DATA SHEET
AUTOMOTIVE GRADE SURGE
CHIP RESISTORS
SR series
20%, 10%, 5%
sizes 0402/0603/0805/1206/1210/1218/2010/2512
Product specification – August 04, 2021 V.9
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SR
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
SR0402 to SR2512 chip resistors
with lead-free terminations made by
thick film process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
2
8
GLOBAL PART NUMBER
SR XXXX X X X XX XXXX L
APPLICATIONS
Telecommunications
Power supplies
Car electronics
FEATURES
AEC-Q200 qualified
Superior to RC series in pulse
withstanding voltage and surge
withstanding voltage.
MSL class: MSL 1
Halogen free epoxy
RoHS compliant
Products with lead-free
terminations meet RoHS
requirements
Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous waste
High component and equipment
reliability
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512
(2) TOLERANCE
J = ± 5%
K = ± 10%
M = ± 20%
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Based on spec.
(5) TAPING REEL & POWER
07 = 7 inch dia. Reel
7W = 7 inch dia. Reel & 2 x standard power
13 = 13 inch dia. Reel
7T = 7 inch dia. Reel & 3 x standard power
47 = 7 inch dia. Reel & 4xstandard power
(6) RESISTANCE VALUE
1 Ω ≤ R ≤ 1M Ω
There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no
need to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance coding
Example
rule
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XXKX
(10 to 97.6 KΩ)
10K = 10,000 Ω
97K6= 976,000 Ω
XXXK
(100 KΩ)
100K = 100,000 Ω
ORDERING EXAMPLE
The ordering code for an SR0805
chip resistor, value 10 KΩ with
± 5% tolerance, supplied in 7-inch
tape reel is: SR0805JR-0710KL.
www.yageo.com
Aug. 04, 2021 V.9
SR
SERIES
3
8
MARKING
SR0402
No Marking
ynsc007
Fig. 1
SR1218
E-24 series: 3 digits
First two digits for significant figure and 3rd digit for number of zeros
YNSC099-1
Fig. 2
Value=10 KΩ
SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512
03
Fig. 3
YNSC001
Value=10 KΩ
NOTE
For further marking information, please refer to data sheet “Chip resistors marking”.
TAPING REEL & POWER
Table 1
POWER, W (P70)
TYPE
CODING
07
7W
7T
47
0402
1/16
1/8
1/5
0603
0805
1206
1/10
1/5
1/4
1/8
1/4
1/3
1/2
1/4
1/2
3/4
1
1210
1218
2010
2512
1/2
1
1
1.5
3/4
1.25
1
2
CONSTRUCTION
The resistor is constructed on top of a high-grade
ceramic body. Internal metal electrodes are added at
each end and connected by a resistive glaze. The
resistive glaze is covered by a lead-free glass. The
composition of the glaze is adjusted to give the
approximately required resistance value. The whole
element is covered by a protective overcoat. The
top of overcoat is marked with the resistance value.
Finally, the two external terminations (Ni/matte tin)
are added, as shown in Fig.4.
OUTLINES
marking layer
overcoat
protective glass
resistive layer
inner electrode
termination (Ni/matte tin)
inner electrode
YNSC095
ceramic substrate
Fig. 4 Chip resistor outlines
www.yageo.com
Aug. 04, 2021 V.9
SR
SERIES
4
8
DIMENSIONS
Table 2
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
SR0402
1.00± 0.05
0.50± 0.05
0.35± 0.05
0.20± 0.10
0.25± 0.10
SR0603
1.60± 0.10
0.80± 0.10
0.45± 0.10
0.25± 0.15
0.25± 0.15
SR0805
2.00± 0.10
1.25± 0.10
0.50± 0.10
0.35± 0.20
0.35± 0.20
SR1206
3.10± 0.10
1.60± 0.10
0.55± 0.10
0.45± 0.20
0.40± 0.20
SR1210
3.10± 0.10
2.60± 0.15
0.55± 0.10
0.45± 0.15
0.50± 0.20
SR1218
3.10± 0.10
4.60± 0.10
0.55± 0.10
0.45± 0.20
0.40± 0.20
SR2010
5.00± 0.10
2.50± 0.15
0.55± 0.10
0.55± 0.15
0.50± 0.20
SR2512
6.35± 0.10
3.10± 0.15
0.55± 0.10
0.60± 0.20
0.50± 0.20
For dimension, please refer to Table 1
SR0402
SR0603/0805/1206/
1210/2010/2512
I1
SR1218
Side view for all type
I1
I1
W
W
Fig. 5 Chip resistor dimensions
H
W
I2
L
L
L
YNSC096_1
ELECTRICAL CHARACTERISTICS
Table 3
TYPE
SR0402
POWER
CHARACTERISTICS
Operating
Temperature
Max.
