CMLS051B-R10MS-70
CMLS051B-R10MS-70
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
CMLS051B-R10MS-70 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLS051B-000 REVISION : A3 PAGE : 1 OF 3 Power Choke Coil CMLS051B MS type Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 1.2mm Low loss realized with low DCR Capable of corresponding high frequency (3MHz) 100% lead (Pb) free meet RoHS standard Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server Outline Dimensions L A' A B W B' H Code Dimensions (mm) L 5.4 ± 0.35 W 5.2 ± 0.2 T 1.0 ± 0.2 A 0.81± 0.18 A’ 1.0 ± 0.1 B 2.5 ± 0.08 B’ 2.8 ± 0.13 H 0 ~ +0.15 T Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.79 B 2.2 C 5.99 Unit : mm Feb., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLS051B-000 REVISION : A3 PAGE : 2 OF 3 Specifications L0 Inductance ( µH ) @ (0A) Typical CMLS051B-R10MS 0.10 CMLS051B-R47MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 4.4 5.1 16.0 15.0 35.0 30.0 0.47 17.5 19.0 6.6 5.9 20.0 17.0 CMLS051B-2R2MS 2.2 73.0 77.3 3.4 3.0 7.0 6.0 CMLS051B-3R3MS 3.3 98.0 112.0 2.8 2.5 5.8 5.0 CMLS051B-4R7MS 4.7 150.0 165.0 2.3 2.0 5.4 4.6 Part Number Rdc ( mΩ) * : If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Feb., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLS051B-000 REVISION : A3 PAGE : 3 OF 3 Current Characteristic 0.50 60 0.06 40 INDUCTANCE(µH) TEMP. RISE(℃) 0.02 20 10 15 20 25 30 DC BIAS(Amps) 35 40 3.50 2.80 2.50 40 20 TEMP. RISE(℃) 0.00 0 2 4 6 8 10 12 14 16 18 20 CMLS051B-4R7MS 100 CMLS051B-2R2MS 80 2.00 60 INDUCTANCE(µH) 1.50 40 TEMP. RISE(℃) 1.00 20 0.50 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 DC BIAS(Amps) 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 DC BIAS(Amps) 5 5.5 6 100 4.50 80 3.60 60 2.70 40 1.80 INDUCTANCE(µH) 0.90 TEMP. RISE(℃) 20 0.00 TEMP. RISE(℃) INDUCTANCE(µH) 0 0 80 INDUCTANCE(µH) 5.40 20 0.00 3.00 60 0.70 TEMP. RISE(℃) 100 2.10 1.40 40 INDUCTANCE(µH) 0.20 DC BIAS(Amps) CMLS051B-3R3MS 4.20 60 0.30 45 INDUCTANCE(µH) 5 80 0.40 0.10 0 0 100 TEMP. RISE(℃) 0.04 CMLS051B-R47MS TEMP. RISE(℃) 80 0.08 0.00 INDUCTANCE(µH) 0.60 TEMP. RISE(℃) INDUCTANCE(µH) 0.10 100 INDUCTANCE(µH) CMLS051B-R10MS TEMP. RISE(℃) 0.12 0 0.0 0.7 1.3 2.0 2.6 3.3 3.9 4.6 5.2 5.9 6.5 DC BIAS(Amps) Feb., 2018
CMLS051B-R10MS-70
物料型号为CMLS051B,由乾坤科技股份有限公司生产。
器件简介包括高性能金属粉末芯,低剖面最大厚度1.2mm,低直流电阻(DCR),高频响应能力(3MHz),符合RoHS标准的100%无铅。
引脚分配信息未提供。
参数特性包括不同型号的直流电阻(Rdc)、电流额定值(Idc、Isat)、电感值(L0)等。
功能详解涉及其在DC/DC转换器、笔记本电脑CPU、薄型板载电源模块、交换器和服务器电压调节模块中的应用。
应用信息包括用于笔记本电脑CPU的DC/DC转换器、薄型板载电源模块、服务器的电压调节模块(VRM)。
封装信息包括尺寸代码和推荐焊盘图案尺寸。
CMLS051B-R10MS-70 价格&库存
很抱歉,暂时无法提供与“CMLS051B-R10MS-70”相匹配的价格&库存,您可以联系我们找货
