ELXZ350ETD221MH15D
ELXZ350ETD221MH15D
    NCC(贵弥功)
    插件,D8xL15mm
    直插铝电解电容 AEC_D8X15MM_TM
ELXZ350ETD221MH15D 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS LXZ Series Low impedance, Downsized, 105℃ LXZ Lower Z ・Adoption of innovative electrolyte and new technologies Downsized ・Very low impedance at high frequency LXY ・Endurance with ripple current: 2,000 to 8,000 hours at 105℃ Lower Z ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant LXV ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 6.3 to 63Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V tanδ(Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.08 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. Time φ5 & 6.3 : 2,000hours φ8 : 3,000hours φ10 : 5,000hoursφ12.5 : 7,000hours φ16 & 18 : 8,000hours Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Endurance Shelf Life ◆DIMENSIONS [mm] φd F±0.5 Code : E Sleeve (PET : Dark blue) F±0.5 ●Terminal φD φD' φd F φD' L' 15min. 4min. (φ5 to φ10) (φ12.5 to φ18) L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 Gas escape end seal Vent (Exceptφ5 & φ6.3) ◆PART NUMBERING SYSTEM 1 2 3 4 E LXZ 5 6 7 8 E 9 10 11 12 13 14 M 15 16 17 18 Supplement code Size code Capacitance tolerance code Capacitance code (ex. 150µF:151, 2,200µF:222) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3, 25V:250, 50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, Downsized, 105℃ LXZSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 150 330 470 680 820 1,000 1,200 1,200 1,500 2,200 2,700 3,300 3,900 6.3 4,700 5,600 5,600 6,800 6,800 6,800 8,200 10,000 10,000 12,000 12,000 15,000 18,000 100 220 330 470 680 680 1,000 1,000 1,200 1,500 1,800 2,200 2,200 10 3,300 3,900 3,900 4,700 5,600 5,600 5,600 6,800 6,800 8,200 8,200 10,000 10,000 12,000 47 100 220 330 470 470 560 16 680 1,000 1,200 1,500 1,500 2,200 2,700 5×11.5 6.3×11.5 6.3×15 8×12 10×12.5 8×15 8×20 10×16 10×20 10×25 10×30 12.5×20 12.5×25 12.5×30 12.5×35 16×20 12.5×40 16×25 18×20 16×30 16×35 18×25 16×40 18×30 18×35 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 8×20 10×16 10×20 10×25 10×30 10×30 12.5×20 12.5×25 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×30 18×25 16×35 18×30 16×40 18×35 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 8×20 10×16 10×20 10×25 10×30 12.5×20 12.5×25 12.5×30 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.50 0.25 0.18 0.12 0.090 0.090 0.080 0.068 0.052 0.045 0.037 0.038 0.030 0.025 0.022 0.029 0.017 0.022 0.028 0.019 0.017 0.020 0.015 0.018 0.016 0.015 0.50 0.25 0.18 0.12 0.090 0.090 0.080 0.068 0.052 0.045 0.037 0.037 0.038 0.030 0.025 0.029 0.022 0.017 0.022 0.028 0.019 0.020 0.017 0.018 0.015 0.016 0.015 0.50 0.25 0.18 0.12 0.090 0.090 0.080 0.068 0.052 0.045 0.037 0.038 0.030 0.025 1.0 0.50 0.36 0.24 0.18 0.18 0.16 0.136 0.104 0.090 0.074 0.076 0.060 0.050 0.044 0.058 0.034 0.044 0.056 0.038 