SiT1552AI-JE-DCC-32.768 数据手册
SiT1552
Smallest (1.2 mm2), Ultra-Low Power, 32.768 kHz MEMS TCXO
Smallest (1.2mm2), Ultra-Low Power, 32.768 kHz MEMS TCXO
Features
Applications
32.768 kHz ±5, ±10, ±20 ppm frequency stability options
over temp
World’s smallest TCXO in a 1.5 x 0.8 mm CSP
Operating temperature ranges:
0°C to +70°C
-40°C to +85°C
Ultra-low power: 3.63V, or lower operating frequency
below 32 kHz.
When measuring the SiT1552 output frequency with a
frequency counter, it is important to make sure the counter's
gate time is >100 ms. The slow frequency of a 32kHz clock
will give false readings with faster gate times.
Power Supply Noise Immunity
In addition to eliminating external output load capacitors
common with standard XTALs, this device includes special
power supply filtering and thus, eliminates the need for an
external Vdd bypass-decoupling capacitor to keep the
footprint as small as possible. Internal power supply filtering is
designed to reject more than ±150 mV noise and frequency
components from low frequency to more than 10 MHz.
Rev 1.4
During initial power-up, the SiT1552 power-cycles internal
blocks, as shown in the power-supply start-up and steady
state plot in the Typical Operating Curves section. Power-up
and initialization is typically 200 ms, and during that time,
the peak supply current reaches 28 µA as the internal
capacitors are charged, then sequentially drops to its
990 nA steady-state current. During steady-state operation,
the internal temperature compensation circuit turns on
every 350 ms for a duration of approximately 10 ms.
Output Voltage
The SiT1552 has two output voltage options. One option is a
standard LVCMOS output swing. The second option is the
NanoDrive reduced swing output. Output swing is customer
specific and programmed between 200 mV and 800 mV. For
DC-coupled applications, output VOH and VOL are individually
factory programmed to the customers’ requirement. VOH
programming range is between 600 mV and 1.225V in
100 mV increments. Similarly, VOL programming range is
between 350 mV and 800 mV. For example; a PMIC or MCU
is internally 1.8V logic compatible, and requires a 1.2V V IH
and a 0.6V VIL. Simply select SiT1552 NanoDrive factory
programming code to be “D14” and the correct output
thresholds will match the downstream PMIC or MCU input
requirements. Interface logic will vary by manufacturer and
we recommend that you review the input voltage
requirements for the input interface.
For DC-biased NanoDrive output configuration, the minimum
VOL is limited to 350mV and the maximum allowable swing
(VOH - VOL) is 750 mV. For example, 1.1V VOH and 400 mV
VOL is acceptable, but 1.2V VOH and 400 mV VOL is not
acceptable.
When the output is interfacing to an XTAL input that is
internally AC-coupled, the SiT1552 output can be factory
programmed to match the input swing requirements.
For example, if a PMIC or MCU input is internally
AC-coupled and requires an 800 mV swing, then simply
choose the SiT1552 NanoDrive programming code “AA8”
in the part number. It is important to note that the SiT1552
does not include internal AC-coupling capacitors.
Please see the Part Number Ordering section at the end of
the datasheet for more information about the part number
ordering scheme.
Page 4 of 12
www.sitime.com
SiT1552
2
Smallest (1.2 mm ), Ultra-Low Power, 32.768 kHz MEMS TCXO
SiT1552 NanoDrive™
SiT1552 Full Swing LVCMOS Output
Figure 3 shows a typical output waveform of the SiT1552
(into a 10 pF load) when factory programmed for a 0.70V
swing and DC bias (VOH/VOL) for 1.8V logic:
The SiT1552 can be factory programmed to generate fullswing LVCMOS levels. Figure 4 shows the typical waveform
(Vdd = 1.8V) at room temperature into a 15 pF load.
Example:
NanoDrive™ part number coding: D14.
Example part number: SiT1552AI-JE-D14-32.768
VOH = 1.1V, VOL = 0.4V (V_sw = 0.70V)
Example:
LVCMOS output part number coding is always DCC
Figure 3. SiT1552AI-JE-D14-32.768
Output Waveform (10 pF load)
Example part number: SiT1552AI-JE-DCC-32.768
Figure 4. LVCMOS Waveform
(Vdd = 1.8V) into 15 pF Load
Table 4 shows the supported NanoDrive™ VOH, VOL
factory programming options.
