SLO-F Series
SMD Molding Power Inductor
◆ Features
Pb
、Magnetically shielded construction, low DC resistance;
2、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 3.0MHz;
6、RoHS compliant。
1
◆ Applications
、Smart phone、MID;
2、Hard disk of ultrabook;
3、LTE module;
4、Portable device;
5、Portable gaming devices, personal navigation systems;
6、personal multimedia devices;
1
◆ Lead Free Part Numbering
SLO
(1)
252012 F 2R2 M
T
T
(2)
(3) (4) (5) (6) (7)
(1) Series Type
(2) Dimension
:L X W X H
(3) Material Code
(4) Inductance R68=0.68μH
2R2=2.2μH
(5) Inductance Tolerance M= 20%, N=±30%
(6) Company Code
(7) Packaging packed in embossed carrier tape
◆ Dimensions
Rev.01
Recommended Land Patterns
A (mm)
B (mm)
E (mm)
0.8
2.05
1.65
Series
L (mm)
W (mm)
C (mm)
F (mm)
SLO201610F
SLO252010F
2.0±0.1
1.6±0.1
1.0 Max
0.5±0.3
2.5±0.2
2.0±0.2
1.0 Max
0.5±0.3
1.2
2.8
2.0
SLO252012F
2.5±0.2
2.0±0.2
1.2 Max
0.5±0.3
1.2
2.8
2.0
Page 1 of 4
www.sunltech.com
SLO-F Series
◆ Specification
Part Number
μ
INDUCTANCE
Lo( H)
Ω
Rdc
(m )
Typ.
Max
Test a
condition
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
SLO201610F
SLO201610FR24MTT
0.24±20%
16
22
1MHz/1.0V
4.60
5.50
SLO201610FR33MTT
0.33±20%
22
31
1MHz/1.0V
3.70
5.15
SLO201610FR47MTT
0.47±20%
33
40
1MHz/1.0V
3.26
3.81
SLO201610FR68MTT
0.68±20%
41
49
1MHz/1.0V
3.15
3.38
SLO201610F1R0MTT
1.0±20%
60
69
1MHz/1.0V
2.56
2.73
SLO201610F1R5MTT
1.5±20%
113
128
1MHz/1.0V
1.79
2.45
SLO201610F2R2MTT
2.2±20%
135
150
1MHz/1.0V
1.68
1.80
SLO201610F3R3MTT
3.3±20%
210
254
1MHz/1.0V
1.33
1.34
SLO201610F4R7MTT
4.7±20%
308
376
1MHz/1.0V
1.07
1.24
SLO252010FR33MTT
0.33±20%
1MHz/1.0V
4.30
6.50
SLO252010FR47MTT
0.47±20%
25
33
1MHz/1.0V
3.60
4.90
SLO252010FR68MTT
0.68±20%
35
46
1MHz/1.0V
3.20
4.10
SLO252010F1R0MTT
1.0±20%
44
55
1MHz/1.0V
2.70
3.46
SLO252010F1R0MTT
1.5±20%
75
92
1MHz/1.0V
2.30
2.46
SLO252010F2R2MTT
2.2±20%
98
120
1MHz/1.0V
1.73
2.27
SLO252010F4R7MTT
4.7±20%
210
276
1MHz/1.0V
1.22
1.69
SLO252012FR47MTT
0.47±20%
19
27
1MHz/1.0V
4.22
5.10
SLO252012FR68MTT
0.68±20%
27
36
1MHz/1.0V
3.50
4.73
SLO252012F1R0MTT
1.0±20%
39
50
1MHz/1.0V
3.29
4.27
SLO252012F1R5MTT
1.5±20%
62
78
1MHz/1.0V
2.39
3.17
SLO252012F2R2MTT
2.2±20%
81
99
1MHz/1.0V
2.27
2.85
SLO252012F4R7MTT
4.7±20%
193
237
1MHz/1.0V
1.55
1.73
SLO252010F
SLO252012F
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -40
to +125
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
Rev.01
Page 2 of 4
www.sunltech.com
SLO-F Series
◆ Wave Soldering
◆ Hand soldering
Rev.01
Page 3 of 4
www.sunltech.com
SLO-F Series
◆ Reliability Mechanical
℃~125℃
-40℃~125℃
-40
Rev.01
Page 4 of 4
www.sunltech.com
很抱歉,暂时无法提供与“SLO201610F2R2MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.10152
- 100+0.08424
- 300+0.07560
- 3000+0.06582
- 6000+0.06064
- 9000+0.05804
