SJA4R7M1HBK-0507
SJA4R7M1HBK-0507
    LELON(立隆电子)
    插件,D5xL7mm
    直插铝电解电容 AEC_D5X7MM_TM
SJA4R7M1HBK-0507 数据手册
Aluminum Electrolytic Capacitors SJA Features ‧ 105℃, 1,000 ~ 2,000 hours assured ‧ High temperature Category range, with 7mm height ‧ RoHS Compliance Sleeve & Marking Color: Brown & White SECIFICATIONS Items Category Temperature Range Capacitance Tolerance Performance -55℃ ~ +105℃ ±20% I = 0.01CV or 3 (μ A) whichever is greater (after 2 minutes) Where, C = rated capacitance in µF V = rated DC working voltage in V Leakage Current (at 20℃) Dissipation Factor (Tanδ at 120Hz, 20℃) Rated Voltage Tanδ(max) 4 0.35 6.3 0.23 10 0.20 16 0.17 25 0.15 (at 120Hz, 20℃) 35 0.12 50 0.10 63 0.10 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 4 6.3 10 16 25 35 50 Impedance Z(-25℃)/Z(+20℃) 6 4 3 3 2 2 2 Z(-55℃)/Z(+20℃) Ratio 12 10 8 6 4 4 4 Low Temperature Characteristics (at 120Hz) 63 2 3 Test Time 2,000 Hrs Capacitance Change Within ±25%of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 105℃. Test time: 1,000 hours; other items are the same as those for the Endurance. Endurance Shelf Life Test Freq.(Hz) Cap.(µF) Under 47 100 to 470 Ripple Current & Frequency Multipliers 60 (50) 120 500 1k 10k up 0.75 0.88 1.00 1.00 1.20 1.10 1.30 1.15 1.45 1.20 DIAGRAM OF DIMENSIONS φD P φd α β P±0.5 15 min Sleeve LEAD SPACING AND DIAMETER φD+βmax φd L+α max 4 min V. DC 4V (0G) Contents φD×L mA 6.3V (0J) φD×L mA 10V (1A) φD×L mA 5 2.0 Unit: mm 6.3 2.5 0.5 8 3.5 1.0 0.5 Dimension: φD× L(mm) Ripple Current: mA/rms at 120 Hz, 105℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT µF 4 1.5 0.45 16V (1C) φD×L mA 25V (1E) φD×L mA 35V (1V) φD×L mA 50V (1H) 63V (1J) φD×L mA φD×L mA 0.1 0.22 0.33 0.47 1 0R1 R22 R33 R47 010 4×7 4×7 4×7 4×7 4×7 2 3 4 5 10 4×7 4×7 4×7 4×7 4×7 2 3 4.4 7.9 11 2.2 3.3 4.7 10 22 33 47 100 2R2 3R3 4R7 100 220 330 470 101 4×7 4×7 4×7 6.3×7 31 32 38 75 4×7 4×7 5×7 6.3×7 17 21 26 40 70 32 38 61 15 18 23 34 53 76 85 4×7 4×7 5×7 6.3×7 8×7 4×7 4×7 5×7 4×7 4×7 5×7 6.3×7 6.3×7 8×7 8×7 220 330 470 221 331 471 6.3×7 8×7 8×7 90 156 180 6.3×7 8×7 8×7 99 156 180 8×7 8×7 32 35 47 80 4×7 5×7* 5×7 6.3×7 6.3×7 25 39 43 59 90 140 160 8×7 8×7 146 180 4×7 5×7 6.3×7 6.3×7 8×7 26 41 53 65 125 4×7 5×7 6.3×7 8×7 8×7 8×7 22 30 47 71 83 145 2011 Verison
SJA4R7M1HBK-0507 价格&库存
很抱歉,暂时无法提供与“SJA4R7M1HBK-0507”相匹配的价格&库存,您可以联系我们找货