0.034 0.040 0.030 0.036 0.032 0.030 1.0 0.50 0.36 0.24 0.18 0.18 0.16 0.136 0.104 0.090 0.074 0.074 0.076 0.060 0.050 0.058 0.044 0.034 0.044 0.056 0.038 0.040 0.034 0.036 0.030 0.032 0.030 1.0 0.50 0.36 0.24 0.18 0.18 0.16 0.136 0.104 0.090 0.074 0.076 0.060 0.050 175 290 400 555 760 730 810 1,050 1,220 1,440 1,690 1,660 1,950 2,310 2,510 2,210 2,870 2,560 2,490 3,010 3,150 2,740 3,710 3,330 3,680 3,800 175 290 400 555 730 760 810 1,050 1,220 1,440 1,690 1,690 1,660 1,950 2,310 2,210 2,510 2,870 2,560 2,490 3,010 2,740 3,150 3,330 3,710 3,680 3,800 175 290 400 555 730 760 810 1,050 1,220 1,440 1,690 1,660 1,950 2,310 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ ELXZ6R3E□□151MEB5D ELXZ6R3E□□331MFB5D ELXZ6R3E□□471MF15D ELXZ6R3E□□681MH12D ELXZ6R3E□□821MJC5S ELXZ6R3E□□102MH15D ELXZ6R3E□□122MH20D ELXZ6R3E□□122MJ16S ELXZ6R3E□□152MJ20S ELXZ6R3E□□222MJ25S ELXZ6R3E□□272MJ30S ELXZ6R3E□□332MK20S ELXZ6R3E□□392MK25S ELXZ6R3E□□472MK30S ELXZ6R3E□□562MK35S ELXZ6R3E□□562ML20S ELXZ6R3E□□682MK40S ELXZ6R3E□□682ML25S ELXZ6R3E□□682MM20S ELXZ6R3E□□822ML30S ELXZ6R3E□□103ML35S ELXZ6R3E□□103MM25S ELXZ6R3E□□123ML40S ELXZ6R3E□□123MM30S ELXZ6R3E□□153MM35S ELXZ6R3E□□183MM40S ELXZ100E□□101MEB5D ELXZ100E□□221MFB5D ELXZ100E□□331MF15D ELXZ100E□□471MH12D ELXZ100E□□681MH15D ELXZ100E□□681MJC5S ELXZ100E□□102MH20D ELXZ100E□□102MJ16S ELXZ100E□□122MJ20S ELXZ100E□□152MJ25S ELXZ100E□□182MJ30S ELXZ100E□□222MJ30S ELXZ100E□□222MK20S ELXZ100E□□332MK25S ELXZ100E□□392MK30S ELXZ100E□□392ML20S ELXZ100E□□472MK35S ELXZ100E□□562MK40S ELXZ100E□□562ML25S ELXZ100E□□562MM20S ELXZ100E□□682ML30S ELXZ100E□□682MM25S ELXZ100E□□822ML35S ELXZ100E□□822MM30S ELXZ100E□□103ML40S ELXZ100E□□103MM35S ELXZ100E□□123MM40S ELXZ160E□□470MEB5D ELXZ160E□□101MFB5D ELXZ160E□□221MF15D ELXZ160E□□331MH12D ELXZ160E□□471MH15D ELXZ160E□□471MJC5S ELXZ160E□□561MH20D ELXZ160E□□681MJ16S ELXZ160E□□102MJ20S ELXZ160E□□122MJ25S ELXZ160E□□152MJ30S ELXZ160E□□152MK20S ELXZ160E□□222MK25S ELXZ160E□□272MK30S 2,700 3,300 3,900 3,900 3,900 4,700 16 4,700 5,600 5,600 6,800 8,200 10,000 47 100 150 220 330 330 390 470 680 820 1,000 1,000 1,500 1,800 25 1,800 2,200 2,200 2,200 2,700 2,700 3,300 3,300 3,300 3,300 3,900 3,900 4,700 4,700 5,600 33 56 100 150 220 220 270 330 470 560 560 680 680 35 1,000 1,000 1,200 1,200 1,500 1,800 1,800 1,800 2,200 2,200 2,200 2,200 2,700 16×20 12.5×35 12.5×40 16×25 18×20 16×30 18×25 16×35 18×30 16×40 18×35 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 8×20 10×16 10×20 10×25 10×30 12.5×20 12.5×25 12.5×30 16×20 12.5×30 12.5×35 18×20 12.5×40 16×25 16×25 16×30 18×20 18×25 16×35 18×30 16×40 18×35 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 8×20 10×16 10×20 10×20 10×25 10×30 12.5×20 12.5×20 12.5×25 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×25 16×30 18×20 18×25 16×35 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.029 0.022 0.017 0.022 0.028 0.019 0.020 