APS07A40M150
APS07A40M150
    COILANK(驰兴)
    SMD
    功率电感 SMD
APS07A40M150 数据手册
Super Power Inductors 1. External Dimensions (Unit:m/m) Type A B C D E F G H Q’TY/Reel APS07A40 6.6±0.3 7.7Max 4.0Max 3.0Ref 1.6Ref 8.4Ref 3.5Ref 3.7Ref 1000 2. Part Number Code APS A A: B: C: D: E: F: 07 B A C 40 D Series Name Dimensions(mm) Materials Thickness(mm) Tolerance Inductance M E 150 F Super Power Inductors 07:6.6x7.7 NO use 40:4.0 Max M:±20% 150=15uH 3. Electrical Characteristics Part Number APS07A40M150 Inductance Test Frequency (uH) (KHz) 15.0 DCR mΩ Max.@ 25℃ 100KHz/1V Heat Rating Current Saturation Current DC(A) Typical DC(A) Typical 101.8 3.1 4.6 Notes: a. All test data is referenced to 25℃ ambient. b. Operating Temperature Range-40℃ to +125℃. c. Irms:DC current(A) that will cause an approximate△T of 40℃. d. lsat:DC current(A) that will cause Lo to drop approximately 40%. e. The part temperature(ambient + temp rise)should not exceed 125℃ under worst case operating conditions. Circuit design,component placement, PWB trace size and thickness,airflow and other cooling provisions all affect the part temperature,Part temperature should be verified in the end application. Http://www.coilank.com E-mail:sales@coilank.com Super Power Inductors 4. Test Data ELECTRICAL CHARCTERISTIC SPEC L(uH) DCR(mΩ) TOL 15.0 101.8 MECHANICAL DIMENSIONS Isat(uH) A(mm) B(mm) C(mm) D(mm) 4.6A 6.6 7.7 4.0 3.0 NO ±20% Max 1 14.28 66.47 (L0A-L4.6A) /L0A≤40% 9.58 2 13.43 66.72 9.49 6.59 7.26 3.86 OK 3 13.68 68.37 9.46 6.62 7.26 3.83 OK 4 14.49 66.38 9.55 6.61 7.23 3.81 OK 5 13.51 62.37 9.42 6.59 7.26 3.85 OK 6 13.56 65.73 9.41 6.58 7.22 3.82 OK 7 13.33 66.27 9.46 6.59 7.28 3.86 OK 8 14.24 66.27 9.58 6.63 7.29 3.83 OK 9 14.54 67.23 9.59 6.62 7.23 3.85 OK 10 13.36 67.21 9.41 6.61 7.25 3.84 OK ±0.3 Max Max Ref 6.57 7.24 3.82 OK Test Equipmets: IM3536,VR126,VR7210,Calipers Curve: 50 12 40 9 30 6 20 3 10 Tenperature(℃) Indutance(uH) Inductance  VS  Temperature 15 L(uH) 0 0 0 1 2 3 4 Current(A) Http://www.coilank.com E-mail:sales@coilank.com 5 ΔT(℃) Super Power Inductors 5. Test and Measurement Procedures 5.1 Test Conditions 5.1.1 Unless otherwise specified, the standard atmospheric conditions for measurement/test as: a. Ambient Temperature: 20±15℃ b. Relative Humidity: 65%±20% c. Air Pressure: 86KPa to 106KPa 5.1.2 If any doubt on the results, measurements/tests should be made within the following limits: a. Ambient Temperature: 20±2℃ b. Relative Humidity: 65%±5% c. Air Pressure: 86KPa to 106Kpa 5.2 Visual Examination a. Inspection Equipment: 10X magnifier 5.3 Electrical Test 5.3.1 Inductance (L) a. Refer to the third item. b. Test equipment: IM3536 LCR meter or equivalent. c. Test Frequency and Voltage: Refer to the third item. 5.3.2 Direct Current Resistance (DCR) a. Refer to the third item. b. Test equipment: VR126 or equivalent. 5.3.3 Saturation Current (Isat) a. Refer to the third item. b. Test equipment: Saturation current meter c. Definition of saturation current (Isat): DC current at which the inductance drops approximate 40% from its value without current. 5.3.4 Temperature rise current (Irms) a. Refer to the third item. b. Test equipment (see Fig.5.3.4-1): Electric Power, Electric current meter, Thermometer. c. Measurement method (see Fig. 5.3.4-1): 1. Set test current to be 0mA. 2. Measure initial temperature of choke surface. 3. Gradually increase current and measure choke temperature for corresponding current. 4. Definition of Temperature rise current: DC current that causes the temperature rise (△T =40°C) from 20°C ambient (see Fig. 5.3.4-2). Fig.5.3.4-1 Http://www.coilank.com Fig.5.3.4-2 E-mail:sales@coilank.com Super P Power Ind ductors 5.4 4 Reliab bility Test Items Require ed Characteristics Test Metthod/Conditiion After fluxing, compo onent shall be b dipped in a melted d. Solder: bath at 235 5℃±5℃ for 5±0.5 secon nds S Solder Abilityy Test The e surface of terminal imm mersed shalll be minimum m of 90% 9 covere ed with a new w coa ating of solde er  Preheeat:150±5℃ ℃ 60seconds s.  Soldeer temperatuure: 250±5℃ ℃.  Flux: rosin.  Dip time:10±0.5sseconds He eat endurancce of Soldering g Te erminal Strength 1.Co omponents should s have e not evidence of electrical and mechanical damage. 