PBO5022-331MT
PBO5022-331MT
    FH(风华)
    SMD
    功率电感 SMD
PBO5022-331MT 数据手册
SMD POWER INDUCTORS PBO PBO SERIES SMD POWER INDUCTORS FEATURES High saturation current SMT type, suitable for solder reflow. APPLICATIONS , LCD , DC/DC Portable communication equipment,Notebook Computer LCD televisions, Power supply for VTRs DC/DC converters etc. HOW TO ORDER 3316 PBO M 150 (L Product Code T W T) ( (mm) H) 1R5 PBO PBO 3316 12.70 9.20 5022 18.20 14.10 Tolerance Packaging Style Inductance Dimensions 5.00 6.80 1.5 150 15 151 150 152 1500 J K L M N 5% 10% 15% 20% 30% T Tape & Reel DIMENSIONS PBO 5022 Marking Marking PBO 3316 RECOMMENDED LAND PATTERNS RECOMMENDED LAND PATTERNS (Unit) Part C B A PBO 3316 12.70 0.30 9.20 PBO 5022 18.20 0.30 14.10 E (typ.) F (typ.) G (typ.) H(typ.) I (typ.) J (typ.) 5.00 0.30 2.54 2.54 7.62 2.79 2.92 7.37 0.30 6.80 0.30 2.54 2.54 12.95 2.79 2.92 12.45 0.30 121 mm PBO3316 Series Part Number H Tolerance Test Freq. DCR( )Max Isat(A) Irms(A) PBO3316-1R0MT 1.0 20% 100kHz 0.011 9.00 6.80 PBO3316-1R5MT 1.5 20% 100kHz 0.012 8.00 6.40 PBO3316-2R2MT 2.2 20% 100kHz 0.015 7.00 6.10 PBO3316-3R3MT 3.3 20% 100kHz 0.018 6.40 5.40 PBO3316-4R7MT 4.7 20% 100kHz 0.022 5.40 4.80 PBO3316-6R8MT 6.8 20% 100kHz 0.027 4.60 4.40 PBO3316-100MT 10 20% 100kHz 0.038 3.80 3.90 PBO3316-120MT 12 20% 100kHz 0.055 3.50 3.30 PBO3316-150MT 15 20% 100kHz 0.060 3.00 3.10 PBO3316-220MT 22 20% 100kHz 0.085 2.60 2.70 PBO3316-330MT 33 20% 100kHz 0.110 2.00 2.10 PBO3316-390MT 39 20% 100kHz 0.150 1.80 1.90 PBO3316-470MT 47 20% 100kHz 0.170 1.60 1.80 PBO3316-680MT 68 20% 100kHz 0.210 1.40 1.50 PBO3316-820MT 82 10% 100kHz 0.310 1.24 1.35 PBO3316-101KT 100 10% 100kHz 0.330 1.20 1.30 PBO3316-151KT 150 10% 100kHz 0.480 1.00 1.00 PBO3316-221KT 220 10% 100kHz 0.800 0.80 0.80 PBO3316-331KT 330 10% 100kHz 1.020 0.60 0.60 PBO3316-471KT 470 10% 100kHz 1.270 0.50 0.50 PBO3316-681KT 680 10% 100kHz 2.020 0.40 0.40 PBO3316-102KT 1000 10% 100kHz 3.000 0.30 0.30 PBO3316-152KT 1500 10% 100kHz 5.780 0.25 0.18 PBO3316-332KT 3300 10% 100kHz 10.200 0.18 0.14 PBO3316-472KT 4700 10% 100kHz 15.900 0.15 0.12 Isat 10% Irms: 40 Isat 20 The DC current is that which cause a 10% inductance reduction from the initial value. Irms: The DC current is inductor surface temperature to rise by 40 122 ( Reference ambient temperature 20 ). SMD POWER INDUCTORS PBO5022 Series Part Number H Tolerance Test Freq. DCR( )Max Isat(A) Irms(A) PBO5022-1R0MT 1.0 20% 100kHz 0.009 20.00 8.60 PBO5022-1R5MT 1.5 20% 100kHz 0.012 18.00 8.00 PBO5022-2R2MT 2.2 20% 100kHz 0.014 16.00 7.10 PBO5022-3R3MT 3.3 20% 100kHz 0.018 14.00 6.20 PBO5022-4R2MT 4.2 20% 100kHz 0.019 13.00 6.00 PBO5022-4R7MT 4.7 20% 100kHz 0.019 13.00 6.00 PBO5022-5R6MT 5.6 20% 100kHz 0.020 12.00 5.30 PBO5022-7R8 T 7.8 20% 100kHz 0.017 11.00 4.50 PBO5022-100MT 10 20% 100kHz 0.031 10.00 4.30 PBO5022-150MT 15 20% 100kHz 0.036 8.00 4.00 PBO5022-220MT 22 20% 100kHz 0.047 7.00 3.50 PBO5022-250MT 25 20% 100kHz 0.066 5.50 3.00 PBO5022-330MT 33 20% 100kHz 0.066 5.50 3.00 PBO5022-470MT 47 20% 100kHz 0.086 4.50 2.60 PBO5022-680MT 68 20% 100kHz 0.130 3.50 2.30 PBO5022-101KT 100 10% 100kHz 0.190 3.00 1.80 PBO5022-151KT 150 10% 100kHz 0.300 2.60 1.50 PBO5022-221KT 220 10% 100kHz 0.380 2.40 1.20 PBO5022-331KT 330 10% 100kHz 0.560 1.90 1.00 PBO5022-471KT 470 10% 100kHz 0.850 1.40 0.82 PBO5022-561KT 560 10% 100kHz 0.980 1.30 0.76 PBO5022-681KT 680 10% 100kHz 1.190 1.20 0.72 PBO5022-102KT 1000 10% 100kHz 2.100 1.00 0.56 PBO5022-152KT 1500 10% 100kHz 3.450 0.80 0.48 PBO5022-103KT 10000 10% 100kHz 25.90 0.28 0.28 Isat 10% Irms: 40 Isat 20 The DC current is that which cause a 10% inductance reduction from the initial value. Irms: The DC current is inductor surface temperature to rise by 40 123 ( Reference ambient temperature 20 ).
PBO5022-331MT
物料型号:PBO系列功率电感
器件简介:PBO系列是SMD类型的贴片功率电感,具有高饱和电流,适合于表面贴装回流焊。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 规格尺寸:3316型号为12.70×9.20×5.00mm,5022型号为18.20×14.10×6.80mm。 - 感量范围:从1.5μH到4700μH。 - 公差:+5%,±15%,±20%,±30%。
功能详解: - 饱和电流(Isat):导致初始电感值下降10%的直流电流。 - 温升电流(Irms):使电感器表面温度上升40℃的直流电流(参考环境温度20℃)。
应用信息:适用于便携式通信设备、笔记本电脑LCD、液晶电视、VTR电源、DC/DC转换器等。
封装信息:文档中提供了3316和5022两种型号的封装尺寸和推荐焊盘图案。
PBO5022-331MT 价格&库存
很抱歉,暂时无法提供与“PBO5022-331MT”相匹配的价格&库存,您可以联系我们找货
