SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
High heat resistance, 125℃
New!
●Endurance
: 2,000 hours at 125℃
voltage range : 10 to 35V
●Nominal capacitance range : 47 to 470µF
●Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
●RoHS Compliant
MHJ
●Rated
Lower ESR
MHB
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf Life
-40 to +125℃
10 to 35Vdc
(20℃, 120Hz)
±20%(M)
I=0.01CV
Where, I : Max. leakage current (μA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage(Vdc)
10V 16V 25V 35V
tanδ (Max.)
(20℃, 120Hz)
0.30 0.23 0.18 0.16
Rated voltage(Vdc)
10V 16V 25V 35V
Z(-25℃)/Z(+20℃)
3
2
2
2
4
3
3
3
(120Hz)
Z(-40℃)/Z(+20℃)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
at 125℃.
Capacitance change ≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
HA0
JA0
F80
ESR
20℃
3.5
0.60
0.40
(Ωmax./100kHz)
-40℃
40
4.5
3.5
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
D.F. (tanδ)
Leakage current
◆DIMENSIONS [mm]
●Terminal
◆PART NUMBERING SYSTEM
1
Code : A
2
3
4
5
6
7
8
9
10
11
12
13
14
15 16
W
18
0.3max.
L±0.3
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470, 100µF:101)
Taping code
Terminal code
Voltage code (ex. 16V:160, 35V:350)
Series code
Category
P
C±0.2
B±0.2
φD±0.5
17
E MH J A A A A D A A A A M A A A G
A±0.2
Please refer to "Product code guide (surface mount type)"
Size code
F80
HA0
JA0
C
B
A
L
φD
6.3 7.7 6.6 6.6 7.2
8 10.0 8.3 8.3 9.0
10 10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.9
3.1
4.5
◆MARKING
10
16
25
35
Cap(µF)
220
330
330
470
100
100
220
330
470
100
220
330
47
47
100
220
Size code
5j
HA0
HA0
JA0
JA0
F80
HA0
HA0
JA0
JA0
HA0
JA0
JA0
F80
HA0
HA0
JA0
ESR (Ωmax/100kHz)
voltage symbol
Rated voltage (Vdc) Symbol
A
10
C
16
E
25
V
35
100
CHJ
◆STANDARD RATINGS
WV(Vdc)
● Rated
EX) 16V100µF
20℃
−40℃
Rated ripple current
(mArms/125℃, 100kHz)
0.15
0.15
0.12
0.12
0.45
0.15
0.15
0.12
0.12
0.15
0.12
0.12
0.45
0.15
0.15
0.12
3.0
3.0
2.0
2.0
5.0
3.0
3.0
2.0
2.0
3.0
2.0
2.0
5.0
3.0
3.0
2.0
350
350
550
550
220
350
350
550
550
350
550
550
220
350
350
550
Part No.
EMHJ100ADA221MHA0G
EMHJ100ADA331MHA0G
EMHJ100ADA331MJA0G
EMHJ100ADA471MJA0G
EMHJ160ADA101MF80G
EMHJ160ADA101MHA0G
EMHJ160ADA221MHA0G
EMHJ160ADA331MJA0G
EMHJ160ADA471MJA0G
EMHJ250ADA101MHA0G
EMHJ250ADA221MJA0G
EMHJ250ADA331MJA0G
EMHJ350ADA470MF80G
EMHJ350ADA470MHA0G
EMHJ350ADA101MHA0G
EMHJ350ADA221MJA0G
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
(1/1)
CAT. No. E1001L
很抱歉,暂时无法提供与“EMHJ350ARA101MHA0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.820261+1.14622
- 10+5.5833210+0.72557
- 50+4.2298950+0.54969
- 100+3.79954100+0.49376
- 国内价格 香港价格
- 500+3.05868500+0.39749
- 1000+2.825061000+0.36713
- 1500+2.707081500+0.35180
- 2500+2.575582500+0.33471
- 3500+2.498313500+0.32467
- 5000+2.423615000+0.31496
- 国内价格
- 5+2.08613
- 50+1.65608
- 150+1.47183
- 500+1.24190
