MPIA2512V2-4R7-R
MPIA2512V2-4R7-R
    EATON(伊顿)
    FIXED IND 4.7UH 1.4A 235MOHM SMD
MPIA2512V2-4R7-R 数据手册
Technical Data 10650 Effective July 2018 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Applications • • Product features • AEC-Q200 qualified • High current carrying capacity in a compact standard 1008 (2520 metric) footprint Body electronics • Central body control module • Vehicle access control system • Headlamps, tail lamps, interior lighting and LED lighting • Doors, window lift and seat control Advanced driver assistance systems • 77 GHz radar system • Basic and smart surround, and rear and front view camera • Adaptive cruise control (ACC) • Automatic parking control • Car black box system • Magnetically shielded, Low EMI • Rugged construction • Self resonant frequency (SRF) greater than 25 MHz • Inductance range from 0.33 μH to 4.7 μH • Current range from 1.2 A to 7.5 A • 2.7 mm x 2.2 mm footprint surface mount package in 1.05 mm, 1.25 mm heights Environmental data • Moisture Sensitivity Level (MSL): 1 • Storage temperature range (Component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant • Halogen free, lead free, RoHS compliant • Infotainment and cluster electronics • Active noise cancellation (ANC) • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation HALOGEN Pb HF FREE MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Product specifications OCL1 (μH) ±20% Irms2 (A) Isat3 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor4 MPIA2510V2-R33-R 0.33 4.8 6.6 15 20 120 6336 MPIA2510V2-R47-R 0.47 4.4 6.0 19 25 100 5039 MPIA2510V2-R68-R 0.68 3.1 4.3 37 44 80 5733 MPIA2510V2-1R0-R 1.00 3.1 4.3 41 52 55 3372 MPIA2510V2-1R5-R 1.50 2.5 2.5 65 85 45 4695 MPIA2510V2-2R2-R 2.20 2.1 2.8 88 110 45 2873 MPIA2510V2-3R3-R 3.30 1.6 2.1 140 170 35 1893 MPIA2510V2-4R7-R 4.70 1.22 1.8 220 262 25 1616 MPIA2512V2-R33-R 0.33 5.1 7.5 14 19 130 6560 MPIA2512V2-R47-R 0.47 4.9 6.7 17 23 100 3628 MPIA2512V2-R68-R 0.68 3.4 6.0 29 35 70 3633 MPIA2512V2-1R0-R 1.00 3.3 4.4 36 44 70 3083 MPIA2512V2-1R5-R 1.50 2.3 3.2 64 77 45 4850 MPIA2512V2-2R2-R 2.20 2.2 3.5 73 87 30 2924 MPIA2512V2-3R3-R 3.30 1.8 2.8 110 135 35 1965 MPIA2512V2-4R7-R 4.70 1.4 1.9 196 235 25 1580 Part Number5 1.0 mm height 1.2 mm height 1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C. 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 3. Isat : Peak current for approximately 30% rolloff @ +25 °C. Dimensions (mm) Dimension A MPIA2510V2 1.05 maximum MPIA2512V2 1.25 maximum, No marking All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ±0.2 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p :(Gauss), K: (K-factor from table), L: (Inductance in uH), ΔI (Peak to peak ripple current in Amps). 