0.017 0.018 0.015 0.016 0.015 0.50 0.25 0.18 0.12 0.090 0.090 0.080 0.068 0.052 0.045 0.037 0.038 0.030 0.025 0.029 0.025 0.022 0.028 0.017 0.022 0.022 0.019 0.028 0.020 0.017 0.018 0.015 0.016 0.015 0.50 0.25 0.18 0.12 0.090 0.090 0.080 0.068 0.052 0.052 0.045 0.037 0.038 0.038 0.030 0.025 0.029 0.022 0.017 0.022 0.028 0.022 0.019 0.028 0.020 0.017 0.058 0.044 0.034 0.044 0.056 0.038 0.040 0.034 0.036 0.030 0.032 0.030 1.0 0.50 0.36 0.24 0.18 0.18 0.16 0.136 0.104 0.090 0.074 0.076 0.060 0.050 0.058 0.050 0.044 0.056 0.034 0.044 0.044 0.038 0.056 0.040 0.034 0.036 0.030 0.032 0.030 1.0 0.50 0.36 0.24 0.18 0.18 0.16 0.136 0.104 0.104 0.090 0.074 0.076 0.076 0.060 0.050 0.058 0.044 0.034 0.044 0.056 0.044 0.038 0.056 0.040 0.034 2,210 2,510 2,870 2,560 2,490 3,010 2,740 3,150 3,330 3,710 3,680 3,800 175 290 400 555 730 760 810 1,050 1,220 1,440 1,690 1,660 1,950 2,310 2,210 2,310 2,510 2,490 2,870 2,560 2,560 3,010 2,490 2,740 3,150 3,330 3,710 3,680 3,800 175 290 400 555 730 760 810 1,050 1,220 1,220 1,440 1,690 1,660 1,660 1,950 2,310 2,210 2,510 2,870 2,560 2,490 2,560 3,010 2,490 2,740 3,150 Part No. ELXZ160E□□272ML20S ELXZ160E□□332MK35S ELXZ160E□□392MK40S ELXZ160E□□392ML25S ELXZ160E□□392MM20S ELXZ160E□□472ML30S ELXZ160E□□472MM25S ELXZ160E□□562ML35S ELXZ160E□□562MM30S ELXZ160E□□682ML40S ELXZ160E□□822MM35S ELXZ160E□□103MM40S ELXZ250E□□470MEB5D ELXZ250E□□101MFB5D ELXZ250E□□151MF15D ELXZ250E□□221MH12D ELXZ250E□□331MH15D ELXZ250E□□331MJC5S ELXZ250E□□391MH20D ELXZ250E□□471MJ16S ELXZ250E□□681MJ20S ELXZ250E□□821MJ25S ELXZ250E□□102MJ30S ELXZ250E□□102MK20S ELXZ250E□□152MK25S ELXZ250E□□182MK30S ELXZ250E□□182ML20S ELXZ250E□□222MK30S ELXZ250E□□222MK35S ELXZ250E□□222MM20S ELXZ250E□□272MK40S ELXZ250E□□272ML25S ELXZ250E□□332ML25S ELXZ250E□□332ML30S ELXZ250E□□332MM20S ELXZ250E□□332MM25S ELXZ250E□□392ML35S ELXZ250E□□392MM30S ELXZ250E□□472ML40S ELXZ250E□□472MM35S ELXZ250E□□562MM40S ELXZ350E□□330MEB5D ELXZ350E□□560MFB5D ELXZ350E□□101MF15D ELXZ350E□□151MH12D ELXZ350E□□221MH15D ELXZ350E□□221MJC5S ELXZ350E□□271MH20D ELXZ350E□□331MJ16S ELXZ350E□□471MJ20S ELXZ350E□□561MJ20S ELXZ350E□□561MJ25S ELXZ350E□□681MJ30S ELXZ350E□□681MK20S ELXZ350E□□102MK20S ELXZ350E□□102MK25S ELXZ350E□□122MK30S ELXZ350E□□122ML20S ELXZ350E□□152MK35S ELXZ350E□□182MK40S ELXZ350E□□182ML25S ELXZ350E□□182MM20S ELXZ350E□□222ML25S ELXZ350E□□222ML30S ELXZ350E□□222MM20S ELXZ350E□□222MM25S ELXZ350E□□272ML35S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, Downsized, 105℃ LXZSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 35 50 2,700 3,300 3,300 3,900 4,700 22 47 68 100 120 120 180 180 220 330 390 390 470 560 680 680 820 820 1,000 1,000 1,200 1,200 1,500 1,800 1,800 18×30 16×40 18×35 18×40 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 8×20 10×16 10×20 10×25 10×30 12.5×20 12.5×20 12.5×25 12.5×30 16×20 12.5×35 18×20 12.5×40 16×25 16×30 18×25 16×35 16×40 18×30 