LS-472M2D--A4070
LS-472M2D--A4070
    LELON(立隆电子)
    AEC_D40X70MM_TM
    贴片铝电解电容 AEC_D40X70MM_TM
LS-472M2D--A4070 数据手册
Aluminum Electrolytic Capacitors LS Features ‧ Snap-in terminal type ‧ 85℃, 2,000 hours assured ‧ RoHS Compliance Sleeve & Marking Color: Black & White SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Performance -40℃ ~ +85℃ ±20% (at 120Hz, 20℃) I = 3 CV or 1.5 mA whichever is smaller (after 5 minutes) V = rated DC working voltage in V Where, C = rated capacitance in µF Leakage Current (at 20℃) Dissipation Factor (Tanδat 120Hz, 20℃) Rated Voltage 16 Tanδ(max) 0.50 25 0.45 35 0.40 50 0.35 63 0.30 100 0.20 160 0.15 200 0.15 250 0.15 350 0.15 400 0.15 420 0.15 450 0.15 500 0.15 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 16 25 35 50 63 100 160 200 250 350 400 420 450 500 3 3 2 2 4 4 4 4 8 8 8 8 8 Impedance Z(-25℃)/Z(+20℃) 4 Ratio Z(-40℃)/Z(+20℃) 15 10 8 6 5 4 8 10 10 16 18 18 20 20 Low Temperature Characteristics (at 120Hz) Test Time 2,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000 hours at 85℃. Endurance Test Time 1,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Shelf Life Test Freq.(Hz) 50 / 60 W. V.(V) Under 100 0.92 Length ≦ 55L 160 ~ 250 0.81 350 to up 0.77 Length ≧ 60L 160 ~ 450 0.88 Case size Ripple Current & Frequency Multipliers 100 / 120 500 1k 10k up 1.00 1.00 1.00 1.00 1.13 1.32 1.30 1.20 1.19 1.45 1.41 1.25 1.20 1.50 1.43 1.40 ‧3,000 Hrs specifications are available upon request DIAGRAM OF DIMENSIONS Unit: mm Sleeve Plate L+2 Max 2011 Version 4.0±1.0 2-φ2±0.1 10± 0. 1 φD+1 Max Vent 10 PC board pin-out Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC µF φD 16V (1C) 22φ 25φ 25V (1E) 30φ 35φ 22φ 5,600 22×25 22×25 22×30 22×25 22×35 22×30 22×35 22×35 22×40 22×40 22×50 6,800 8,200 22×25 2.56 27,000 22×25 22×30 22×25 22×30 22×30 22×35 22×30 22×40 22×35 22×50 22×50 2.60 2.81 2.88 3.13 3.45 3.69 3.47 3.98 3.84 4.52 4.84 33,000 22×50 5.20 10,000 12,000 15,000 18,000 22,000 25×25 25×30 2.81 3.03 25×25 2.96 25×25 25×30 25×25 25×35 25×30 25×40 3.38 3.64 3.47 3.98 3.93 4.44 V. DC µF φD 30×25 3.73 22×50 30×25 30×30 4.08 4.38 35×25 25φ 35φ 22φ 22×25 22×25 22×30 22×30 22×30 22×35 22×35 22×40 22×40 22×45 22×45 22×50 3,300 3,900 22×25 22×30 22×30 22×35 22×35 22×40 22×35 22×45 22×40 22×50 2.21 2.41 2.69 2.79 2.70 2.89 3.09 3.47 3.22 3.59 22×45 3.71 25×25 2.42 25×25 2.69 25×25 25×30 25×30 25×35 25×35 25×40 25×40 25×45 2.67 2.89 3.12 3.33 3.37 3.59 3.79 4.01 15,000 25×45 4.55 18,000 25×50 4.84 6,800 8,200 10,000 12,000 22,000 4.54 30φ 25×25 2.78 25×25 2.85 25×25 25×30 25×30 25×35 25×35 25×40 25×40 25×45 2.93 3.16 3.26 3.48 3.77 