C82473J3AD8R8LC
C82473J3AD8R8LC
    SRD(圣融达)
    插件,P=15mm
    薄膜电容 径向
C82473J3AD8R8LC 数据手册
深圳圣融达科技有限公司 SHENZHEN SINCERITY TECHNOLOGY CO., LTD. 产品技术规格承认书 Product Specification 客 户 名 : Customer: 品 名 立创商城 : MMKP-82 型双面金属化聚丙烯膜电容器(盒式) D e s c r i p t i o n : MMKP-82 Series Double sided metallized polypropylene film capacitor (Box) 圣融达料号: Srd P/N: C82473J3AD8R8LC 客 户 料 号 : Customers P/N: 品 牌 : B r a n d s : 作 成 日 期 : Issue Date: 圣融达(SRD) May.27.2021 客户承认 Customer's Approval 接收 receive 审核 check 批准 approve 圣融达承认 Sincerity Approval 制作 inspet 审核 check 批准 approve 伽文暖 电话 Tel: +86-755-84251666 84251168 手机 Cell:+86-13534221536 邮箱 Email:sales@srdkj.com,网址 Http://www.srdkj.com 地址:中国广东省深圳市龙岗区平湖街道新力路 36 号圣融达科技园 Add: No. 36, Xinli Rd., Pinghu Street, Longgang District, Shenzhen 518111 Guangdong, China * 本规格书归深圳圣融达科技有限公司版权所有,未经许可,不得复制或提供给第三方。 请贵 公司承认此规格书后并及时回传该规格书电子档文件或者复印件,作为本公司合同技术评审依据。 * This specification is the copyright of Shenzhen Sincerity technology co., ltd. it cannot be copied or provided to a third party without permission. Please acknowledge the specification book and send back the electronic document or copy of the specification in time as the basis for the technical review of the contract. 第 1 页/共 6 页 MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series Double sided metallized polypropylene film capacitor(Box) MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series metallized polypropylene film capacitor 1、产品特点及主要用途 Product characteristics and application 该系列电容器采用聚丙烯膜作介质,用真空蒸发方法将铝沉积在薄膜正反面上作电极卷绕而成;该系列电容 器采用环氧树脂真空灌封,塑壳封装型号,高频损耗小,内部温升小、自愈性好、可靠性高,适用于高压高频脉 冲电路中,变频器的谐振电路中,LED 驱动高效电路和开关电源高效电路中,吸收和 SCR 整流电路中。 This series capacitors use polypropylene film as medium, vacuum deposition method is used to deposit aluminum on the front and back of the film for electrode winding; the series of capacitors are vacuum potted epoxy resin, molded case type. low loss, small internal temperature rise, good self-healing, high reliability, suitable for high-voltage high-frequency pulse circuit, in the resonant circuit of the inverter, led drive high-efficiency circuit and switching power supply high-efficiency circuit, Absorption and SCR rectifier circuits. 2、外形图 Outline Drawing 标志示例 Marking Example MMKP-82 473J1000V www.srdkj.com 3、引线加工图形 Lead forming shape (mm) 图号 Drawing No.1 图号 Drawing No.2 图号 Drawing No.3 图号 Drawing No.4 4、技术参数 Specification 参照标准 Reference Standard GB/T 10190 工作温度范围 Operation Temperature Range -40℃~105℃ ((85~105℃ decrease factory 1.35%UR per ℃ for UR) 额定电压 Rated Voltage 450V,630V,1000V,1250V,1600V,2000V,3000V 电容量范围 Capacitance Range 0.001μF~1.0μF 