NFA 500V33 16*25
NFA 500V33 16*25
    SAMYOUNG(韩国三莹)
    插件,D16xL25mm
    直插铝电解电容 AEC_D16X25MM_TM
NFA 500V33 16*25 数据手册
RoHS APPROVAL NO MESSRS: DATE 697 - 091 2016.11.04 ALUMINUM ELECTROLYTIC CAPACITOR APPROVAL SHEET CATALOG TYPE NFA 500 VB 33 (Φ 16.0 × 25.0 L) USER PART NO. 适用机种 特记事项 Halogen-Free QINGDAO SAMYOUNG ELECTRONICS CO.,LTD MANAGER OF DEVELOPMENT DEPARTMENT GONG JANG SUG 长 孔 硕 USER APPROVAL: APPROVAL NO.: SamYoung(Korea) : 47,SAGIMAKGOL-RO,JUNGWON-GU,SEONGNAM-SI,GYEONGGI-DO,KOREA SamYoung(China) : No.5 CHANGJIANG ROAD,PINGDU-CITY,SHANDONG-PROVINCE,CHINA 样式:H-1001-011 A4 (210×297) SamYoung Electronics Co., Ltd. APPROVAL NO. PAGE:1 OF 5 ALUMINUM ELECTROLYTIC CAPACITOR 697 - 091 DATE: 2016.11.04 NFA SERIES VBSN 500 33 NFA 500 WV 33 μ F Φ 16.0 × 25.0 L RATING CASE SIZE A. DIAGRAM OF DIMENSION UNIT:mm MAX 25+2.0 15MIN 4MIN 7 . 5 ± 0 . 5 M A X 1 6 . Φ + 0 . 5 0 + - Φd=0.8±0.05 SAFETY VENT B. MARKING: SLEEVE DARK BROWN SLEEVE, SILVER .N O FRONT VIEW OF CAPACITOR 105℃ LO T NFA 500V 33μF INK BACK VIEW OF CAPACITOR C. ELECTRICAL CHARACTERISTICS :- 25 ~ +105 ℃ A. OPERATING TEMPERATURE RANGE B. RATED VOLTAGE :500 VDC C. SURGE VOLTAGE :550 VDC at Hz D. CAPACITANCE TOLERANCE : ( 20℃, 120 ) E. LEAKAGE CURRENT : LOWER 760 μA,AFTER 1 MIN. AT 20℃ 0.24 AT 20℃,120Hz F. DISSIPATION FACTOR(TANδ ) : LOWER G. MAX. RIPPLE CURRENT(mArms) : 228 AT 105℃,120Hz H. TEMPERATURE CHARACTERISTIC : * IMPEDANCE RATIO Z` / Z ≤ 6 AT 120Hz Z:IMP. AT 20℃, Z`:IMP. AT -25℃ ± 20% : THE FOLLOWING SPECIFICATIONS SHALL BE SATISFIED WHEN THE CAPACITORS ARE RESTORED TO 20℃,AFTER THE RATED VOLTAGE WITH THE RATED RIPPLE CURRENT IS APPLIED(THE PEAK VOLTAGE SHALL NOT EXCEED THE RATED VOLTAGE) AT 105℃ FOR 10,000 HOURS. :≤ ± 20 % OF INITIAL VALUE # CAPACITANCE CHANGE # TAN δ :≤ 200 % OF INITIAL SPECIFIED VALUE #L. C. :≤ THE INITIAL SPECIFIED VALUE J. SHELF LIFE : THE FOLLOWING SPECIFICATIONS SHALL BE SATISFIED WHEN THE CAPACITORS ARE RESTORED TO 20℃,AFTER EXPOSING THEM FOR 1000 HRS,AT 105 ℃ WITHOUT VOLTAGE APPLIED. THE RATED VOLTAGE SHALL BE APPLIED TO THE CAPACITORS FOR A MINIMUM OF 30 MINUTES,AT LEAST 24 HOURS AND NOT MORE THAN 48 HOURS BEFORE THE MEASUREMENTS # CAPACITANCE CHANGE :≤ ± 20 % OF INITIAL VALUE # TAN δ :≤ 200 % OF INITIAL SPECIFIED VALUE #L. C. :≤ 500 %THE INITIAL SPECIFIED VALUE K. OTHERS: SATISFIED CHARACTERISTIC KS C IEC 60384-4 I. LOAD LIFE ← 李波 SamYoung Electronics Co., Ltd. ← ← 立范 波 阿 吕 勇 PAGE: 2 OF 5 APPROVAL NO. ALUMINUM ELECTROLYTIC CAPACITORS 697 - 091 STRUCTURE AND MATERIALS LEAD WIRE PACKING PAD LEAD WIRE AL LEAD AL FOIL (-) AL LEAD AL FOIL (+) SLEEVE AL CASE ADHESIVE TAPE ELEMENT SEPARATOR CE04 TYPE MINIATURE SIZED TYPE CAPACITORS COMPONENT PART NAME LEAD WIRE MATERIALS TINNED COPPER - PLY WIRE(Pb-FREE) VENDER KISTRON (KOREA/CHINA) KOHOKU NANTONG HONG YANG (JAPAN/CHINA) (CHINA) KANG WON AUTO FITTING NAN TONG HUI FENG AL LEAD PACKING PAD SLEEVE AL CASE AL FOIL AL FOIL ALUMINUM 99.92 % OVER SYNTHETIC RUBBER P.E.T (Poly Ethlylene Terephthalate Resin ) ALUMINUM 99.0 % OVER FORMED ALUMINUM 99.9 % OVER ETCHED ALUMINUM 98.0 % OVER NANTONG HONG YANG KOHOKU KISTRON INSULATION PAPER ADHESIVE