4.00 4.42 4.68 25×45 4.71 35φ 30×25 3.21 30×25 30×30 30×25 30×35 30×30 30×35 30×35 30×45 3.59 3.86 3.60 4.12 4.40 4.66 4.70 5.26 35×25 3.58 35×25 3.96 35×25 35×30 35×25 35×35 4.34 4.68 4.60 5.20 50V (1H) 30φ 2,700 5,600 2.31 2.38 2.56 2.43 2.81 2.97 3.18 3.33 3.53 3.68 4.08 4.15 2,200 4,700 25φ 35V (1V) 22φ LS 30×25 2.99 30×25 30×30 30×25 30×30 30×30 30×35 30×35 30×40 30×40 30×45 3.04 3.29 3.36 3.61 3.74 4.01 4.54 4.80 4.87 5.18 30×45 5.79 35×25 3.32 35×25 35×30 35×25 35×35 35×30 35×40 35×35 35×45 3.75 4.02 4.37 5.01 5.03 5.71 5.71 6.38 25φ 1.93 2.05 2.21 2.41 2.51 2.72 2.83 3.01 3.21 3.43 3.73 3.94 30φ 25×25 25×25 25×30 2.38 2.46 2.68 25×30 3.03 25×35 3.37 25×35 25×40 25×40 25×45 3.59 3.87 4.10 4.37 25×50 4.91 35φ 30×25 3.01 30×25 30×30 30×30 30×35 30×30 30×35 30×35 30×40 30×40 30×50 3.17 3.43 3.56 3.87 4.12 4.42 4.68 5.02 5.10 5.60 35×25 3.47 35×25 3.64 35×25 35×30 35×30 35×35 35×35 35×40 35×40 35×45 4.07 4.41 4.59 4.92 5.30 5.60 6.03 6.44 2011 Verison Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 63V (1J) φD µF 22φ 25φ 100V (2A) 30φ 35φ 22φ 1,200 1,500 1,800 22×25 1.90 2,200 22×30 2.35 2,700 22×35 2.50 3,300 22×35 22×40 22×45 22×50 2.62 2.90 3.10 3.49 3,900 25×25 25×25 25×30 25×30 2.30 2.34 2.52 2.69 30×25 2.78 25×35 3.09 30×30 3.09 25×40 3.37 30×30 3.37 35×25 3.36 5,600 25×45 3.77 30×35 3.75 6,800 25×50 4.41 35×30 35×30 35×35 35×35 3.88 4.04 4.33 4.80 35×40 35×45 35×50 5.47 5.97 6.30 4,700 30×40 4.41 8,200 30×45 4.90 10,000 30×50 5.49 12,000 V. DC φD µF 25φ 25φ 30φ 22×30 2.12 25×25 2.10 35φ 22×35 2.45 25×30 2.43 30×25 2.46 22×40 2.77 25×35 2.77 30×25 2.65 22×45 3.12 25×40 3.20 30×30 3.10 35×25 3.14 25×45 3.61 30×35 3.60 35×30 3.71 25×50 4.06 30×40 4.05 35×35 4.07 30×45 4.60 35×35 4.50 30×50 5.13 35×40 5.12 35×45 5.75 35×50 6.01 160V (2C) 20φ ~ 22φ LS 200V (2D) 30φ 35φ ~ 40φ 22φ 25φ 30φ 35φ ~ 40φ 150 22×25 0.95 22×25 0.95 180 22×25 1.04 22×25 1.04 220 22×25 20×25 22×25 20×30 22×25 1.15 1.12 1.27 1.28 1.40 22×25 1.15 22×25 1.30 22×30 1.44 25×25 1.43 22×30 22×35 22×35 22×40 22×40 22×45 22×45 22×50 1.65 1.76 1.88 1.97 2.08 2.18 2.36 2.47 25×25 25×30 1.63 1.74 25×30 1.86 30×25 1.85 25×30 25×35 25×35 25×40 25×40 25×45 25×45 25×50 2.05 2.16 2.36 2.43 2.66 2.79 2.96 3.12 25×50 3.44 30×25 30×30 30×30 30×35 30×30 30×35 30×35 30×40 30×40 30×45 2.05 2.15 2.36 2.43 2.62 2.77 3.00 3.10 3.44 3.53 30×50 3.93 270 330 390 22×30 1.62 470 22×30 1.77 25×25 1.77 22×30 22×35 22×35 22×40 22×40 22×45 1.92 2.05 2.12 2.24 2.32 2.55 22×50 2.88 25×25 25×30 25×30 25×35 25×30 25×35 25×40 25×45 25×45 25×50 1.92 2.05 2.22 2.31 2.32 2.52 2.86 2.98 3.27 3.43 560 680 820 1,000 1,200 1,500 1,800 