电容量偏差 Capacitance Tolerance ±5%(J)、±10%(K)、±20%(M)(20℃, 1kHz) 耐电压 Voltage Proof 引线之间 Between Terminals 1.6UR(VDC),5s 绝缘电阻 Insulation Resistance CR≤0.33μF,IR≥30000 MΩ CR>0.33μF,τ≥10000MΩ·μF(20℃, 1min) UR≤500V,test voltage:100V, UR>500V,test voltage:500V 损耗角正切 Dissipation Factor tgδ≤0.0010(1kHz) 第 2 页/共 6 页 MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series Double sided metallized polypropylene film capacitor(Box) 5、产品代码及编写说明:Part number code rules6、产品代码及编写说明:Part number code rules C 8 2 1 0 4 J 2 J D 2 R 8 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 第 1~3 位 Digit 1 to 4 电容器型号代码 Series code C82=MMKP-82 ABC=AB×10CpF 电容量偏差代码 Capacitance tolerance code 第 7 位 Digit 7 标称电容量代码 Rated capacitance code 第 4~6 位 Digit 4 to 6 Example103=10×103pF=0.01μF 额定电压代码 Rated voltage code 第 8~9 位 Digit 4 to 9 J=±5%,K=±10%,M=±20% 2J=630Vdc,3A=1000Vdc,3C=1600Vdc,3D=2000Vdc 第 10~11 位 Digit 10 to 11 外形尺寸代码 Dimension code 第 12 位 Digit 12 商标颜色 Trademark color 第 13 位 Digit 13 线径代码 Line diameter code 第 14~15 位 Digit 14 to 15 特殊码 Special code 6、产品尺寸及性能参数:Product Dimension and Characteristic Data 圣融达料号 客户料号 额定 电压 Rated SRD P/N Customer P/N C82473J3AD8R8A0 Voltage 1000VDC 标称容 量 Cap 容量偏差 Tolerance 0.047uF J(±5%) 备注: 外形尺寸(mm) Dimension(mm) W ±0.5 T ±0.5 H ±0.5 P ±0.5 d ±0.05 L ±0.5 18 11.2 19.2 15 0.8 3.5 切脚 7、品质保证(产品出厂检查)试验: Quality ensuring test (before shipment): 检查项目(每批) Inspection item(each batch) 检查水平IL 技术要求 GB 2828一次正常抽样方案 标志正确,清晰可读,无明显损伤,针孔气泡,引出 线无严重损伤。Marking is correct, clearly readable, No 外观检查 Appearance inspection obvious damage, pinhole bubbles, There was no serious damage to the lead. 外形尺寸 Dimensions 接收质量限AQL Ⅱ 1.0 按本文件第4条Refer to item 4 Ⅱ 0.25* 按本文件第8.1条Refer to item8.1 S-3 1.0 按本文件第6条Refer to item 6 电容量 Capacitance 损耗角正切 Dissipation Factor 耐电压 Dielectric strength 绝缘电阻 Insulation resistance 可焊性 Solder ability *:耐电压不允许失效Voltage proof failure is not allowed 8、试验方法及性能 Test Method And Performance No. 项目 project 性能要求 Performance requirements 试验方法(GB/T 10190) experiment method 第 3 页/共 6 页 MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series Double sided metallized polypropylene film capacitor(Box) 8.1 上锡面积 90%以上 More than 90% of the tin area 初始测量 Initial measurement 电容量 capacitance 损耗角正切 DF:CR≤1μF,Test frequency:10kHz CR>1μF, Test frequency:1kHz 引出端强度 Terminal strength 外观无可见损伤 There shall be no visible damage 8.2 耐焊接热 Resistance to solder heat 最后测量 Final measurement 初始测量 Initial measurement 温度快速变化 Rapid temperature change 振动 vibration 8.3 方法 1method 1 焊料温度 Solder temperature:245±5℃ 浸渍时间 Immersion time:2.0±0.5s 可焊性 Solder ability 碰撞 Bump 最后测量 Final measurement 