MCF-1050-R33-S1
MCF-1050-R33-S1
    HOTLAND(合泰盟方)
    SMD,11.5x10mm
    330NH ±20%
MCF-1050-R33-S1 数据手册
    方         合 盟 ※ Application 合 泰 Thin type of on-board power supply module for       盟 方   (C)3.5±0.5 泰 合 4,1   方   盟 泰 合     S 1   ④ Inductance Value:2R2=2.2µH; 方 ⑤ The Material Code; 泰 盟 盟 方 ⑥ Material Type; 合 20 (E)0~0.15 泰 盟 方   合 (B)10.0±0.3 (D)5.0Max   方 盟 方 盟 泰 -   ⑤ ⑥   ④ 泰 2R2     合 4,1 泰 - 合 1050 ③   方 盟 the diagram above applies to values 0.56uH and below   - ② 12,2 Suggested pad layout Dimensions are in mm 合 泰 合   MC F ③ Dimensions(unit:mm):10.0x10.0x5.0; 泰 Suggested pad layout Dimensions are in mm 方 盟 方 盟 泰 heating current depending on which value is lower. 12,2 the diagram above applies to values 0.56uH and above The rated current as listed is either the saturation current or the 合   泰 合         component.PWB trace size and thickness, airflow and other should be verified in the end application. 5,4     125℃ under the worst case operating conditions.Circuit design,   (F)2.0±0.5 5,4 cooling provision all affect the part temperature.Part temperature     (C)3.0±0.5 盟 泰 合 泰 合     (E)0~0.15 泰 合 方 盟 方 方   盟 (F)2.0±0.5 The part temperature (ambient + temp rise ) should not exceed ① (A)11.15±0.35 盟 (B)10.0±0.3 (D)5.0Max               合 合 泰 泰 盟 盟 方 方   (A)11.15±0.35 方         ※ Dimensions in inches (unit:mm) Operat between temperature range -55℃ to +125℃       合 合 Voltage regulator VRM for server 泰 盟 泰 DC/DC converters for laptop motherboards/CPU Isat :DC current (A) that will cause L0 to drop approximately 20% ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards Idc: DC current (A) that will cause an approximate △T of 40℃         Low loss and low resistance Test Condition:100KHz,1.0Vrms ② Mold Categories:F;   Low profile:Thickness max.5.0mm All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (3MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-1050-XXX-S1 Series
MCF-1050-R33-S1 价格&库存
很抱歉,暂时无法提供与“MCF-1050-R33-S1”相匹配的价格&库存,您可以联系我们找货