2,200 30×25 2.02 30×25 2.22 30×25 30×30 30×30 30×35 30×35 30×40 30×40 30×45 30×45 30×50 2.31 2.51 2.82 2.94 3.25 3.42 3.77 3.92 4.10 4.32 35×25 2.50 35×25 35×30 35×30 35×35 35×35 35×40 35×35 35×40 35×45 35×50 2.79 2.92 3.24 3.40 3.75 3.90 4.08 4.30 4.72 4.88 35×70 40×60 35×80 40×70 5.00 5.00 5.40 5.60 40×80 6.60 2,700 3,300 3,900 4,700 5,600 6,800 2011 Version 22×50 2.68 35×25 2.10 35×30 35×25 35×30 35×35 35×35 35×40 35×40 35×45 35×45 35×50 35×50 40×40 35×70 40×50 35×80 40×60 35×80 40×80 35×90 40×80 35×100 40×90 40×100 2.72 2.39 2.96 3.09 3.40 3.50 3.87 3.95 4.37 4.45 5.00 4.92 5.40 5.00 5.90 5.90 6.30 6.40 7.10 7.38 8.90 8.00 8.65 Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC φD µF 250V (2E) 22φ 25φ 350V (2V) 30φ 35 ~ 40φ 20φ ~ 22φ 82 22×25 0.81 100 22×25 20×30 22×25 22×30 20×35 22×30 22×35 20×40 22×35 22×40 20×45 22×40 22×45 22×45 22×50 0.90 0.95 0.99 1.05 1.05 1.14 1.24 1.23 1.28 1.38 1.36 1.40 1.49 1.62 1.69 120 150 22×25 0.91 180 22×25 1.01 220 22×25 22×30 1.18 1.27 22×30 22×35 22×30 22×35 22×35 22×40 22×40 22×45 1.43 1.52 1.58 1.67 1.79 1.89 2.05 2.14 270 330 390 470 560 22×50 2.43 680 25×25 1.24 25×25 1.49 25×25 25×30 25×30 25×35 1.53 1.62 1.79 1.87 25×35 2.05 25×40 25×45 25×45 25×50 2.32 2.41 2.62 2.70 820 1,000 30×25 1.59 30×25 30×30 30×25 30×30 30×30 30×35 30×35 30×40 30×40 30×45 1.77 1.85 1.80 2.03 2.24 2.32 2.58 2.65 2.92 3.00 30×45 30×50 3.11 3.47 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 V. DC φD µF 22×50 35×25 35×30 35×30 35×35 35×35 35×40 35×35 35×40 35×45 35×40 35×45 35×50 40×40 35×70 40×50 35×80 40×60 35×90 40×80 35×90 40×80 35×100 40×90 40×100 25φ 35φ 20φ ~ 22φ 20×25 22×25 0.66 0.72 82 20×25 22×25 0.72 0.80 100 22×25 22×30 0.81 0.94 25×25 0.97 120 22×30 22×35 1.04 1.12 25×25 25×30 1.08 1.16 20×35 22×35 22×40 20×40 22×40 22×45 20×50 22×50 22×50 1.00 1.18 1.25 1.17 1.34 1.40 1.43 1.56 1.56 25×30 1.21 30×25 1.24 25×30 25×35 1.23 1.37 30×25 30×30 1.45 1.52 35×25 1.54 25×35 25×40 1.56 1.62 30×30 30×35 1.58 1.64 35×25 1.60 22×50 1.74 25×40 25×45 1.70 1.76 30×30 30×35 30×40 1.56 1.73 1.79 35×25 35×30 1.53 1.75 220 270 35φ 25×25 1.04 25×25 25×30 1.16 1.24 30×25 1.24 25×30 25×35 1.30 1.37 30×25 1.37 25×35 25×40 1.46 1.51 30×25 30×30 1.47 1.52 25×35 25×40 25×40 25×45 1.65 1.73 1.88 1.96 25×45 2.04 30×30 30×35 30×35 30×40 30×35 30×40 30×40 30×45 1.71 1.76 1.93 1.98 2.12 2.18 2.41 2.48 30×45 2.60 35×25 1.72 35×25 35×30 35×30 35×35 35×35 35×40 35×35 35×40 35×40 35×45 1.77 1.96 2.19 2.24 2.43 2.50 2.62 2.69 2.80 3.08 450V (2W) 30φ 68 180 30φ 2.21 2.30 2.54 2.62 2.90 2.98 3.06 3.39 3.45 3.39 3.74 3.81 4.04 4.60 4.50 4.90 4.90 5.40 6.30 6.10 7.00 