Aluminum Electrolytic Type / Surface Mount Type
Capacitors
Surface
Mount Type
CE-BD
CE-LH
Long Life
Series
105℃ 5,000hours
Solvent proof (within 2 minutes)
● AEC-Q200
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
6.3
10
16
25
35
50
Surge voltage
(V)
Room temperature
8.0
13
44
63
0.13
0.12
−40 to +105
CE-BSS
Category temperature range (℃)
CE-BS
Capacitance tolerance (%)
120Hz/20℃
CE-LD
Dissipation Factor(tan δ)
tanδ
(max.)120Hz/20℃
CE-FSS
CE-FS
CE-FS(High Voltage)
CE-FH
Leakage current
(LC)
M : ±20
0.32
0.24
4
3
2
2
2
2
10
7
5
3
3
3
μA/after 2minutes (max.)
105℃, 5,000hours
rated voltage applied
(With the rated
ripple current)
Endurance
CE-ZX
0.20
0.16
The greater value of either 0.01CV or 3
Based on the value at −25℃ Z/Z20℃
120Hz, +20℃ −40℃ Z/Z20℃
Impedance ratio at
Iow temperature
CE-AX
CE-KX
RoHS compliance
△C/C
Within ±30% of the initial value
tanδ
Less than 300% of the specified value
LC
Less than the specified value
CE-ZC
CE-LX
CE-GA
Polarity
(Cathode)
CE-PC
Lot No.
Rated Capacitance
Series Symbol
Rated Voltage
6.3V:6, 10V:A, 16V:C
25V:E, 35V:V, 50V:H
CE-PH
L
C
CE-LF
W
(P)
0D
100
A LH
CE-LL
(Unit : mm)
0.3max.
H
CE-LH(High Voltage)
■ Marking, Dimensions
φD
CE-LS
CE-LH
D±0.5
L±0.3
W±0.2
H±0.2
C±0.2
R
P
4
6.0
4.3
4.3
5.0
0.5 to 0.8
1.0
5
6.0
5.3
5.3
6.0
0.5 to 0.8
1.4
6.3
6.0
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
7.7
6.6
6.6
7.3
0.5 to 0.8
2.2
R (+)
CE-PS
(P)reference size
CE-PF
CE-TH
CE-JX
CE-NP
CE-FN
■ Size, Rated Ripple Current
V
μF
6.3
10
16
25
35
50
1.0
4×6.0
2.2
4×6.0
11
4×6.0
14
4×6.0
15
5×6.0
19
3.3
4.7
10
22
33
4×6.0
18
5×6.0
25
5×6.0
25
6.3×6.0
30
6.3×7.7
49
5×6.0
30
5×6.0
30
6.3×6.0
42
6.3×6.0
42
6.3×7.7
57
5×6.0
35
5×6.0
35
6.3×6.0
48
6.3×6.0
48
6.3×7.7
63
47
5×6.0
36
6.3×6.0
50
6.3×6.0
50
100
6.3×6.0
60
6.3×7.7
81
6.3×7.7
81
220
6.3×7.7
101
Please refer to page 14 for ripple current frequency coefficients.
■ Part number
10 CE 100 LH
Series code
Rated capacitance
Type code
Rated voltage
60
6.2
Case size:φDxL(mm)
Rated ripple current
mArms(120Hz, 105℃)
很抱歉,暂时无法提供与“35CE22LH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.39958
- 10+1.11111
- 30+0.98745
