MEA682M2G--D145
MEA682M2G--D145
    LELON(立隆电子)
    AEC_D76.2X145MM
    贴片铝电解电容 AEC_D76.2X145MM
MEA682M2G--D145 数据手册
LELON ELECTRONICS CORP. Lelon P/N: MEA682M2G--D145 MEA Page: 1 / 1 6800 µF / 400 V – 76.2 φ × 145L CUSTOMER : CUSTOMER P/N: PRODUCT DIMENSIONS Unit: mm 76.2 145 32.0 44.5 49.2 30 24 7 14.0 5.0 φD L P WI W2 H±1 h± 1 a±0.5 b±0.5 c±0.5 Items Performance Rated Voltage VR 400 V ℃ 6800 µF (120 Hz, 20 ) Category Temperature Range -25 Capacitance Tolerance -20 % ~ +20 % (120 Hz, 20 ) Capacitance CR Surge Voltage VS ℃ ~ +85℃ ℃ 440 VDC ℃ ≦ 4948 µA ≦ 0.15 Leakage Current (20 ) ILEAK Tan δ After 5 minutes ℃ ℃ (120 Hz, 20 ) 12.3 A Ripple Current (IAC, R / rms) (120 Hz, 85 ) Rated Voltage Capacitance change C(-25℃ ) / C(+20℃ ) Low Temperature Characteristics at 120 Hz Ripple Current (A) and Frequency Multipliers Frequency (Hz) 50 / 60 100 / 120 300 1k 10k up Multipliers 0.7 1.0 1.1 1.3 1.4 ℃ Ripple Current (A) and Temperature Multipliers Endurance and Shelf Life Test 400 ≧ 0.7 Temperature ( ) 40 60 70 85 Multipliers 2.7 2.0 1.7 1.0 Items Endurance Test Time 2,000 Hrs at 85 , VR, IAC, R Shelf Life Test Cap. Change Within ±15 % of initial value Within ±20 % of initial value Tan δ Less than 175% of specified value Less than 200% of specified value Leakage Current Within specified value Within specified value ℃ ℃ 500 Hrs at 85 Shelf Life Test: The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1) Mounting capacitor Do not mount the capacitor with terminals (safety vent) upside down Standards JIS C 5101-4, IEC 60384-4 Remarks RoHS Compliance * Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in Lelon's catalog for further details. Publication Date November 15, 2018 Approval Signatures: Revision Date Version No. RDD0366A, A4, 100309 1 Please return one copy with your approval Approved Checked Designed R&D R&D R&D NOV. 15. 2018 NOV. 15. 2018 NOV. 15. 2018 Jack Huang H.Y.Huang Z.X.Sun
MEA682M2G--D145 价格&库存
很抱歉,暂时无法提供与“MEA682M2G--D145”相匹配的价格&库存,您可以联系我们找货
MEA682M2G--D145
    • 1+133.05600
    • 3+128.30400
    • 30+121.30560