5. Part Number Definition: MPIA25xxV2-xxx-R MPIA25 = Product code xx= Height indicator V2=Version indicator xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Packaging information (mm) Supplied in tape and reel packaging, 3000 parts per 7” diameter reel Core loss vs. Bp-p (+25 °C) MPIA2510V2-R47-R MPIA2510V2-R33-R 10.000 3 MHz 10.000 3 MHz 2 MHz 2 MHz 300 kHz 0.100 100 kHz 1.000 Core Loss (mW) 500 kHz Core Loss (mW) 1 MHz 1 MHz 1.000 500 kHz 300 kHz 0.100 100 kHz 0.010 0.010 0.001 0.001 100 1000 Bp-p (Gauss) 100 1000 Bp-p (Gauss) www.eaton.com/electronics 3 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Core loss vs. Bp-p (+25 °C) MPIA2510V2-R68-R MPIA2510V2-1R0-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 500 kHz 300 kHz 0.100 100 kHz 1 MHz 1.000 1 MHz 500 kHz Core Loss (mW) Core Loss (mW) 1.000 0.010 300 kHz 0.100 100 kHz 0.010 0.001 0.001 100 1000 100 Bp-p (Gauss) 1000 Bp-p (Gauss) MPIA2510V2-1R5-R MPIA2510V2-2R2-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 1.000 1 MHz 1.000 500 kHz 0.100 300 kHz 100 kHz 0.010 Core Loss (mW) Core Loss (mW) 1 MHz 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 0.001 100 Bp-p (Gauss) MPIA2510V2-3R3-R MPIA2510V2-4R7-R 3 MHz 10.000 2 MHz 1 MHz 1.000 0.100 100 kHz 0.010 500 kHz Core Loss (mW) 300 kHz 1 MHz 1.000 500 kHz Core Loss (mW) 3 MHz 10.000 2 MHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 Bp-p (Gauss) 4 1000 Bp-p (Gauss) www.eaton.com/electronics 0.001 1000 100 Bp-p (Gauss) MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Core loss vs. Bp-p (+25 °C) MPIA2512V2-R47-R MPIA2512V2-R33-R 10.000 3 MHz 10.000 3 MHz 2 MHz 1 MHz 1 MHz Core Loss (mW) 500 kHz 300 kHz 0.100 500 kHz 1.000 100 kHz 300 kHz Core Loss (mW) 1.000 100 kHz 0.100 0.010 0.010 0.001 0.001 100 100 1000 MPIA2512V2-1R0-R MPIA2512V2-R68-R 3 MHz 10.000 1000 Bp-p (Gauss) Bp-p (Gauss) 3 MHz 10.000 2 MHz 1.000 0.100 100 kHz Core Loss (mW) 500 kHz 300 kHz 2 MHz 1 MHz 1 MHz 1.000 Core Loss (mW) 2 MHz 500 kHz 300 kHz 100 kHz 0.100 0.010 0.010 0.001 0.001 100 100 1000 1000 Bp-p (Gauss) Bp-p (Gauss) MPIA2512V2-1R5-R MPIA2512V2-2R2-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 500 kHz 300 kHz 0.100 100 kHz 0.010 1 MHz 1.000 1 MHz Core Loss (mW) Core Loss (mW) 1.000 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 Bp-p (Gauss) 0.001 100 1000 Bp-p (Gauss) www.eaton.com/electronics 5 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Core loss vs. Bp-p (+25 °C) MPIA2512V2-3R3-R MPIA2512V2-4R7-R 3 MHz 10.000 3 MHz 10.000 2 MHz 2 MHz 1 MHz 1 MHz 1.000 1.000 300 kHz 0.100 100 kHz Core Loss (mW) Core Loss (mW) 500 kHz 0.010 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 0.001 1000 100 1000 Bp-p (Gauss) Bp-p (Gauss) Inductance and Q vs. Frequency MPIA2510V2-R33-R MPIA2510V2-R47-R 0.40 30 0.20 0.15 Q value 40 0.25 20 0.10 0.00 1.0 10.0 100.0 35 30 0.4 25 0.3 20 15 10 0.1 0 1,000.0 5 0 0.1 1 Frequency (MHz) 70 2.0 60 1.8 60 1 50 40 0.6 30 0.4 