EMVY800ARA221MKG5S
EMVY800ARA221MKG5S
    NCC(贵弥功)
    SMD,D12.5xL16mm
    贴片铝电解电容 AEC_D12.5X16MM_SM
EMVY800ARA221MKG5S 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MVY - Series Low impedance, 105℃ MZA Lower Z ・Endurance : 1,000 to 5,000 hours at 105℃ ・Low impedance ・For digital equipment, especially DC-DC converters ・Solvent resistant type except 80 & 100Vdc (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MVY Longer life MLA Lower Z MVE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ (6.3 to 63Vdc) -40 to +105℃ (80 & 100Vdc) 6.3 to 100Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3μA, whichever is greater. Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V When nominal capacitance exceeds - 1,000μF, add 0.02 to the value above D55 to F80 0.24 0.20 0.16 0.14 0.12 0.12 tanδ (Max.) HA0 & JA0 0.28 0.24 0.20 0.16 0.14 0.12 - for each 1,000μF increase. (at 20℃, 120Hz) KE0 to MN0 0.26 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.10 Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V D55 to JA0 3 2 2 2 2 2 Z(-40℃)/Z(+20℃) KE0 to MN0 10 8 6 4 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified ime at 105℃. D55 to F80 : 1,000 hours Time HA0 & JA0 : 2,000 hours KE0 to MN0 : 5,000 hours Rated voltage 6.3Vdc (D55 to JA0) 6.3 to 100Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3Vdc (D55 to JA0) 6.3 to 100Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except HA0) 0.3max. L±0.3 (Note) φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.5 A±0.2 Note : L±0.5 for HA0 to MN0 2 3 4 5 6 7 8 9 10 11 12 A±0.2 : Dummy terminals ◆PART NUMBERING SYSTEM 1 W B±0.2 Vent (Except D55 to HA0) Code : G(Vibration resistant structure) code : HA0 to MN0 Size code P C±0.2 Code : A code : D55 to MN0 13 14 15 16 17 18 E MV Y AAA A DA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7µF:4R7,10µF:100) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,10V:100,50V:500) Series code Category D55 E55 F55 F61 F80 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 D 4 5 6.3 6.3 6.3 8 10 12.5 12.5 16 16 18 18 L 5.2 5.2 5.2 5.8 7.7 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 A 4.3 5.3 6.6 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 4.3 5.3 6.6 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 7.2 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆MARKING D55 to JA0 EX) 6.3V100µF 7hY 100 6.3V KE0 to MN0 EX) 16V1,000µF 0V MVY 1000 16V Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MVYSeries - ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 Low impedance, 105℃ Cap (µF) Size code 22 33 47 100 220 330 470 680 1,000 1,500 2,200 2,200 3,300 3,300 4,700 4,700 6,800 6,800 8,200 22 33 47 100 220 330 