400V 200V 400V 300V 400V 20~30K 20~30K 20~30K --- --- 4.7~200K 1~1.5M 1~1.5M 1~1.5M 1~1.5M ±25 4.7~200K 1~1.5M 1~1.5M 1~1.5M 1~1.5M ±15 4.7~200K 4.7~800k 4.7~800k --- --- ±10 4.7~200K 4.7~800k 4.7~800k --- --- 20~50K 20~50K 20~50K --- --- ±50 5.6~500K 1~1.5M 1~1.5M 1~1.5M 1~1.5M ±25 5.6~500K 1~1.5M 1~1.5M 1~1.5M 1~1.5M ±15 5.6~500K 5.6~1M 5.6~1M --- --- ±10 5.6~500K 5.6~1M 5.6~1M --- --- ±5 20~100K 20~100K 20~100K --- --- ±50 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±25 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±15 100~100k 4.7~100k 4.7~100k --- --- ±10 100~100k 4.7~100k 4.7~100k --- --- --- --- --- --- --- ±50 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±25 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±15 100~100k 4.7~100k 4.7~100k --- --- ±10 100~100k 4.7~100k 4.7~100k --- --- ±5 RT2010 –55 °C to +125 °C 1/2W 200V 400V 400V ±5 RT2512 3/4W 200V 400V 400V 20~70k ±50 ±5 RT1206 Resistance Range (E-24/E-96 series)(2) & Tolerance --- --- --- --- --- ±50 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±25 4.7~1M 4.7~1M 4.7~1M 4.7~1M 4.7~1M ±15 100~100k 4.7~100k 4.7~100k --- --- ±10 100~100k 4.7~100k 4.7~100k --- --- --- --- ±5 --- --- --- NOTE 1. The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8” 2. Value of E-192 series is on request www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 6 10 0201 to 2512 (RoHS Compliant) FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL RT0201 DIMENSION Paper/PE taping reel (R) RT0402 RT0603 RT0805 RT1206 RT1210 RT2010 RT2512 7" (178 mm) 10,000 10,000 5,000 5,000 5,000 5,000 --- --- 13" (330 mm) 50,000 50,000 20,000 20,000 20,000 20,000 --- --- 7" (178 mm) --- --- --- --- --- --- 4,000 4,000 Embossed taping reel (K) NOTE 1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing” FUNCTIONAL DESCRIPTION POWER RATING Each type rated power at 70°C: RT0201=1/20W, RT0402=1/16W, RT0603=1/10W, RT0805=1/8W, RT1206=1/4W, RT1210=1/4W, RT2010=1/2W, RT2512=3/4W. R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (PxR ) or max. working voltage whichever is less Where Fig. 6 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (Tamb) V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 7 10 0201 to 2512 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C REQUIREMENTS Refer to table 2 Formula: R2–R1 ×106 (ppm/°C) T.C.R= ------------------------R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25.1 MIL-STD-202 Method 108A At 70±5 °C for 1,000 hours, RCWV applied for 1.5 hours on, 0.5 hour off, still air required ±(0.5%+0.05 Ω ) High Temperature Exposure IEC 60068-2-2 1000 hours at maximum operating temperature depending on specification, unpowered ±(0.5%+0.05 Ω) Moisture Resistance MIL-STD-202 Method 106G Each temperature / humidity cycle is defined at 8 hours, 3 cycles / 24 hours for 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ±(0.5%+0.05 Ω) Parts mounted on test-boards, without condensation on parts Measurement at 24±2 hours after test conclusion Thermal Shock MIL-STD-202 Method 107G -55/+125 °C Number of cycles required is 300. Devices mounted ±(0.5%+0.05 Ω) for 10 KΩ to 10 MΩ ±(0.5%+0.05 Ω) for others Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Humidity (steady state) IEC 60115-1 4.24.2 Steady state for 1000 hours at 40 °C / 95% R.H. ±(0.5%+0.05 Ω) RCWV applied for 1.5 hours on and 0.5 hour off www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 8 10 0201 to 2512 (RoHS Compliant) TEST Short Time Overload TEST METHOD PROCEDURE REQUIREMENTS IEC60115-1 4.13 2.5 times of rated voltage or maximum ±(0.5%+0.05 Ω) overload voltage whichever is less for 5 sec No visible damage at room temperature Board Flex/ Bending IEC 60115-1 4.33 Chips mounted on a 90mm glass epoxy resin ±(0.25%+0.05 Ω) PCB (FR4) No visible damage Bending: see table 6 for each size Bending time: 60±5 seconds Insulation Resistance IEC 60115-1 4.6 Rated continuous overload voltage (RCOV) for 1 minute ≥10 GΩ Details see below table 5 Dielectric Withstand Voltage Solderability - Wetting IEC 60115-1 4.7 Maximum voltage (Vrms) applied for 1 minute No breakdown or flashover J-STD-002 test B Electrical Test not required Well tinned (≥95% covered) No visible damage Magnification 50X SMD conditions: 1st step: method B, aging 4 hours at 155°C dry heat 2nd step: leadfree solder bath at 245±3°C Dipping time: 3±0.5 seconds - Leaching - Resistance to Soldering Heat J-STD-002 test D Leadfree solder, 260 °C, 30 seconds immersion time No visible damage IEC 60115-1 4.18 Condition B, no pre-heat of samples. Leadfree solder, 260 °C, 10 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ±(0.5%+0.05 Ω) No visible damage www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 9 10 0201 to 2512 (RoHS Compliant) Table 5 Criteria of rated continued working voltage and overload voltage TYPE RT0201 RT0402 RT0603 RT0805 RT1206 RT1210 RT2010 RT2512 50 100 100 300 500 500 500 500 Voltage (DC/unit: V); (AC/ unit: Vrms) Table 6 Bending for sizes 0201 to 2512 TYPE Specification (mm) RT0201 RT0402 RT0603 RT0805 RT1206 RT1210 RT2010 RT2512 5 5 3 3 2 2 2 2 www.yageo.com May. 11, 2015 V.6 Product specification Chip Resistor Surface Mount RT SERIES 10 10 0201 to 2512 (RoHS Compliant) REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 6 May. 11, 2015 - -Extend resistor value Version 5 Aug. 22, 2014 - -Add RT0201 - RT0402/0603/0805/1206: resistance range and operating temperature range updated - Fig. 6 updated Version 4 Oct 21, 2009 - - Test Items and methods updated - Test requirements upgraded Version 3 Jul 11, 2008 - - Change to dual brand datasheet that describe RT0402 to RT2512 with RoHS compliant - Description of "Halogen Free Epoxy" added - Define global part number - Modify electrical characteristic Version 2 Dec 26, 2005 - - New datasheet for thin film high precision - high stability chip resistors sizes of 0201/0402/0603/0805/1206/1210/2010/2512, 1%, 0.5%, 0.25%, 0.1%, 0.05%, TC25/50 with lead-free terminations - Replace the 0402 to 1210 parts of pdf files: TFx10_1_1, TFx11_.5_2, TFx12_.25_2, TFx13_.1_3, TFx14_.05_1, TFx20_1_2, TFx21_.5_2, TFx22_.25_2, TFx23_.1_2, TFx24_.05_1, and combine into a document. - Test method and procedure updated - PE tape added (paper tape will be replaced by PE tape) “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com May. 11, 2015 V.6 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Yageo: RT0603BRD0710KL RT0603BRD0712K4L RT0603BRD072K67L RT0603BRD0749R9L RT0603FRE0710K2L RT0603FRE071K78L RT0603FRE072K7L RT0603FRE0733KL RT0603FRE07348RL RT0603FRE075K49L RT0603FRE076K2L RT1206BRD07100KL RT1206BRD0710K5L RT1206BRD0710KL RT1206BRD0712KL RT1206BRD0715KL RT1206BRD07187KL RT1206BRD0719K1L RT1206BRD0720KL RT1206BRD0723K2L RT1206BRD0726K1L RT1206BRD072KL RT1206BRD07301RL RT1206BRD0730K1L RT1206BRD0731K6L RT1206BRD07357KL RT1206BRD073K01L RT1206BRD073K74L RT1206BRD07402RL RT1206BRD07442RL RT1206BRD0744K2L RT1206BRD07475KL RT1206BRD0749K9L RT1206BRD0749R9L RT1206BRD074K99L RT1206BRD0756K2L RT1206BRD076K65L RT1206BRD0775KL RT1206BRD0784K5L RT1210BRD07120RL RT0402BRD07100KL RT0402FRE0712K1L RT0603FRE0711KL RT0603FRE07150KL RT0603FRE0719K1L RT0603FRE072K21L RT0603FRE0768KL RT0603FRE078R25L RT0402DRE078K87L RT0603BRD0710K5L RT0603FRE073K92L RT0603FRE0717K4L RT0603DRE071KL RT0603DRE07100KL RT0603DRE07121RL RT0603BRD07267KL RT0603BRD07118KL RT0603BRD07196KL RT0603BRD0764K9L RT0603BRD0724KL RT0603FRE0712KL RT0603BRD071K07L RT0603BRD071K65L RT0603BRD071K87L RT0603BRD075K49L RT0603BRD071K4L RT0603BRD071K37L RT0603FRE076K49L RT0402BRD071KL RT0402BRD071K5L RT0603BRD0712K7L RT0603BRD0714K7L RT1206BRD0717K4L RT0402BRD0747K5L RT0603FRE0724K9L RT0603BRD0712K1L RT1206BRD0782KL RT0603BRD0717K4L RT0805FRE072K43L RT0603BRD131KL RT0805FRE074K64L RT1206BRD07154KL RT1206DRD07100KL RT0402BRD0756KL RT0402BRD075K6L RT0402BRD078K2L RT0402BRD07680RL RT0402BRD0768RL RT0402BRD0768KL RT0402BRD0761K9L RT0402BRD076K8L RT0402BRD076K34L RT0402BRD0756RL RT0402BRD0782RL RT0402BRD07470RL RT0402BRD0747RL RT0402BRD0747KL RT0402BRD0743KL RT0402BRD0742R2L RT0402BRD074K99L
RT0603CRB07100KL 价格&库存
很抱歉,暂时无法提供与“RT0603CRB07100KL”相匹配的价格&库存,您可以联系我们找货
RT0603CRB07100KL
  • 20+0.21272
  • 200+0.17141
  • 600+0.14845
  • 5000+0.13468
  • 10000+0.12275
库存:17108
RT0603CRB07100KL
    • 1+0.72820
    • 100+0.46970
    • 1000+0.33460
    • 2500+0.24840
    • 5000+0.18500
    库存:5150
