YSR315S503
1. SCOPE
This specification is applied to a SAW resonator designed for the stabilization of transmitters
such as garage door openers and security transmitters.
2. EL ECTRICAL
SPECIFICATION
2.1 Maximum Rating
DC Voltage VDC
AC Voltage Vpp
Operation temperature
Storage temperature
Max Input Power
10V
10V 50Hz/60Hz
-40℃ to +85℃
-45℃ to +85℃
10dBm
2.2Electronic Characteristics
Item
Center Frequency
Insertion Loss
Quality Factor Unload Q
50Ω Loaded Q
Temperature Turnover Temperature
Stability
Freq.temp.Coefficient
Frequency Aging
DC. Insulation Resistance
Motional Resistance R1
RF Equivalent
Motional Inductance L1
RLC Model
Motional Capacitance C1
Transducer Static Capacitance
Unites
MHz
dB
ppm/℃2
ppm/yr
MΩ
Ω
μ H
fF
pF
Minimum Typical Maximum
314.925 315.000 315.075
1.5
2.2
8000
12800
1000
2000
10
25
40
0.037
≤±10
1.0
17
26
109.28
2.3357
2.7
come visit our site http://www.yxc.hk
1/4
YSR315S503
3. TEST CIRCUIT
4. DIMENSION
4-1 Typical dimension (unit: mm)
4-2 Typical circuit board land patter
2/4
YSR315S503
5. ENVIRONMENTAL CHARACTERISTICS
5-1 High temperature exposure
Subject the device to +85℃ for 16 hours. Then release the resonator into the room
conditions for 24 hours prior to the measurement. It shall fulfill the specifications in 2.2.
5-2 Low temperature exposure
Subject the device to -40℃ for 16 hours. Then release the device into the room conditions
5-3 Temperature cycling
Subject the device to a low temperature of -40℃for 30 minutes. Following by a high
temperature of +85℃ for 30 Minutes. Then release the device into the room conditions
for 24 hours prior to the measurement. It shall meet the specifications in 2.2.
5-4 Resistance to solder heat
Dip the device terminals no closer than 1.5mm into the solder bath at 260℃ ±10℃ for
10±1 sec. Then release the device into the room conditions for 4 hours. The device shall
5-5 Solderability
Subject the device terminals into the solder bath at 245℃ ±5℃ for 5s, More than 95%
area of the terminals must be covered with new solder. It shall meet the specifications in
2.2.
5-6 Mechanical shock
Drop the device randomly onto the concrete floor from the height of 1m 3 times. the
device shall fulfill the specifications in 2.2.
5-7 Vibration
Subject the device to the vibration for 1 hour each in x, y and z axes with the amplitude of
1.5 mm at 10 to 55 Hz. The device shall fulfill the specifications in 2.2.
6. REMARK
6.1 Static voltage
Static voltage between signal load & ground may cause deterioration &destruction of
the component. Please avoid static voltage.
6.2 Ultrasonic cleaning
Ultrasonic vibration may cause deterioration & destruction of the component. Please
avoid ultrasonic cleaning
6.3 Soldering
Only leads of component may be soldered. Please avoid soldering another part of
component.
3/4
YSR315S503
7. TYPCIAL APPLICATION CIRCUITS
4/4
很抱歉,暂时无法提供与“R5035315MA4SI”相匹配的价格&库存,您可以联系我们找货
