CC4-0603N220J500F3
CC4-0603N220J500F3
    FH(风华)
    插件,P=5.08mm
    直插陶瓷电容/独石电容 径向 22pF ±5% C0G(NP0)
CC4-0603N220J500F3 数据手册
RADIAL LEADED MLCC HOW TO ORDER CT4 0805 A B Y 104 M 500 P F3 C E G D F A: H B: UNIT INCHES ( Nominal Body Size(L Product Type E: ) W) 0805 0.17 0.15 1206 0.22 Class I Dielectric Radial Leaded Mlcc 1209 II Class II Dielectric Radial Leaded Mlcc Tolerance B 0.10pF 0.18 C 0.25pF 0.22 0.22 D 0.5pF 1210 0.22 0.22 F 1.0% G 2.0% 1812 0.34 0.26 J 5.0% K 10% M 20% N 30% Type Code I CC4 CT4 D: C: Nominal Capacitance Temperature Characteristics CG COG (N) (NPO) 0 30ppm/ (-55~+125 ) X7R 15% Y(F) Y5V +30 % - 80 (-55~+125 ) (-25~+85 ) 5R6=5.6pF +80% -20% P +100% -0% mm Lead Space(Unit:mm) Packaging Style Rated Voltage P Ammo F1 2.54 F2 4.57 F3 5.08 F4 3.50 Tape T digit is number of zeros. Reel For example: Bulk 500=50V Z H: G: First two digits are significant, and the third -20% B.C.D C 10PF B.C.D for C 10PF NPO:B.C.D.F.G.J.K.M X7R:K.M.N.S.Z Y5V:M.N.S.Z.P For example: 104=100000pF F: +50% First two digits are significant, and the third digit is number of zeros. B S Blank 101=100V 1 RADIAL LEADED MLCC SIZE CODE CAPACITANCE AND VOLTAGE mm Dimensions Unit mm Size Code 0805 1206 1210/ 1209 1812 Shape F 0.5 H 1 a b C1 C2 C3 2.54/3.5 2.54 5.08 5.08 5.08 5 10 5/10 5 5/10 a b C1 2.54 3.50 5.08 b C1 3.50 5.08 b 4.57 10 10 10 L max 4.2 W max 3.8 Available Capacitance Range T max 5.5 8.5 4.5 3.8 5.5 6.5 3.8 3.8 3.8 C0G (NP0) X7R Y5V 25 0R5~272 101~105 102~125 50 0R5~222 101~105 102~105 100 0R5~102 101~104 --- 25 0R5~562 101~225 102~125 50 0R5~472 101~105 102~105 100 0R5~332 101~154 --- 25 100~103 471~105 472~155 50 100~103 471~105 472~205 100 5R0~103 101~105 --- 25 100~153 471~335 103~335 50 100~103 471~225 103~225 100 5R0~103 101~105 --- 0.1 0.50 5.5 Voltage * . Others are available, contact FH. d 2 PACKAGING STYLE h L1 H1 h T1 D0 Note:P1=3.85mm for F=5.08mm; P1=5.1mm for F=2.54mm Code P P0 12.7 12.7 Dim P1 3.85 P2 d 6.35 0.5 h 0 W W0 8 18.5 0.2 0.7 W2 H1 9 3.0 32.25 10 5.1 1.0 W1 1.3 0.1 1 1 1 H0 T1 D0 L1 16 1.42 4.0 0.7 19.5 0.5 Max Max 1.0 Max 0.2 Tol AMMO PACKAGING TAPE& REEL PACKAGING 52Max 45 1 3 Max
CC4-0603N220J500F3 价格&库存
很抱歉,暂时无法提供与“CC4-0603N220J500F3”相匹配的价格&库存,您可以联系我们找货
