KNP2WS-0.15Ω±5%
KNP2WS-0.15Ω±5%
    CCO(千志电子)
    插件,D4.5xL11.5mm
KNP2WS-0.15Ω±5% 数据手册
品 名 Product Name 版 線繞電阻器 本 B/3 版 制定日期 Wirewound Resistor 2017 年 06 月 10 日 頁數 13-1 Version Enactment Date JUN 30, 2017 Page 1. 一般事項 General 1.1 適用 Scope 本承認書適用於 [線繞電阻器],符合環境關聯物質要求之 RoHS 測試。 This specification is available for Wirewound Resistor,it accords with RoHS test of Environment related substance requirement。 1.2 形名(例) Type designation (example) 依使用種類、額定電力、公稱電阻值、容許誤差及型狀而區別,其構造如下。 The type designation shall be in the following form and as specified. KNP(NKNP) 1WS 10Ω J T52 種 類 額定電力 Type Rated power 標準 小型 公稱電阻值 Nominal resistance value Normal Small E-24 Series 電阻值容許誤差 Resistance 形狀 Form tolerance P 型 P Type J ±5% M 型 M Type G ±2% MB 型 MB Type 1/2W 1WS 1W 2WS FK1 型 FK1Type 2W 3WS FK2 型 FK2 Type 3W 5WS FKK 型 FKK Type 5W 1.3 額定電力 Rated power 額定電力係應在周圍溫度 70℃可以連續負載的最大電力, 如表-1;但周圍溫度如超過 70℃ 時之額定電力則依圖一的電力遞減曲線實施。 Rated power is maximum power which can be continuously loaded at specified ambient temperature 70℃,as Table-1;however when the ambient temperature exceeds 70℃,rated power should be determined from the derating curve of Fig.1. 品 名 Product Name 版 線繞電阻器 本 制定日期 B/3 版 Version Wirewound Resistor 2017 年 06 月 10 日 頁數 Enactment Date JUN 30, 2017 表-1 Table-1 種 類 定格電力 Type Rated power KNP 阻值範圍(Ω) KNP Resistance Page NKNP 阻值範圍(Ω) NKNP Range(Ω) KNP1/2W, KNP1W, Normal size KNP2W, 2W NKNP2W KNP3W, 0.1Ω~680Ω 0.05Ω~1KΩ 0.1Ω~680Ω 5W NKNP5W KNP1WS, 1W NKNP1WS KNP2WS, Small size 0.05Ω~1KΩ 3W NKNP3W KNP5W, 2W NKNP2WS KNP3WS, 3W NKNP3WS KNP5WS, 5W NKNP5WS 圖一 額定電力比 (%) Rated load(%) Range(Ω) 1W NKNP1W -55℃ Resistance 0.5W NKNP1/2W 100 13-2 電力遞減曲線 Figure 1 Power derating curve 70℃ 120 80 60 40 20 0 -60 255℃ -40 -20 0 20 40 60 80 100 120 140 160 180 200 220 240 260 Ambient Temperature(℃) 周圍溫度℃ 1.4 額定電壓 Rated voltage 額定電壓係指對應於額定電力的直流或交流(商用頻率之有效值)的電壓,由下式求得。 The rated voltage shall be the D.C. or A.C.(R.M.S. at power frequency) voltage which corresponds the rated power and the value of which is calculated from the formula below. 品 名 Product Name 版 本 Version 線繞電阻器 制定日期 B/3 版 E=√(P×R) Wirewound Resistor 2017 年 06 月 10 日 Enactment Date JUN 30, 2017 頁數 Page 13-3 Where E: 定格電壓 Rated voltage(V) P: 定格電力 Rated power(W) R: 公稱電阻值 Nominal resistance(Ω) 使用溫度 Operating Temperature Range:-55℃~+255℃ 2. 構造 Construction 2.1 外形尺寸 External dimensions 參照本承認書的 [5. 外形尺寸]。 The dimensions shall be satisfied with [5. External dimensions]. 2.2 構造圖 Structure diagram KNP/NKNP 系列之繞線電阻器係按下表的材料而構成: The construction of resistor (KNP/NKNP series) shall be as follows: 號碼 NO 構造名稱 內 容 1 Item 基體磁器 使用高含鋁量的磁器棒。 