承 認
書
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N
PART NO:
DESCRIPTION:
PRODUCTS NO:
PRODUCTS REV:
DATE:
鹿鸣
SMD POWER INDUCTORS
CYSCM4520TL-142
1
2018-7-20
PURCHASER CONFIRMED
REMARK
PROVIDER ENGINEER DEPT.
APPROVAL BY
CHECK BY
DRAWN BY
chenlinli
誠陽實業有限公司
TAIWAN CHENG YANG COMPONENT CORP
TAIPEI OFFICE
2F-1, NO. 176, Chine-Yi Road., Zhonghe
TAIWAN(R.O.C)
新北市中和區建一路176號2樓之一
District, New Taipei City,
POSTAL CODE: 23500
TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 Email:h21803@ms29.hinet.net
寶誠電子有限公司
CHINA FACTORY
ZHUHAI BAO CHENG ELECTRONICSCO.,LTD
Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong
Province, CHINA
中國廣東省珠海市塘家灣鎮官塘工業區
POSTAL CODE: 519085
TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail:
baocheng@baocheng.biz
昆山誠陽電子有限公司
CHINA FACTORY
KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP
Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province,
江蘇省昆山市高科技工業園區強安路38號
China
POSTAL CODE: 215300
TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw
REVISION NOTES
NO.
Date
Description of Revision
1
2018-7-20
首次送樣
ROHS Compliant
TEST DATA
DIMENSION&ELECTRIC CHARACTER
CUSTOMER:
CUSTOMER :
鹿鸣
PART NO.:
SMD INDUCTOR
SERIES NO:
CYSCM4520TL-142
UNIT:mm
EXTERNAL DIMENSIONS
2R2
RECOMMEND LAND PATTERN DIMENSIONS
A
4.7±0.5
B
4.5±0.5
C
2.2MAX
D
2.7REF
E
0.75REF
F
1.258REF
G
1.0REF
a
1.75
b
2.00
c
1.75
d
0.90
Part NO.
Impedance
(Ω)
DCR
(mΩ)
Rated Current
(A)
Rated Voltage
(V)
Insulation
Resistance
(MΩ)
CYSCM4520TL-142
950MIN
81MAX
1.7MAX
50MAX
10 MIN
NOTE:
Operating temperature:‘-40℃~+125℃
storage : 温度:0℃~+40℃ 湿度:RH10%~70%
APPROVED BY: Vincent
CHECKED BY: Yasir
DRAWN BY: chenlinli
Rohs Compliant
TEST DATA
CUSTOMER:
CUSTOMER :
鹿鸣
PART NO.:
SMD INDUCTOR
SERIES NO:
CYSCM4520TL-142
APPROVED BY
CHECKED BY
PREPARED BY
Vincent
Yasir
chenlinli
ROHS Compliant
TEST DATA
CUSTOMER:
CUSTOMER :
鹿鸣
PART NO.:
SMD INDUCTOR
SERIES NO:
CYSCM4520TL-142
APPROVED BY
CHECKED BY
PREPARED BY
Vincent
Yasir
chenlinli
■GENERAL CHARACTERISTICS
page.1
Operation Temperature
-40℃ to +125℃ (Includes temperature when the coil is heated)
External Appearance
On visual inspection, the coil has no external defects.
More than 90% of terminal electrode should be covered with solder.
l After fluxing, component shall be dipped in a melted.
Solder Ability Test
dipped in a melted.
Solder:bath at 235℃±5℃ for 5 ± 0.5senonds
1.Components should have not evidence of electrical and mechanical damage.
2.Inductance: within±10% of initial value.
3.Impedance: within±10% of initial value.
Heat endurance of
Soldering
●Preheat:150±5℃ 60seconds.
●Solder temperature: 250±5℃.
●Flux: rosin.
●Dip time:10±0.5seconds.
After soldering of X,Y withstanding at below conditions .The terminal should not Peel
off. (Refer to figure at below)
Terminal Strength
Insulating Resistance
Dielectric Strength
VibrationTest
5N:60sec.
Over 100MΩ at 100V D.C. between coil and core.
No dielectric breakdown at 30V D.C. for 1 minute between coil and core.
Inductance deviation within +10% after vibration for 1 hour. In each of three
orientations at sweep vibration(10-~55-~10HZ)with 1.5mmP-P amplitudes
Inductance deviation within +10% after being dropped once with 981m/s2 (100G)
Drop test
shock Attitude upon a rubber block method shock testing machine, in three different
orientations
Application Notice/Handling
1. Storage Conditions
To maintain the solder ability of terminal electrodes:
(1) Temperature and humidity conditions: less than 40℃ and 70% RH.
(2) Products should be used within 6 months.
(3) The packaging material should be kept where no chlorine or sulfur exists in the air.
2. Handling
(1) Do not touch the electrodes(soldering terminals)with fingers as this may lead to deterioration of solderability.
(2) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(3) Bulk handling should ensure that abrasion and mechanical shock are minimized.
TEST
Required Characteristics
page.2
Test Method/Condition
1. No case deformation or change
in appearance
2. △L/L≦10%
High Temperature StorageTest 3. △Q/Q≦30%
4. △DCR/DCR≦10%
Reference documents:
MIL-STD-202G Method108A
Temperature:125℃±2℃ Time:96±2 hours.
Tested not less than 1 hour, nor more than 2
hours at room.
in appearance
2. △L/L≦10%
Low Temperature Storage Test 3. △Q/Q≦30%
4. △DCR/DCR≦10%
IEC 68-2-1A 6.1 6.2
Humidity Test
Temperature:-40℃±2℃ Time:96±2 hours.
hours at room.
in appearance
2. △L/L≦10%
3. △Q/Q≦30%
4. △DCR/DCR≦10%
MIL-STD-202G Method103B
Thermal Shock Test
1. Dry oven at a temperature of 40℃±2℃ for
96hours
2. Measurements At the end of this period
3. Exposure: Temperature: 40℃±2℃.
Humidity:93±2hoyrs.
4. Tested while the chamber.
5. Tested not less than 1 hour. Nor more than 2
hours at room temperature.
in appearance
2. △L/L≦10%
3. △Q/Q≦30%
4. △DCR/DCR≦10%
MIL-STD-202G Method107G
First–40℃ for 30 Minutes, last 125℃ for 30
Minutes as 1 cycle. Go through 20 cycles.
■Application Notice/Handling
(1) Temperature and humidity conditions : less than 40℃ and 70% RH.
(4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability
(5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(6) Bulk handling should ensure that abrasion and mechanical shock are minimized.
■THE CONDITION OF REFLOW(RECOMMENDATION)
TYPICAL WAVE SOLDER PROFILE FOR
LEADED AND
LEAD -FREE THROUGH-HOLE PACKAGES
IPC/JEDEC J-STD-020C, Figure 5-1
page.3
TYPICAL IR REFLOW PROFILE FOR LEADED AND
LEAD -FREE SURFACE MOUNT PACKAGES
很抱歉,暂时无法提供与“CYSCM4520FTL-142”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.77800
- 10+4.68720
- 30+4.13640
- 100+3.59640
- 500+3.27240
- 1000+3.09960