470 680 1,000 2,200 2,200 3,300 3,300 4,700 4,700 6,800 10 22 33 47 100 220 330 470 680 1,000 1,000 2,200 2,200 3,300 3,300 4,700 10 22 33 47 100 220 D55 E55 E55 F55 F55 F80 HA0 HA0 HA0 JA0 KE0 LH0 KG5 MH0 LN0 MH0 LN0 MN0 MN0 E55 E55 F55 F55 F80 HA0 HA0 JA0 JA0 KG5 LH0 LH0 MH0 LN0 MN0 MN0 D55 E55 F55 F55 F55 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 LN0 MH0 MN0 E55 F55 F55 F55 F80 HA0 is not solvent resistant (80/100Vdc). Rated ripple Impedance current (Ω max./20℃, (mArms/105℃, 100kHz) 100kHz) 3.0 1.8 1.8 1.0 1.0 0.34 0.30 0.30 0.30 0.15 0.070 0.054 0.060 0.054 0.038 0.054 0.038 0.038 0.038 1.8 1.8 1.0 1.0 0.34 0.30 0.30 0.15 0.15 0.060 0.054 0.054 0.054 0.038 0.038 0.038 3.0 1.8 1.0 1.0 1.0 0.34 0.30 0.30 0.15 0.070 0.054 0.054 0.054 0.038 0.054 0.038 1.8 1.0 1.0 1.0 0.34 0.30 60 95 95 140 140 280 450 450 450 670 820 1,260 950 1,350 1,630 1,350 1,630 1,750 1,750 95 95 140 140 280 450 450 670 670 950 1,260 1,260 1,350 1,630 1,750 1,750 60 95 140 140 140 280 450 450 670 820 1,260 1,260 1,350 1,630 1,350 1,750 95 140 140 140 280 450 Part No. EMVY6R3ARA220MD55G EMVY6R3ARA330ME55G EMVY6R3ARA470ME55G EMVY6R3ARA101MF55G EMVY6R3ARA221MF55G EMVY6R3ARA331MF80G EMVY6R3□RA471MHA0G EMVY6R3□RA681MHA0G EMVY6R3□RA102MHA0G EMVY6R3□RA152MJA0G EMVY6R3□RA222MKE0S EMVY6R3□RA222MLH0S EMVY6R3□RA332MKG5S EMVY6R3□RA332MMH0S EMVY6R3□RA472MLN0S EMVY6R3□RA472MMH0S EMVY6R3□RA682MLN0S EMVY6R3□RA682MMN0S EMVY6R3□RA822MMN0S EMVY100ARA220ME55G EMVY100ARA330ME55G EMVY100ARA470MF55G EMVY100ARA101MF55G EMVY100ARA221MF80G EMVY100□RA331MHA0G EMVY100□RA471MHA0G EMVY100□RA681MJA0G EMVY100□RA102MJA0G EMVY100□RA222MKG5S EMVY100□RA222MLH0S EMVY100□RA332MLH0S EMVY100□RA332MMH0S EMVY100□RA472MLN0S EMVY100□RA472MMN0S EMVY100□RA682MMN0S EMVY160ARA100MD55G EMVY160ARA220ME55G EMVY160ARA330MF55G EMVY160ARA470MF55G EMVY160ARA101MF55G EMVY160ARA221MF80G EMVY160□RA331MHA0G EMVY160□RA471MHA0G EMVY160□RA681MJA0G EMVY160□RA102MKE0S EMVY160□RA102MLH0S EMVY160□RA222MLH0S EMVY160□RA222MMH0S EMVY160□RA332MLN0S EMVY160□RA332MMH0S EMVY160□RA472MMN0S EMVY250ARA100ME55G EMVY250ARA220MF55G EMVY250ARA330MF55G EMVY250ARA470MF55G EMVY250ARA101MF80G EMVY250□RA221MHA0G □ : Enter the appropriate terminal code. WV (Vdc) 25 35 50 63 80 100 Cap (µF) Size code 330 470 1,000 1,000 2,200 2,200 3,300 4.7 10 22 33 47 47 68 100 220 330 470 470 1,000 1,000 2,200 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 330 470 470 1,000 68 100 220 220 330 330 470 470 100 220 330 330 470 47 68 100 100 220 220 330 HA0 JA0 LH0 MH0 LN0 MN0 MN0 D55 E55 F55 F55 F55 F61 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 MN0 D55 D55 D55 E55 F55 F55 F80 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 MN0 KE0 KE0 KE0 LH0 