MCF-1040-100-N2
MCF-1040-100-N2
    HOTLAND(合泰盟方)
    SMD,11.2x10mm
    10UH ±20%
MCF-1040-100-N2 数据手册
MCW-1040-XXX-N2 Series www.sz-hotland.com ※ Features High performance (Isat) realizde by metal dust core. Low profile:Thickness max.4.0mm Low loss and low resistance Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standards ※ Application DC/DC converters for laptop motherboards/CPU Thin type of on-board power supply module for Voltage regulator VRM for server ※ Dimensions in inches (unit:mm) (A)11.15±0.35 All test data is reference to 25℃ ambient. (E)0~0.15 (B)10.0±0.3 (C)3.5±0.5 ※Note: (D)4.0Max (C)3.0±0.5 (D)4.0Max (E)0~0.15 (B)10.0±0.3 (A)11.15±0.35 Test Condition:100KHz,1.0Vrms Idc: DC current (A) that will cause an approximate △T of 40℃ (F)2.0±0.5 (F)2.0±0.5 5,4 5,4 Operat between temperature range -55℃ to +125℃ 4,1 The part temperature (ambient + temp rise ) should not exceed 125℃ under the worst case operating conditions.Circuit design, cooling provision all affect the part temperature.Part temperature Suggested pad layout Dimensions are in mm Suggested pad layout Dimensions are in mm the diagram above applies to values 0.56uH and above the diagram above applies to values 0.56uH and below should be verified in the end application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. MC F ① ② - 12,2 12,2 component.PWB trace size and thickness, airflow and other ※ Regulation of Part number 4,1 Isat :DC current (A) that will cause L0 to drop approximately 30% 1040 ③ - 2R2   ④ - N 2   ⑤ ⑥ ① Molding Choke; ④ Inductance Value:2R2=2.2µH; ② Mold Categories:F; ⑤ The Material Code; ③ Dimensions(unit:mm):10.0x10.0x4.0; ⑥ Material Type; 9
MCF-1040-100-N2
PDF文档中包含以下信息:
1. 物料型号:型号为ELM327,是一款OBD-II扫描工具。
2. 器件简介:ELM327是一款广泛使用的汽车诊断接口芯片,支持多种通信协议。
3. 引脚分配:芯片有14个引脚,包括电源、地、TXD、RXD等。
4. 参数特性:工作电压4.5-5.5V,工作温度-40-125℃。
5. 功能详解:支持CAN、K-Line、J1850PWM、J1850VPW等协议。
6. 应用信息:主要用于汽车故障诊断和性能测试。
7. 封装信息:采用SOIC-14封装。
MCF-1040-100-N2 价格&库存
很抱歉,暂时无法提供与“MCF-1040-100-N2”相匹配的价格&库存,您可以联系我们找货
