金属化丙烯膜箔式高压电容器---CBB81(PPS)系列
Metallized Polypropylene Film And Foil Capacitors---CBB81(PPS)series
■ 引用标准 Reference standards
GB10188(IEC384-13)
■ 结构 Structure
介质:聚丙烯膜
电极:金属真空蒸发层和铝箔
封装:阻燃粉末环氧树脂,符合 UL94V-0
Dielectric: Polypropylene film
Electrode: Metal vacuum evaporation layer and aluminum foil
Encapsulation: inflame retardant power epoxy resin, conforming to UL94 V-0
典型应用 Typical
Application
高频、直流、交流及脉冲大电流场合 如:灯具、电源,显示器及彩电行逆程线路等 电子整流器,节能灯等
high frequency, direct current, alternating current or large pulse current occasion
For example damp, power supply, display and colorful TV lines retrace circuits, electronic rectifier, energy-saving
lamps etc
特点 Features
有良如自愈性能。高频损耗小,温升低,高冲击强度。内部串联结构,电压高,过电流大等
Small volume with good self-healing property, low dissipation at high frequency, low temperature rise
High impact strength. Internal series structure, high voltage, large current passage etc.
符合 RoHS 及 REACH 环保标准 Compliance with RoHs &
电性能规范 Performance Specifications
REACH requirements.
气候类别 Climate category
40/105/56
额定温度 Rated Temperature
85℃
工作温度范围
-40℃--+105℃.
Operating Temperature range
(+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC)
额定电压 Rated Voltage
630VDC, 1000VDC, 1250VDC, 1600VDC, 2000VDC, 3000VDC
容量误差 Capacitance Tolerance
J: ±5%
容量范围
0.001μF~22μF
Capacitance Range
测试条件 Test Condition:
(+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC)
耐电压
Withstand Voltage
20℃, 1KHz, 1Vrms
无击穿或飞弧
2.0UR,5S
No breakdown or electric arcing
损耗角 Dissipation factor
≤0.001
绝缘电阻或时间常数
CR≤0.1μF IR≥30000MΩ
Insulation Resistance
CR>0.1μF IR≥10000S
(1KHZ )
测试条件 Test Condition :
20℃
1Vrms
20℃
100V
1 min
最大脉冲爬升速率
P=10
P=15
P=20
P=22.2
P=25
P=27.5
P=31.5
Max. Pulse Rise Time
(dV / dt)
1000
1500
1000
500
500
500
500
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change ( relative to the initial
value):△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0020(1KHZ),CR>1uF
耐久性试验
温度 Temp.: +85℃,
绝缘电阻 Insulation Resistance
Endurance Test
电压 Voltage:
IR:≥ 额定值的 50%
IR:≥ 50% of rated value
1.25 Times Rated Voltage
持续时间 Duration Time: 1000H
损耗角增加:≤0.0040
dissipation factor rise:≤0.0040
容量变化(相对初始值):△C/C≤±10%
Capacitance change
(relative to the initial value):△C/C≤±10%
产品编码说明 Part No. Description:
18 位产品编码如下:
The Part No. Is total 18 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
P
P
S
1
J
3
C
Digit 1-3
型号代码 Product series Code
Digit 4-6
Digit 7
Digit 8-9
Digit 10-15
Digit 16
Digit 17-18
标称容量 Rated Capacitance Value
容量偏差 Capacitance Tolerance
额定电压 Rated Voltage Code
2
11
12
13
14
15
16
17
18
9
1
5
2
3
8
PPS= CBB81 series
For example : 104 = 10×104pF = 0.1F
J=±5% K=±10%
2J=630VDC 3A=1000VDC 3C=1600VDC 3D=2000VDC
外形尺寸 Dimensions Code
线径代码 Line diameter code
6=0.6 8=0.8
成型或内部识别码 Forming Type or Internal Use
1=1.0
料号明细及尺寸 Part No. List and Dimensions
UR :1000Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS104J3A2608158LC
PPS
0.1
25
8
15
22.5
0.8
PPS104J3A2612198LC
PPS
0.1
25
12
19.5
22.5
0.8
PPS332J3A1307126LC
PPS
0.0033
13
6
11
10.0
0.6
PPS473J3A1913208LC
PPS
0.047
18
11.5
19
15.0
0.8
UR :1250Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS102J3B1909148LC
PPS
0.001
18
9.5
14.5
15.0
0.8
PPS104J3B2914218LC
PPS
0.1
28
12
19
25.0
0.8
PPS153J3B1908138LC
PPS
0.015
18
7.5
12.5
15.0
0.8
PPS154J3B2914208LC
PPS
0.15
28
12.5
18
25.0
0.8
PPS203J3B2408148LC
PPS
0.02
23
7.5
13.5
20.0
0.8
PPS224J3B2922278LC
PPS
0.2
28
18
26
25.0
0.8
PPS472J3B1309136LC
PPS
0.0047
13
5.5
9.5
10.0
0.6
PPS562J3B1307136LC
PPS
0.0056
13
6
12
10.0
0.6
UR :1600Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS103J3C1908158LC
PPS
0.01
18
8
14.5
15.0
0.8
PPS104J3C2914218LC
PPS
0.1
28
12.5
19.5
25.0
0.8
PPS203J3C2911178LC
PPS
0.02
28
9.5
16.5
25.0
0.8
PPS822K3C2408158LC
PPS
0.0082
23
8
15
20.0
0.8
UR :2000Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS151K3D1905106LC
PPS
0.00015
18
7.0
10.5
15.0
0.6
PPS223J3D2409148LC
PPS
0.022
23
9
14
20.0
0.8
PPS332J3D2408148LC
PPS
0.0033
23
8
13.5
20.0
0.8
PPS472J3D2410158LC
PPS
0.0047
23
8.5
15
20.0
0.8
PPS562J3D2407138LC
PPS
0.0056
23
8
12.5
20.0
0.8
PPS822J3D1911188LC
PPS
0.0082
18
9.5
16.5
15.0
0.8
UR :2500Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS102J3E1909148LC
PPS
0.001
18
10
15
15.0
0.8
PPS103J3E3509168LC
PPS
0.01
34
10
17
31.5
0.8
UR :3000Vdc
成品编码
系列
Part No.
PPS682J3F2415228LC
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
Φd±0.05
PPS
0.0068
24
15
22
20.0
0.8
Note: We can customize the capacitors according to customers special requirements.
很抱歉,暂时无法提供与“PPS104J3A2612198LC”相匹配的价格&库存,您可以联系我们找货
