YSO752ST
Features
000 X
5
X
1 2
XX
C
Y X
. External dimensions: 7.5 x 5.0 x 1.6 mm.
. Frequency range: 1MHz ~ 150MHz.
.Smallest & Thinest SMD package.
.Excellent temperature range, Best Reliability.
.Excellent total frequency stability.
.Applications: WLAN, Bluetooth, DSC, DSL, IP CAM, SSD,e-books
and other IT product.
Electrical Specifications
Item / Type
YSO752ST
Output Frequency Range
1~90MHz
Supply Voltage
Current Consumption ( Max. )
90~150MHz
1.8V
2.25~5.5V
1.6~3.6V
5.0V
18mA
46mA
48mA
80mA
Output Type
CMOS
Oscillation Mode
Fundamental / 3rd Overtone
Frequency Tolerance
± 20ppm, ± 25ppm,
or specify
Output Load
15 pF, or specify
Operating Temperature Range
- 40 ~ + 85 ℃, or specify
Storage Temperature Range
- 55 ~ + 125 ℃
Voltage Vol ( Max. ) / Vol ( Min. )
90%Vdd min./10%Vdd max
Symmetry
45~55%DT,40/60~60/40%Svm
Rise ( Tr ) / Fall ( Tf ) Time
10Max./8 ns Max.
Start-up Time
10 ms Max.
Aging ( at 25 ℃ )
± 3 ppm / year Max.
Phase
Noise(Pn)
Three State Function
-125 Max.
dBc/Hz @1khz
Enable Voltage
70%Vdd Min.
By Low Pressure
30%Vdd Max.
Dimensions
引脚功能定义
引脚
.YXC XXXX
1
功能
E/D
定义
三态/无三态
2
GND
接地
3
OUTPUT
输出
4
Vdd
电源电压
6
3
125.000
Units: mm
1/2
YSO752ST
★ PART NUMBER GUIDE 部件号示例
Frequency
Stability output
Overall
(ppm)
Quartz Crystal Oscillator Dimensions Frequency Supply voltage
(Hz)
(V)
O
125M
7050
Supply voltage
H
Frequency tolerance
1.8V
D
±20PPM
C
-20 to 70 ℃
3.3V
E
±25PPM
I
-40 to 85 ℃
F
G
5.0V
3.3Vto5V
H
±50PPM
F
-40 to 105 ℃
A
-40 to 125℃
H
2.25Vto5.5V
★ TAPING SPECIFICATION (Unit: mm)
φ1.31
Material Operating Temp.
Range
I
S
Output
Operating temperature
E
Pin
4
A
E
A
4.0
YSO 7 52ST=7 .0×5.0 SMD SEAM TYPE
e.g. O 7 050125MH EA4 SI
A
CMOS
编带规格
1.02
12
0°
φ13
2.0
C
B
D
OSC-SMD7050
G
A
F
E
A
B
178±2.0
16.0±0.3
C
8.40±0.15
D
5.80±0.15
E
F
G
7.88±0.1
1.90±0.1
58.0±1.0
1000 pcs per reel
★ REFLOW SOLDERING PROFILE
★ Test Circuit
回流焊特性
2/2
很抱歉,暂时无法提供与“O70508192MHEA4SI-1”相匹配的价格&库存,您可以联系我们找货