Table 4. Acceptable VOH/VOL NanoDrive™ Levels
NanoDrive
VOH (V)
VOL (V)
Swing (mV)
Comments
D26
1.2
0.6
600 ±55
D14
1.1
0.4
700 ±55
D74
0.7
0.4
300 ±55
XTAL compatible
AA3
n/a
n/a
300 ±55
XTAL compatible
The values listed in Table 4 are nominal values at 25°C
and will exhibit a tolerance of ±55 mV across Vdd and
-40°C to 85°C operating temperature range.
Rev 1.4
Page 5 of 12
www.sitime.com
SiT1552
2
Calculating Load Current
No Load Supply Current
Total Supply Current with Load
When calculating no-load power for the SiT1552, the core
and output driver components need to be added. Since the
output voltage swing can be programmed to minimize load
current, the output driver current is variable. Therefore,
no-load operating supply current is broken into two sections;
core and output driver. The equation is as follows:
To calculate the total supply current, including the load,
follow the equation listed below.
Total Current = Idd Core + Idd Output Driver + Load Current
Example 1: Full-swing LVCMOS
Vdd = 1.8V
Idd Core = 990n
Load Capacitance = 10pF
Idd Output Driver: (Cdriver)(Vout)(Fout) =
(3.5pF)(1.8V)(32768Hz) = 206nA
Load Current: (10pF)(1.8V)(32768Hz) = 590nA
Total Current = 990nA + 206nA + 590nA = 1.79µA
Total Supply Current (no load) = Idd Core + Idd Output Driver
Vdd = 1.8V
Idd Core = 990nA (typ)
Voutpp = 1.8V
Supply Current = 990nA + 206nA = 1.2µA
Example 2: NanoDrive™ Reduced Swing
Vdd = 1.8V
Idd Core = 990nA
Voutpp (D14): VOH – VOL = 1.1V - 0.4V = 700mV
(3.5pF)(0.7V)(32768Hz) = 80nA
Load Current: (10pF)(0.7V)(32.768kHz) = 229nA
Total Current = 990nA + 80nA + 229nA = 1.299µA
Vdd = 1.8V
Voutpp (D14) = VOH – VOL = 1.1V - 0.4V = 700mV
Supply Current = 990nA + 80nA = 1.07µA
Rev 1.4
Page 6 of 12
www.sitime.com
SiT1552
2
Frequency Stability (PPM)
(TA = 25°C, Vdd = 1.8V, unless otherwise stated)
Pre-reflow
5 ppm Option (E)
200 units
Post 3x-reflow
5 ppm Option (E)
200 units
Temperature (°C)
Figure 6. Frequency Stability Over
Temperature (Post-Reflow)
Output Stage Current (nA/Vpp)
Figure 5. Frequency Stability Over Temperature
(Pre-Reflow)
Vdd = 3.63V
Vdd = 1.5 – 1.8V
Vdd = 3.63V
Vdd = 1.5 – 1.8V
Temperature (°C)
No Load Current (µA)
Figure 7. Core Current Over Temperature
Figure 8. Output Stage Current Over
Temperature
Vdd = 3.63V
(6µA)
Vdd = 1.5 – 1.8V
0.99
Time from Power ON [ms]
Temperature (°C)
Figure 9. Total Supply Current Over Temperature,
LVCMOS (Core + LVCMOS Output Driver, No Load)
Rev 1.4
Page 7 of 12
Figure 10. Start-up and Steady-State Current
Profile
www.sitime.com
2
Frequency Error (ppm)
SiT1552
Noise Injection Frequency (Hz)
Figure 11. Power Supply Noise Rejection (±150mV Noise)
Figure 12. Temperature Ramp Response
Figure 13. NanoDrive™ Output Waveform
(VOH = 1.1V, VOL = 0.4V; SiT1552AI-JE-D14-32.768)
Rev 1.4
Figure 14. LVCMOS Output Waveform
(Vswing = 1.8V, SIT1552AI-JE-DCC-32.768, 10 pF Load)
Page 8 of 12
www.sitime.com
SiT1552
2
Dimensions and Patterns
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
#4
#3
#2
#1
(soldermask openings shown with
dashed line around NSMD pad)
Recommended 4-mil (0.1mm) stencil thickness
Rev 1.4
Page 9 of 12
www.sitime.com
SiT1552
2
Manufacturing Guidelines
1) No Ultrasonic Cleaning: Do not subject the SiT1552 to an ultrasonic cleaning environment. Permanent damage or long term
reliability issues to the MEMS structure may occur.
