EMVH101ARA100MHA0G
EMVH101ARA100MHA0G
    NCC(贵弥功)
    SMD,D8xL10mm
    贴片铝电解电容 AEC_D8X10MM_SM
EMVH101ARA100MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS High heat resistance, 125C MVH @Endurance : 125C 1000 to 5000 hours @Suitable to fit for automotive equipment @Solvent-proof type (10 to 50V) (see PRECAUTIONS AND GUIDELINES) @Pb-free design 125C size extended MVK ?SPECIFICATIONS Items Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life Characteristics -40 to +125C 10 to 450Vdc P20% (M) (at 20C, 120Hz) 10 to 100Vdc 160 to 450Vdc I=0.03CV or 4MA, whichever is greater. I=0.04CV+100max Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) (at 20C after 2 minutes) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V 0.24 0.20 0.16 0.14 0.14 0.18 0.18 F60 to JA0 tanE (Max.) 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.20 0.24 KE0 to MN0 When nominal capacitance exceeds 1000MF, add 0.02 to the value above for each 1000MF increase. (at 20C, 120Hz) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V Z(-25C)/Z(+20C) 4 3 2 2 2 2 2 F60 to JA0 Z(-40C)/Z(+20C) 10 8 6 4 4 4 4 Z(-25C)/Z(+20C) 4 3 6 3 2 2 2 2 2 KE0 to MN0 Z(-40C)/Z(+20C) 8 (at 120Hz) 6 10 6 4 3 3 3 3 The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for the specified time at 125C. F60 to H63 (10 to 100Vdc) : 1000hours HA0 to JA0 (10 to 100Vdc) : 2000hours Time KE0 to MN0 (10 to 100Vdc) : 5000hours KE0 to MN0 (160 to 450Vdc) : 2000hours Capacitance change [P30% of the initial value D.F. (tanE) [300% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1000 hours (500 hours for 350 to 450WV) at 125C without voltage applied. Rated voltage(Vdc) 10 to 50Vdc 63 to 450Vdc Capacitance change [P30% of the initial value [P30% of the initial value D.F. (tanE) [300% of the initial specified value [300% of the initial specified value Leakage current [The initial specified value [500% of the initial specified value ?DIMENSIONS [mm] @Terminal Code : A @Size code : F60 to KG5 ?MARKING F60 to JA0 EX) 35V47MF W P CP0.2 BP0.2 FDP0.5 74H @Terminal Code : G @Size code : LH0 to MN0 W BP0.2 FDP0.5 0.3max. AP0.2 LP0.5 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.9 1.9 2.3 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 KE0 to MN0 EX) 16V1000MF 0V MVH 1000 16V P CP0.2 0.3max. LP0.5 (Note) Note : LP0.3 for F60 and F80 C B A L Size code D 6.3 5.7 6.6 6.6 7.2 F60 6.3 7.7 6.6 6.6 7.2 F80 6.3 8.3 8.3 9.0 8 H63 8 10.0 8.3 8.3 9.0 HA0 10 10.0 10.3 10.3 11.0 JA0 12.5 13.5 13.0 13.0 13.7 KE0 12.5 16.0 13.0 13.0 13.7 KG5 16 16.5 17.0 17.0 18.0 LH0 16 21.5 17.0 17.0 18.0 LN0 18 16.5 19.0 19.0 20.0 MH0 18 21.5 19.0 19.0 20.0 MN0 47 35V AP0.2 : Dummy terminals (1/2) CAT. No. E1001E SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS High heat resistance, 125C ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MV H AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7MF:4R7,10MF:100) Taping·Tray code Terminal code (A, G) Voltage code (ex. 10V:100,50V:500,100V:101) Series code Category Please refer to "A guide to global code (surface mount type)" ?STANDARD RATINGS WV Cap (Vdc) (mF) Size code 100 100 220 330 1000 2200 2200 3300 4700 47 470 680 680 1000 2200 33 47 47 100 220 330 470 470 680 680 1000 10 22 33 33 47 100 330 330 470 470 680 10 22 22 33 F80 H63 HA0 JA0 KE0 LH0 MH0 MH0 MN0 F60 KE0 KE0 LH0 MH0 MH0 F60 F80 H63 HA0 JA0 KE0 KE0 LH0 LH0 MH0 MN0 F60 F60 F80 H63 HA0 JA0 KE0 LH0 KG5 LH0 MH0 F60 F80 H63 HA0 ESR (omax/ 100kHz) 20c 10 16 25 35 50 