MPB201205T-1R5M-NA2
MPB201205T-1R5M-NA2
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
MPB201205T-1R5M-NA2 数据手册
SMD Multilayer Power Inductors – MP Series Multilayer Power Inductors The MPx Series is a miniature type of multilayer power inductor constructed using low-loss ferrite material to support high-speed switching frequencies. The compact size and high efficiency is ideal for DC-DC converter applications in space-limited boards. Features Applications  RoHS compliant  DC-DC converters  Small size  Power modules  Low profile  Cellular phones  High current  DSC, PND, DVD  Magnetically shielded configuration allowing for high density  Wireless card and other electronic devices. mounting Product Identification  Product Symbol : MPA, MPB  Type : A : General , B : Low RDC  Packaging : T:Tape and Reel , B:Bulk  Tolerance : M = ± 20% , T = ±30% Dimensions in mm Dimensions in mm D TYPE A B C 0.80.15 0.30.2 160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 0.55 Max 0.50.3 201205 0.8 ~ 1.2 2.3 ~ 2.9 1.0 ~ 1.4 1.0 Max 0.50.3 201210 0.8 ~ 1.2 2.3 ~ 2.9 1.0 ~ 1.4 1.250.20 0.50.3 201212 0.8 ~ 1.2 2.3 ~ 2.9 1.0 ~ 1.4 1.0 Max 0.50.3 201610 0.8 ~ 1.2 2.1 ~ 2.7 1.6 ~ 2.0 2.00.20 1.0 Max 0.50.3 252010 1.3 ~ 1.9 2.7 ~ 3.5 2.0 ~ 2.6 2.00.20 1.2 Max 0.50.3 252012 1.3 ~ 1.9 2.7 ~ 3.5 2.0 ~ 2.6 TYPE A B 160808 1.60.15 0.80.15 201205 2.00.20 1.250.20 201210 2.00.20 1.250.20 201212 2.00.20 1.250.20 201610 2.00.20 1.60.20 252010 2.50.20 252012 2.50.20 C SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPA : General Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPA201210T-1R0-N 1.0 1 20, 30 0.18 1100 MPA201210T-1R5-N 1.5 1 20, 30 0.19 1000 MPA201210T-2R2-N 2.2 1 20, 30 0.22 900 MPA201210T-3R3-N 3.3 1 20, 30 0.25 700 MPA201210T-4R7-N 4.7 1 20, 30 0.35 600 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 1MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Characteristics Inductance vs. DC Current 10 12 9 10 8 7 4R7 L (uH) L (uH) 8 6 3R3 4 6 5 4R7 4 3R3 3 2R2 2R2 2 2 1R5 1R5 1R0 1 1R0 0 0 1 10 100 Frequency(MHz) 1000 1 10 DC Current(m A) 100 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPA : General Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPA252010T-1R0-N 1.0 1 20, 30 0.11 1200 MPA252010T-1R5-N 1.5 1 20, 30 0.13 1100 MPA252010T-2R2-N 2.2 1 20, 30 0.15 1000 MPA252010T-3R3-N 3.3 1 20, 30 0.18 1000 MPA252010T-4R7-N 4.7 1 20, 30 0.25 900 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 1MHz 200mV  RDC:HP 4118B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Characteristics Inductance vs. DC Current 18 10 16 9 14 8 4R7 7 L (uH) L(uH) 12 10 8 3R3 6 6 5 4R7 4 3R3 3 2R2 4 2R2 2 1R5 2 1R5 1R0 1 1R0 0 0 1 10 100 Frequency(MHz) 1000 1 10 DC Current (m A) 100 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB160808T-R56-NA2 0.56 3 20, 30 0.23 900 MPB160808T-1R0-NA2 1.0 3 20, 30 0.28 800 MPB160808T-2R2-NA2 2.2 3 20, 30 0.40 600 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Chaaracteristics Inductance vs. DC Current 2.5 3 2.5 2 L(uH) L(uH) 2 2R2 1.5 2R2 1.5 1R0 1 1 1R0 R56 0.5 0.5 R56 0 0 1 10 100 FREQUENCY(MHz) 1000 0 200 400 600 DC Current(m A) 800 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB201205T-R47-NA2 0.47 3 20, 30 0.11 1200 MPB201205T-1R0-NA2 1.0 3 20, 30 0.16 900 MPB201205T-1R5-NA2 1.5 3 20, 30 0.18 800 MPB201206T-2R2-NA2 2.2 3 20, 30 0.29 600 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Chaaracteristics Inductance vs. DC Current 3.0 2.5 2R2 2.5 2.0 2R2 1.5 1R5 1R5 L (uH) L(uH) 2.0 1.5 1R0 1.0 1R0 1.0 R47 0.5 0.5 R47 0.0 0.0 1 10 100 FREQUENCY(MHz) 1000 0 100 200 300 400 500 600 DC Current(m A) 700 800 900 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB201210T-R47-NA2 0.47 3 20, 30 0.09 1300 MPB201210T-1R0-NA2 1.0 3 20, 30 0.12 1200 MPB201210T-1R5-NA2 1.5 3 20, 30 0.15 1100 MPB201210T-2R2-NA2 2.2 3 20, 30 0.19 1100 MPB201210T-3R3-NA2 3.3 3 20, 30 