SD4581D3W
SD4581D3W
    LEIDITECH(雷卯电子)
    SOD-323
    4.5V
SD4581D3W 数据手册
SD4581D3W 1-Line Bi-directional TVS Diode Features  Small SOD-323 package Dimensions SOD-323 Protects one data or power line Working Voltage: 4.5V High peak pulse current capability Ultra low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 80A (5/50ns) – IEC61000-4-5 (Lightning) 100A (8/20 μs) RoHS Compliant Pin Configuration Applications  Mobile Phones and Accessories  Battery Protection   USB VBus Power Line Protection  Hand Held Portable Applications Mechanical Characteristics ● Package: SOD-323 ● Lead Finish: Sn ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 1450 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com SD4581D3W Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SD4581D3W Device Marking VRWM (V) 48 4.5 VBR (V) 4.7 IT (mA) VC @20A 1 9 (Max) (@A) 14.5 100 IR μA (Max) C (Pf) (Typ.) 1 300 Characteristic Curves 10 240 Peak Power_Ppp(W) Clamping Voltage_Vc (V) 300 180 120 60 0 0 1 2 3 4 1 0.1 0.01 5 0.1 1 10 100 Pulse Duration_tp(uS) Peak Pulse Power vs. Pulse Time 30 120 24 100 % of Rated Power Clamping Voltage_Vc (V) Peak Pulse Current_Ipp (A) Junction Capacitance vs. Reverse Voltage 18 12 6 80 60 40 20 0 0 20 40 60 80 100 0 120 0 Peak Pulse Current_Ipp (A) Rev : 01.06.2014 2/4 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 www.leiditech.com SD4581D3W Clamping Voltage vs. Peak Pulse Current (tp = 8/20us) Power Derating Curve 100 Peak Pulse Current (Ipp) % of Peak Pulse Current 90 80 70 Ipp/2 60 50 40 30 20 10 0 0 Rev : 01.06.2014 20 40 60 Time_t(uS) 8 X 20uS Pulse Waveform ESD Clamping Voltage 80 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com SD4581D3W SOD-323 Package Outline & Dimensions Millimeters Inches Symbol Min. Nom. Max. Min. Nom. Max. A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 Soldering Footprint 0.15 REF 0.006 REF b 0.25 0.32 0.40 0.010 0.012 0.016 C 0.089 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.062 0.066 0.070 E 1.15 1.25 1.35 0.045 0.049 0.053 L 0.08 HE 2.30 0.098 0.105 0.003 2.50 2.70 0.090 Symbol Millimeters Inches F 1.60 0.063 G 2.85 0.112 J 0.83 0.033 K 0.63 0.025 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
SD4581D3W 价格&库存
很抱歉,暂时无法提供与“SD4581D3W”相匹配的价格&库存,您可以联系我们找货
SD4581D3W
  • 1+0.22770
库存:30