LH0 MH0 LN0 MH0 KE0 KG5 LN0 MH0 MN0 KE0 KE0 KE0 LH0 LN0 MH0 MN0 Rated ripple Impedance current (Ω max./20℃, (mArms/105℃, 100kHz) 100kHz) 0.30 0.15 0.054 0.054 0.038 0.038 0.038 3.0 1.8 1.0 1.0 1.0 1.0 0.34 0.30 0.30 0.15 0.070 0.054 0.054 0.054 0.038 5.0 5.0 5.0 3.0 2.0 2.0 0.60 0.60 0.60 0.60 0.30 0.11 0.087 0.087 0.087 0.050 0.19 0.19 0.19 0.12 0.12 0.12 0.085 0.12 0.33 0.26 0.16 0.24 0.16 0.33 0.33 0.33 0.24 0.16 0.24 0.16 450 670 1,260 1,350 1,630 1,750 1,750 60 95 140 140 140 140 280 450 450 670 820 1,260 1,260 1,350 1,750 30 30 30 50 70 70 170 170 300 300 500 650 900 900 1,060 1,520 500 500 500 845 845 905 1,100 905 450 550 900 700 950 450 450 450 650 900 700 950 Part No. EMVY250□RA331MHA0G EMVY250□RA471MJA0G EMVY250□RA102MLH0S EMVY250□RA102MMH0S EMVY250□RA222MLN0S EMVY250□RA222MMN0S EMVY250□RA332MMN0S EMVY350ARA4R7MD55G EMVY350ARA100ME55G EMVY350ARA220MF55G EMVY350ARA330MF55G EMVY350ARA470MF55G EMVY350ARA470MF61G EMVY350ARA680MF80G EMVY350□RA101MHA0G EMVY350□RA221MHA0G EMVY350□RA331MJA0G EMVY350□RA471MKE0S EMVY350□RA471MLH0S EMVY350□RA102MLH0S EMVY350□RA102MMH0S EMVY350□RA222MMN0S EMVY500ARA1R0MD55G EMVY500ARA2R2MD55G EMVY500ARA3R3MD55G EMVY500ARA4R7ME55G EMVY500ARA100MF55G EMVY500ARA220MF55G EMVY500ARA330MF80G EMVY500ARA470MF80G EMVY500□RA680MHA0G EMVY500□RA101MHA0G EMVY500□RA221MJA0G EMVY500□RA331MKE0S EMVY500□RA331MLH0S EMVY500□RA471MLH0S EMVY500□RA471MMH0S EMVY500□RA102MMN0S EMVY630□RA680MKE0S EMVY630□RA101MKE0S EMVY630□RA221MKE0S EMVY630□RA221MLH0S EMVY630□RA331MLH0S EMVY630□RA331MMH0S EMVY630□RA471MLN0S EMVY630□RA471MMH0S EMVY800□RA101MKE0S EMVY800□RA221MKG5S EMVY800□RA331MLN0S EMVY800□RA331MMH0S EMVY800□RA471MMN0S EMVY101□RA470MKE0S EMVY101□RA680MKE0S EMVY101□RA101MKE0S EMVY101□RA101MLH0S EMVY101□RA221MLN0S EMVY101□RA221MMH0S EMVY101□RA331MMN0S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Size code D55 to JA0 KE0 to MN0 Capacitance(µF) Frequency(Hz) 1.0 to 4.7 10 to 100 220 to 470 680 to 1,500 47 to 100 220 to 470 1,000 2,200 to 3,300 4,700 to 8,200 120 0.35 0.40 0.50 0.60 0.40 0.50 0.60 0.75 0.85 1k 0.70 0.75 0.85 0.87 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.90 0.94 0.95 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
EMVY800ARA221MKG5S 价格&库存
很抱歉,暂时无法提供与“EMVY800ARA221MKG5S”相匹配的价格&库存,您可以联系我们找货
EMVY800ARA221MKG5S
  • 1+14.299461+1.83503
  • 10+9.2391610+1.18565
  • 50+7.1373650+0.91593
  • 100+6.47382100+0.83078
EMVY800ARA221MKG5S
  • 200+5.92094200+0.75983
  • 400+5.46142400+0.70086
  • 600+5.22937600+0.67108
  • 1000+4.970701000+0.63788
  • 1400+4.818611400+0.61837
  • 2000+4.671682000+0.59951
EMVY800ARA221MKG5S
  • 1+13.765901+1.76656
  • 10+8.8955510+1.14155
  • 50+6.8761250+0.88240
  • 100+6.23638100+0.80031