2.3 2.3 1.0 0.70 0.14 0.10 0.10 0.10 0.058 3.3 0.14 0.14 0.10 0.10 0.10 3.3 2.3 2.3 1.0 0.70 0.14 0.14 0.10 0.10 0.10 0.058 3.3 3.3 2.3 2.3 1.0 0.70 0.14 0.10 0.11 0.10 0.10 3.3 2.3 2.3 1.0 is non solvent-proof (63 to 450Vdc). Rated ripple current (mArms/125c) Part No. WV Cap (Vdc) (mF) Size code 47 100 220 220 330 330 470 10 10 22 33 100 220 330 470 10 22 47 68 100 220 10 22 33 68 10 22 33 33 47 10 22 22 33 4.7 6.8 10 10 3.3 4.7 10 JA0 KE0 KE0 LH0 KG5 LH0 MH0 F80 H63 HA0 JA0 KE0 KG5 LH0 LN0 HA0 JA0 KE0 KG5 LH0 MN0 KE0 LH0 MH0 MN0 KE0 LH0 LN0 MH0 MN0 KG5 LN0 MH0 MN0 KE0 LH0 LN0 MH0 KG5 LH0 MN0 -40c 100kHz 120Hz 46.0 46.0 20.0 13.4 2.1 1.5 1.5 1.5 0.87 66.0 2.1 2.1 1.5 1.5 1.5 66.0 46.0 46.0 20.0 13.4 2.1 2.1 1.5 1.5 1.5 0.87 66.0 66.0 46.0 46.0 20.0 13.4 2.1 1.5 1.5 1.5 1.5 66.0 46.0 46.0 20.0 72 72 136 188 750 1000 1200 1200 1550 43 750 750 1000 1200 1200 45 68 68 126 211 750 750 1000 1000 1200 1550 27 39 62 62 92 151 750 1000 900 1000 1200 38 50 50 83 - EMVH100ADA101MF80G EMVH100ADA101MH63G EMVH100ADA221MHA0G EMVH100ADA331MJA0G EMVH100ASS102MKE0S EMVH100GTR222MLH0S EMVH100GTR222MMH0S EMVH100GTR332MMH0S EMVH100GTR472MMN0S EMVH160ADA470MF60G EMVH160ASS471MKE0S EMVH160ASS681MKE0S EMVH160GTR681MLH0S EMVH160GTR102MMH0S EMVH160GTR222MMH0S EMVH250ADA330MF60G EMVH250ADA470MF80G EMVH250ADA470MH63G EMVH250ADA101MHA0G EMVH250ADA221MJA0G EMVH250ASS331MKE0S EMVH250ASS471MKE0S EMVH250GTR471MLH0S EMVH250GTR681MLH0S EMVH250GTR681MMH0S EMVH250GTR102MMN0S EMVH350ADA100MF60G EMVH350ADA220MF60G EMVH350ADA330MF80G EMVH350ADA330MH63G EMVH350ADA470MHA0G EMVH350ADA101MJA0G EMVH350ASS331MKE0S EMVH350GTR331MLH0S EMVH350ASS471MKG5S EMVH350GTR471MLH0S EMVH350GTR681MMH0S EMVH500ADA100MF60G EMVH500ADA220MF80G EMVH500ADA220MH63G EMVH500ADA330MHA0G 50 63 100 160 200 250 400 450 ESR (omax/ 100kHz) Rated ripple current (mArms/125c) 20c -40c 100kHz 120Hz 0.70 0.23 0.23 0.15 0.18 0.15 0.15 2.3 2.3 1.0 0.70 0.25 0.20 0.18 0.11 1.0 0.70 0.33 0.26 0.24 0.16 - 13.4 3.5 3.5 2.3 2.7 2.3 2.3 115 115 50.0 35.0 12.5 10.0 9.0 5.5 50.0 35.0 16.5 13.0 12.0 8.0 - 111 550 550 850 700 850 920 42 42 56 71 500 600 820 1100 53 63 450 550 650 950 - 100 180 245 380 100 180 250 245 315 110 200 205 260 70 100 140 135 65 85 145 Part No. EMVH500ADA470MJA0G EMVH500ASS101MKE0S EMVH500ASS221MKE0S EMVH500GTR221MLH0S EMVH500ASS331MKG5S EMVH500GTR331MLH0S EMVH500GTR471MMH0S EMVH630ADA100MF80G EMVH630ADA100MH63G EMVH630ADA220MHA0G EMVH630ADA330MJA0G EMVH630ASS101MKE0S EMVH630ASS221MKG5S EMVH630GTR331MLH0S EMVH630GTR471MLN0S EMVH101ADA100MHA0G EMVH101ADA220MJA0G EMVH101ASS470MKE0S EMVH101ASS680MKG5S EMVH101GTR101MLH0S EMVH101GTR221MMN0S EMVH161ASS100MKE0S EMVH161GTR220MLH0S EMVH161GTR330MMH0S EMVH161GTR680MMN0S EMVH201ASS100MKE0S EMVH201GTR220MLH0S EMVH201GTR330MLN0S EMVH201GTR330MMH0S EMVH201GTR470MMN0S EMVH251ASS100MKG5S EMVH251GTR220MLN0S EMVH251GTR220MMH0S EMVH251GTR330MMN0S EMVH401ASS4R7MKE0S EMVH401GTR6R8MLH0S EMVH401GTR100MLN0S EMVH401GTR100MMH0S EMVH451ASS3R3MKG5S EMVH451GTR4R7MLH0S EMVH451GTR100MMN0S SS : Taping / Tray code (2/2) CAT. No. E1001E
EMVH101ARA100MHA0G 价格&库存
很抱歉,暂时无法提供与“EMVH101ARA100MHA0G”相匹配的价格&库存,您可以联系我们找货
EMVH101ARA100MHA0G
  • 500+3.31953500+0.43146
  • 1000+3.070181000+0.39905
  • 1500+2.944341500+0.38270
  • 2500+2.803992500+0.36445
  • 3500+2.721463500+0.35373
  • 5000+2.641775000+0.34337
库存:160
EMVH101ARA100MHA0G
  • 1+9.446251+1.22779
  • 10+6.0199910+0.78245
  • 50+4.5704950+0.59406
  • 100+4.11056100+0.53428
库存:160
EMVH101ARA100MHA0G
    库存:3500
