SLO252012FR47MTT
SLO252012FR47MTT
    SUNLTECH(顺磁)
    功率电感 SMD
SLO252012FR47MTT 数据手册
SLO-F Series SMD Molding Power Inductor ◆ Features Pb 、Magnetically shielded construction, low DC resistance; 2、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 1 ◆ Applications 、Smart phone、MID; 2、Hard disk of ultrabook; 3、LTE module; 4、Portable device; 5、Portable gaming devices, personal navigation systems; 6、personal multimedia devices; 1 ◆ Lead Free Part Numbering SLO (1) 252012 F 2R2 M T T (2) (3) (4) (5) (6) (7) (1) Series Type (2) Dimension :L X W X H (3) Material Code : ; (4) Inductance R68=0.68μH 2R2=2.2μH : ± (5) Inductance Tolerance M= 20%, N=±30% (6) Company Code (7) Packaging packed in embossed carrier tape : ◆ Dimensions Rev.01 Recommended Land Patterns A (mm) B (mm) E (mm) 0.8 2.05 1.65 Series L (mm) W (mm) C (mm) F (mm) SLO201610F SLO252010F 2.0±0.1 1.6±0.1 1.0 Max 0.5±0.3 2.5±0.2 2.0±0.2 1.0 Max 0.5±0.3 1.2 2.8 2.0 SLO252012F 2.5±0.2 2.0±0.2 1.2 Max 0.5±0.3 1.2 2.8 2.0 Page 1 of 4 www.sunltech.com SLO-F Series ◆ Specification Part Number μ INDUCTANCE Lo( H) Ω Rdc (m ) Typ. Max Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) SLO201610F SLO201610FR24MTT 0.24±20% 16 22 1MHz/1.0V 4.60 5.50 SLO201610FR33MTT 0.33±20% 22 31 1MHz/1.0V 3.70 5.15 SLO201610FR47MTT 0.47±20% 33 40 1MHz/1.0V 3.26 3.81 SLO201610FR68MTT 0.68±20% 41 49 1MHz/1.0V 3.15 3.38 SLO201610F1R0MTT 1.0±20% 60 69 1MHz/1.0V 2.56 2.73 SLO201610F1R5MTT 1.5±20% 113 128 1MHz/1.0V 1.79 2.45 SLO201610F2R2MTT 2.2±20% 135 150 1MHz/1.0V 1.68 1.80 SLO201610F3R3MTT 3.3±20% 210 254 1MHz/1.0V 1.33 1.34 SLO201610F4R7MTT 4.7±20% 308 376 1MHz/1.0V 1.07 1.24 SLO252010FR33MTT 0.33±20% 20 27 1MHz/1.0V 4.30 6.50 SLO252010FR47MTT 0.47±20% 25 33 1MHz/1.0V 3.60 4.90 SLO252010FR68MTT 0.68±20% 35 46 1MHz/1.0V 3.20 4.10 SLO252010F1R0MTT 1.0±20% 44 55 1MHz/1.0V 2.70 3.46 SLO252010F1R0MTT 1.5±20% 75 92 1MHz/1.0V 2.30 2.46 SLO252010F2R2MTT 2.2±20% 98 120 1MHz/1.0V 1.73 2.27 SLO252010F4R7MTT 4.7±20% 210 276 1MHz/1.0V 1.22 1.69 SLO252012FR47MTT 0.47±20% 19 27 1MHz/1.0V 4.22 5.10 SLO252012FR68MTT 0.68±20% 27 36 1MHz/1.0V 3.50 4.73 SLO252012F1R0MTT 1.0±20% 39 50 1MHz/1.0V 3.29 4.27 SLO252012F1R5MTT 1.5±20% 62 78 1MHz/1.0V 2.39 3.17 SLO252012F2R2MTT 2.2±20% 81 99 1MHz/1.0V 2.27 2.85 SLO252012F4R7MTT 4.7±20% 193 237 1MHz/1.0V 1.55 1.73 SLO252010F SLO252012F NOTES: 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -40 to +125 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ℃ Rev.01 △ ℃ ℃ ℃ ℃ Page 2 of 4 www.sunltech.com SLO-F Series ◆ Wave Soldering ◆ Hand soldering Rev.01 Page 3 of 4 www.sunltech.com SLO-F Series ◆ Reliability Mechanical ℃~125℃ -40℃~125℃ -40 Rev.01 Page 4 of 4 www.sunltech.com
SLO252012FR47MTT 价格&库存
很抱歉,暂时无法提供与“SLO252012FR47MTT”相匹配的价格&库存,您可以联系我们找货
