INPAQ
Global RF/Component Solutions
HCM 2012 G Series
Specification
Product Name
Series
Size
Chip Common Mode Filter
HCM G Series
EIAJ 2012
INPAQ
HCM2012G SERIES (Chip Common Mode Filter ) Engineering Specification
RoHS
Pb
This product belongs to the industrial grade standard, not the vehicle gauge
product! Can not use auto parts, if the customer is not expressly informed and
privately used to auto parts, produce any consequences, the original is not
responsible for after-sales service, thank you!
Features and Application
.Powerful components with composite co-fired material to solve EMI problem for high speed
differential signal transmission line as USB, and LVDS, without distortion to high speed signal
transmission.
.MIPI, MHL serial interface in mobile device.
1.PRODUCT DETAIL
Part No.
Imp. Com.
(Ω)±25%
@100MHz
DCR
Max. (Ω)
Rated
Current
Max.(mA)
Rated
Voltage
(V)
Insulation
Resistance
Min.(MΩ)
HCM2012GH670AE
67
1.0
200
10
100
HCM2012GH900AE
90
1.0
200
10
100
HCM2012GD500AE
50
1.0
100
10
100
HCM2012GD900AE
90
1.0
200
10
100
HCM2012GD121AE
120
1.2
100
10
100
Test Instruments
•HP4991B RF IMPEDANCE / MATERIAL ANALYZER
•HP4338A/B MILLIOHMMETER
•Agilent E5071C S-PARAMETER NETWORK ANALYZER
•HP6632B SYSTEM DC POWER SUPPLY
•Keithley 2410 1100V SOURCE METER
HCM 2012 G Series Engineer Specification
All Specifications are subject to change without notice.
Version: A8
Page 1 of 10
www.inpaq.com.tw ; www.inpaqgp.com
INPAQ
2.PART NUMBER CODE
HCM 2012 G □ 90 0 □ E
1
2
3 4 5 6 7 8
1:Series name
2:Dimensions L*W
3:Material code
4:Product identification number
5:Impedance value
(ex:900=90Ω)
6:Fixed decimal point
7:INPAQ internal code
8:Packaging style
E – Embossed tape, 7" reel
3.TYPICAL CHARACTERISTIC
HCM2012GH670A
IMPEDANCE vs. FREUQENCY CHARACTERISTICS
INSERTION LOSS vs. FREUQENCY CHARACTERISTICS
1000
Common Mode
100
10
Differential Mode
Insertion loss (dB)
Impedance (ohm)
Differential Mode
-5
-10
-15
-20
Common Mode
1
-25
10
100
1,000
Frequency (MHz)
10,000
10
100
1,000
10,000
Frequency (MHz)
Version: A8
Page 2 of 10
INPAQ
HCM2012GH900A
Insertion loss (dB)
Impedance (ohm)
Differential Mode
Common Mode
100
Differential Mode
10
-5
-10
-15
-20
Common Mode
-25
1
10
100
1,000
10
10,000
100
1,000
10,000
Frequency (MHz)
Frequency (MHz)
HCM2012GD500A
Insertion loss (dB)
Impedance (ohm)
Differential Mode
Common Mode
100
Differential Mode
10
-5
-10
-15
-20
Common Mode
1
-25
10
100
1,000
Frequency (MHz)
10,000
10
100
1,000
10,000
Frequency (MHz)
Version: A8
Page 3 of 10
INPAQ
HCM2012GD900A
Insertion loss (dB)
Impedance (ohm)
Differential Mode
1000
Common Mode
100
-5
-10
-15
Differential Mode
10
-20
Common Mode
1
-25
10
100
1,000
10,000
10
100
1,000
10,000
Frequency (MHz)
Frequency (MHz)
HCM2012GD121A
Insertion loss (dB)
Impedance (ohm)
Differential Mode
Common Mode
100
Differential Mode
10
-5
-10
-15
-20
Common Mode
1
-25
10
100
1,000
Frequency (MHz)
10,000
10
100
1,000
Frequency (MHz)
Version: A8
Page 4 of 10
10,000
INPAQ
4.SHAPES AND DIMENSIONS
HCM2012GH & GD SERIES
TYPE
Dimension
L
W
T
2.00±0.20
1.20±0.20
1.00±0.10
P
C1
C2
1.60±0.20
0.40±0.20
0.30±0.20
Unit:mm
HCM2012GD500A
Version: A8
Page 5 of 10
INPAQ
5.MEASURING CIRCUITS
(A):Common mode
(B):Differential mode
6.CIRCUIT CONFIGURATION & LAYOUT PAD
Version: A8
Page 6 of 10
INPAQ
7.TAPE AND REEL SPECIFICATIONS/ TAPING DIMENSIONS
Type:Embossed Carrier
Unit:mm
Symbol
Size
Symbol
Size
W
8.00±0.10
Po
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
E
1.75±0.10
Bo
2.30±0.10
F
3.50±0.10
Ao
1.40±0.10
Do
1.55±0.05
Ko
1.13±0.10
D1
1.00±0.05
t
0.22±0.05
Version: A8
Page 7 of 10
INPAQ
8.REEL DIMENSIONS
Unit:mm
9.STANDARD QUANTITY FOR PACKAGING
Packaging style:Taping
Reel packaging quantity:3000 pcs/reel
Inner box:5 reel/inner box
Version: A8
Page 8 of 10
INPAQ
10.RECOMMENDED SOLDERING CONDITIONS
11.GENERAL TECHNICAL DATA
Operating temperature range : - 40℃ ~ +85℃
Storage Condition : Less than 40℃ and 70% RH
Storage Time: 6 months Max.
Soldering method: Reflow
Version: A8
Page 9 of 10
INPAQ
12.RELIABILITY AND TEST CONDITION
Test item
Temperature Cycle
Test condition
A. Temperature : -40 ~ +85℃
B. Cycle : 100 cycles
C. Dwell time : 30minutes
Measurement : at ambient
temperature 24 hrs after test
completion
A. Temperature : 85℃ ± 5℃
Operational Life
Criteria
A. No mechanical damage
B.Impedance value should be
within ± 20 % of the initial value
B. Test time : 1000 hrs
C. Apply current : full rated current
completion
Biased Humidity
A. Temperature : 40 ± 2℃
B. Humidity : 90 ~ 95 % RH
C. Test time : 1000 hrs
D. Apply current : full rated current
B. Impedance value should be
completion
A. Solder temperature : 260 ± 5℃
Resistance to Solder
Heat
B. Flux : Rosin
C. DIP time : 10 ± 1 sec
A. More than 95 % of terminal
electrode should be covered
with new solder
B. No mechanical damage
C.Impedance value should be
A. Temperature : 93 ± 2℃
Steam Aging Test
B. Test time : 4 hrs
C. Solder temperature : 235 ± 5℃
electrode should be covered with
new solder
D. Flux : Rosin
E. DIP time : 5 ± 1 sec
13.NOTE
All the products in this specification comply with RoHS 1.0 directive.
Version: A8
Page 10 of 10
很抱歉,暂时无法提供与“HCM2012GD900AE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46991
- 100+0.37401
- 300+0.32606
