MHCI06020-1R5M-R8A
MHCI06020-1R5M-R8A
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
MHCI06020-1R5M-R8A 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 華勤 Customer: Customer P/N: Drawing No: Quantity: X Pcs. Date : 2017/12/12 MHCI06020-1R5M-R8A Chilisin P/N: SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com http://www.chilisin.com Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com 奇力新電子(河南)有限公司 蘇州奇益新電子有限公司 Chilisin Electronics (Henan) Co., Ltd. XiuWu Xian, industry gathering area JiaoZuo, Henan China Postal Code:454350 TEL:+86-391-717-0682 FAX:+86-391-717-0666 Drawn by 吳韋邑 Wayne.Wu SUZHOU QI YIXIN Electronics Co., Ltd. Co.No 179 chang jiang Road New District.Suzhou.China Postal Code:215129 TEL:+86-512-6841-2350 FAX:+86-512-6841-2356 E-mail:suzhou@chilisin.com Checked by 吳韋邑 Wayne.Wu Approved by 鍾瑞民 jacky.chung MHCI06020 Series Specification 1 Scope: This specification applies to Large current and Low Loss SMD Power INDUCTOR 2 Part Numbering: 3 Rating: Operating Temperature: - 55°C ~ 125°C (Including self - temperature rise) Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max. 4 Marking: Ex : MHCI06020-1R5M-R8A Marking : 1R5 Marking color : Black 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35℃) Ordinary Humidity(25 to 85% RH) In case of doubt 20 to 30℃ 50 to 80 %RH MHCI06020 Series Specification 6 Configuration and Dimensions: Dimensions in mm TYPE MHCI06020 A 6.6 ± 0.2 B 6.95 ± 0.35 C 1.8 ± 0.2 D 3.0 ± 0.3 F 1.6 ± 0.5 7 Electrical Characteristics: Part No. MHCI06020-1R5M-R8A Inductance (uH ) Tolerance (±%) Test Freq. Irms(A) Typ Isat(A) Typ RDC(mΩ) Max Marking 1.5 20 100kHz,0.5V 9 12 20 1R5 Note: 1.Operating temperature range -55℃~125℃(Including self - temperature rise) 2.Isat for Inductance drop 30% from its value without current. 3.Irms for a 40℃ temperature rise from 25℃ ambient. 4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 5.Absolute maximum voltage 30VDC MHCI06020 Series Specification 8 MHCI06020 Series 8.1 Construction: 8.2 Material List: MHCI06020 Series Specification 9 PACKAGING 9.1 Packaging -Cover tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity TYPE PCS/REEL MHCI06020 1000 9.3 Reel Dimensions Dimensions in mm TYPE A MHCI06020 330 B C D 100 13 16 MHCI06020 Series Specification 9 PACKAGING 9.4 Tape Dimensions in mm TYPE A0 B0 K0 D E W P P0 P2 MHCI06020 6.9 7.6 2.4 1.55 1.75 16 12 4 2 10 Recommended Pattern Dimensions in mm TYPE A(mm) MHCI06020 3.5 B(mm) C(mm) 6.05 2.35 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. MHCI06020 Series Specification 12 Graph:
MHCI06020-1R5M-R8A 价格&库存
很抱歉,暂时无法提供与“MHCI06020-1R5M-R8A”相匹配的价格&库存,您可以联系我们找货
MHCI06020-1R5M-R8A
    • 1+0.62532
    • 10+0.36720
    • 30+0.17280
    • 100+0.15984
    • 500+0.15444
    • 1000+0.15012
    库存:921