拉力试验 Ual: 拉力: 0.51μF Δtgδ≤0.004 (1kHz) 电容量 capacitance 损耗角正切 DF:CR≤1μF,Test frequency:10kHz CR>1μF, Test frequency:1kHz 外观无可见损伤 There shall be no visible damage TA=-40℃, TB=+105℃ 5 次循环,持续时间:t=30min 5 cycles, duration: t=30min 外观无可见损伤 There shall be no visible damage 振幅 0.75mm 或加速度 98m/s2(取严酷度较小者), 频率 10~500Hz 三个方向,每个方向 2h, 共 6h Amplitude 0.75mm or acceleration 98m/s2 (slightly less severe), frequency 10~500Hz three sides Direction, 2h in each direction, total 6h 4000 次,加速度 400 m/s2,脉冲持续时间:6ms 4000 times, acceleration 400 m / s2 , Pulse duration: 6ms 观无可见损伤 There shall be no visible damage 电容量变化:△C/C≤±3% 损耗角正切增加: CR≤1μF ≤0.004 (10kHz) CR>1μF ≤0.004 (1kHz) 绝缘电阻 IR:≥额定值的 50% Capacitance: △C/C≤±3% (relative to the initial value) Increase of tgδ:CR≤1μF Δtgδ≤0.004 (10kHz) CR>1μF Δtgδ≤0.004 (1kHz) I.R.: ≥50%of the rated value 第 4 页/共 6 页 MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series Double sided metallized polypropylene film capacitor(Box) NO. 项目 project 性能要求 Performance requirements 初始测量 Initial measurement 气候顺序 climate sequence 8.4 最后测量 Final measurement 8.5 稳态湿热 Damp heat steady state 8.6 耐久性 Endurance 试验方法(GB/T 10190) Test method 按 8.2 或 8.3 的最终测量 Refer to item 10.2 and 10.3 final measurement 干热 Dry heat +105℃,16h 循环湿热 Damp heat, Cyclic 试验 Db,严酷度 b,第一次循环 Test Db, severity b, First cycle 寒冷 cold -40℃,2h 循环湿热 Damp heat, Cyclic 外观无可见损伤,标志清晰, 电容量变化:ΔC/C≤5%, 损耗角正切增加:CR≤1μF ≤0.005 (10kHz) CR>1μF ≤0.005 (1kHz) 耐电压:UR,1min 无击穿或飞弧, 绝缘电阻 IR:≥额定值的 50% There shall be no visible damage, legible marking ΔC/C ≤5% (relative to the initial value) Increase of tgδ:CR≤1μF Δtgδ≤0.005 (10kHz) CR>1μF Δtgδ≤0.005 (1kHz) Voltage proof:Applying UR,1min no breakdown and flashover I.R.: ≥50%of the rated value 外观无可见损伤,标志清晰, 电容量变化:ΔC/C≤5%, 损耗角正切增加:Δtgδ≤0.002(1kHz), 耐电压:UR,1min 无击穿或飞弧, 绝缘电阻 IR:≥额定值的 50% There shall be no visible damage, legible marking ΔC/C ≤5% (relative to the initial value) Increase of tgδ:Δtgδ≤0.002(1kHz) Voltage proof:Applying UR,1min no breakdown and flashover I.R.: ≥50%of the rated value 外观无可见损伤,标志清晰, 电容量变化:ΔC/C≤5%, 损耗角正切增加:CR≤1μF ≤0.004 (10kHz) CR>1μF ≤0.004 (1kHz) 绝缘电阻 IR:≥额定值的 50% There shall be no visible damage, legible marking ΔC/C ≤5% (relative to the initial value) Increase of tgδ:CR≤1μF Δtgδ≤0.004 (10kHz) CR>1μF Δtgδ≤0.004 (1kHz) no breakdown and flashover I.R.: ≥50%of the rated value 试验 Db,严酷度 b,剩余循环 Test Db, severity b, the other cycles, 温度:40±2℃ 湿度:93(+2/-3)%RH 持续时间:21 天 Temperature: 40±2°C Humidity: 93 (+2/-3)% rh Duration: 21 days 105℃,1.25UR,1000h 第 5 页/共 6 页 MMKP-82 型双面金属化聚丙烯膜电容器(盒式) MMKP-82 Series Double sided metallized polypropylene film capacitor(Box) NO. 