2.Ind ductance: within±10% w o initial value of e. 3.Im mpedance: within±10% w o initial value. of Specime en shall be soldered on n a PCB an nd a static fo orce of 17.7 7N shall be applied on the coil from m X、Y direcctions individ dually and held h Afterr soldering of X,Y wiithstanding at for 60±2 2S below conditionss .The terminal should not n Peell off. (Refer to figure at below) b Vibration Te est Inductance ch hange: Withiin ± 10% Without mecha anical dama age such as brreak Drop testt △L≦±10.0% change fro △ om an initial v value Http://ww ww.coilank.com m 1. Vibration frequen ncy: (10 Hzz to 55 Hz to o 10Hz) in 60 seconds as a a period d 2. Vibration time: Period d cycled for 2 hours in each e of 3 mutu ual perpendiicular directiions. 3. Amplitude: 1.5 mm max. Drop sp pecimen thre ee times on concrete c floor from a he eight 0f 1 me eter which mounted m on n test board d. E-maiil:sales@coilaank.com Super Power Inductors Items Required Characteristics Test Method/Condition Temperature:125℃±2℃ Time:96±2 hours. Tested not less than 1 hour, nor more than 2 hours at room. High Temperature StorageTest 1. No case deformation or change in appearance 2. △L/L≦10% 3. △Q/Q≦30% 4. △DCR/DCR≦10% Temperature:-40℃±2℃ Time:96±2 hours. Tested not less than 1 hour, nor more than 2 hours at room. Low Temperature Storage Test 1. No case deformation or change in appearance. 2 . △L/L≦10% 3. △Q/Q≦30% 4. △DCR/DCR≦10% Humidity Resistance 1. No case deformation or change in appearance. 2. △L/L≦10% 3. △Q/Q≦30% 4. △DCR/DCR≦10% 1. No case deformation or change in appearance. Thermal Shock Test 2. △L/L≦10% 3. △Q/Q≦30% 4. △DCR/DCR≦10% Http://www.coilank.com 1. Environment condition: 85 ± 2 ℃ Humidity: 80–85% Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours 1.Repeat 100 cycles as follow: (-40 ± 2 ℃; 30 ± 3 min) →(Room temp., 5 min) → (+125 ± 2 ℃, 30 ± 3 min) → (Room temp., 5 min) 2. Recovery: 48 + 4 / -0 hours of recovery under the standard condition after the test. E-mail:sales@coilank.com Super Power Inductors 6. Packaging, Storage 6.1 Tape and Reel Packaging Dimensions 6.1 .1 Taping Dimensions (Unit: mm) Please refer to Fig. 6.1.1-1 6.1.1-1 TYPE A0 B0 APS07A40 7.0±0.1 7.5±0.1 W E 16.0±0.3 1.75±0.1 F P0 P P1 T0 K0 7.5±0.1 4.0±0.1 12.0±0.1 2.0±0.1 0.4±0.1 5.3±0.15 6.1.2 Reel Dimensions (Unit: mm) Please refer to Fig. 6.1.2-1. Fig. 6.1.2-1. TYPE A B C D APS07A40 16.5±2.0 330.0±2.0 100.0±2.0 20.5±2.0 Http://www.coilank.com E-mail:sales@coilank.com Super Power Inductors 6.2 Packaging 6.2.1 The inner box specification: 350*340*40MM Packing quantity: 2000PCS/ box Bubble bag: 37*45CM Job description: putting the air bubble bag products placed inside the box, sealed with scotch tape 6.2.2 The outside box specification: 370*360*255MM Packing quantity: 10000PCS/ box Job description: will be outside the box bottom sealed, inner box into the box. a. With transparent tape sealed box at the top b. The specified location with a box labels in the outer box. c. If the mantissa box under a FCL with inner box or filling full 6.3 Storage a.To maintain the solderability of terminal electrodes and to keep the packing material in good condition, temperature and humidity in the storage area should be controlled. b. Recommended conditions: -10℃~40℃, 70%RH (Max.) c.The ambient temperature must be kept below 30℃.Even under ideal storage conditions, solderability of products electrodes may decrease as time passes. For this reason, product should be used with one year from the time of delivery. d. In case of storage over 6 months, solderability shall be checked before actual usage. Http://www.coilank.com E-mail:sales@coilank.com Super Power Inductors 7. Recommended Soldering Technologies 7.1 Re-flowing Profile: △ 1~2 ℃/sec. Ramp △ Pre-heating: 150~190℃/90±30 sec. △ Time above 240℃: 20~40sec △ Peak temperature: 255℃ Max./5sec; △ Solder paste: Sn/3.0Ag/0.5Cu △ Max.2 times for Re-flowing 7.2 Iron Soldering Profile: △ Iron soldering power: Max.30W △ Pre-heating: 150℃/60sec. △ Soldering Tip temperature: 350℃Max. △ Soldering time: 3sec Max. △ Solder paste: Sn/3.0Ag/0.5Cu △ Max.1 times for iron soldering [Note: Take care not to apply the tip of the soldering iron to the] Http://www.coilank.com E-mail:sales@coilank.com
APS07A40M150 价格&库存
很抱歉,暂时无法提供与“APS07A40M150”相匹配的价格&库存,您可以联系我们找货