7.47 8.00 8.88 56 150 1.94 25φ 400V (2G) 20φ ~ 22φ LS 20×25 22×25 20×25 22×25 22×30 20×30 22×30 20×35 22×30 22×35 20×40 22×35 22×40 20×45 22×35 22×40 20×50 22×45 22×50 0.57 0.68 0.62 0.72 0.80 0.74 0.87 0.87 0.87 1.00 0.96 1.05 1.15 1.13 1.20 1.25 1.29 1.36 1.51 25φ 30φ 25×25 0.85 25×25 0.98 25×30 25×35 1.09 1.12 25×30 25×35 25×40 25×35 25×40 25×45 25×40 25×45 25×50 1.16 1.27 1.35 1.31 1.45 1.50 1.47 1.65 1.73 25×45 25×50 1.59 1.72 35φ 30×25 1.10 30×25 30×30 1.16 1.32 30×30 30×35 1.43 1.49 30×30 30×35 30×40 30×35 30×40 30×45 1.45 1.63 1.72 1.65 1.83 1.95 35×25 35×30 1.35 1.49 35×25 35×30 1.43 1.61 35×30 35×35 1.71 1.86 2011 Verison Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC φD µF 400V (2G) 20φ ~ 22φ 25φ 450V (2W) 30φ 35 ~ 40φ 330 25×45 25×50 1.76 1.90 30×35 30×40 30×45 1.76 1.97 2.02 390 25×50 1.95 30×40 30×45 2.15 2.22 470 30×45 30×50 2.23 2.40 560 30×50 2.44 680 820 1,000 1,200 1,500 1,800 V. DC 35×30 35×35 1.95 2.02 35×30 35×35 35×40 35×35 35×40 35×45 35×40 35×45 35×50 35×45 35×50 35×60 40×50 35×60 40×50 35×70 40×60 35×100 40×70 35×100 40×80 40×100 1.97 2.17 2.24 2.20 2.42 2.48 2.49 2.71 2.78 2.88 2.95 3.70 3.70 4.10 4.00 4.80 4.80 6.10 5.50 6.80 6.50 7.80 420V (2P) φD µF 35φ 20φ ~ 22φ 25φ 25×50 30φ 1.76 22φ 25φ 30φ 0.70 68 22×30 0.82 82 22×35 0.96 25×30 0.97 100 22×40 1.14 25×35 1.15 30×30 1.16 120 22×45 1.30 25×35 1.25 30×30 1.26 35×25 1.20 150 22×50 1.52 25×40 1.48 30×35 1.50 35×30 1.34 25×50 1.65 30×40 1.60 35×30 1.55 30×45 1.90 35×30 1.85 270 35×40 1.95 330 35×45 2.00 180 220 3.70 1.93 2.10 2.19 30×45 30×50 2.03 2.24 30×50 2.33 35×30 35×35 35×40 35×35 35×40 35×45 1.88 2.06 2.13 2.00 2.11 2.34 35×45 35×50 2.43 2.63 35×45 2.60 35×50 35×70 40×50 2.91 4.00 3.70 35×80 40×60 35×100 40×70 4.60 4.30 5.60 5.10 40×80 5.80 40×100 7.20 35φ 22×25 35×60 35 ~ 40φ 30×40 30×45 30×50 500V (2H) 40φ 56 680 LS 40×50 3.70 820 35×70 4.40 40×60 4.30 1,000 35×80 5.10 40×60 4.80 1,200 40×70 5.50 1,500 40×100 7.20 1,800 40×100 7.80 Ripple current: A/rms Case size:φD×L(mm) Part numbering system ±20% 400V 101 M 2G Capacitance Capacitance tolerance LS series 100µF LSSeries name Example: Cap. Symbol 56 560 220 221 470 471 M = ±20% K = ±10% 4.0±0.5mm 22φ×30L -- A 2230 Rated voltage Terminal type Terminal length Case size Example: WV Symbol 400 2G 450 2W Example: Type Symbol 2 pins -5 pins L5 “-“: 6.3±1.0 mm Note: For more details, please refer to “Product Code Guide– Snap-in Type” on page 15. 2011 Version Example: φD×L 22×30 25×25 30×40 Code 2230 2525 3040 Pb-free Terminal + PVC Sleeve Terminal and Sleeve Type
LS-472M2D--A4070 价格&库存
很抱歉,暂时无法提供与“LS-472M2D--A4070”相匹配的价格&库存,您可以联系我们找货