2 Ceramic core 電阻體 High alumina ceramic is used. 電阻體的成份係使用電阻線(例如 : CN49W Φ1.0mm)。 Resistor element The resistor element shall consist of Resistance wire(Exemple:CN49W Φ1.0mm) . 3 端子 鐵帽 4 Terminal 連接 Tinned iron cap. 導線對鐵帽須以電氣熔接。 Connection The lead wire,which is plated with solder,shall be mounted to the caps by welding process. 焊錫或鍍錫的導線。 5 導線 6 Lead wire 上塗塗裝 7 Finishing painting 表示 Indication Material Soldered or tinned annealed wire. 使用矽樹酯塗料。符合 UL-94V-0 不燃性規定。 Silicon resin is used. Accord with UL-94V-0 Nonflammable specification. 色碼。 Color code. 品 名 Product Name 版 線繞電阻器 本 制定日期 B/3 版 Wirewound Resistor 2017 年 06 月 10 日 Version Enactment Date JUN 30, 2017 2.3 鐵帽端子 Terminal caps 鐵帽端子須確實地連接(電氣的及機械的)於電阻體上。 頁數 Page 13-4 The caps shall be securely connected with the resistor element electrically and mechanically. 2.4 外裝色澤 Resistor body color 表-2 普通型 Normal size 種類 Type 顏色 Color KNP1/2W,NKNP1/2W, KNP1W,NKNP1W KNP2W,NKNP2W, KNP3W,NKNP3W 2.5 Table-2 灰色 Gray 表示 Indication 參照本承認書的 [4. 表示]。 The indication shall be satisfied with [4. Indication]. 3. 特性 Characteristics 表-3 項 目 Item 溫度係數 Temperature Coefficient 規格值 Performance ±350PPM/℃ (±500PPM/℃<1Ω) Table-3 試驗方法(依據 JIS C 5202) Test methods(Conform to JIS C 5202) 5.2 項參照 Comply with 5.2 R1-R0 ×106(PPM/℃) R0(T1-T0) R0:室溫(T0)所測量之電阻值。 R1:室溫+100℃(T1)後所測量之電阻值。 R0:Resistance value at room temp.( T0). R1:Resistance value at room temp.plus 100℃(T1) 短時間過負荷 Short time overload ±(2%+0.05Ω)以內。 不得有機械的損傷。 Within ±(2%+0.05Ω). No evidence of mechanical damage. 5.5 項參照 Comply with 5.5 額定電壓×2.5 倍,5 秒。 不可超過最高過負荷電壓(見表-1) Rated voltage×2.5 times,5s But not to exceed maximum overload voltage. (See table-1) 品 名 Product Name 版 線繞電阻器 本 B/3 版 Version 項 目 Item 絕緣電阻 Insulation Resistance 制定日期 Wirewound Resistor 2017 年 06 月 10 日 Enactment Date Performance 10 MΩ以上。 104MΩ or more. 耐電壓 無電弧放電、燒損及絕緣 Dielectric Withstanding Voltage 破壞等異狀。 斷續過負荷 Pulse overload ±(2%+0.05Ω)以內。 Within ±(2%+0.05Ω) 端子強度 Terminal strength 端子不得斷裂及鬆弛。 No evidence of mechanical damage. 13-5 Test methods(Conform to JIS C 5202) 5.6 項參照 Comply with 5.6 置於 V 型槽方法。V-block method 施加直流電壓 500V 60 秒。 Resistor shall be tested at DC 500V for 60 seconds. 5.7 項參照 Comply with 5.7 常壓,置於 V 型槽方法。 施加個別規定之交流電壓 60 秒。(見表-1) Constant pressure, V-block method Resistor shall be tested at AC potential respectively for 60 seconds.(See table-1) 5.8 項參照 Comply with 5.8 額定電壓×4 倍,10000 回(1 秒 ON,25 秒 OFF)。 不可超過最高斷續電壓(見表-1) Rated voltage X 4 times, 10000 cyc.(1s ON, 25s OFF) But not to exceed maximum pulse voltage.