0.24 800 MPB201210T-4R7-NA2 4.7 3 20, 30 0.26 700 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Chaaracteristics Inductance vs. DC Current 5 12 4R7 10 4 4R7 L(uH) L(uH) 8 3R3 6 3R3 3 2R2 2 1R5 4 2R2 1R0 1R5 2 1 R47 1R0 R47 0 0 1 10 100 FREQUENCY(MHz) 1000 0 100 200 300 400 500 600 DC Current(m A) 700 800 900 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB201212T-1R0-NA2 1.0 3 20, 30 0.13 1200 MPB201212T-1R5-NA2 1.5 3 20, 30 0.16 1100 MPB201212T-2R2-NA2 2.2 3 20, 30 0.23 900 MPB201212T-3R3-NA2 3.3 3 20, 30 0.23 900 MPB201212T-4R7-NA2 4.7 3 20, 30 0.27 700 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. DC Current Inductance vs. Frequency Chaaracteristics 12 5 4.5 4R7 10 4 4R7 3.5 6 L(uH) L(uH) 8 3R3 4 2R2 2.5 2R2 2 1R5 1.5 1R0 1 1R5 2 3R3 3 0.5 1R0 0 0 1 10 100 FREQUENCY(MHz) 1000 0 200 400 600 DC Current(m A) 800 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB201610T-R47-NA2 0.47 3 20, 30 0.06 1600 MPB201610T-1R0-NA2 1.0 3 20, 30 0.09 1300 MPB201610T-2R2-NA2 2.2 3 20, 30 0.13 1000 MPB201610T-3R3-NA2 3.3 3 20, 30 0.17 850 MPB201610T-4R7-NA2 4.7 3 20, 30 0.21 800 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. DC Current Inductance vs. Frequency Chaaracteristics 4.5 12 4.0 10 4R7 3R3 3.0 L(uH) 8 L(uH) 4R7 3.5 3R3 6 2.5 2R2 2.0 1.5 4 2R2 1R0 1.0 2 1R0 R47 R47 0.5 0.0 0 1 10 100 FREQUENCY(MHz) 1000 0 100 200 300 400 500 600 DC Current(m A) 700 800 900 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB252010T-R47-NA2 0.47 3 20, 30 0.04 1800 MPB252010T-1R0-NA2 1.0 3 20, 30 0.06 1500 MPB252010T-1R5-NA2 1.5 3 20, 30 0.07 1400 MPB252010T-2R2-NA2 2.2 3 20, 30 0.10 1200 MPB252010T-3R3-NA2 3.3 3 20, 30 0.12 1100 MPB252010T-4R7-NA2 4.7 3 20, 30 0.14 1000 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. DC Current Inductance vs. Frequency Chaaracteristics 5 12 4R7 10 4 4R7 3R3 L(uH) L(uH) 8 3R3 6 3 2R2 2 1R5 4 2R2 1R0 1R5 1 2 R47 1R0 R47 0 0 1 10 100 FREQUENCY(MHz) 1000 0 100 200 300 400 500 600 DC Current(m A) 700 800 900 1000 SMD Multilayer Power Inductors – MP Series Electrical Characteristics MPB : Low RDC Series Inductance Test Frequency Tolerance RDC Rated current (uH) (MHz) (±%) (Ω) ±30% (mA) Max MPB252012T-R47-NA2 0.47 3 20, 30 0.04 1800 MPB252012T-1R0-NA2 1.0 3 20, 30 0.05 1600 MPB252012T-1R5-NA2 1.5 3 20, 30 0.07 1400 MPB252012T-2R2-NA2 2.2 3 20, 30 0.10 1200 MPB252012T-3R3-NA2 3.3 3 20, 30 0.12 1100 MPB252012T-4R7-NA2 4.7 3 20, 30 0.14 1000 MPB252012T-6R8-NA2 6.8 3 20, 30 0.16 900 MPB252012T-100-NA2 10 3 20, 30 0.20 500 Part Number  Tolerance:M = ±20% ,T = ±30%  Packaging: Clear tape and reel {standard}.  L:Agilent/HP4287A+16197A, 3MHz 200mV  RDC:HP 4338B, or equivalent  Rated Current:Applied the current to coils, the temperature rise shall not be more than 40℃  Operating temperature range from -55℃ to 125℃. (Including self - temperature rise) Test Instruments:HP4287A Inductance / Material Analyzer Inductance vs. Frequency Chaaracteristics Inductance vs. DC Current 30 10 9 25 100 100 8 7 15 L(uH) L(uH) 20 6R8 3R3 3 3R3 5 2R2 1R5 1R0 R47 2 2R2 1R5 1R0 R47 0 4R7 5 4 4R7 10 6R8 6 1 0 1 10 FREQUENCY(MHz) 100 1000 0 100 200 300 400 500 600 DC Current(m A) 700 800 900 1000 SMD Multilayer Power Inductors – MP Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions TYPE Reel Dimensions Quantity A B T W P F K Tape Type A B C D PCS / REEL 160808 1.05 1.85 0.95 8.0 4.0 3.5 0.80 B 178 60 12 1.5 4000 201205 1.42 2.25 0.22 8.0 4.0 3.5 0.80 A 178 60 12 1.5 4000 201210 1.45 2.25 0.22 8.0 4.0 3.5 1.04 A 178 60 12 1.5 3000 201212 1.35 2.25 0.22 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000 201610 1.80 2.20 0.22 8.0 4.0 3.5 1.15 A 178 60 12 1.5 3000 252010 2.25 2.8 0.25 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000 252012 2.25 2.8 0.25 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000
MPB201205T-1R5M-NA2 价格&库存
很抱歉,暂时无法提供与“MPB201205T-1R5M-NA2”相匹配的价格&库存,您可以联系我们找货
