MP2224K32C3R6LC
MP2224K32C3R6LC
    SRD(圣融达)
    插件,P=10mm
    安规电容 径向
MP2224K32C3R6LC 数据手册
Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 引用标准 Reference standards GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14 IEC60384-14 /EN60384-14/KC60384-14/KC60384-1 ■ 结构 Structure 介质:(金属化)聚丙烯膜 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: (Metallized )Polypropylene film Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0 Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0 ■ 典型应用 Typical Application 跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等 Interlines, Surge suppression, Across-in-line as EMI filter; Power switch etc. Such as: Lamps, Power Sources etc. ■ 特点 Features 外观一致性好;有良好自愈性 抗湿性强;高耐温 长寿命,耐过电压优良 Good appearance consistency; Good self-healing property; Good resistance to humidity; Can withstand high temperature; Long lifetime; Good ability to withstand surge voltage. ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications 气候类别 Climate category 阻燃等级 Passive flammability class 额定电压 Rated Voltage 容量误差 Capacitance Tolerance REACH requirements. 40/110/56 B 320VAC K: ±10% 容量范围 0.0022μF~4.7μF Capacitance Range Test Condition: 耐电压 No breakdown or electric arcing Withstand Voltage Terminal to terminal:4.3UR(Vdc),5S Terminal to shell:2140VAC 60S 损耗角 ≤0.0020 10KHZ CR≤1.0μF Test Condition : Dissipation factor ≤0.0010 1KHZ CR>1.0μF 绝缘电阻或时间常数 CR≤0.33μF IR≥15000MΩ Insulation Resistance CR>0.33μF IR≥5000S 最大脉冲爬升速率 Max. Pulse Rise Time (dV / dt) 20℃, 1KHz, 1Vrms 20℃ 1V Test Condition : 20℃ P=7.5mm dV / dt = 800V/μs P=10mm dV / dt = 500V/μs P=15mm dV / dt = 400V/μs P=22.5mm dV / dt = 200V/μs P=27.5mm dV / dt = 150V/μs P=37.5mm dV / dt = 80V/μs 100V 1 min Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change:△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0080(10KHZ),CR≤1uF Rise ≤0.0050(1KHZ),CR>1uF 绝缘电阻 Insulation Resistance 耐久性试验 温度 Temp.: +110℃, Endurance Test 施加电压:1.25×额定电压(每小时 IR:≥ 50% of rated value 增加电压到 1000Vac,0.1 秒,1 次) 容量变化(相对初始值):△C/C≤±10% Test Voltage: Capacitance change: △C/C≤±10% 1.25 Times Rated Voltage(Rise the voltage to 1000Vac for .01s once per hours ) 持续时间 Duration Time: 1000H ■ ■ 安规认证 Safety Certification 认证标志 额定电压 证书号码 引用标准 认证国家 Certification Rated Voltage Certificate No. Reference standard Certification Country UL/CUL 320VAC E319615 UL60384-14 CSA E60384-14 美国、加拿大 America / Canada VDE 320VAC 40028812 EN60384-14 德国 Germany