(See table-1) 6.1 項參照 Comply with 6.1 線徑 mm 引張力 時 間 Diameter Tensile force Time N(kgf) Φ0.38mm~0.50mm 5(0.51) 10±1 second Φ0.50mm~0.68 mm 10(1.02) 扭轉強度: 自電阻體起約 6mm~6.5mm 處之端子線, 以約 0.75mm 曲率半徑彎曲 90 度,其次由彎曲處向端子 線先端 1.2±0.4mm 處挾定端子引出軸,作回轉軸,以約 5 秒時間沿直面回轉 360°再逆轉 360°,如此施行回逆轉 2 次,不可發生折斷及鬆動現象。 Torsion strength:To bend the lead wire at the point of about 6mm~6.5mm from resistor body. about 0.75mm curvature radii to 90°then catch the wire at 1.2±0.4mm apart from the bend point end and turn it ( clockwise ) by 360 degrees perpendicular to the resistor axis at speed of same 5 seconds per turn, and do the same counterclockwise again which constitute a whole turn. Repeat the turn for 2 times without causing any break and looseness. 引張強度 Tensile strength No evidence of flashover mechanical damage,arcing or insulation breakdown. Page 試驗方法(依據 JIS C 5202) 規格值 4 JUN 30, 2017 頁數 品 名 Product Name 版 本 Version 項 目 線繞電阻器 B/3 版 制定日期 Wirewound Resistor 2017 年 06 月 10 日 Enactment Date 規格值 Item Performance 焊錫耐熱性 Resistance to soldering heat ±(1%+0.05Ω)以內。 不得有機械的損傷。 Within ±(1%+0.05Ω) No evidence of mechanical damage. 焊錫附著性 Solderability 導線至少 95%以上新錫覆蓋。 Covered with new solder by 95% at least. 耐溶劑性 Resistance to solvent 塗裝及色碼不得脫落。 No deterioration of protective coating and markings. 溫度循環 Temperature cycle ±(2%+0.05Ω)以內。 不得有機械的損傷。 Within ±(1%+0.05Ω) No evidence of mechanical damage. 耐濕負荷壽命 Load life in humidity ±(5%+0.05Ω)以內。 Within ±(5%+0.05Ω) 負荷壽命 Load life ±(5%+0.05Ω)以內。 Within ±(5%+0.05Ω) JUN 30, 2017 頁數 Page 13-6 試驗方法(依據 JIS C 5202) Test methods(Conform to JIS C 5202) 6.4 項參照 Comply with 6.4 350±10℃, 3±1 秒, 試驗後放置半小時。 350±10℃, 3±1s After test leave for 0.5h. 6.5 項參照 Comply with 6.5 焊錫溫度:255±5℃。 浸錫時間:3±1.0 秒。 Test temperature of solder:255±5℃ Dipping time in solder:3±1.0 s 6.9 項參照 Comply with 6.9 放入酒精溶劑之超音波機內,保持 3 分鐘。 Specimens shall be immersed in a bath of isoproalcohol completely for 3 minutes with ultrasonic. 7.4 項參照 Comply with 7.4 低溫側:-55℃/30 分, 室溫:10~15 分鐘 高溫側:+80℃/30 分, 室溫:10~15 分鐘 5回 Low side:-55℃/30min, Room temp.:10 to 15min High side:80℃/30min, Room temp.:10 to 15min 5 cycles 7.9 項參照 Comply with 7.9 40±2℃, 濕度 90~95%, 1000 小時 定格電壓(90 分鐘 ON, 30 分鐘 OFF) 40±2℃, 90 to 95%RH, 1000h Rated voltage (90 min ON, 30 min OFF) 7.10 項參照 Comply with 7.10 70±3℃, 1000 小時 定格電壓(90 分鐘 ON, 30 分鐘 OFF) 70±3℃, 1000h Rated voltage (90 min ON, 30 min OFF) 品 名 Product Name 版 本 線繞電阻器 B/3 版 Version 4. 