Max.
Dielectric
RESISTANCE
Range Working Overload Withstanding
RANGE
Voltage
Voltage
Voltage
1/16W
1/8W
50 V
100 V
100 V
75V
150V
150V
150V
300V
300V
Temperature
Coefficient of
Resistance
1/5W
1/10W
SR0603
1/5W
1/4W
1/8 W
SR0805
1/4W
1/3W
10Ω < R ≤ 1MΩ
± 100 ppm/°C
1/2W
1/4 W
SR1206
1/2W
3/4W
E24 5%, 10%, 20%
1 Ω ≤ R ≤ 1M Ω
–55 °C to +155 °C
200 V
400 V
500 V
200 V
400 V
500 V
1W
SR1210
1/2W
1W
SR1218
1W
1.5W
200 V
400 V
500 V
SR2010
3/4W
1.25W
200 V
400 V
500 V
200 V
400 V
500 V
SR2512
1W
2W
1Ω ≤ R ≤ 10Ω
± 200 ppm/°C
www.yageo.com
Aug. 04, 2021 V.9
SR
SERIES
5
8
FOOTPRINT AND SOLDERING PROFILES
Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 4 Packing style and packaging quantity
PACKING STYLE
Paper taping reel (R)
Embossed taping reel (K)
REEL DIMENSION
SR0402
SR0603/0805/1206
SR1210
SR1218/2010/2512
7" (178 mm)
10,000
5,000
5,000
13" (330 mm)
50,000
20,000
20,000
7" (178 mm)
4,000
NOTE
1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
RESISTANCE
FUNCTIONAL DESCRIPTION
RANGE
OPERATING TEMPERATURE RANGE
MRA632
Pmax
PT040–55 °C to +155 °C 100 mΩ to 910 mΩ
Range:
(%Prated)
2
± 200 ppm/°C
POWER RATING
100
PT060
Each
type rated power at 70 °C:
± 200 ppm/°C
3
SR0402:
1/16W, 1/8W, 1/5W
SR0603:
PT080 1/10W, 1/5W, 1/4W
50
± 200 ppm/°C
SR0805:
1/8W, 1/4W, 1/3W, 1/2W
5
SR1206: 1/4W,
1/2W,
3/4W,
100 MΩ
TO 910
MΩ 1W
PT120 1/2W, 1W
SR1210:
100 mΩ
0 > 100 mΩ
6
SR1218:
1W, 1.5W
55
155
SR2010: 3/4W, 1.25W
Tamb ( C)
PT201
SR2512: 1W, 2W
± 100 ppm/°C
± 75 ppm/°C
Fig. 6 Maximum dissipation (P max ) in percentage of rated power
RATED VOLTAGE
as a function of the operating ambient temperature (T amb )
PT251
± 100 working
ppm/°C voltage
± 75 ppm/°C
The
DC
or
AC
(rms)
continuous
2
corresponding to the rated power is determined by
the following formula:
V=
(P X R)
Where
V = Continuous rated DC or AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
www.yageo.com
Aug. 04, 2021 V.9
SR
SERIES
6
8
PULSE LOAD BEHAVIOR
YNSC093
104
One-Pulse limiting electric power (W)
103
102
101
2512
2010
1218
1
1210
1206
0805
0603
0402
10-1
10-2
10-1
1
101
102
103
Pulse duration (ms)
Fig. 7
Pulse-Load behavior
TESTS AND REQUIREMENTS
Table 5 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
High Temperature
Exposure
AEC-Q200 Test 3
1,000 hours at TA = 155 °C, unpowered
± (3.0%+0.05Ω)
Moisture Resistance
AEC-Q200 Test 6
Each temperature / humidity cycle is defined at
8 hours (method 106F), 3 cycles / 24 hours for 10d.
