Power Inductors
1. External Dimensions (Unit:m/m)
Type
A
B
C
D
E
F
a
b
c
Q’TY/Reel
ABG06A28
6.0±0.3
6.0±0.3
2.8Max
4.9Ref
1.65Ref
2.7Ref
2.4Ref
1.95Ref
5.2Ref
2000
2. Part Number Code
ABG
A
A:
B:
C:
D:
E:
F:
06
B
A
C
Series Name
Dimensions(mm)
Materials
Thickness(mm)
Tolerance
Inductance
28
D
M
E
151
F
Power Inductors
06:6.0x6.0
NO use
28:2.8 Max
M:±20%
151=150uH
3. Electrical Characteristics
Part Number
ABG06A28M151
Inductance Test Frequency DC Resistance
(µH)
(KHz)
(mΩ)±30%
150.0
100KHz/1V
800.0
Heat Rating
Current
Irms (A)
Saturation
Current
lsat (A)
0.35
0.35
Notes:
a. All test data is referenced to 25℃ ambient.
b. Operating Temperature Range-40℃ to +125℃.
c. Irms: DC current(A) that will cause an approximate△T of 40℃.
d. lsat :DC current(A) that will cause Lo to drop approximately 35%.
e. The part temperature(ambient + temp rise)should not exceed 125℃ under worst case operating
conditions. Circuit design,component placement, PWB trace size and thickness,airflow and other
cooling provisions all affect the part temperature,Part temperature should be verified in the end
application.
Http://www.coilank.com
E-mail:sales@coilank.com
Power Inductors
4. Test Data
ELECTRICAL CHARCTERISTIC
MECHANICAL DIMENSIONS
SPEC
L(uH)
DCR(mΩ)
Isat(uH)
A(mm)
B(mm)
C(mm)
D(mm)
TOL
150.0
800.0
6.0
6.0
2.8
4.9
NO
±20%
±30%
0.35A
(L0A-L0.35A)
/L0A≤35%
±0.3
±0.3
Max
Ref
1
152.8
869.8
136.5
6.02
6.03
2.72
OK
2
151.5
872.1
136.8
6.01
6.03
2.69
OK
3
148.2
871.4
132.9
6.02
6.06
2.70
OK
4
147.3
870.2
131.8
6.04
6.01
2.68
OK
5
150.4
873.6
134.7
6.02
6.04
2.71
OK
6
148.9
869.9
132.5
6.02
6.02
2.69
OK
7
151.1
872.3
135.7
6.03
6.03
2.72
OK
8
150.7
869.7
135.4
6.03
6.02
2.70
OK
9
148.6
870.6
132.1
6.00
6.05
2.71
OK
10
147.5
871.4
130.9
6.02
6.04
2.68
OK
Test Equipmets: IM3536,VR126,VR7210,Calipers
Curve:
40
128
32
96
24
64
16
32
8
Tenperature(℃)
Indutance(uH)
Inductance VS Temperature
160
L(uH)
0.2
0.3
0.4
Current(A)
0.5
ΔT(℃)
Power Inductors
5. Test and Measurement Procedures
5.1 Test Conditions
5.1.1 Unless otherwise specified, the standard atmospheric conditions for measurement/test as:
a. Ambient Temperature: 20±15℃
b. Relative Humidity: 65%±20%
c. Air Pressure: 86KPa to 106KPa
5.1.2 If any doubt on the results, measurements/tests should be made within the following limits:
a. Ambient Temperature: 20±2℃
b. Relative Humidity: 65%±5%
c. Air Pressure: 86KPa to 106Kpa
5.2 Visual Examination
a.
Inspection Equipment: 10X magnifier
5.3 Electrical Test
5.3.1 Inductance (L)
a. Refer to the third item.
b. Test equipment: IM3536 LCR meter or equivalent.
c. Test Frequency and Voltage: Refer to the third item.
5.3.2 Direct Current Resistance (DCR)
b. Test equipment: VR126 or equivalent.
5.3.3 Saturation Current (Isat)
b. Test equipment: Saturation current meter
c. Definition of saturation current (Isat): DC current at which the inductance drops approximate
35% from its value without current.
5.3.4 Temperature rise current (Irms)
b. Test equipment (see Fig.5.3.4-1): Electric Power, Electric current meter, Thermometer.
c. Measurement method (see Fig. 5.3.4-1):
1. Set test current to be 0mA.
2. Measure initial temperature of choke surface.
3. Gradually increase current and measure choke temperature for corresponding current.
4. Definition of Temperature rise current: DC current that causes the temperature rise (△T
=40°C) from 20°C ambient (see Fig. 5.3.4-2).
Fig.5.3.4-1
Fig.5.3.4-2
Power Inductors
5.4
Reliability Test
Items
Requirements
Test Methods and Remarks
No removal or split of the termination
or other defects shall occur.
①Solder the inductor to the testing jig (glass epoxy
board shown in Fig.5.4.1-1) using eutectic solder.
Then applya force in the direction of the arrow.
②17.7N force.
③Keep time: 5s
5.4.1
Terminal
Strength
Fig.5.4.1-1
No visible mechanical damage.
① Solder the chip to the test jig (glass epoxy board)
using eutectic solder. Then apply a force in the
direction shown as Fig.5.4.2-1.
② Flexure: 2mm
③ Pressurizing Speed: 0.5mm/sec
④ Keep time: 30±1s
⑤ Test board size: 100X40X1.0
5.4.2
Resistance to
Flexure
Fig.5.4.2-1.
