CMLW201610S100MST
CMLW201610S100MST
    CYBERMAX(思博)
    SMD,2x1.6mm
    功率电感 SMD
CMLW201610S100MST 数据手册
CMLW201610S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems 7、Telecomm base stations CMLW (1) (1) (2) (3) (4) 201610 S (2) (3) 2R2 M S T (4) (5) (6) (7) Series Type Dimension:L ×W× H(2.0×1.6×1.0mm) Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : ◆ Dimensions Unit:mm Series A B C D E CMLW201610 2.0±0.2 1.6±0.1 1.0Max. 0.60 ref 0.80 ref Rev.01 Page 1 of 5 www.cybermaxtech.com.cn CMLW201610S Series ◆ Electrical Characteristics 1) Operating and storage temperature range (individual chip without packing): cking): -25 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ℃ ℃ ℃ ~ +125℃ ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 5 www.cybermaxtech.com.cn CMLW201610S Series ◆ Specification Inductance Part Number @100KHz, 1V ( H) μ DC Resistance( ) Saturation Current(A) DCR 20% Isat ± Ω Min. Typ. Heat Rating Current (A) Min. Typ. Irms CMLW201610 Series CMLW201610SR47NST 0.47±30% 0.044 2.70 3.00 2.35 2.60 CMLW201610SR68NST 0.68±30% 0.062 2.00 2.45 2.05 2.25 CMLW201610S1R0MST 1.0±20% 0.080 1.80 1.95 1.60 1.75 CMLW201610S1R5MST 1.5±20% 0.130 1.46 1.65 1.26 1.40 CMLW201610S2R2MST 2.2±20% 0.145 1.26 1.45 1.20 1.35 CMLW201610S3R3MST 3.3±20% 0.245 0.90 1.05 0.95 1.05 CMLW201610S4R7MST 4.7±20% 0.360 0.77 0.85 0.90 1.00 CMLW201610S6R8MST 6.8±20% 0.500 0.72 0.80 0.55 0.70 CMLW201610S100MST 10±20% 0.720 0.55 0.62 0.45 0.50 CMLW201610S150MST 15±20% 1.400 0.45 0.50 0.36 0.40 CMLW201610S180MST 18±20% 1.800 0.40 0.45 0.34 0.38 CMLW201610S220MST 22±20% 2.000 0.38 0.43 0.27 0.30 ◆ Note :All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. 1 ◆ Standard Packing Quantity: :2000 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW201610SR47NST Rev.01 CMLW201610SR68NST Page 3 of 5 www.cybermaxtech.com.cn CMLW201610S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW201610S1R5NST CMLW201610S1R0NST CMLW201610S2R2MST CMLW201610S3R3MST CMLW201610S6R8MST CMLW201610S4R7MST Rev.01 Page 4 of 5 www.cybermaxtech.com.cn CMLW201610S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW201610S100MST CMLW201610S150MST CMLW201610S220MST CMLW201610S180MST Rev.01 Page 5 of 5 www.cybermaxtech.com.cn
CMLW201610S100MST
1. 物料型号:CMLW201610S Series,提供不同电感值的型号,例如2.2μH、10μH等。
2. 器件简介: - 该系列电感采用磁性树脂屏蔽结构,可大幅降低噪音。 - 铁氧体核心上的金属化处理提供优异的抗冲击性和耐用性。 - 闭环磁路设计减少漏磁和电磁干扰(EMI)。 - 比同等尺寸的传统电感有30%的更高电流额定值。
3. 引脚分配:未明确提及,但从封装信息可推测可能为贴装型。
4. 参数特性: - 工作和存储温度范围:-25℃至+125℃(未包装的单个芯片)。 - 存储温度范围(包装条件):-10℃至+40℃,相对湿度70%(最大)。
5. 功能详解: - 电感值从0.47μH到220μH不等,具有不同的公差。 - DC电阻(DCR)和饱和电流(Isat)的具体数值随型号而异。 - 热额定电流(Irms)定义为导致从20°C环境温度上升40°C的DC电流。
6. 应用信息: - LED照明、移动设备、平板电视、蓝光录像机、机顶盒、笔记本电脑、桌面计算机、服务器、图形卡、便携式游戏设备、个人导航系统、个人多媒体设备、汽车系统、电信基站等。
7. 封装信息: - 尺寸:2.0mm x 1.6mm x 1.0mm(最大值)。 - 封装:胶带载体封装。
