MEA332M2G--C105
MEA332M2G--C105
    LELON(立隆电子)
    AEC_D63.5X105MM
    贴片铝电解电容 AEC_D63.5X105MM
MEA332M2G--C105 数据手册
LELON ELECTRONICS CORP. Lelon P/N: MEA332M2G--C105 MEA Page: 1 / 1 3300 µF / 400 V – 63.5 φ × 105L CUSTOMER : CUSTOMER P/N: PRODUCT DIMENSIONS Unit: mm 63.5 105 28.6 38.1 42.6 30 24 7 14.0 4.5 φD L P WI W2 H±1 h± 1 a±0.5 b±0.5 c±0.5 Items Performance Rated Voltage VR 400 V ℃ 3300 µF (120 Hz, 20 ) Category Temperature Range -25 Capacitance Tolerance -20 % ~ +20 % (120 Hz, 20 ) Capacitance CR Surge Voltage VS ℃ ~ +85℃ ℃ 440 VDC ℃ ≦ 3447 µA ≦ 0.15 Leakage Current (20 ) ILEAK Tan δ After 5 minutes ℃ ℃ (120 Hz, 20 ) 7.9 A Ripple Current (IAC, R / rms) (120 Hz, 85 ) Rated Voltage Capacitance change C(-25℃ ) / C(+20℃ ) Low Temperature Characteristics at 120 Hz Ripple Current (A) and Frequency Multipliers Frequency (Hz) 50 / 60 100 / 120 300 1k 10k up Multipliers 0.7 1.0 1.1 1.3 1.4 ℃ Ripple Current (A) and Temperature Multipliers Endurance and Shelf Life Test 400 ≧ 0.7 Temperature ( ) 40 60 70 85 Multipliers 2.7 2.0 1.7 1.0 Items Endurance Test Time 2,000 Hrs at 85 , VR, IAC, R Shelf Life Test Cap. Change Within ±15 % of initial value Within ±20 % of initial value Tan δ Less than 175% of specified value Less than 200% of specified value Leakage Current Within specified value Within specified value ℃ ℃ 500 Hrs at 85 Shelf Life Test: The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1) Mounting capacitor Do not mount the capacitor with terminals (safety vent) upside down Standards JIS C 5101-4, IEC 60384-4 Remarks RoHS Compliance * Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in Lelon's catalog for further details. Publication Date November 15, 2018 Approval Signatures: Revision Date Version No. RDD0366A, A4, 100309 1 Please return one copy with your approval Approved Checked Designed R&D R&D R&D NOV. 15. 2018 NOV. 15. 2018 NOV. 15. 2018 Jack Huang H.Y.Huang Z.X.Sun
MEA332M2G--C105 价格&库存
很抱歉,暂时无法提供与“MEA332M2G--C105”相匹配的价格&库存,您可以联系我们找货
MEA332M2G--C105
    • 1+179.87400
    • 30+172.42200
