PTVS0542H100
PTVS0542H100
    LEIDITECH(雷卯电子)
    DFN1006
    5V截止 峰值浪涌电流:100A@8/20US
PTVS0542H100 数据手册
PTVS0542H100 1-Line Bi-directional ESD Diode Features ● Ultra small package: 1.0x0.6x0.5mm ● Protects one power line ● Ultra low leakage: nA level ● Low clamping voltage ● 2-pin leadless package ● Complies with following standards: Dimensions DFN1006 – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV –IEC61000-4-5 (Lightning) 100A (8/20μs) ● Pin Configuration RoHS Compliant Applications ● Mobile Phones ● Battery Protection ● Power Line Protection ● Vbat pin for Mobile Devices ● Hand Held Portable Applications Mechanical Characteristics ● Package: DFN1006 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch ● Device Marking: V5 Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 900 W Peak Pulse Current (8/20µs) IPP 100 A ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range Rev 2.0 : 01.07.2021 1/4 ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C www.leiditech.com PTVS0542H100 Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Test Condition Min Typ VRWM VBR IT = 1mA 5.5 6.3 Max Unit 5.0 V 7.5 V 0.5 µA Reverse Leakage Current IR VRWM = 5.0V Clamping Voltage VC IPP = 50A (8 x 20µs pulse) 7.5 9.0 V Clamping Voltage VC IPP = 100A (8 x 20µs pulse) 9.0 10.5 V Clamping Voltage VC IPP = 4 A (TLP) 6.7 V Clamping Voltage VC IPP = 16A (TLP) 8.5 V Dynamic Resistance RDYN TLP=0.2/100ns 0.015 Ω Junction Capacitance CJ VR = 0V, f = 1MHz 200 300 pF TLP Waveform Rev 2.0 : 01.07.2021 2/4 www.leiditech.com PTVS0542H100 20 300 275 250 225 200 175 150 125 100 75 50 25 0 Vc-Clamping Voltage(V) CJ-Junction Capacitance (pF) Typical Performance Characteristics (TA=25°C unless otherwise Specified) 15 10 5 0 0 1 2 3 4 0 5 VR—Reverse Voltage(V) 20 40 60 80 100 Ipp-Peak Pulse Current(A) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage 10 Voltage (V) Peak Power_Ppp(kW) 100 1 0.1 -20 0.01 0.1 1.0 10.0 Pulse Duration_tp(uS) 100 100 Ipp-Peak Pulse Current-%of Ipp % of Rated Power 120 80 60 40 20 0 50 75 100 125 150 60 80 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) Power Derating Curve Rev 2.0 : 01.07.2021 40 IEC61000−4−2 Pulse Waveform 120 25 20 Time (nS) Peak Pulse Power vs. Pulse Time 0 0 100.0 8 X 20us Pulse Waveform 3/4 www.leiditech.com PTVS0542H100 DFN1006 PACKAGE OUTLINE & DIMENSIONS h h - b - E A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.40 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 e D L A1 c A Bottom View SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern ╋ Y3 SYM Y1 Y2 Z ╋ DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev 2.0 : 01.07.2021 4/4 www.leiditech.com
PTVS0542H100 价格&库存
很抱歉,暂时无法提供与“PTVS0542H100”相匹配的价格&库存,您可以联系我们找货
