Lead-Free & RoHs Compliance!!
SPECIFICATION FOR APPROVAL
CUSTOMER
國益商絡
CUSTOMER P/N :
OUR DWG No :
QUANTITY
TE1-610234
x
Pcs.
DATE
: 2016/1/19
SL1010T-470K-N
ITEM :
SPECIFICATION
ACCEPTED BY:
COMPONENT
ENGINEER
ELECTRICAL
ENGINEER
MECHANICAL
ENGINEER
APPROVED
REJECTED
奇力新電子股份有限公司 東莞奇力新電子有限公司
CHILISIN ELECTRONICS CORP.
NO.29,LANE 301,TEHHSIN
ROAD,HUKOU,
HSINCHU,TAIWAN,303,
REPUBLIC OF CHINA
TEL:(03) 599-2646
FAX:(03) 599-9176
E-mail:Sales@chilisin.com.tw
http://www.chilisin.com.tw
DRAWN
BY
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei
Administration Area, Qingxi Town,
Dongguan City, Guangdong,China
TEL:+86-769-8773-0251~3
FAX: +86-769-8773-0232
E-mail:cect@chilisin.com.tw
Jiusheng CHECKED
BY
Liukan
奇力新電子(
奇力新電子(河南)
河南)有限公司
Chilisin Electronics (Henan) Co., Ltd.
XiuWu Xian, industry gathering area
JiaoZuo, Henan China
Postal Code:454350
TEL:+86-391-717-0682
FAX:+86-391-717-0666
APPROVED
BY
Tangshan
奇力新電子(
奇力新電子(蘇州)
蘇州)有限公司
Chilisin Electronics (Suzhou) Co., Ltd.
No.143,Song Shan Rd., Suzhou New
District, Suzhou,China
Postal Code:215129
TEL:+86-512-6841-2350
FAX:+86-512-6841-2356
E-mail:suzhou@chilisin.com.tw
QRA
BY
SPECIFICATIONFOR APPROVAL
CUSTOMER
國益商絡
CUSTOMER,S PART NO/DWG NO.
DESCRIPTION
CLS DWG. NO.
Rev
TE1-610234
A
DATE
SL1010T-470K-N
2016/1/19
(1)MECHANICAL ASSEMBLY
B
E
C
D
470K
470K
470K
A
UL TUBE
(2)ELECTRICAL REQUIREMENTS
L
47.0±10%
uH
RDC
75.0max
mΩ
IDC
2.3max
A
Irms
2.1max
A
SRF
5.0min
MHZ
A
13.5max
m/m
B
3.5±0.5
m/m
C
5.0±0.5
m/m
D
12.0max
m/m
E
0.8±0.1
m/m
F
m/m
G
m/m
H
m/m
I
m/m
J
m/m
(3)SCHEMATIC
TEST
FREQUENCY
1KHZ
0.25V
1KHZ
0.25V
TEST
FREQUENCY
TEST
FREQUENCY
TEST
FREQUENCY
△T≦40℃
TEST
FREQUENCY
RATED CURRENT
(4)TEST INSTRUMENTS
*16502 (RDC)
*HP4284A+42841A (L,IDC,Irms)
*HP4285A(SRF)
25℃ ,Humidity < 75% RH(6 Month)
* Operating temperature -25℃ to +85℃
*Storage Temperature: Under
NOTE:
APPROVED BY
CHECKED
套管需捺印
BY
白色字样 量產時改善
“470K”
* The casing need to be stamped with the
words "470K" in white,to improve in the
process of mass production
DRAWN
BY
*IDC:L drop 10%max
產品使用時電流不得超過規格爲準
The current shall not exceed the specified
one when using this part.
Jiusheng
TEST DATA FOR PREPRODUCTION SAMPLES
CUSTOMER
CLS DWG. NO.
Rev
TE1-610234
A
國益商絡
DATE
CUSTOMER'S PART NO./DWG.NO.DESCRIPTION
2016/1/19
SL1010T-470K-N
QUANTITY
MEAS.