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.018 0.015 0.016 0.015 0.015 0.90 0.45 0.31 0.22 0.16 0.16 0.12 0.13 0.088 0.073 0.054 0.059 0.059 0.044 0.039 0.048 0.033 0.042 0.029 0.034 0.028 0.029 0.025 0.021 0.025 0.036 0.030 0.032 0.030 0.030 1.8 0.90 0.62 0.44 0.32 0.32 0.24 0.26 0.18 0.15 0.11 0.12 0.12 0.088 0.078 0.096 0.066 0.084 0.058 0.068 0.056 0.058 0.050 0.042 0.050 3,330 3,710 3,680 3,800 3,800 155 260 360 485 635 620 730 850 1,050 1,250 1,500 1,480 1,480 1,840 2,220 1,840 2,290 1,980 2,500 2,240 2,700 2,610 2,800 3,200 3,000 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ ELXZ350E□□272MM30S ELXZ350E□□332ML40S ELXZ350E□□332MM35S ELXZ350E□□392MM40S ELXZ350E□□472MM40S ELXZ500E□□220MEB5D ELXZ500E□□470MFB5D ELXZ500E□□680MF15D ELXZ500E□□101MH12D ELXZ500E□□121MH15D ELXZ500E□□121MJC5S ELXZ500E□□181MH20D ELXZ500E□□181MJ16S ELXZ500E□□221MJ20S ELXZ500E□□331MJ25S ELXZ500E□□391MJ30S ELXZ500E□□391MK20S ELXZ500E□□471MK20S ELXZ500E□□561MK25S ELXZ500E□□681MK30S ELXZ500E□□681ML20S ELXZ500E□□821MK35S ELXZ500E□□821MM20S ELXZ500E□□102MK40S ELXZ500E□□102ML25S ELXZ500E□□122ML30S ELXZ500E□□122MM25S ELXZ500E□□152ML35S ELXZ500E□□182ML40S ELXZ500E□□182MM30S 50 63 2,200 2,700 12 22 39 68 100 100 120 150 180 220 330 330 390 470 470 680 680 680 820 820 820 1,000 1,000 1,200 1,200 1,500 1,800 2,200 18×35 18×40 5×11.5 6.3×11.5 6.3×15 8×12 8×15 10×12.5 10×16 8×20 10×20 10×25 10×30 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 12.5×40 16×30 18×25 16×30 16×35 16×40 18×30 18×35 18×40 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.023 0.020 1.9 1.0 0.61 0.34 0.27 0.255 0.19 0.21 0.145 0.13 0.090 0.085 0.070 0.055 0.059 0.047 0.050 0.055 0.042 0.043 0.043 0.043 0.036 0.030 0.032 0.030 0.025 0.025 0.046 0.040 4.0 2.0 1.4 0.75 0.65 0.51 0.38 0.52 0.29 0.26 0.18 0.17 0.14 0.11 0.12 0.094 0.10 0.11 0.084 0.086 0.086 0.086 0.072 0.060 0.064 0.060 0.050 0.050 3,100 3,400 145 240 330 405 535 540 600 690 890 1,050 1,300 1,290 1,720 2,090 1,770 2,270 2,160 2,290 2,560 2,670 2,590 2,670 2,770 2,850 2,950 3,100 3,210 3,210 Part No. ELXZ500E□□222MM35S ELXZ500E□□272MM40S ELXZ630E□□120MEB5D ELXZ630E□□220MFB5D ELXZ630E□□390MF15D ELXZ630E□□680MH12D ELXZ630E□□101MH15D ELXZ630E□□101MJC5S ELXZ630E□□121MJ16S ELXZ630E□□151MH20D ELXZ630E□□181MJ20S ELXZ630E□□221MJ25S ELXZ630E□□331MJ30S ELXZ630E□□331MK20S ELXZ630E□□391MK25S ELXZ630E□□471MK30S ELXZ630E□□471ML20S ELXZ630E□□681MK35S ELXZ630E□□681ML25S ELXZ630E□□681MM20S ELXZ630E□□821MK40S ELXZ630E□□821ML30S ELXZ630E□□821MM25S ELXZ630E□□102ML30S ELXZ630E□□102ML35S ELXZ630E□□122ML40S ELXZ630E□□122MM30S ELXZ630E□□152MM35S ELXZ630E□□182MM40S ELXZ630E□□222MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 12 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 18,000 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
ELXZ350ETD221MH15D 价格&库存
很抱歉,暂时无法提供与“ELXZ350ETD221MH15D”相匹配的价格&库存,您可以联系我们找货