with 25 °C / 65 °C 95% R.H, without steps 7a & 7b,
unpowered
± (2.0%+0.05Ω)
1,000 hours; 85 °C / 85% RH
10% of operating power
± (3.0%+0.05Ω)
MIL-STD-202 Method 108
MIL-STD-202 Method 106
Biased
Humidity
AEC-Q200 Test 7
MIL-STD-202 Method 103
Measurement at 24± 4 hours after test conclusion.
Operational Life
Resistance to
Soldering Heat
AEC-Q200 Test 8
± (3.0%+0.05Ω)
1,000 hours at 125 °C, derated voltage applied for
1.5 hours on, 0.5 hour off, still-air required
AEC-Q200 Test 15
Condition B, no pre-heat of samples
± (1.0%+0.05Ω)
MIL-STD-202 Method 210
Lead-free solder, 260± 5 °C, 10± 1 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Aug. 04, 2021 V.9
TEST
Thermal Shock
SR
SERIES
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200 Test 16
-55/+125 °C
± (1.0%+0.05Ω)
MIL-STD-202 Method 107
Number of cycles is 300. Devices mounted
7
8
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
ESD
AEC-Q200 Test 17
Human Body Model,
AEC-Q200-002
1 pos. + 1 neg. discharges
± (3.0%+0.05Ω)
0201: 500V
0402/0603: 1KV
0805 and above: 2KV
Solderability
- Wetting
AEC-Q200 Test 18
Electrical Test not required Magnification 50X
J-STD-002
SMD conditions:
(a) Method B, aging 4 hours at 155 °C dry heat,
dipping at 235± 3 °C for 5± 0.5 seconds.
Well tinned (≥95% covered)
No visible damage
(b) Method B, steam aging 8 hours, dipping at
215± 3 °C for 5± 0.5 seconds.
(c) Method D, steam aging 8 hours, dipping at
260± 3 °C for 30± 0.5 seconds.
Board Flex
AEC-Q200 Test 21
AEC-Q200-005
Chips mounted on a 90mm glass epoxy resin
PCB (FR4)
± (1.0%+0.05Ω)
Bending for 0201/0402: 5 mm
0603/0805: 3 mm
1206 and above: 2 mm
Holding time: minimum 60 seconds
Temperature
Coefficient of
Resistance (T.C.R.)
MIL-STD-202 Method 304
At +25/–55 °C and +25/+125 °C
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- × 106 (ppm/°C)
R1(t2–t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Short Time
Overload
IEC60115-1 4.13
2.5 times of rated voltage or maximum
overload voltage whichever is less for 5 sec
at room temperature
± (2.0%+0.05Ω)
www.yageo.com
Aug. 04, 2021 V.9
SR
SERIES
8
8
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 9
Aug. 04, 2021
- Upgrade to Automotive Grade
Version 8
Jul. 22, 2019
- Update power rating
- Extend resistance range of 0402 ~ 2512 to 1Mohm,
Version 7
Sep. 27, 2018
- Tighten TCR of all sizes for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ±
100 ppm/°C
- Add SR1210, SR1218, SR2010 7W (double power)
Version 6
Oct. 02, 2017
- Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512
7W (double power)
Version 5
Nov.11, 2016
- Update 7T power for 1206
Version 4
Sep. 01, 2015
Version 3
Jul. 31, 2015
Version 2
Jan. 06, 2014
Version 1
Mar 18, 2011
- Update SR0603 Dielectric Withstanding Voltage to 150V
- Update 7T power for 0603/0805 & 7W for 1210
- Comply with AEC-Q200 standard
- Add SR0402/0603/1210
- Update electrical characteristic
- Change to dual brand datasheet that describes SR0805 to SR2512 with
RoHS compliant
- Define global part number
Version 0
Oct 19, 2004
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products are unchanged. Any
product change will be announced by PCN.”
"The reimbursement is limited to the value of the products."
www.yageo.com
Aug. 04, 2021 V.9