TAPE POLY PROPYLENE OR POLY IMIDE FILM (JAPAN/CHINA) (KOREA/CHINA) SUNG NAM CCW/ZHE JIANG TIAN TAI ZHE JIANG TIAN HUA (KOREA/CHINA) MOO DEUNG (KOREA/CHINA) SUZHOU QILIAN SHUN PENG PLASTIC YUN LIN PLASTIC ZHANG JIA GANG LIAN YI LIN AN AO XING NANTONG CHUANGJIA DONG NAM D.N TECH/HA NAM K.D.K/JCC/MATSUSHITA SAM YOUNG BECROMAL SATMA HEC XINJIANG JOINWORLD HUAFENG / NANTONG /RAOIO LUXON/LITON K-JCC K.D.K AFT/INCULCU/SHENGHONG ELECON/WU JIANG FEILO KAN/LUNAN SEPARATOR (CHINA) SPO N.K.K NITTO/NICHIBAN DAEIL/SWECO SamYoung Electronics Co., Ltd. (CHINA) (CHINA) (CHINA) (KOREA/CHINA) (JAPAN) (KOREA) (ITALY) (FRANCE) (CHINA) (TAIWAN) (KOREA) (JAPAN) (CHINA) (CHINA) (GERMANY) (JAPAN) (JAPAN) (KOREA) PAGE: 3 OF 5 APPROVAL NO. ALUMINNUM ELECTROLYTIC CAPACITOR 697 - 091 CC 端子加工 F P d Air 抽气段 L 〔单位:mm〕 制品 Φ 16 L F P ±0.5 ±0.5 ±0.5 4.0 7.5 7.5 备考 d 0.80 SamYoung Electronics Co., Ltd. PAGE: 4 OF 5 When using aluminum electrolytic capacitors,pay strict attention to the following: 1. Electrolytic capacitors for DC application require polarization. Confirm the polarity.If used in reversed polarity,the circuit life may be shortened or the capacitor may be damaged.For use on circuits whose polarity is occasionally reversed,or whose polarity is unknown,use bi-polarized capacitors (BP-series).Also,note that the electrolytic capacitor cannot be used for AC application. 2. Do not apply a voltage exceeding the capacitor`s voltage rating. If a voltage execeeding the capacitor`s voltage rating is applied,the capacitor may be damaged as leakage current inc-reases. When using the capacitor with AC voltage superimposed on DC voltage,care must be exercised that the peak value of AC voltage does not exceed the rated voltage. 3. Do not allow excessive ripple current to pass. Use the electrolytic capacitor at current values within the permissible ripple range.If the ripple current exceeds the sp-ecified value,request capacitors for high ripple current applications. 4. Ascertain the operating temperature range. Use the electrolytic capacitors according to the specified operating temperature range.Usage at room temperature will ensure longer life. 5. The electrolytic capacitor is not suitable for circuits in which charge and discharge are frequently repeated. If used in circuits in which charge and discharge are frequently repeated,the capacitance value may drop,or the capaci-tor may be damaged.Please consult our engineering department for assistance in these applications. 6. Apply voltage treatment to the electrolytic capacitor which has been allowed to stand for a long time. If the electrolytic capacitor is allowed to stand for a long time,its withstand voltage is liable to drop,resulting in increas-ed leakage current.If the rated voltage is applied to such a product,a large leakage current occurs and this generates internal heat,which damaged the capacitor.If the electrolytic capacitor is allowed to stand for a long time,therefore,use it after giving voltage treatment (Note 1).(However,no voltage treatment is required if the electrolytic capacitor is allow-ed to stand for less than 2 or 3 years at normal temperature.) 