X1H027000DK1H-HV
X1H027000DK1H-HV
    HELE(加高电子)
    SMD5032_4P
    无源晶振 SMD5032_4P
X1H027000DK1H-HV 数据手册
SPECIFICATIONS FOR APPROVAL GP Customer Part No.: HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: HSX531S / 27.000MHz Sample Order No: CRYSTAL Date: EOS-E70005-4 X1H027000DK1H-HV 2014/07/03 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. HARMONY ELECTRONICS (SUZHOU) CO.,LTD TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號2樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, HWA DONG RD., DALLIAO DIST.,DAFA INDUSTRIAL PARK., KAOHSIUNG CITY 831, TAIWAN TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源 工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-27309272 / 27309262 FAX: 0755-27309755 SUZHOU FACTORY: 蘇州市相城區黃埭鎮安民路 5 號 NO.5 ANMING ROAD, HUANGDAI TOWN, XIANGCHENG DISTRCT, SUZHOU CITY, JIANGSU PROVINCE TEL:86-512-67592373 FAX:86-512-67592363 Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Spec. No. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 1 HSX531S SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION............. 3 2. MARKING & DIMENSIONS.................... 4 3. INSIDE STRUCTURE....................... 5 4. EMBOSS CARRIER TAPE&REEL................. 6 a. DIMENSIONS OF CARRIER TAPE................ 6 b. DIMENSIONS OF REEL.................... 6 c. STORAGE CONDITION..................... 7 d. STANDARD PACKING QUANTITY................ 7 e. MATERIAL OF TAPE...................... 7 f. LABEL CONTENTS....................... 7 g. TAPING DIMENSION....................... 8 h. JOINT OF TAPE........................ 8 i. RELEASE STRENGHT OF COVER TAPE............. 8 j. PACKAGE.......................... 9 5. MECHANICAL PERFORMANCE................. 10 6. ENVIRONMENTAL PERFORMANCE............... 10 7. SUPPLEMENT ........................ 11-12 8. FLOW CHART......................... 13 9. Environmental Workload Chemical Substance Components List..... 14 Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 2 1.QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 27.000000MHz 2. Holder type : HSX531S 3. Frequency tolerance: +/-20ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 40 ohms Max. / SERIES 5. Storage temperature range: -40deg.C To +125deg.C 6. Operable temperature range: -20deg.C To +75deg.C 7. Temperature drift: +/-20 ppm 8. Loading capacitance (CL) : 20.0 pF 9. Drive level: 10uW 10. Shunt Capacitance: 2.0 pF Max. 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 75 cm height 3 times on firm wood Variation : -20deg.C To +75deg.C (300uW Max.) Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/- 5 ppm/Year 16. Holder HSX531S Seam type 17. Dimensions and marking Refer to page.4 18. Emboss carrier tape & reel Refer to page.6 and page.8 19. Moisture Sensitivity Level Level 1 20. Note: Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 3 2. HSX531S MARKING & DIMENSIONS Chamfer index mark depends on the ceramic base supplier. *Marking should be printed as following: Nominal Frequency, Logo, Manufactured year & month *Nominal frequency = 3 number after decimal point MAX. ( ex. 12.000 MHz  12.000 ) *Manufacturing Lot No. (Year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (Month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2) Marking : Laser marking (Table-1) Year 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017 2018 2019 Code 0 1 2 3 4 5 6 7 8 9 (Table-2) Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec. A B C D E F G H J K L M Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 4 3. INSIDE STRUCTURE PAD(6) ELECTRODE(7) PAD(6) Cap(2) CRYSTAL BLANK(4) ADHESIVE(5) Base(1) ※Reference drawing (1) Base Alumina Ceramic (Al2O3) (6) Metallized Pad: W Ni Plating Au Plating (2) Cap Fe-Ni (3) Crystal Enclosure Seal Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin (7) Electrode Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 5 4. HSX531S EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 12.8+/-0.3 Outer Width W2 15.5+/-1.0 Out Line diameter B ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 Q 120deg C ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Center Core slit Width Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 1,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material A – PET Polyester f.) Label contents Sticks label for every reel. Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 8 j.) Package TYPE: SPEC. No.: Parts No.: Lot No.: Label Up side(Produce) Q.C PASS H10 FREQ.: Q'TY: MHz PCS HSF HARMONY ELECTRONICS CORP. Under side(Fixing Hole) One reel quantity: [1000pcs]&[3000pcs] 1 Top and bottom with 2.3cm thickness foam-rubber cushion for protection 2 Carton's Q'TY:1~15 pcs. 3 Carton Type=A,B ,C use 4 trigon pillar to fasten the Reel. 4 Need to add 3 pages dry agent in each outer box. use 4 trigon pilla OR Green Product ROHS Compliant Carton Type A B Reel Gree n Pr oduc ROHS t Co mp lia D C 630/531/ 321/221 Produce Type 840/751 421 211/111 OTHER 15 15 15 1~7 200 200 200 195 200 200 200 195 230/260 230 230 150 nt 1.Every Carton with 3 desiccant. 2.Top and bottom with 2.3cm thickness foam-rubber cushion for protection Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 9 5. Mechanical Performance Specifications Code Item Test Methods 1 Natural Drop 2 Vibration 3 Sealing Tightness 4 Solder ability Drop 3 times from the height of 75cm onto min. 30mm thickness hard wooden board Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X,Y and Z 3 axes, Duration of 2 hours to each axis. Leak Rate 1.0x10-8 Pa-m3/sec. Max. measured by Helium leak detector.. After applying ROSIN Flux, dipping in solder bath at 245℃+/-5℃ for 3+/-0.5 sec. A A --B 6. Environment Performance Item 1 2 3 4 Humidity Storage in Low Temperature Storage in High Temperature Temperature cycles Specifications code A B Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours Back to room temperature first, then in 1~2 hours, the component shall be checked. -40℃+/-2℃, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. +85℃+/-2℃, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. -40℃+/-2℃(30min)↔+85℃+/-2℃(30min) 25 cycles Back to the room temperature first, then in 1~2 hours, the component shall be checked. QUARTZ CRYSTAL SPECIFICATION Confirm 2014/07/03 F. S. TSAI A A A A Specifications Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test More than 90% of lead shall be covered by new solder. Tittle HSX531S Date Specifications Code Test Methods Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 10 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 11 7.4.Solder iron (Example) Bit temp.:350℃ max., Time: 3sec max. , Each terminal solder a 1 time max. 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be Sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering process. Avoid mounting and processing by Ultrasonic welding because this method has a possibility of an excessive vibration spreading inside the crystal products and becoming the cause of characteristic deterioration and not oscillating. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity, which may cause put Solderbility. No direct Sunlight, No dew as well. Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 12 8. Flow Chard LID(外 殼 蓋 ) BLANK(晶 片 ) LID進 料 檢 查 BASE進 料 檢 查 BLANK進 料 檢 查 1 Incoming Inspection of LID 5 2 LID洗 淨 6 Cleaning of LID BASE(基 座 ) 7 8 9 10 Incoming Inspection of BLANK 3 化學蝕刻 4 Etching Incoming Inspection of BASE BASE洗 淨 Cleaning of BASE 頻率選別 Freq. Sorting 蒸著前洗淨 Cleaning before Base Plating 微蝕刻 Flash Etching 基礎蒸著 Base Plating 11 押入接著 12 接著硬化 13 14 15 16 17 18 Blank Ass'y Adhesive Curing 接著檢查 Bonding Check 調整蒸著 Partial Adjustment 中 間 檢 查 ($) Middle Check 高真空烘烤 24 High Vacuum Annealing 熔 接 Seam Seal 氣 密 檢 查 II(氦 氣 加 壓 ) Leak Check II (Helium Pressurization) 25 氣 密 檢 查 II(HE) 26 最 終 檢 查 ($) 27 TAPING 28 Taping外 觀 檢 查 29 出貨檢查 Leak Check II 強 力 振 Over Driver 19 REFLOW 20 老 化 Aging 21 印 字 +外 觀 檢 查 Final Check Check of Taping Marking & Check 22 23 溫 特 檢 查 (C) Check of Temp. Characteristics 氣 密 檢 查 I (AIR) Leak Check I ($): 特 殊 特 性 (For Special Characteristics) (C): 指 定 流 程 (For Specific Assignment) QUARTZ CRYSTAL SPECIFICATION Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY 出貨捆包 Packing to Shipment/stock 出 貨 Shipment Tittle HSX531S Date 30 Outgoing Inspection Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 13 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX531S PERCENTAGE 40.4(mg) ppm SILICON(Si) 0.15756 63.65 GOLD(Au) 0.15756 63.65 COBALT AND ITS COMPOUND(Co) 2.56944 1038.05 MOLYBDENUM AND ITS COMPOUND(Mo) 0.12928 52.23 SILVER(Ag) 0.71104 287.26 COPPER(Cu) 0.10100 40.80 CHROMIUM AND ITS COMPOUND(Cr) 0.06868 27.75 11.11000 4488.44 MANGANESE AND ITS COMPOUND(Mn) 0.06464 26.11 WOLFRAM AND ITS COMPOUND(W) 0.15352 62.02 NICKEL AND ITS COMPOUND(Ni) 6.13676 2479.25 IRON(Fe) 9.45764 3820.89 Chemical Substance Components ALUMINIUM(Al) Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 14 REV. No. DATE REASON 0 2014/07/03 New CONTENTS Tittle HSX531S QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/07/03 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Spec. No. Rev. Page X1H027000DK1H-HV ELECTRONICS CORP. 0 15
X1H027000DK1H-HV 价格&库存
很抱歉,暂时无法提供与“X1H027000DK1H-HV”相匹配的价格&库存,您可以联系我们找货