5.4.3
Vibration
5.4.4
Temperature
coefficient
5.4.5
Solderability
① No visible mechanical damage.
② Inductance change: Within ±10%
Inductance change: Within ±20%
90% or more of electrode area shall be
Coated by new solder.
①Solder the chip to the testing jig (glass epoxy board
shown as the following figure) using eutectic solder.
②Thechip shall be subjected to a simple harmonic
motion having total amplitude of 1.5mm, the
frequency being varied uniformly between the
approximate limits of 10 and 55 Hz.
③The frequency range from 10 to 55 Hz and return to
10Hz shall be traversed in approximately 1 minute.
This motion shall be applied for a period of 2 hours
in each 3mutually perpendicular directions (total of
6 hours).
①Temperature: -40℃~+125℃
②With a reference value of +20℃, change rate shall
be calculated
①The test samples shall be dipped in flux, and then
immersed in molten solder.
②Solder temperature: 245±5℃
③Duration: 5±1 sec.
④Solder: Sn/3.0Ag/0.5Cu
⑤Flux: 25% resin and 75% ethanol in weight
⑥Immersion depth: all sides of mounting terminal
shall be immersed
Power Inductors
Items
Requirements
①Re-flowing Profile: Please refer to Fig. 5.4.6-1
②Test board thickness: 1.0mm
③Test board material: glass epoxy resin
④The chip shall be stabilized at normal condition for
1~2hours before measuring
5.4.6
Resistance to
Soldering Heat
①No visible mechanical damage.
②Inductance change: Within ±10%
Fig. 5.4.6-1
①Temperature and time: -40±3℃ for 30±3
min→125℃ for 30±3min
②Transforming interval: Max. 20 sec
③Tested cycle: 100 cycles
1~2 hours before measuring
5.4.7
Thermal Shock
5.4.8
Resistance to Low
Temperature
5.4.9
Resistance to High
Temperature
5.4.10
Damp Heat
5.4.11
Loading Under
Damp Heat
5.4.12
Loading at High
Temperature
①No mechanical damage.
①Temperature: -40±3℃
②Duration: 1000±24 hours
③The chip shall be stabilized at normal condition for
①Temperature: 125±2℃
1~2 hours before measuring.
①Temperature: 85±2℃
②Humidity: 80% to 85%RH
③Duration: 1000±24 hours
①Temperature: 85±2℃
②Humidity: 80% to 85% RH
③Applied current: Irms
④Duration: 1000±24 hours
⑤The chip shall be stabilized at normal condition for
①Temperature: 85±2℃
②Applied current: Irms
Power Inductors
6. Packaging, Storage
6.1 Tape and Reel Packaging Dimensions
6.1 .1 Taping Dimensions (Unit: mm)
Please refer to Fig. 6.1.1-1
Fig. 6.1.1-1
TYPE
A0
ABG06A28
6.4±0.1
B0
W
E
F
6.4±0.1 16.0±0.3 1.75±0.1 7.5±0.1
P0
P1
P2
D0
T
K0
4.0±0.1
8.0±0.1
2.0±0.1
1.5±0.1
0.4±0.1
3.2±0.1
6.1.2 Direction of rolling
Please refer to Fig. 6.1.2-1.
Fig. 6.1.2-1.
Power Inductors
6.1.3 Reel Dimensions (Unit: mm)
Please refer to Fig. 6.1.3-1.
Fig. 6.1.3-1.
6.2
TYPE
A
B
C
D
ABG06A28
16.5±2.0
330.0±2.0
100.0±2.0
20.5±2.0
Packaging
6.2.1 The inner box specification: 350*340*40MM
Packing quantity: 4000PCS/ box
Bubble bag: 37*45CM
Job description: putting the air bubble bag products placed
inside the box, sealed with scotch tape
6.2.2 The outside box specification: 370*360*255MM
Packing quantity: 20000PCS/ box
Job description: will be outside the box bottom
sealed, inner box into the box.
a. With transparent tape sealed box at the top
b. The specified location with a box labels in the outer box.
c. If the mantissa box under a FCL with inner box or filling full
Power Inductors
6.3 Storage
a.To maintain the solderability of terminal electrodes and to keep the packing material in good
condition, temperature and humidity in the storage area should be controlled.
b. Recommended conditions: -10℃~40℃, 70%RH (Max.)
c.The ambient temperature must be kept below 30℃.Even under ideal storage conditions,
solderability of products electrodes may decrease as time passes. For this reason, product should
be used with one year from the time of delivery.
d. In case of storage over 6 months, solderability shall be checked before actual usage.
7. Recommended Soldering Technologies
7.1 Re-flowing Profile:
△ 1~2 ℃/sec. Ramp
△ Pre-heating: 150~190℃/90±30 sec.
△ Time above 240℃: 20~40sec
△ Peak temperature: 255℃ Max./5sec;
△ Solder paste: Sn/3.0Ag/0.5Cu
△ Max.2 times for Re-flowing
7.2 Iron Soldering Profile:
△ Iron soldering power: Max.30W
△ Pre-heating: 150℃/60sec.
△ Soldering Tip temperature: 350℃Max.
△ Soldering time: 3sec Max.
△ Max.1 times for iron soldering
[Note: Take care not to apply the tip of the
soldering iron to the]
很抱歉,暂时无法提供与“ABG06A28M151”相匹配的价格&库存,您可以联系我们找货
