PSE25201B-4R7MS
PSE25201B-4R7MS
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
PSE25201B-4R7MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : PSE25201B-000 REVISION : A5 PAGE : 1 OF 4 Sealed Choke Coil PSE25201B type  Features : Low profile 2.5mm x 2.0mm x 1.2mm Low coil resistance with large currents. High magnetic shield construction should actualize high resolution for EMC protection. 100% lead (Pb) free meet RoHS standard  Application Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..  Outline Dimensions W L Code L Dimensions (mm) 2.0 ± 0.2 W 2.5 ± 0.2 T 1.2 Max. T Note  :This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product. Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.1 B 0.8 C 2.6 Unit : mm Nov., 2014 Downloaded from Arrow.com. CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : PSE25201B-000 REVISION : A5 PAGE : 2 OF 4 Specifications Part Number PSE25201B-R24MS PSE25201B-R47MS PSE25201B-R50MS PSE25201B-R68MS PSE25201B-R82MS PSE25201B-1R0MS PSE25201B-1R5MS PSE25201B-2R2MS PSE25201B-3R3MS PSE25201B-4R7MS PSE25201B-6R0MS PSE25201B-6R8MS PSE25201B-100MS PSE25201B-150MS PSE25201B-220MS L0 Inductance ( µH ) @ (0A) Typical 0.24 0.47 0.50 0.68 0.82 1.0 1.5 2.2 3.3 4.7 6.0 6.8 10.0 15.0 22.0 20 25 27 31 36 37 63 80 140 190 260 325 360 820 910 Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 25 29 32 36 42 43 72 90 155 212 288 370 410 984 1,050 3.90 3.70 3.60 3.30 2.70 2.60 2.20 1.85 1.45 1.20 1.10 1.00 0.75 0.60 0.50 3.51 3.33 3.24 2.97 2.43 2.34 1.98 1.75 1.31 1.08 0.99 0.90 0.68 0.54 0.45 5.00 3.90 3.80 2.90 2.73 2.70 2.30 2.15 1.70 1.50 1.35 1.15 0.85 0.63 0.56 4.50 3.50 3.40 2.60 2.46 2.45 2.07 1.95 1.60 1.40 1.25 1.04 0.77 0.56 0.50 Rdc ( mΩ) :If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:1MHz, 1.0Vrms * : Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating. Note 3. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7. : The rated current as listed is either the saturation current or the heating current depending on which value is lower. Nov., 2014 Downloaded from Arrow.com. CYNTEC CO., LTD. 乾坤科技股份有限公司 REVISION : A5 PAGE : 3 OF 4 100 80 0.20 60 INDUCTANCE(µH) ℃ TEMP.RISE( ) 40 0.10 20 0.05 0.00 ℃ 3.0 4.0 5.0 6.0 0.27 ℃ TEMP RISE ( ) 0 0.0 0.5 1.0 1.5 2.0 0.84 80 0.70 60 0.3 INDUCTANCE(µH) 40 ℃) ℃ 20 0.1 0.0 INDUCTANCE(µH) 100 TEMP RISE( ) INDUCTANCE(µH) 0.4 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 INDUCTANCE(µH) 0.28 TEMP RISE( ) ℃ 80 1.0 40 ℃ 20 0.2 0.0 INDUCTANCE(µH) ℃ TEMP RISE ( ) 0 1.6 2.0 2.4 2.8 3.2 3.6 0 0.5 1.0 1.5 80 1.2 60 0.9 40 INDUCTANCE(µH) ℃) 20 0.3 