项目 project 性能要求 Performance requirements 试验方法(GB/T 10190) Test method 在 b,d,f 点上进行电容量测量: 在下限类别温度-40℃时的特性: 0(Cb-Cd)/Cd+3 在上限类别温度 105℃时的特性: -4.0(Cf-Cd)/Cd0 在 f 点上测量绝缘电阻: 8.7 随温度而定的特 性 Temperature characteristic 静态法,电容器依次保持在下述 每 个 温 度 : a.(20  2) ℃ , b.(-40  3) ℃ , d.(20  2) ℃ , f.(1052) ℃,g.(202) ℃ IR2500M CR≤0.33μF IR750s CR>0.33μF Measuring capacitance at test point b, d, f: Static method: The Capacitors Characteristic at lower category temperature -40˚C: should be kept at the following temperature in turn: 0(Cb-Cd)/Cd+3 a(20±2) ˚C, b(–40±3) ˚C, d(20±2) Characteristic at upper category temperature +105˚C: ˚C,f(105±2) ˚C, g(20±2) ˚C -4.0(Cf-Cd)/Cd0 I.R. (test at point f ): IR2500M IR750s 8.8 充电和放电 Charging discharging and CR≤0.33μF CR>0.33μF 电容量变化:ΔC/C≤5%, 损耗角正切增加:CR≤1μF ≤0.005 (10kHz) CR>1μF ≤0.005 (1kHz) ΔC/C ≤10% (relative to the initial value) Increase of tgδ:CR≤1μF Δtgδ≤0.005 (10kHz) CR>1μF Δtgδ≤0.005 (1kHz) Number of times: 10,000 times Charging duration: 0.5s , discharge duration: 0.5s Charging voltage is UR Disharging resistance: 220/(CR × dV/dt) or 2.2Ω(which is greater)CR is the rated capacitance (μF) 9、包装及运输要求 Packaging and transportation requirements 电容器以纸箱包装,应避免雨雪的直接淋浇和机械损伤,并保存在-10℃~+40℃温度下,相对湿度 75%以下, 应避免温度剧烈变化,阳光直射和腐蚀性气体,存放期不超出 12 个月。 Capacitors are packaged in Corrugated box, should be stored at temperatures ranging from - 10 to + 40 C, with relative humidity below 75%, drastic temperature changes, direct sunlight and corrosive gases should be avoided. Storage period should not exceed 12 months 第 6 页/共 6 页
C82473J3AD8R8LC
物料型号: - 产品名称:MMKP-82 型双面金属化聚丙烯膜电容器(盒式) - 品牌:圣融达(SRD) - 圣融达料号:C82473J3AD8R8LC
器件简介: - 该系列电容器采用聚丙烯膜作介质,用真空蒸发方法将铝沉积在薄膜正反面上作电极卷绕而成。 - 采用环氧树脂真空灌封,塑壳封装型号。 - 特点:高频损耗小,内部温升小,自愈性好,可靠性高。 - 应用:适用于高压高频脉冲电路、变频器的谐振电路、LED驱动高效电路和开关电源高效电路、吸收和SCR整流电路中。
引脚分配: - 文档中未提供具体的引脚分配图或描述。
参数特性: - 工作温度范围:-40°C~105°C - 额定电压:450V, 630V, 1000V, 1250V, 1600V, 2000V, 3000V - 电容量范围:0.001pF~1.0F - 电容量偏差:±5%(J)、±10%(K)、±20%(M)(20°C,1kHz) - 耐电压:引线之间1.6UR (VDC),5s - 绝缘电阻:CR 0.33 F, IR≥30000 MΩ;CR>0.33F, t≥10000M-F(20°C, Imin) - 损耗角正切:tg ≤0.0010(1kHz)
功能详解: - 产品代码及编写说明:提供了电容器型号代码、标称电容量代码、电容量偏差代码、额定电压代码、外形尺寸代码、商标颜色、线径代码和特殊码的详细说明。
应用信息: - 电容器适用于高压高频脉冲电路、变频器的谐振电路、LED驱动高效电路和开关电源高效电路、吸收和SCR整流电路中。
封装信息: - 产品尺寸及性能参数:提供了圣融达料号、客户料号、额定电压、标称容、容量偏差、外形尺寸等信息。 - 品质保证(产品出厂检查)试验:包括外观检查、外形尺寸、电容量、损耗角正切、耐电压、绝缘电阻、可焊性等。
试验方法及性能: - 包括可焊性、初始测量、耐焊接热、温度快速变化、振动、碰撞、气候顺序、稳态湿热、耐久性、随温度而定的特性、充电和放电等测试方法和性能要求。
包装及运输要求: - 电容器以纸箱包装,应避免雨雪的直接淋浇和机械损伤,并保存在-10℃~+40℃温度下,相对湿度75%以下,应避免温度剧烈变化、阳光直射和腐蚀性气体,存放期不超出12个月。
C82473J3AD8R8LC 价格&库存
很抱歉,暂时无法提供与“C82473J3AD8R8LC”相匹配的价格&库存,您可以联系我们找货