ENEC 320VAC 40028812 EN60384-14 欧盟 Europe CQC 320VAC CQC09001035778 GB/T6346.14-2015 中国 China KC 320VAC SU030803(16001-16005) KC60384-14 韩国 Korea 产品编码说明 Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 M 4 R 8 * * Digit 1-3 P 2 1 0 5 K 型号代码 Product Name Code 3 2 E MP2= Class X2 Capacitors Digit 4-6 标称容量 Rated Capacitance Value For example : 105 = 10×105pF = 1.0F Digit 7 容量偏差 Capacitance Tolerance K=±10% Digit 8-9 额定电压 Rated Voltage Code 32=320VAC Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 料号明细及尺寸 Part No. List and Dimensions 成品编码 等级 电压 Part No. Class MP2222K32B2R6** 容量 尺寸 Dimension (mm) Voltage Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 X2 320VAC 0.0022 10 5 11 7.5 0.6 MP2272K32B2R6** X2 320VAC 0.0027 10 5 11 7.5 0.6 MP2332K32B2R6** X2 320VAC 0.0033 10 5 11 7.5 0.6 MP2392K32B2R6** X2 320VAC 0.0039 10 5 11 7.5 0.6 MP2472K32B2R6** X2 320VAC 0.0047 10 5 11 7.5 0.6 MP2562K32B2R6** X2 320VAC 0.0056 10 5 11 7.5 0.6 MP2682K32B2R6** X2 320VAC 0.0068 10 5 11 7.5 0.6 MP2822K32B2R6** X2 320VAC 0.0082 10 5 11 7.5 0.6 MP2103K32B2R6** X2 320VAC 0.01 10 5 11 7.5 0.6 MP2123K32B2R6** X2 320VAC 0.012 10 5 11 7.5 0.6 MP2153K32B2R6** X2 320VAC 0.015 10 5 11 7.5 0.6 MP2183K32B2R6** X2 320VAC 0.018 10 5 11 7.5 0.6 MP2223K32B2R6** X2 320VAC 0.022 10 5 11 7.5 0.6 MP2273K32B2R6** X2 320VAC 0.027 10 5 11 7.5 0.6 MP2333K32B2R6** X2 320VAC 0.033 10 5 11 7.5 0.6 MP2393K32B2R6** X2 320VAC 0.039 10 5 11 7.5 0.6 MP2473K32B2R6** X2 320VAC 0.047 10 5 11 7.5 0.6 MP2393K32B3R6** X2 320VAC 0.039 10 6 12 7.5 0.6 MP2473K32B3R6** X2 320VAC 0.047 10 6 12 7.5 0.6 MP2563K32B3R6** X2 320VAC 0.056 10 6 12 7.5 0.6 MP2683K32B3R6** X2 320VAC 0.068 10 6 12 7.5 0.6 MP2222K32C2R6** X2 320VAC 0.0022 13 5 11 10 0.6 MP2272K32C2R6** X2 320VAC 0.0027 13 5 11 10 0.6 MP2332K32C2R6** X2 320VAC 0.0033 13 5 11 10 0.6 MP2392K32C2R6** X2 320VAC 0.0039 13 5 11 10 0.6 MP2472K32C2R6** X2 320VAC 0.0047 13 5 11 10 0.6 MP2562K32C2R6** X2 320VAC 0.0056 13 5 11 10 0.6 MP2682K32C2R6** X2 320VAC 0.0068 13 5 11 10 0.6 MP2822K32C2R6** X2 320VAC 0.0082 13 5 11 10 0.6 MP2103K32C2R6** X2 320VAC 0.01 13 5 11 10 0.6 MP2123K32C2R6** X2 320VAC 0.012 13 5 11 10 0.6 MP2153K32C2R6** X2 320VAC 0.015 13 5 11 10 0.6 MP2183K32C2R6** X2 320VAC 0.018 13 5 11 10 0.6 说明 Note: “**”表示内部特征码 “**”=Internal use. Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 料号明细及尺寸 Part No. List and Dimensions 成品编码 等级 电压 Part No. Class MP2223K32C2R6** 容量 尺寸 Dimension (mm) Voltage Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.5 X2 320VAC 0.022 13 5 11 10 0.6 MP2273K32C2R6** X2 320VAC 0.027 13 5 11 10 0.6 MP2333K32C2R6** X2 320VAC 0.033 13 5 11 10 0.6 MP2393K32C2R6** X2 320VAC 0.039 13 5 11 10 0.6 MP2473K32C2R6** X2 320VAC 0.047 13 5 11 10 0.6 MP2563K32C2R6** X2 320VAC 0.056 13 5 11 10 0.6 MP2683K32C2R6** X2 320VAC 0.068 13 5 11 10 0.6 MP2104K32C2R6** X2 320VAC 0.1 13 5 11 10 0.6 MP2683K32C3R6** X2 320VAC 0.068 13 6 12 10 0.6 MP2104K32C3R6** X2 320VAC 0.1 13 6 12 10 0.6 MP2154K32C3R6** X2 320VAC 0.15 13 6 12 10 0.6 MP2224K32C5R6** X2 320VAC 0.22 13 7.8 13.8 10 0.6 MP2563K32CDR6** X2 320VAC 0.056 12.5 5 13 10 0.6 MP2823K32CDR6** X2 320VAC 0.082 12.5 5 13 10 0.6 MP2823K32CGR6** X2 320VAC 0.082 12.5 6 15.5 10 0.6 MP2104K32CGR6** X2 320VAC 0.1 12.5 6 15.5 10 0.6 MP2124K32CGR6** X2 320VAC 0.12 12.5 6 15.5 10 0.6 MP2154K32CGR6** X2 320VAC 0.15 12.5 6 15.5 10 0.6 MP2184K32CKR6** X2 320VAC 0.18 12.5 7 17.5 10 0.6 MP2184K32CGR6** X2 320VAC 0.18 12.5 6 15.5 10 0.6 MP2224K32CKR6** X2 320VAC 0.22 12.5 7 17.5 10 0.6 MP2274K32CKR6** X2 320VAC 0.27 12.5 7 17.5 10 0.6 MP2274K32CNR6** X2 320VAC 0.27 12.5 8 18.5 10 0.6 MP2334K32CNR6** X2 320VAC 0.33 12.5 8 18.5 10 0.6 MP2334K32CRR6** X2 320VAC 0.33 12.5 9 19.5 10 0.6 MP2104K32D1R6** X2 320VAC 0.1 18 5 11 15 0.6 MP2124K32D1R6** X2 320VAC 0.12 18 5 11 15 0.6 MP2104K32D2R8** X2 320VAC 0.1 18 6 12 15 0.8 MP2124K32D2R8** X2 320VAC 0.12 18 6 12 15 0.8 MP2184K32D2R8** X2 320VAC 0.18 18 6 12 15 0.8 MP2334K32D3R8** X2 320VAC 0.33 18 7.5 13.5 15 0.8 MP2224K32D4R8** X2 320VAC 0.22 18 8.4 14.5 15 0.8 MP2334K32D4R8** X2 320VAC 0.33 18 8.4 14.5 15 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 料号明细及尺寸 Part No. List and Dimensions 成品编码 等级 电压 Part No. Class MP2474K32D4R8** 容量 尺寸 Dimension (mm) Voltage Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.5 X2 320VAC 0.47 18 8.4 14.5 15 0.8 MP2474K32D6R8** X2 320VAC 0.47 18 10 16 15 0.8 MP2684K32D6R8** X2 320VAC 0.68 18 10 16 15 0.8 MP2474K32D8R8** X2 320VAC 0.47 18 11.2 19.2 15 0.8 MP2684K32D8R8** X2 320VAC 0.68 18 11.2 19.2 15 0.8 MP2154K32DBR6** X2 320VAC 0.15 17.5 5 13 15 0.6 MP2224K32DBR6** X2 320VAC 0.22 17.5 5 13 15 0.6 MP2184K32DDR8** X2 320VAC 0.18 17.5 6 15.5 15 0.8 MP2224K32DDR8** X2 320VAC 0.22 17.5 6 15.5 15 0.8 MP2274K32DDR8** X2 320VAC 0.27 17.5 6 15.5 15 0.8 MP2334K32DDR8** X2 320VAC 0.33 17.5 6 15.5 15 0.8 MP2394K32DDR8** X2 320VAC 0.39 