Aluminum Electrolytic Type / Surface Mount Type
105℃ Long Life
160 to 400V, 105℃ 5,000hours
Non solvent proof
● AEC-Q200
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
160
200
400
Surge voltage
(V)
Room temperature
200
250
450
Category temperature range (℃)
−40 to +105
Capacitance tolerance (%)
120Hz/20℃
M : ±20
Dissipation Factor(tan δ)
tanδ
(max.)120Hz/20℃
μA/after
2minutes (max.)
Leakage current
(LC)
0.20
CE-BS
CV > 1,000
0.02CV +25
Endurance
105℃, 5,000hours
rated voltage applied
(With the rated
ripple current)
CE-LD
0.25
0.03CV +15
Based on the value at −25℃ Z/Z20℃
120Hz, +20℃ −40℃ Z/Z20℃
CE-BD
CE-BSS
0.20
CV ≤ 1,000
Impedance ratio at
Iow temperature
Surface
Mount Type
High Voltage
Series
Capacitors
CE-LH
RoHS compliance
CE-FSS
CE-FS
3
3
6
6
6
10
CE-FS
(High Voltage)
CE-FH
CE-AX
△C/C
Within ±30% of the initial value
CE-KX
tanδ
Less than 300% of the specified value
CE-ZX
LC
Less than the specified value
CE-ZC
CE-LX
CE-GA
CE-LS
■ Marking, Dimensions
[ φD≤10 ]
0.3max.
Polarity
(Cathode)
C
H
Series Symbol
(P)
Rated Capacitance
Rated Voltage★
L
[ φD≥12.5 ]
Polarity
(Cathode)
0DT
47
2D L
W
Lot No.
φD
0D
10
2C L
(Unit : mm)
R (+)
pressure relief vent
(P)reference size
Lot No.
Indicated φD=16, 18
D±0.5
L
W±0.2
H±0.2
C±0.2
8
10.5±0.3
8.3
8.3
10
10.5±0.3
10.3
12.5
13.5±0.5
12.8
16
16.5±0.5
18
18
CE-LH
R
P
9.0
0.7 to 1.0
3.2
CE-LL
10.3
11.0
1.0 to 1.4
4.6
CE-LF
12.8
13.5
1.0 to 1.4
4.6
CE-PC
16.3
16.3
17.3
1.7 to 2.1
7.0
CE-PH
16.5±1.0
19.0
19.0
20.0
1.7 to 2.1
7.0
CE-PS
21.5±1.0
19.0
19.0
20.0
1.7 to 2.1
7.0
CE-PF
CE-LH
(High Voltage)
CE-TH
Rated Capacitance
Series Symbol
CE-JX
CE-NP
Rated Voltage★
★(160V : 2C, 200V : 2D, 400V : 2G)
CE-FN
■ Size, Rated Ripple Current
V
μF
160
200
400
2.2
8×10.5
25
3.3
8×10.5
31
10×10.5
36
4.7
8×10.5
37
10×10.5
38
10
10×10.5
43
10×10.5
43
12.5×13.5
57
22
12.5×13.5
112
12.5×13.5
112
16×16.5
115
18×16.5
125
33
12.5×13.5
137
12.5×13.5
137
18×21.5
160
47
16×16.5
180
16×16.5
180
16×16.5
215
16×16.5
215
18×16.5 ★
270
18×21.5
330
27
68
82
16×16.5
235
100
18×16.5
320
120
18×21.5
340
Please refer to page 14 for ripple current frequency coefficients.
★LHV
■ Part number LH
Case size:φDxL(mm)
φ16, φ18:CE-LHT
LHV
160 CE 10 LH
200 CE 68 LHV T
Series code
Rated capacitance
Type code
Rated voltage
Rated ripple current
mArms(120Hz, 105℃)
LHT
Sn plating terminal option
Series code
Rated capacitance
Type code
Rated voltage
200 CE 47 LH T
Series code
Rated capacitance
Type code
Rated voltage
61
很抱歉,暂时无法提供与“400CE2R2LH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.74482
- 100+2.53368
- 500+2.42811
- 1000+2.36477
- 2000+2.32254