7. Be careful of temperature and time when soldering. When soldering a printed circuit board with various,components,care must be taken that the soldering temperature is not too high and that the dipping time is not too long.Otherwise,there will be adverse effects on the electrical charact-eristics and insulation sleeve of electrolytic capacitors in the case of small-sized electrolytic capacitors,nothing abno-rmal will occur if dipping is performed at less than 260℃ for less than 10 seconds. 8. Do not place a soldering iron on the body of the capacitor. The electrolytic capacitor is covered with a vinyl sleeve.If the soldering iron comes in contact with the electrolytic capa-citor body during wiring,damage to the vinyl sleeve and/or case may result in defective insulation,or improper protecti-on of the capacitor element. 9. Cleaning circuit boards after soldering. Some solvents have adverse effects on capacitors. Please refer to the next page. 10.Do not apply excessive force to the lead wires or terminals. If excessive force is applied to the lead wires and terminals,they may be broken or their connections with the internal elements may be affectde.(For strength of terminals,refer to KS C IEC 60384-4(JIS C5101-1,JIS C5101-4) 11.Care should be used in selecting a storage area. If electrolytic capacitors are exposed to high temperatures caused by such things as direct sunlight,the life of the cap-acitor may be adversely affected.Storage in a high humidity atmosphere may affect the solderability of lead wires and terminals. 12.Surge voltage. The surge voltage rating is the maximum DC over-voltage to which the capacitor may be subjected for short periods n-ot exceeding approximately 30 seconds at infrequent intervals of not more than six minutes.According to KS C IEC 60384 4,the test shall be conducted 1000 cycles at room temperature for the capacitors of characteristic KS C IEC 60384-4 or at the maximum operating temperature for the capacitors of characteristics B and C of KS C IEC 60384-4 with voltage app-lied through a series resistance of 1000 ohms without discharge.The electrical characteristics of the capacitor after the test are specified in KS C IEC 60384-4.Unless otherwise specified,the rated surge voltage are as follows: 2 4 6.3 10 16 25 35 50 63 80 100 160 200 250 315 350 400 450 500 Rated Voltage(V) 2.5 5 8 13 20 32 44 63 79 100 125 200 250 300 365 400 450 500 550 Rated Surge Voltage(V) Note 1 Voltage treatment … Voltage treatment shall be performed by increasing voltage up to the capacitor`s voltage ra-ting gradually while lowering the leakage current.In this case,the impressed voltage shall be in the range where t-he leakage current of the electrolytic capacitor is less than specified value.Meanwhile,the voltage treatment time may be effectively shortened if the ambient temperature is increased (within the operating temperature range). Note 2 For methods of testing, refer to KS C IEC 60384-4,(JIS C 5101-1,JIS C 5101-4) SamYoung Electronics Co., Ltd. PAGE: 5 OF 5 CLEANING CONDITIONS Aluminum electrolytic capacitors that have been