17.5 6 15.5 15 0.8 MP2224K32DGR8** X2 320VAC 0.22 17.5 7 17.5 15 0.8 MP2274K32DGR8** X2 320VAC 0.27 17.5 7 17.5 15 0.8 MP2334K32DGR8** X2 320VAC 0.33 17.5 7 17.5 15 0.8 MP2474K32DGR8** X2 320VAC 0.47 17.5 7 17.5 15 0.8 MP2334K32DKR8** X2 320VAC 0.33 17.5 8 18.5 15 0.8 MP2394K32DKR8** X2 320VAC 0.39 17.5 8 18.5 15 0.8 MP2474K32DKR8** X2 320VAC 0.47 17.5 8 18.5 15 0.8 MP2564K32DKR8** X2 320VAC 0.56 17.5 8 18.5 15 0.8 MP2684K32DKR8** X2 320VAC 0.68 17.5 8 18.5 15 0.8 MP2394K32DNR8** X2 320VAC 0.39 17.5 9 19.5 15 0.8 MP2564K32DNR8** X2 320VAC 0.56 17.5 9 19.5 15 0.8 MP2564K32DRR8** X2 320VAC 0.56 17.5 10 22.5 15 0.8 MP2684K32DRR8** X2 320VAC 0.68 17.5 10 22.5 15 0.8 MP2684K32DUR8** X2 320VAC 0.68 17.5 11 26.5 15 0.8 MP2824K32DUR8** X2 320VAC 0.82 17.5 11 26.5 15 0.8 MP2105K32DXR8** X2 320VAC 1.0 17.5 12 24.5 15 0.8 MP2334K32E2R8** X2 320VAC 0.33 26.5 7 16.5 22.5 0.8 MP2394K32E2R8** X2 320VAC 0.39 26.5 7 16.5 22.5 0.8 MP2474K32E2R8** X2 320VAC 0.47 26.5 7 16.5 22.5 0.8 MP2334K32E3R8** X2 320VAC 0.33 26.5 8.5 17 22.5 0.8 MP2394K32E3R8** X2 320VAC 0.39 26.5 8.5 17 22.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 料号明细及尺寸 Part No. List and Dimensions 成品编码 等级 电压 Part No. Class MP2474K32E3R8** 容量 尺寸 Dimension (mm) Voltage Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.5 X2 320VAC 0.47 26.5 8.5 17 22.5 0.8 MP2564K32E3R8** X2 320VAC 0.56 26.5 8.5 17 22.5 0.8 MP2684K32E3R8** X2 320VAC 0.68 26.5 8.5 17 22.5 0.8 MP2474K32E4R8** X2 320VAC 0.47 26.5 10 19 22.5 0.8 MP2564K32E4R8** X2 320VAC 0.56 26.5 10 19 22.5 0.8 MP2684K32E4R8** X2 320VAC 0.68 26.5 10 19 22.5 0.8 MP2824K32E4R8** X2 320VAC 0.82 26.5 10 19 22.5 0.8 MP2105K32E4R8** X2 320VAC 1.0 26.5 10 19 22.5 0.8 MP2824K32E5R8** X2 320VAC 0.82 26.5 11 20 22.5 0.8 MP2105K32E5R8** X2 320VAC 1.0 26.5 11 20 22.5 0.8 MP2105K32E6R8** X2 320VAC 1.0 26.5 12 21.5 22.5 0.8 MP2125K32E6R8** X2 320VAC 1.2 26.5 12 21.5 22.5 0.8 MP2155K32E7R8** X2 320VAC 1.5 26.5 13 23 22.5 0.8 MP2105K32F1R8** X2 320VAC 1.0 31.5 10.8 19.5 27.5 0.8 MP2125K32F1R8** X2 320VAC 1.2 31.5 10.8 19.5 27.5 0.8 MP2125K32F2R8** X2 320VAC 1.2 31.5 13 21.5 27.5 0.8 MP2155K32F2R8** X2 320VAC 1.5 31.5 13 21.5 27.5 0.8 MP2185K32F2R8** X2 320VAC 1.8 31.5 13 21.5 27.5 0.8 MP2155K32F3R8** X2 320VAC 1.5 31 14 25 27.5 0.8 MP2185K32F3R8** X2 320VAC 1.8 31 14 25 27.5 0.8 MP2205K32F3R8** X2 320VAC 2.0 31 14 25 27.5 0.8 MP2225K32F3R8** X2 320VAC 2.2 31 14 25 27.5 0.8 MP2205K32F4R8** X2 320VAC 