100ME47AX
100ME47AX
    SUNCON
    插件,D10xL16mm
    直插铝电解电容 AEC_D10X16MM_TM
100ME47AX 数据手册
Aluminum Electrolytic Type / Radial Lead Type Aluminum Electrolytic Capacitors Radial Lead Type ME-SWB ME-AX ● ● Low Impedance Long Life Series 105℃ 2,500 to 10,000hours Solvent proof (within 5 minutes) ■ Specifications Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 63 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 79 Category temperature range (℃) − ME-UAX・SAX Capacitance tolerance (%) 120Hz/20℃ ME-LS ME-CZ ME-CA ME-CX tanδ (max.)120Hz/20℃ Impedance ratio at Iow temperature Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) ME-AX ME-WX ME-WA ME-WL ME-WG ME-FX ME-HWN Test 0.14 0.12 0.10 0.10 sleeve The greater value of either 0.01CV or 3 3 2 2 2 2 2 2 2 4 4 3 3 3 2 2 − φ5 : 2,500hours, φ6.3 : 3,000hours, φ8×11.5, φ8×12.5 : 3,500hours, φ8×15, φ8×20 : 4,500hours, φ10 : 5,000hours, φ12.5 : 7,000hours, φ16 to φ18 : 10,000hours △C/C Within ±20% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value (Unit : mm) φd±0.05 15min. 20min. L+αmax. 0.10 Exceeding 1,000μF, +0.02 every 1,000μF φD±0.5 ME-SWN 016 ■ Dimensions ME-FC・FD ME-FH 0.19 F±0.5 ME-PX ME-HPC・HPD 0.22 μA/after 2minutes (max.) Leakage current (LC) 125 −40 to +105 M : ±20 ME-SWG Dissipation Factor(tan δ) 100 −55 to +105 ME-UZ・SZ ME-HC RoHS compliance φD 5 6.3 8 10 12.5 16 18 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 φd 0.5 0.5 0.6 0.6 0.6 0.8 0.8 5min. α : L
100ME47AX 价格&库存
很抱歉,暂时无法提供与“100ME47AX”相匹配的价格&库存,您可以联系我们找货