表示 Indication 色碼 Color Code 顏色 Color Enactment Date 第 1 數字 第 2 數字 倍 率 1st figure 2nd figure Multiplier 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 5-Band code JUN 30, 2017 誤差率 Tolerance Page 區 分 Distinguish 0 10 101 102 103 104 105 106 107 10-1 10-2 2%,5% 頁數 ±1% ±2% (F) (G) ±5% ±10% (J) (K) 黑‘色 表’示有感繞線電阻 , ‘綠色’表示無感繞線電阻 . Black Brown Red Orange Yellow Green Blue Violet Gray White Gold Silver Plain 制定日期 KNP type in ‘Black’, NKNP type in ‘Green’. 黑 棕 紅 橙 黃 綠 藍 紫 灰 白 金 銀 無 Wirewound Resistor 2017 年 06 月 10 日 13-7 品 名 Product Name 版 本 Version 線繞電阻器 B/3 版 Wirewound Resistor 2017 年 06 月 10 日 制定日期 Enactment Date JUN 30, 2017 頁數 Page 5. 外形寸法 External dimensions 散裝 P 型 P type P Type 第 5 道色碼,‘黑色’表示有感繞線電阻,‘綠色’表示無感繞線電阻 The 5th color band; KNP type in ‘Black’, NKNP type in ‘Green’ I 種 類 普通型 Normal Size KNP1/2W, NKNP1/2W KNP1W, NKNP1W Type 小型化 Small Size KNP1WS, NKNP1WS KNP2WS, NKNP2WS KNP2W, NKNP2W KNP3WS, NKNP3WS KNP3W, KNP5WS, NKNP3W NKNP5WS KNP5W,NKNP5W 尺 寸 單位:mm Unit:mm Dimensions I L±1.0 ψD ψd±0.05 H±2.0 60 9.0 3.2±0.5 0.50 28 60 73 60 81 94 11.5 11.5 15.5 15.5 15.5 4.5±1.0 4.5±1.0 5.0±1.0 5.0±1.0 5.0±1.0 0.60 0.60 0.68 0.68 0.68 25 31 23 33 40 94 17.5 6.0±1.0 0.68 38 94 24.5 8.0±1.0 0.68 35 13-8 品 名 Product Name 版 線繞電阻器 本 制定日期 B/3 版 Version 5.2 帶裝 Wirewound Resistor 2017 年 06 月 10 日 Enactment Date 頁數 JUN 30, 2017 13-9 Page Axial Lead Taping R Txx Type e W R P t Z T 種類 Type 普通型 Normal Size 小型化 Small Size KNP 1/2W KNP 1WS KNP 1W KNP 2WS KNP2W KNP5W KNP 3WS 帶狀 Taping L1 L 尺 L S L2 單位:mm Unit:mm 寸 Dimensions W P L1-L2 Max. T Z R t e S Max. Max. Max. Max. Max. T52 9.0±1.0 52±1.0 5±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T52 11.5±1.0 52±1.0 5±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T67 11.5±1.0 67±1.0 5±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T52 15.5±1.0 52±1.0 10±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T73 15.5±1.0 84±1.0 10±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T84 15.5±1.0 84±1.0 10±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 T84 24.5±1.0 84±1.0 10±0.5 1.0 6±0.5 1.2 0 3.0 0.6 0.5 品 名 Product Name 版 線繞電阻器 本 Version 5.3 制定日期 B/3 版 Wirewound Resistor 2017 年 06 月 10 日 Enactment Date MB 型&M 型& MK 型 JUN 30, 2017 頁數 Page 13-10 MB Type &M Type&MK Type MB 瓦特數 Watts 1/2w,1ws 1w,2ws 2w,3ws D 3.2±0.5 4.5±1.0 5.0±1.0 L 9.0±1.0 11.5±1.0 15.5±1.0 3W5WS 6.0±1.0 17.5±1.0 5W 8.0±1.0 24.5±1.0 尺寸 Dimensions (mm) P±1.0 H1±1.0 H2±0.5 12.5/15 10.5 4.5 15 10.5 4.5 20 10.5 4.5 25 10.5 4.5 30 尺寸 Dimensions (mm) 瓦特數 Watts ΦD L P±1.0 H±1.0 1/2w,1ws 3.5±0.5 9.0±1.0 12.5/15 10 1w,2ws 2w,3ws 3w 5w 4.5±1.0 5.0±1.0 6.0±1.0 8.0±1.0 11.5±1.0 15.5±1.0 17.5±1.0 24.5±1.0 15 20 25 30 10 10 10 10 10.5 4.5 瓦特數 Watts t±0.15 1.2 1.25 1.25 qMax 3 3 3 1.25 3 1.25 3 D 1/2w,1ws 3.2±0.5 