C08000J533
C08000J533
    ECEC(东晶)
    HC-49S/SMD
    无源晶振 HC-49S/SMD
C08000J533 数据手册
SPECIFICATION NO: QUARTZ CRYSTAL UNITS SPECIFICATION OF QUARTZ CRYSTAL UNITS 1.HOLDER TYPE: HC-49S/SMD 8.000 MHz 2.GENERAL 2-1 FREQUENCY (F0) 8.000 MHz 2-2 MODE OF OSCILLATION (Mn) FUNDAMENTAL 2-3 OPERATION TEMPERATURE RANGE (T0) -20℃ ~ +70℃ 2-4 STORAGE TEMPERATURE RANGE (Ts) -55℃ ~ +125℃ 2-5 TEST SET S&A 250B ANALYSIS SYSTEM 2-6 DRIVE LEVEL (DL) 10±2μw 2-7 LOADING CAPACITANCE (CL) 20pF 3.ELECTRICAL CHARACTERISTICS (This test shall be performed under the condition of temperature at 25±3℃.) 3-1 FREQUENCY TOLERANCE (△f) ±30ppm Max 3-2 EQUIVALENT 40 ΩMax/Series RESISTANCE (Rr) 3-3 TEMPERATURE DRIFT (TC) ±30ppm/ Max ( -20℃ ~ +70℃ ) 3-4 SHUNT CAPACITANCE (C0) 2.3±0.3pF 3-5 INSULATION 500MΩmin/DC 100V±15V RESISTANCE (Lead to lead ,case to lead) ±2 ppm Max/Year 3-6 AGING 4.DIMENSIONS AND MARKING 4-1 HOLDER TYPE 4-2 DIMENSION (mm) HC-49S/SMD C08000J533
C08000J533 价格&库存
很抱歉,暂时无法提供与“C08000J533”相匹配的价格&库存,您可以联系我们找货