exposed to halogenated hydrocarbon cleaning and defluxing solvents are susceptible to attack by these solvents.This exposure can result in solvent penetration into the capacitors, leading to internal corrosion and potential failure. Common type of halogenated cleaning agents are listed below. Structural Formula Chemical Name Representatice Brand Name Trichlorotrifluoroethane C2CI3F3 Freon TF,Daiflon S-3 Fluorotrichloromethane CCI3F Freon-11,Daiflon S-1 1,1,1-Trichloroethane F2H3CI3 Chloroethane Trichloroethylene C2HCI3 Trichiene Methyl Chloride CH3CI MC We would like to recommend you the below cleaning materials for your stable cleaning condition taking the place of previous materials. ◎Isopropyl Alcohol(IPA) or Water Cleaning method: One of immersion, ultrasonic or vapor cleaning. Maximum cleaning time: 5 minutes(Chip type: 2 minutes) ※Do not use AK225AES Aluminum electrolytic capacitors are easily affeceted by halogen ions,particularly by chloride ions. Excessive amounts of halogen ions,if happened to enter the inside of the capacitors, will give corrosion accidents-rapid capacitance drop and vent open. The extent of corrosion accidents varies with kinds of electrolytes and seal-materials. Therefore, the prevention of halogen ion contamination is the most improtant check point for quality control in our procuction lines. At present, halogenated hydrocarbon-contained organic solvents such as Trichloroethylene, 1,1,1Trichloroethane, and Freon are used to remove flux from circuit boards. If electroytic capacitors are cleaned with such solvents,they may gradually penetrate the seal portion and cause the eosion.When using latex-based adhesive on the capacitors rubber end seal for adhesion to a PCB, corrosion may occur depending on the kind of solvent in the adhesive. Select an adhesive as an organic solvent with dissolved polymer that is not halogenated hydrocarbon. Hot air drying is required for eliminating the solvent between the product and the PCB at 50℃~80℃ after coating. Followings are the penetration path of the halogenated solvent. ① Penetration between the rubber and the aluminum case ② Penetration between the rubber and the lead wire ③ Penetration through the rubber The inside of the capacitors,the mechanism of corrosion of aluminum electrolytic capacitors by halogen ions can be explainedas follows: Halides(RX) are absorbed and diffused into the seal portion. The halides then enter the inside of the capacitors and contact with the electrolyte of the capacitors. Where by halogen ions are made free by a hydrolysis with water in the electrolyte: + - RX+H2O→ROH+H +X - The halogen ions (X ) react with the dielectric substance(Al 2O3) of aluminum electrolytic capacitors: + AI2O3 + 6H + 6X →2ALX3 + 3H2O AIX3 is dissociated with water: + ALX3 + 3H2O → AL(OH)3 + 3H + 3X ※MANUFACTURING SITE ﹣SamYoung Electronics Co.,Ltd.(Korea/China) SamYoung Electronics Co., Ltd.
NFA 500V33 16*25 价格&库存
很抱歉,暂时无法提供与“NFA 500V33 16*25”相匹配的价格&库存,您可以联系我们找货
NFA 500V33 16*25
    • 1+7.85160
    • 10+6.49080
    • 30+5.81040
    • 250+4.40640
    • 500+4.00680
    • 1000+3.80160
    库存:86