SPEC
ITEM
L
RDC
IDC
Irms
SRF
uH
mΩ
A
A
MHZ
2.3max
2.1max
5.0min
OK
8.10
x
CUSTOMER
SUGGEST
47.0±10% 75.0max
△T≦40℃
TEST
1KHZ
1KHZ
FREQ.
0.25V
47.40
63.35
0.25V
OK
47.51
63.80
OK
OK
8.40
47.98
64.30
OK
OK
8.30
47.75
63.80
OK
OK
8.30
47.54
64.38
OK
OK
8.50
47.57
63.60
OK
OK
8.60
48.24
63.95
OK
OK
8.30
47.95
64.03
OK
OK
8.30
47.70
64.69
OK
OK
8.30
47.74
63.82
OK
OK
8.50
47.74
63.97
8.36
0.84
1.34
0.50
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
X
R
CUSTOMER
SAMPLE
TEST CONDITION:
TEMP.
25
R.H.
65%
APPROVED BY
CHECKED BY
DRAWN BY
Jiusheng
PCS.
CUSTOMER
國益商絡
CLS DWG. NO.
Rev
TE1-610234
A
DATE
2016/1/19
SL1010T-470K-N
QUANTITY
MEAS.
SPEC
ITEM
A
B
C
D
E
m/m
m/m
m/m
m/m
m/m
13.5max
3.5±0.5
5.0±0.5
12.0max
0.8±0.1
12.01
3.35
4.90
10.62
0.76
11.92
3.46
4.92
10.65
0.75
11.95
3.56
5.00
10.65
0.77
12.03
3.80
4.77
10.68
0.76
11.89
3.37
4.95
10.63
0.78
11.93
3.40
4.90
10.64
0.78
12.04
3.83
4.95
10.68
0.75
12.15
3.63
4.99
10.60
0.76
11.92
3.28
4.97
10.62
0.77
11.89
3.45
4.95
10.66
0.78
11.97
3.51
4.93
10.64
0.77
0.26
0.55
0.23
0.08
0.03
x
CUSTOMER
SUGGEST
TEST
FREQ.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
X
R
CUSTOMER
SAMPLE
TEST CONDITION:
TEMP.
25
R.H.
65%
APPROVED BY
CHECKED BY
DRAWN BY
Jiusheng
PCS.
5. MATERIAL LIST :
ITEM
PART
DESCRIPTION
TEMP
1
WIRE
2SFBW
2
CORE
Ferrite
CHENZHOU
OR EQUIV
3
PIN
CP wire
MINGTONG
OR EQUIV
4
Solder
Sn99.9
QIANDAO
OR EQUIV
5
EPOXY
FK661-S
FUHUI
180
SUPPLIERS
UL NO.
JUNG SHING
OR EQUIV
E174837
OR EQUIV
6
TUBE
Black UL
DRAWN BY CHECKED BY APPROVED BY
Jiusheng
XINGQI
OR EQUIV
CUSTOMER :
國益商絡
PART NO :
ISSUE NO
: SL1010T-470K-N
DATE
REV
RACE
2016/1/19
A
1-1 Mechanical Performance
No
1-1-1
Item
Vibration
Specification
Test Method
Appearance: No damage
Test device shall be soldered on the substrate
L change: within±10%
Oscillation Frequency: 10 to 55 to 10Hz for 1min
Amplitude: 1.5mm
Time: 2hrs for each axis (X, Y & Z), total 6hrs
1-2 Environmental Performance
No
1-2-1
Item
Temperature Cycle
Specification
Test Method
One cycle:
Step
Time (min)
1
Temperature
-25±3
2
25±2
3
3
85±3
30
4
25±2
3
30
Total: 100cycles
Measured after exposure in the room condition for 24hrs
1-2-2
Humidity Resistance
Temperature: 40 ±2℃
Relative Humidity: 90 ~ 95%
Time: 1000hrs
1-2-3
Heat Life
Temperature: 85 ±3℃
Relative Humidity: 0%
Applied Current: Rated Current
Time: 1000hrs
1-2-4
Cold Resistance
Temperature: -25 ±3℃
Time: 1000hrs
很抱歉,暂时无法提供与“SL1010T-470K-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.21328
- 50+0.95915
- 120+0.85018