2) Do not apply underfill to the SiT1552. The device will not meet the frequency stability specification if underfill is applied.
3) Reflow profile, per JESD22-A113D.
4) For additional manufacturing guidelines and marking/tape-reel instructions, refer to: SiTime Manufacturing Notes.
Rev 1.4
Page 10 of 12
www.sitime.com
SiT1552
2
Ordering Information
Part number characters in blue represent the customer specific options. The other characters in the part number are fixed.
SiT1552AI-JE-DCC-32.768S
Part Family
Packaging
“SiT1552”
“S”: 8 mm Tape & Reel, 10ku reel
“D”: 8 mm Tape & Reel, 3ku reel
“E”: 8 mm Tape & Reel, 1ku reel
Revision Letter
“A”: is the revision
Blank for Bulk
Samples in cut Tape & Reel strips
Temperature Range
“C”: Commercial, 0 to 70ºC
Output Clock Frequency (kHz)
“I”: Industrial, -40 to 85ºC
32.768 kHz
Package Size
“J”: 1.5 mm x 0.8 mm CSP
Output Voltage Setting
DCC: LVCMOS Output
NanoDrive™ Reduced Swing Output
Refer to Table 5 for output setting options
Over Temperature Stability Options
“E”: ±5 ppm
“F”: ±10 ppm
“1”: ±20 ppm
“A”: AC-coupled signal path
“D”: DC-coupled signal path
The following examples illustrate how to select the appropriate temp range and output voltage requirements:
Example 1: SiT1552AI-JE-DCC-32.768
Example 2: SiT1552AC-JF-D14-32.768
Industrial temperature range
CSP package
5 ppm frequency stability over temp
Output swing requirements:
a)
b)
c)
d)
Output frequency = 32.769 kHz
“D” = DC-coupled receiver
“C” = LVCMOS output swing
Commercial temperature range
CSP package
10 ppm frequency stability over temp
a)
b)
c)
d)
“1” = VOH = 1.1V
“4” = VOL = 400mV
Table 5. Acceptable VOH/VOL NanoDrive™ Levels[4]
NanoDrive
VOH (V)
VOL (V)
Swing (mV)
D26
1.2
0.6
600 ±55
D14
1.1
0.4
700 ±55
D74
0.7
0.4
300 ±55
XTAL compatible
AA3
n/a
n/a
300 ±55
XTAL compatible
Comments
Note:
4. If these available options do not accommodate your application, contact SiTime for other NanoDrive options.
Rev 1.4
Page 11 of 12
www.sitime.com
SiT1552
2
Table 6. Revision History
Version
Release Date
1.0
09/17/2014
Change Summary
Rev 0.9 Preliminary to Rev 1.0 Production Release
Updated start-up time specification
Added typical operating plots
Removed SOT23 and 2012 SMD package options
Added “no underfill” in frequency stability specification condition
Added Manufacturing Guidelines section
1.1
10/14/2014
Improved Start-up Time at Power-up spec
Added 5 pF LVCMOS rise/fall time spec
1.2
11/10/2014
Updated 5 pF LVCMOS rise/fall time spec
1.3
11/12/2015
Removed NanoDrive from EC Table and Ordering Info
1.31
01/18/2018
Updated SPL, page layout changes
1.32
03/15/2018
Updated POD (Package Outline Drawing)
Updated logo and company address, other page layout changes
1.4
04/12/2018
Added the NanoDrive sections
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2014-2018. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liabi lity for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or
usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by
SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved
or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR
FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.4
Page 12 of 12
www.sitime.com