0.0 0 1.2 1.6 2.0 DC BIAS(Amps) 3.5 4.0 4.5 2.4 2.8 3.2 100 80 60 INDUCTANCE(µH) 0.6 TEMP RISE ( 0.4 ℃) 40 ℃ 20 0.2 0 0.4 0.8 1.2 1.6 2.0 2.4 DC BIAS(Amps) 2.8 3.2 3.6 4.0 PSE25201B-2R2MS 100 2.25 ℃ INDUCTANCE(µH) 1.5 0.8 3.0 0.8 2.70 TEMP RISE( ) INDUCTANCE(µH) 100 0.4 2.5 PSE25201B-1R0MS 0.0 PSE25201B-1R5MS 0.0 2.0 0.0 4.0 1.8 TEMP RISE ( ℃ 20 DC BIAS(Amps) 0.6 40 0.14 1.2 INDUCTANCE(µH) 1.2 100 60 0.42 100 60 0.8 5.0 80 0.0 TEMP RISE( ) INDUCTANCE(µH) 0.6 0.4 4.5 DC BIAS(Amps) 0.8 0.0 4.0 0.56 5.5 PSE25201B-R82MS 0.4 3.5 PSE25201B-R68MS DC BIAS(Amps) 1.0 3.0 0.00 0 0.0 2.5 DC BIAS(Amps) 0.5 TEMP RISE ( ℃ 20 0.09 7.0 PSE25201B-R50MS 0.2 40 0.18 DC BIAS(Amps) 0.6 60 INDUCTANCE(µH) TEMP RISE( ) 2.0 80 0.36 TEMP RISE( ) 1.0 0.45 0.00 0 0.0 100 80 1.80 60 1.35 INDUCTANCE(µH) 0.90 TEMP.RISE( ) ℃ 40 ℃ TEMP RISE( ) 0.15 INDUCTANCE(µH) 0.25 PSE25201B-R47MS 0.54 TEMP RISE( ) PSE25201B-R24MS 0.30 INDUCTANCE(µH) : PSE25201B-000 Current Characteristic TEMP RISE( )  DOCUMENT 20 0.45 0 0.00 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 DC BIAS(Amps) Nov., 2014 Downloaded from Arrow.com. 60 INDUCTANCE(µH) ℃ 2.1 TEMP RISE ( ) 40 1.4 ℃ 20 0.7 INDUCTANCE(µH) 2.8 PAGE : 4 OF 4 PSE25201B-4R7MS 80 4.0 60 3.2 INDUCTANCE(µH) 2.4 TEMP RISE ( 1.6 ℃) 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 DC BIAS(Amps) 1.6 1.8 2.0 PSE25201B-6R0MS 7.5 INDUCTANCE(µH) 6.0 100 9.0 80 7.5 60 4.5 INDUCTANCE(µH) ℃ 3.0 40 TEMP RISE ( ) 1.5 20 0.0 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 0.0 ℃ 0.2 0.4 0.6 0.8 1.0 1.2 DC BIAS(Amps) 80 60 INDUCTANCE(µH) 6.0 ℃ TEMP RISE ( ) 4.0 40 ℃ TEMP RISE( ) 8.0 20 2.0 0.0 60 4.5 INDUCTANCE(µH) 0.2 0.4 0.6 0.8 1.0 TEMP RISE ( ) 20 1.5 0.2 0.4 0.6 0.8 1.0 DC BIAS(Amps) 60 TEMP RISE ( ) PSE25201B-150MS 100 15.0 80 12.0 60 9.0 40 INDUCTANCE(µH) 6.0 ℃ TEMP RISE( ) ℃ 20 3.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 ℃ 40 20 5.0 0.0 ℃ TEMP RISE( ) 80 20.0 INDUCTANCE(µH) 1.4 100 25.0 10.0 1.2 DC BIAS(Amps) PSE25201B-220MS 15.0 ℃ 0 0.0 1.2 DC BIAS(Amps) 30.0 40 ℃ 3.0 0.0 0 0.0 100 80 18.0 INDUCTANCE(µH) 10.0 1.8 6.0 0.0 100 PSE25201B-100MS 1.6 PSE25201B-6R8MS DC BIAS(Amps) 12.0 1.4 0.0 1.6 ℃ 20 0.0 2.2 INDUCTANCE(µH) 0.0 INDUCTANCE(µH) 40 0.8 0.0 INDUCTANCE(µH) 100 4.8 TEMP RISE( ) 80 : A5 5.6 TEMP RISE( ) INDUCTANCE(µH) 3.5 REVISION TEMP RISE( ) 100 : PSE25201B-000 TEMP RISE( ) PSE25201B-3R3MS 4.2 DOCUMENT TEMP RISE( ) CYNTEC CO., LTD. 乾坤科技股份有限公司 0 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 DC BIAS(Amps) Nov., 2014 Downloaded from Arrow.com.
PSE25201B-4R7MS 价格&库存
很抱歉,暂时无法提供与“PSE25201B-4R7MS”相匹配的价格&库存,您可以联系我们找货