1w,2ws 2w,3ws 4.5±1.0 5.0±1.0 3W5WS 6.0±1.0 尺寸 Dimensions (mm) L P±1.0 H±1.0 9.0±1.0 12.5 10 11.5±1.0 15 10 15.5±1.0 20 10 17.5±1.0 25 10 H1±1.0 4.5 4.5 4.5 4.5 品 名 Product Name 版 線繞電阻器 本 Version 5.4 制定日期 B/3 版 Wirewound Resistor 2017 年 06 月 10 日 Enactment Date F 型&FK2 型& FKK 型 頁數 JUN 30, 2017 13-11 Page F Type &FK2Type&FKK Type 尺寸 Dimensions (mm) 瓦特數 Watts ΦD L 1/2w,1ws 3.2±0.5 9.0±1.0 6 3.5 1w,2ws 4.5±1.0 11.5±1.0 8 2w,3ws 5.0±1.0 15.5±1.0 3w 6.0±1.0 17.5±1.0 尺寸 Dimensions (mm) 瓦特數 Watts ΦD L P±2.0 E Max H±1.0 5-8 1/2w,1ws 3.2±0.5 9.0±1.0 6 3.5 5-8 3.5 5-8 1w,2ws 4.5±1.0 11.5±1.0 8 3.5 5-8 8 3.5 5-8 2w,3ws 5.0±1.0 15.5±1.0 8 3.5 5-8 8 3.5 5-8 3w 6.0±1.0 17.5±1.0 8 3.5 5-8 P±2.0 E Max H±1.0 尺寸 Dimensions(mm) 瓦特数 Watts ΦD L P±1.0 E Max H1±1.0 H2±1.0 1/2w,1ws 3.2±0.5 9.0±1.0 5-7 3.5 8 4.5 1w,2ws 4.5±1.0 11.5±1.0 5-9 3.5 8 4.5 2w,3ws 5.0±1.0 15.5±1.0 5-9 3.5 8 4.5 3w 6.0±1.0 17.5±1.0 5-10 3.5 8 4.5 品 名 Product Name 版 本 線繞電阻器 B/3 版 制定日期 Wirewound Resistor 2017 年 06 月 10 日 頁數 Version Enactment Date JUN 30, 2017 6 包裝 Package 6.1 帶裝品包裝 Tape in box packing (Ammo packing) 6.1.1 表示項目 Indication (1) 客戶品號 Customer Part No. (2) 製造品號 Manufacturer Part No. (3) 數 量 Quantity (4) 製造者名 Manufacturer Page H 表示 Indication W 6.1.2 包裝盒尺寸和數量 Packing box size and quantity 種 類 Type 普通型 小型化 Normal Size Small Size KNP1/2W, KNP1WS, NKNP1/2W NKNP1WS KNP1W, KNP2WS, NKNP1W NKNP2WS KNP2W, KNP3WS, NKNP2W NKNP3WS KNP3W, KNP5WS, NKNP3W NKNP5WS KNP5W,NKNP5WS L 形 狀 Form 包裝數量 Quantity T52 尺寸 Dimensions (mm) L W H 2000 PCS 260 80 85 T52 T67 T52 T73 1000 PCS 1000 PCS 1000 PCS 1000 PCS 260 260 260 260 80 85 80 95 85 92 100 92 T84 500PCS 260 110 75 T84 250PCS 260 110 75 13-12 品 名 Product Name 版 本 線繞電阻器 B/3 版 制定日期 Wirewound Resistor 2017 年 06 月 10 日 Version Enactment Date 6.2 散裝品包裝 Tape in box Bulk (Ammo Bulk) 6.2.1 表示項目 Indication (5) 客戶品號 Customer Part No. (6) 製造品號 Manufacturer Part No. (7) 數 量 Quantity (8) 製造者名 Manufacturer 頁數 JUN 30, 2017 Page 表示 Indication 6.2.2 包裝盒尺寸和數量 Packing box size and quantity 種 類 Type 形 狀 普通型 小型化 Form Normal Size Small Size P KNP1/2W, KNP1WS, NKNP1/2W NKNP1WS 成型 Moulding P KNP1W, KNP2WS, NKNP1W NKNP2WS 成型 Moulding P KNP2W, KNP3WS, NKNP2W NKNP3WS 成型 Moulding P KNP3W, KNP5WS, NKNP3W NKNP5WS 成型 Moulding P KNP5W,NKNP5WS 成型 Moulding 包裝數量 Quantity 5000 PCS 5000 PCS 2000 PCS 2000 PCS 2000 PCS 2000 PCS 100PCS 250PCS 50PCS 50PCS 尺寸 Dimensions (mm) L W H 240 240 240 240 240 240 240 240 240 240 140 140 140 140 140 140 140 140 140 140 76 76 76 76 76 76 76 76 76 76 13-13
KNP2WS-0.15Ω±5% 价格&库存
很抱歉,暂时无法提供与“KNP2WS-0.15Ω±5%”相匹配的价格&库存,您可以联系我们找货
