X3S027000BA1H-U
X3S027000BA1H-U
    HELE(加高电子)
    SMD3225_4P
    无源晶振 27MHz ±10ppm 10pF 50Ω -30℃~+85℃
X3S027000BA1H-U 数据手册
SPECIFICATIONS FOR APPROVAL GP X3S027000BA1H-U Customer Part No. HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: HSX321S / 27.000MHz EOS-970245-3 Sample Order No: CRYSTAL 2009/07/21 Date: Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號 2 樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN (R.O.C.) TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄縣大寮鄉大發工業區華東路 39 號 NO. 39, HWA DONG RD., TA FA IND. DIST., TA LIAO KAOHSIUNG HSIEN 831, TAIWAN, R.O.C. TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-7309272 / 7309262 FAX: 0755-7309755 TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 1 HSX321S SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION........... 3 2. MARKING & DIMENSIONS................... 4 3. INSIDE STRUCTURE...................... 5 4. EMBOSS CARRIER TAPE&REEL................ a. DIMENSIONS OF CARRIER TAPE............... 6 b. DIMENSIONS OF REEL................... 6-7 c. STORAGE CONDITION................... 7 d. STANDARD PACKING QUANTITY................... 7 e. MATERIAL OF TAPE..................... 7 f. LABEL CONTENTS...................... 7 g. TAPING DIMENSION..................... 8 h. JOINT OF TAPE....................... 8 i. RELEASE STRENGHT OF COVER TAPE............ 8 5. MECHANICAL PERFORMANOE................. 9 6. ENVIRONMENTAL PERFORMANOE............... 9 7. SUPPLRMENT........................ 10-11 8. FLOW CHARD......................... 12 9. Environmental Workload Chemical Substance Components List. 13 10. TEST DATA.......................... Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 27.000000MHz 2. Holder type : HSX321S 3. Frequency tolerance: +/-10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 60 ohms Max. / SERIES 5. Storage temperature range: -40 deg.C To +85 deg.C 6. Operable temperature range: -20 deg.C To +70 deg.C 7. Temperature drift: +/-10 ppm 8. Loading capacitance (CL) : -20 deg.C To +70deg.C 10.0 pF +/- 0.2 pF 9. Drive level: 10 uW +/- 2 uW 10. Shunt Capacitance: 2.0 pF Max 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in S&A 250B ,HP/E5100A 14. Shocking : Dropping from 50 cm height 3 times on firm wood Variation : Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/- 5 ppm/Year 16. Holder HSX321S Seam type 17.Dimensions and marking Refer to page.4 18.Emboss carrier tape & reel Refer to page.6 and page.7 19.Note: Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 3 2. HSX321S MARKING & DIMENSIONS *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz Æ 14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (The last digit of the year) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-1). Marking : Laser marking. (Table-1) Jan. A Feb. B Mar. C Apr. D May. E Jun. F Jul. G Aug. H Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY Sep. J Oct. K Dec. M TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS Nov. L CORP. 0 4 3. INSIDE STRUCTURE ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metallized Pad: W Ni Plating Au Plating (2) Lid : Fe- Ni -Co (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin Adhesive bonding: upper & lower bonding/lower bonding only (6) Electrode Cr+Ag (7) PAD Alumina Ceramic (W. Ni. Au) (8) Kovaring: Fe-Ni-Co Alloy The use prohibition chemistry substance of Table 1 of DHE-0204-1 (QA-QM-08) is not included in this item. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 5 4. HSX321S EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ178+1/-1 Inner Width W1 9.0+/-0.3 Outer Width W2 Out Line diameter B 11.5+/-0.2 ψ60+1.0/-0.0 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13+/-0.5 E 2.5+0.5/-0 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS Conductive Polyester f.) Label contents .The type of product .Our specification No. .Your Part No. .Lot No. .Nominal Frequency .Quantity .Our Company Name Sticks label for every reel. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 8 5. Mechanical Performance Specifications Code Item Test Methods 1 Natural Drop 2 Vibration 3 Sealing Tightness 4 Solderability Drop 3 times from the height of 50cm onto min. 30mm thickness hard wooden board. Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z 3 axes, Duration of 2 hours to each axis. Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. – Fine Leakage. After applying ROSIN Flux, dipping in solder bath at 245deg.C+/-5deg.C for 3+/-0.5 sec. 6. 2 3 4 5 A --B Environment Performance Item 1 A Specifications Code Test Methods Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours. Back to room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. +85deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C (30min) ↔ +85deg.C +/-2deg.C (30min) 25 cycles. Back to the room temperature first, then in 1~2 hours, the component shall be checked. FC-70(the boiling point:+215℃)Vapor for 30 sec Back to the room temperature first, then in 1~2 hours, the component shall be checked. Humidity Storage in Low Temperature Storage in High Temperature Temperature cycles VPS A A A A A Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test B More than 90% of lead shall be covered by new solder. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 9 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 10 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity ,which may cause put solderbility. No direct Sunlight, No dew as well. Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 11 8. Flow Chard LID BASE BLANK 1 INCOMING INSPECTION 5 INCOMING INSPECTION 3 INCOMING INSPECTION 2 LID CLEANING 6 CLEANING BEFORE ETCHING 4 BASE CLEANING & DRY 7 ETCHING 8 FREQ SORTING 9 CLEANING BEFORE BASE PLATING 10 FLASH ETCHING 11 BASE PLATING ($) 12 BLANK ASS'Y 13 ADHESIVE CURING 14 BONDING CHECK ($) 15 PARTIAL PLATING 16 MIDDLE CHECK ($) 17 ANNEALING IN HIGH VACUUM 18 APPEARANCE CHECK BEFORE SEALING (C) 28 19 SEALING(SEAM SEAL) 29 20 OVER DRIVER 30 21 REFLOW 22 AGING 31 REFLOW (C) Te mp. Characte ristics Che ck (C) 23 CF INSPECTION(C) 33 TAPING 24 REFLOW (C) 34 APPEARANCE CHECK OF TAPING 35 OUTGOING INSPECTION 25 MARKING+ VISUAL+ INSPECTION 26 LEAK CHECK Ⅰ (AIR LEAK) ($) 27 LEAK CHECK II (PRESSURIZE OF HE LEAK ) 36 Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare C. L. WANG U. F. CHEN OUTGOING PACKING (C): SPECIAL APPORTIONMENT Tittle HSX321S HARMONY FINAL CHECK($) (C) FINAL CHECK($) 32 SHIPPING 2009/07/21 F. S. TSAI LEAK CHECK II (HE LEAK CHECK) ($) ($): SPECIAL CHARACTERISTICS TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 12 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX321S PERCENTAGE Chemical Substance Components 19(mg) ppm Si 0.0437 2,300 Au 0.1463 7,700 Co & Co Compound 1.1286 59,400 Mo & Mo Compound 0.0380 2,000 Ag 0.3952 20,800 Cu 0.1102 5,800 Cr & Cr Compound 0.0380 2,000 Al 4.7234 248,600 Mn & Mn Compound 0.0228 1,200 W & W Compound 0.1843 9,700 Ni & Ni Compound 2.8424 149,600 Fe 3.8437 202,300 Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 13 REV. DATE REASON No. 0 2009/07/21 New CONTENTS Tittle HSX321S Country of origin Date Spec. No. QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2009/07/21 F. S. TSAI C. L. WANG U. F. CHEN HARMONY TAIWAN FACTORY THAILAND FACTORY Rev. Page X3S027000BA1H-U ELECTRONICS CORP. 0 14
X3S027000BA1H-U 价格&库存
很抱歉,暂时无法提供与“X3S027000BA1H-U”相匹配的价格&库存,您可以联系我们找货
X3S027000BA1H-U
    • 5+0.81443
    • 50+0.79629
    • 150+0.78419
    库存:5