20 Q value 0.8 Inductance (uH) 1.6 50 1.4 40 1.2 30 1.0 0.8 20 0.6 0.4 0.2 10 0 0.1 1 10 Frequency (MHz) www.eaton.com/electronics 0 1000 MPIA2510V2-1R0-R 1.2 Inductance (uH) 100 Frequency (MHz) MPIA2510V2-R68-R 6 10 100 0 1000 10 0.2 0.0 0.1 1.0 10.0 Frequency (MHz) 100.0 0 1000.0 Q value 0.1 40 0.2 10 0.05 45 0.5 Inductance (uH) 0.30 50 0.6 50 0.35 Inductance (uH) 0.7 60 Q value 0.45 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Inductance and Q vs. Frequency MPIA2510V2-1R5-R MPIA2510V2-2R2-R 1.0 10 0.5 2.5 10.0 100.0 15 1.5 10 1.0 5 0.5 0 1000.0 0.0 0.1 1.0 Frequency (MHz) 8 40 30 5 25 4 20 3 15 2 10 2.0 1 5 1.0 0 1000 0.0 Inductance (uH) 35 6 100 35 8.0 7 0 40 9.0 Q value Inductance (uH) 10.0 45 10 30 7.0 25 6.0 5.0 20 4.0 15 3.0 10 5 0.1 1.0 0.40 90 0.35 80 0.8 0.30 60 0.25 50 0.20 40 0.15 30 0.10 20 0.05 10 0.00 100 0 1000 90 80 0.6 70 Frequency (MHz) 0 1000.0 100 0.7 Inductance (uH) 100 Q value Inductance (uH) 0.45 10 100.0 MPIA2512V2-R47-R MPIA2512V2-R33-R 1 10.0 Frequency (MHz) Frequency (MHz) 0.1 0 1000.0 MPIA2510V2-4R7-R 9 1 100.0 Frequency (MHz) MPIA2510V2-3R3-R 0.1 10.0 Q value 1.0 20 2.0 70 0.5 60 0.4 50 40 0.3 Q value 0.1 25 3.0 5 0.0 30 3.5 Inductance (uH) 15 Q value 20 1.5 35 4.0 25 2.0 40 4.5 30 2.5 Inductance (uH) 5.0 35 Q value 3.0 30 0.2 20 0.1 10 0 0.1 1 10 100 0 1000 Frequency (MHz) www.eaton.com/electronics 7 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Inductance and Q vs. Frequency MPIA2512V2-R68-R 50 1.6 60 1.4 50 0.6 40 30 0.4 Inductance (uH) 0.8 Q value Inductance (uH) 60 1.8 70 1.0 MPIA2512V2-1R0-R 2.0 80 40 1.2 1.0 30 0.8 20 0.6 20 0.2 0.4 10 0.0 0.1 1 10 100 Q value 1.2 10 0.2 0.0 0 1000 0.1 1 Frequency 10 (MHz) 100 0 1000 Frequency (MHz) 45 45 4 40 40 3.5 35 3 30 2.5 25 2 20 1.5 15 1 10 35 1.5 30 25 20 1 Q value 15 10 0.5 0 0.1 1 10 100 5 0.5 0 1000 0 5 0.1 1 MPIA2512V2-3R3-R 8 10 35 9 20 4 15 3 10 5 1 0 Frequency (MHz) www.eaton.com/electronics 100 0 1000 Inductance (uH) 25 5 35 30 8 30 6 2 8 40 Q value Inductance (uH) 7 10 0 1000 MPIA2512V2-4R7-R 9 1 100 Frequency (MHz) Frequency (MHz) 0.1 10 25 7 6 20 5 15 4 3 10 2 5 1 0 0.1 1 10 Frequency (MHz) 100 0 1000 Q value Inductance (uH) 2 50 Inductance (uH) 2.5 4.5 Q value MPIA2512V2-2R2-R MPIA2512V2-1R5-R MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Inductance and temperature rise vs. Current MPIA2510V2-R33-R MPIA2510V2-R47-R 0.5 60 0.20 50 0.15 40 30 0.10 Inductance (uH) 70 0.25 Temperature rise (°C) 80 0.30 20 0.05 100 90 90 0.35 80 70 0.4 60 0.3 50 40 0.2 30 20 0.1 10 10 0.00 0.0 0 1 2 3 4 5 6 7 0 0 8 1 2 3 0.8 100 0.7 90 90 0.4 50 0.3 40 30 0.2 20 0.1 10 0.0 0 4 5 Inductance (uH) 60 100 1.0 Temperature rise (°C) Inductance (uH) 70 0.5 3 80 70 0.8 60 0.6 50 40 0.4 30 20 0.2 10 0.0 0 0 6 1 2 MPIA2510V2-1R5-R 100 1.4 90 1.0 60 0.8 50 0.6 40 30 0.4 20 0.2 10 0.0 0 3 4 5 2.0 Inductance (uH) 70 100 90 Temperature rise (°C) Inductance (uH) 1.2 Idc (A) 5 2.5 80 2 4 MPIA2510V2-2R2-R 1.6 1 3 Idc (A) Idc (A) 0 8 1.2 80 0.6 2 7 MPIA2510V2-1R0-R MPIA2510V2-R68-R 1 6 Idc (A) Idc (A) 0 5 4 Temperature rise (°C) 0 80 70 1.5 60 50 1.0 40 30 Temperature rise (°C) Inductance (uH) 0.6 100 Temperature rise (°C) 0.40 20 0.5 10 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 Idc (A) www.eaton.com/electronics 9 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Inductance and temperature rise vs. Current 2.5 5.0 100 90 4.5 90 80 4.0 80 3.5 70 3.0 60 2.5 50 2.0 40 1.5 30 20 1.0 20 10 0.5 10 0 0.0 70 60 2.0 50 1.5 40 30 1.0 0.5 0.0 1 1.5 2 2.5 3 0 0 0.5 Idc (A) 90 0.25 70 60 0.20 50 0.15 40 30 0.10 20 0.05 10 0.00 0 3 4 5 6 7 Inductance (uH) 80 Temperature rise (°C) Inductance (uH) 0.30 2 0.50 100 0.45 90 0.40 80 0.35 70 0.30 60 0.25 50 0.20 40 0.15 30 0.10 20 0.05 10 0.00 8 0 0 Idc (A) 1 2 3 80 Inductance (uH) 0.6 70 0.5 60 0.4 50 0.3 40 30 0.2 20 0.1 10 0.0 0 4 Idc (A) 10 www.eaton.com/electronics 7 8 5 6 7 100 90 1.0 Inductance (uH) 0.7 90 3 6 1.2 Temperature rise (°C) 100 2 5 MPIA2512V2-1R0-R MPIA2512V2-R68-R 1 4 Idc (A) 0.8 0 2.5 MPIA2512V2-R47-R 100 0.35 1 2 Idc (A) MPIA2512V2-R33-R 0 1.5 1 Temperature rise (°C) 0.5 80 70 0.8 60 0.6 50 40 0.4 30 20 0.2 10 0.0 0 0 1 2 3 Idc (A) 4 5 6 Temperature rise (°C) 0 Inductance (uH) Inductance (uH) 3.0 100 Temperature rise (°C) 3.5 Temperature rise (°C) MPIA2510V2-4R7-R MPIA2510V2-3R3-R MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Inductance and temperature rise vs. Current MPIA2512V2-1R5-R MPIA2512V2-2R2-R 100 90 90 1.4 2.0 60 0.8 50 40 0.6 30 0.4 20 0.2 80 70 Inductance (uH) 70 1.0 Temperature rise (°C) 80 1.2 1.5 60 50 1.0 40 30 0.5 20 10 0.0 10 0 0 1 2 3 4 0.0 5 0 0 0.5 1 1.5 2 Idc (A) 3 3.5 4 Idc (A) MPIA2512V2-3R3-R 3.5 MPIA2512V2-4R7-R 100 100 6.0 90 3.0 90 5.0 2.5 70 60 2.0 50 1.5 40 30 1.0 20 0.5 10 0.0 0 0 0.5 1 1.5 2 Idc (A) 2.5 3 3.5 4 Inductance (uH) 80 Temperature rise (°C) Inductance (uH) 2.5 80 70 4.0 60 50 3.0 40 2.0 30 Temperature rise (°C) Inductance (uH) 2.5 100 Temperature rise (°C) 1.6 20 1.0 10 0.0 0 0 0.5 1 1.5 2 2.5 Idc (A) www.eaton.com/electronics 11 MPIA25-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10650 Effective July 2018 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
MPIA2512V2-4R7-R 价格&库存
很抱歉,暂时无法提供与“MPIA2512V2-4R7-R”相匹配的价格&库存,您可以联系我们找货
MPIA2512V2-4R7-R
  • 3000+6.04551
  • 12000+5.09032
库存:14456
MPIA2512V2-4R7-R
    • 3000+8.695493000+1.13000
    • 12000+7.3911612000+0.96050
    库存:12000
    MPIA2512V2-4R7-R
    • 8+9.855348+1.28073
    • 10+9.7037510+1.26103
    • 25+9.5510425+1.24119
    • 100+9.39946100+1.22149
    • 250+6.97147250+0.90596
    • 500+6.85635500+0.89100
    • 1000+6.742081000+0.87615
    库存:2693
    MPIA2512V2-4R7-R
    • 1+9.855341+1.28073
    库存:2693
