RL0603JR-070R75L
RL0603JR-070R75L
    YAGEO(国巨)
    贴片电阻 0603 750mΩ ±5% 1/10W ±300ppm/℃
RL0603JR-070R75L 数据手册
DATA SHEET LOW OHMIC CHIP RESISTORS RL series 5%, 2%, 1% sizes 0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – June 01, 2017 V.2 RoHS compliant & Halogen Free Product specification Chip Resistor Surface Mount RL SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RL0402 to RL2512 low ohmic chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Converters RL XXXX X X X XX XXXX L YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) (1) Printer equipment  Server board  Telecom  Consumer F = ± 1%  Car electronics G = ± 2%  Halogen Free Epoxy  RoHS compliant  Hazardous wastes  High component and equipment reliability  Saving of PCB space  Non-forbidden materials used in products/production  Low resistances applied to current sensing  MSL Class: MSL 1 (2) (3) (4) (5) (6) (7) (1) SIZE  FEATURES  AEC-Q200 qualified 2 9 0402 to 2512 SERIES 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE J = ± 5% "-" = Jumper ordering (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec (5) TAPING REEL 07 = 7 inch dia. Reel and standard power 10 = 10 inch dia. Reel and standard power 13 = 13 inch dia. Reel and standard power 7W = 7 inch dia. Reel and 2 x standard power (0805 and 1206) (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for order only (Note) Resistance rule of global part number Resistance code rule Example 0RXXX (1 to 976 mΩ) XRXX (1 to 9.76 Ω) 0R1 = 0.1 Ω 0R12 = 0.12 Ω 0R105 = 0.105 Ω 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω O RDERING EXAMPLE The ordering code of a RL0603 chip resistor, value 0.56Ω with ± 1% tolerance, supplied in 7-inch tape reel is: RL0603FR-070R56L. NOTE 1. All our R-Chip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jun. 01, 2017 V.2 Product specification Chip Resistor Surface Mount RL SERIES 3 9 0402 to 2512 PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2350 / 2390 / 2322 (1) SIZE TYPE Last digit of 12NC XXX XXXXX L (2) (3) (4) START TOL. RESISTANCE IN (1) (%) RANGE Resistance decade (3) EMBOSSED (2) PAPER/PE (2) TAPE ON REEL TAPE ON REEL (units) 4,000 5,000 10,000 Last digit 0.01 to 0.0976Ω 0 0.1 to 0.976Ω 7 0402 LRC31 ± 5% 0.05 to 1 Ω 1 to 9.76Ω 2350 - - 513 20xxx 8 LRC32 ± 1% 0.05 to 1 Ω 10 to 97.6Ω 2350 - - 513 22xxx 9 0603 LRC21 2350 ± 5% 0.01 to 1 Ω 100 to 976Ω - 512 10xxx - 1 LRC22 2350 ± 1% 0.01 to 1 Ω 1 to 9.76 kΩ - 512 12xxx - 2 0805 LRC11 ± 5% 0.01 to 1 Ω 10 to 97.6 kΩ 2350 - 511 10xxx - 3 LRC12 ± 1% 0.01 to 1 Ω 100 to 976 kΩ 2350 - 511 12xxx - 4 LRC11P 2350 ± 1% 0.01 to 1 Ω 1 to 9.76 MΩ - 511 15xxx - 5 LRC12P 2350 ± 5% 0.01 to 1 Ω 10 to 97.6 MΩ - 511 17xxx - 6 Example: 0.02Ω = 0200 or 200 0.3Ω = 3007 or 307 1Ω = 1008 or 108 33 kΩ = 3303 or 333 10 MΩ = 1006 or 106 1206 LRC01 2350 ± 5% 0.01 to 1 Ω - 510 10xxx - LRC02 2350 ± 1% 0.01 to 1 Ω - 510 12xxx - LRC01P 2350 ± 1% 0.01 to 1 Ω - 519 01xxx - LRC02P 2350 ± 5% 0.01 to 1 Ω - 519 1xxxx - ± 5% 0.01 to 0.0976 Ω - 735 90xxx - LPRC101 2390 ± 5% 0.1 to 1 Ω - 735 60xxx - O RDERING EXAMPLE LPRC102 2390 ± 1% 0.01 to 1 Ω - 735 3xxxx - The ordering code of a RL0603 chip 1218 LPRC201 2322 ± 5% 0.01 to 1 Ω 735 64xxx - - LPRC201 2322 ± 1% 0.01 to 1 Ω resistor, value 0.56 Ω with ±1% tolerance, supplied in tape of 5,000 units per reel is: 235051212567L or RL0603FR-070R56L. 1210 LPRC101 2390 735 7xxxx - - ± 5% 0.01 to 0.0976 Ω 760 90xxx - - LPRC111 2322 ± 5% 0.1 to 1 Ω 760 60xxx - - LPRC111 2322 ± 1% 0.01 to 0.0976 Ω 761 90xxx - - NOTE LPRC111 2322 ± 1% 0.1 to 1 Ω 761 6xxxx - - ± 5% 0.01 to 0.0976 Ω 762 90xxx - - LPRC221 2322 ± 5% 0.1 to 1 Ω 762 60xxx - - 1. All our R-Chip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" LPRC221 2322 ± 1% 0.01 to 0.0976 Ω 763 90xxx - - LPRC221 2322 ± 1% 0.1 to 1 Ω - - 2010 LPRC111 2322 2512 LPRC221 2322 763 6xxxx 2. On customized label, "LFP" or specific symbol can be printed (1) The resistors have a 12-digit ordering code starting with 2350/2390/2322. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (In 12NC code, only 07'' tape reel code is supplied. Supply of 10''/13'' tape reel is requested in Global part number ordering code.) (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) Letter L is system default code for order only (Note) . www.yageo.com Jun. 01, 2017 V.2 Product specification Chip Resistor Surface Mount RL SERIES 0402 to 2512 4 9 MARKING RL0402 / RL0603: R
RL0603JR-070R75L 价格&库存
很抱歉,暂时无法提供与“RL0603JR-070R75L”相匹配的价格&库存,您可以联系我们找货
RL0603JR-070R75L
  • 5000+0.274485000+0.03563
  • 10000+0.2573210000+0.03340
  • 15000+0.2489615000+0.03231
  • 25000+0.2399125000+0.03114
  • 35000+0.2347335000+0.03047
  • 50000+0.2298350000+0.02983
库存:4556
RL0603JR-070R75L
  • 1+1.757561+0.22810
  • 10+0.9075410+0.11779
  • 25+0.7187925+0.09329
  • 50+0.6114250+0.07935
  • 100+0.52674100+0.06836
  • 250+0.44078250+0.05721
  • 500+0.39163500+0.05083
  • 1000+0.352531000+0.04576
库存:4556