2.0 31.5 16 25.5 27.5 0.8 MP2255K32F4R8** X2 320VAC 2.5 31.5 16 25.5 27.5 0.8 MP2275K32F4R8** X2 320VAC 2.7 31.5 16 25.5 27.5 0.8 MP2305K32F4R8** X2 320VAC 3.0 31.5 16 25.5 27.5 0.8 MP2225K32F5R8** X2 320VAC 2.2 31.5 16 30 27.5 0.8 MP2255K32F5R8** X2 320VAC 2.5 31.5 16 30 27.5 0.8 MP2335K32F5R8** X2 320VAC 3.3 31.5 16 30 27.5 0.8 MP2305K32F6R8** X2 320VAC 3.0 31 18 33 27.5 0.8 MP2335K32F6R8** X2 320VAC 3.3 31 18 33 27.5 0.8 MP2355K32F6R8** X2 320VAC 3.5 31 18 33 27.5 0.8 MP2395K32F6R8** X2 320VAC 3.9 31 18 33 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MPX/MKP X2 320VAC--MP2 Series/ MP2 系列) ■ 料号明细及尺寸 Part No. List and Dimensions 成品编码 等级 电压 Part No. Class MP2405K32F6R8** 容量 尺寸 Dimension (mm) Voltage Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.5 X2 320VAC 4.0 31 18 33 27.5 0.8 MP2455K32F6R8** X2 320VAC 4.5 31 18 33 27.5 0.8 MP2475K32F6R8** X2 320VAC 4.7 31 18 33 27.5 0.8 MP2505K32F6R8** X2 320VAC 5.0 31 18 33 27.5 0.8 MP2275K32F9R8** X2 320VAC 2.7 31.5 18 28 27.5 0.8 MP2335K32F9R8** X2 320VAC 3.3 31.5 18 28 27.5 0.8 MP2355K32F9R8** X2 320VAC 3.5 31.5 18 28 27.5 0.8 MP2155K32S0R1** X2 320VAC 1.5 41 11 22 37.5 1.0 MP2185K32S0R1** X2 320VAC 1.8 41 11 22 37.5 1.0 MP2205K32S0R1** X2 320VAC 2.0 41 11 22 37.5 1.0 MP2185K32S1R1** X2 320VAC 1.8 41 12 26 37.5 1.0 MP2205K32S1R1** X2 320VAC 2.0 41 12 26 37.5 1.0 MP2225K32S1R1** X2 320VAC 2.2 41 12 26 37.5 1.0 MP2255K32S1R1** X2 320VAC 2.5 41 12 26 37.5 1.0 MP2275K32S1R1** X2 320VAC 2.7 41 12 26 37.5 1.0 MP2225K32S2R1** X2 320VAC 2.2 41 14 28 37.5 1.0 MP2255K32S2R1** X2 320VAC 2.5 41 14 28 37.5 1.0 MP2275K32S2R1** X2 320VAC 2.7 41 14 28 37.5 1.0 MP2305K32S2R1** X2 320VAC 3.0 41 14 28 37.5 1.0 MP2335K32S2R1** X2 320VAC 3.3 41 14 28 37.5 1.0 MP2355K32S2R1** X2 320VAC 3.5 41 14 28 37.5 1.0 MP2305K32S3R1** X2 320VAC 3.0 41 16 30 37.5 1.0 MP2335K32S3R1** X2 320VAC 3.3 41 16 30 37.5 1.0 MP2355K32S3R1** X2 320VAC 3.5 41 16 30 37.5 1.0 MP2395K32S3R1** X2 320VAC 3.9 41 16 30 37.5 1.0 MP2405K32S3R1** X2 320VAC 4.0 41 16 30 37.5 1.0 MP2455K32S3R1** X2 320VAC 4.5 41 16 30 37.5 1.0 MP2475K32S3R1** X2 320VAC 4.7 41 16 30 37.5 1.0 说明 Note:“**”表示内部特征码 “**”=Internal use. 说明 Note:“**”表示内部特征码 We can customize the capacitors according to customers special requirements. “**”=Internal use.
MP2224K32C3R6LC 价格&库存
很抱歉,暂时无法提供与“MP2224K32C3R6LC”相匹配的价格&库存,您可以联系我们找货
MP2224K32C3R6LC
  • 10+0.41505
  • 100+0.33210
  • 500+0.26946
  • 1000+0.23836
库存:1735
