RL1220S-100-G
RL1220S-100-G
    SUSUMU
    贴片电阻 0805 10Ω ±2% 330W 0~+200ppm/℃
RL1220S-100-G 数据手册
Low resistance chip resistors (short-side terminal) ■RL series Features ・ Innovative structure that takes consideration of heat dissipation suppress the surface temperature enabling the small sizes reducing the influence of heat on surrounding components. Applications ・ PC power sources, inverters, automotive electronics, adopters, industrial machines *1 * 1:Except for RL0510, RL1632 and RL3264 ◆Part numbering system RL 1220 S - 1R0 - F RL 1632 S - R047 - F - T5 Resistance tolerance Packing quantity , :T1 (1,000pcs) T5 (5,000pcs) Current sensing surface mount resistors Nominal resistance Value 1R0=1.0Ω Series code Temperature coefficient of resistance Temperature coefficient of resistance Series code Size : RL0510, RL0816, RL1220 Size : RL1632 ◆Electrical Specification Type Power ratings Temperature coefficient of resistance Resistance range(Ω) Resistance tolerance (ppm/°C) RL series Resistance tolerance Nominal resistance Value 4digit 1/8W RL0510 1/6W 1/4W 0 ∼ +350(T) 0 ∼ +200(S) 1/5W 1/4W RL1220 RL1632 1/2W 63 ー 100m≦R≦6.8 10,000pcs ー -55℃ 7.5≦R≦68 0 ∼ +200(S) 43m≦91m 0 ∼ +350(T) 10m≦91m √(P・R) E-24 ~ 125℃ 5,000pcs 100m≦R≦10 0 ∼ +200(S) 11≦R≦100 510m≦R≦4.7 0 ∼ +200(S) 0 ∼ +500(T) *1 ー 100m≦R≦4.7 20m≦R<100m 0 ∼ +200(S) 0 ∼ +350(T) Packaging quantity ±5% (J) 50m≦R<100m 0 ∼ +350(T) 0 ∼ +100(R) Resistance Operating value series temperature 5.1≦R≦47 0 ∼ +100(R) 1/3W ±2% (G) 0 ∼ +200(S) 0 ∼ +100(R) RL0816 ±1% (F) Maximum voltage *1 56m≦R≦470m 33m≦R≦51m ー ー 27m≦R≦30m 18m≦R≦24m ー 10m≦R≦16m RL series with resistance tolerance 0.5% is also available. Please contact our sales office. ー T1 T5 ◆Dimensions L Size Type RL0510 W RL0816 a RL1220 t (inch) R≦0.2Ω R>0.2Ω R≦0.082Ω R>0.091Ω R≦0.068Ω R>0.075Ω RL1632 0402 L W a 1.00±0.05 0.50±0.05 0.15±0.10 b t 0.25±0.10 0.35+0.15/−0.10 0.15±0.10 0.35±0.10 0.25±0.20 0.45+0.15/−0.10 0.20±0.15 0.45±0.10 0603 1.60±0.20 0.80±0.20 0.20±0.15 0805 2.00±0.20 1.25±0.20 0.40±0.20 0.40±0.20 1206 3.20±0.20 1.60±0.20 ー 1.00±0.15 0.50±0.20 0.40±0.10 0.50±0.15 b (unit:mm) 100 50 0 −55 50 0 70 100 Current sensing surface mount resistors Ratio to rated power (%) ◆Derating Curve 125 155 Ambient temperature (℃) Maximum pulse power limit(W) 200 RL7520W-R10 RL7520-R10 150 100 RL series ◆Resistance to power pulse Test procedure RL3264-R050 Voltage pulse is applied to the test samples mounted on the test board. RL1632-R050 After each pulse, resistance drift is measured. Pulse 50 voltage is increased until the drift exceeds +/-0.5%. RL1220-R10 0 0.001 0.01 The power at that voltage is defined as the maximum 0.1 1 10 pulse power. Pulse duration(seconds) 64
RL1220S-100-G
1. 物料型号:文档中列出了几种型号,包括RL0510、RL0816、RL1220和RL1632。
2. 器件简介:RL系列电阻器具有创新结构,考虑了散热,以降低表面温度,减小尺寸,减少对周围元件的热影响。
3. 引脚分配:文档中没有明确提供引脚分配信息,但通常这类电阻器是表面贴装的,不需要引脚分配
4. 参数特性: - 电阻公差:±1%(F)、±2%(G)、±5%(J) - 温度系数:不同型号有不同的温度系数范围 - 额定功率:1/8W、1/6W、1/4W、1/5W、1/3W、1/2W等 - 最大电压、电阻范围、电阻值序列、工作温度范围、包装数量等详细信息。
5. 功能详解:文档中提到了电阻器的电流感应功能,以及如何测试电阻器对功率脉冲的耐受性。
6. 应用信息:适用于PC电源、逆变器、汽车电子、适配器、工业机械等领域。
7. 封装信息:提供了不同型号的尺寸数据,单位为英寸和毫米,包括长、宽和高度。
8. RoHS合规性:除了RL0510、RL1632和RL3264外,所有型号均符合RoHS标准。
9. 订购编号系统:提供了如何根据电阻值、公差、温度系数等参数来确定订购编号的示例。
10. 包装数量:不同型号的电阻器有不同的包装数量,如T1(1,000pcs)、T5(5,000pcs)等。
RL1220S-100-G 价格&库存
很抱歉,暂时无法提供与“RL1220S-100-G”相匹配的价格&库存,您可以联系我们找货
