Approval Sheet
for
Carbon Film Resistors
General Type
CFR series
±2% & ±5%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-6629-9999 Fax: 886-2-6628-8885
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
Jul 16, 2007
Sara Lin
Joyce Chung
01
Add new lead dia for 52.4mm
Nov 8, 2007
Lynn Chen
Joyce Chung
02
New lead dia is included(F:φd≥0.6mm)
Jan 31, 2008
Lynn Chen
Joyce Chung
03
Add special forming type(52H)
Apr 22, 2009
Lynn Chen
Ken Hsu
04
Jan 11, 2011
Feng Ye
Ken Hsu
05
The environmental characteristics are
adjusted.
“MB”, “MR” forming types are included
Jul 14, 2011
Feng Ye
Ken Hsu
06
“62-” special type is included
Dec 05, 2011
Feng Ye
Ken Hsu
07
Mar 07, 2012
Feng Ye
Ken Hsu
08
Revise the applicable range of PN & AV
types forming for taping.
26A &26C types are included
Mar 29, 2012
Feng Ye
Ken Hsu
09
Revise S.T.O test description
Mar 31, 2012
Feng Ye
Ken Hsu
10
May 31, 2013
Feng Ye
Flora Shen
Jun.24, 2014
Feng Ye
Flora Shen
Sep.22, 2014
Feng Ye
Flora Shen
Sep.23, 2015
Feng Ye
Flora Shen
14
Dimension h of FK&FFK&FKK types is
revised; “62-” special type is deleted;
Add “H” dimension for Short lead type
for CFR200&CFR3WS types
Revise forming pitch value from 6±1 to
8±1 for CFR200&CFR3WS types
Revised the dia. of 52T type. Deleted
the MR type.
T-63 type is included
Aug.30, 2016
Feng Ye
Flora Shen
15
Deleted 52T type.
Jun.12, 2018
Mingfa Liu
Feng Ye
16
Revised the dimension “A” of tape on
reel packing , Add dimension “B” for
tape on reel packing.
Feb.25, 2020
Mingfa Liu
Feng Ye
Rev.
16
11
12
13
Description
Carbon Film Resistors, General Type
Series
CFR
Page-2
1.
PRODUCT:
CARBON FILM RESISTORS-GENERAL TYPE
(Normal & Miniature Style)
2.
PART NUMBER:
Part number of the carbon film resistor is identified by the name, power, tolerance, packing, temperature
coefficient, special type and resistance value. The resistors are coated with layers of tan color lacquer.
Example:
CFR
-12
J
T
52H
100R
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Series Power Resistance Packing Temperature Special Resistance
Name Rating Tolerance Style
Coefficient
Type
Value
of Resistance
(1) Style: CFR SERIES
(2) Power Rating:
-12=1/6W、25S=1/4W、-25=1/4W、50S=1/2W、-50=1/2W、
1WS=1W、100=1W、2WS=2W、200=2W 、3WS=3W
(3) Tolerance: G=±2%
(4) Packaging Type:
J=±5%
R = Paper Taping Reel
T = Tape on Box Packing
B = Bulk Packing
(5) Temperature Coefficient: “-“=Base on spec., see p.4 Table 1
(6) Special Type:
26- = 26mm, 52- = 52.4mm, 73- = 73mm
26A = 26mm with 0.4±0.02mm Φd
26C = 26mm with 0.5±0.02mm Φd
26G = 26mm with Φd ≥ 0.6mm
52A = 52.4mm with 0.4±0.02mm Φd
52B = 52.4mm with 0.45±0.02mm Φd
52C = 52.4mm with 0.5±0.02mm Φd
52G = 52.4mm with Φd ≥ 0.6mm
52H = 52.4mm without lacquer on soldering spots
63F = 63mm with 0.55±0.05mm Φd
73G = 73mm with Φd ≥ 0.6mm
M = M Type Forming for Bulk
MB=MB-Type Forming
F = F Type Forming for Bulk
FK = FK Type Forming
FFK = FFK Type Forming
FKK = FKK Type Forming
MT = MTsert ( rated watts -12 & 25s size only )
PN = PANAsert (rated watts from 1/4W to 2WS applicable only )
AV = Avlsert (rated watts from 1/4W to 2WS applicable only )
(7) Resistance Value: E24 Series
Example: 1R、10R、100R、10K、100K、330K、1M……
Page-3
3. BAND-CODE:
COLOR
BLACK
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GREY
WHITE
GOLD
SILVER
1ST BAND
2
3
4
5
6
7
8
9
2ND BAND
2
3
4
5
6
7
8
9
MULTIPLIER
1Ω
10Ω
100Ω
1KΩ
10KΩ
100KΩ
1MΩ
10MΩ
TOLERANCE
0.1Ω
0.01Ω
± 5 % (J )
± 2% (G )
4. ELECTRICAL CHARACTERISTICS
TABLE 1
STYLE
CFR-12
CFR25S
CFR-25 CFR50S
CFR-50 CFR1WS CFR100 CFR2WS
Power Rating at 70 ℃
1/6W
1/4W
Maximum Working Voltage
150V
200V
250V
300V
350V
400V
500V
Maximum Overload Voltage
300V
400V
500V
600V
700V
800V
1000V
Voltage Proof
300V
400V
500V
700V
1000V
Resistance Range
1Ω ~ 10MΩ & 0Ω for E24 series value
Operating Temp. Range
- 55 ℃ to + 155 ℃
see Table. 2
1/2W
1W
2W
* Below or over this resistance on request.
TABLE.2
TEMPERATURE COEFFICIENT
STYLE
CFR100, CFR200, CFR2WS
CFR3WS
CFR-12 , CFR-25 , CFR-50
CFR25S , CFR50S , CFR1WS
Max. Va lue of Te m p. Coef f ic ie nt pp m/ ℃
Under 100KΩ
100K ~ 1MΩ
1M ~ 10MΩ
± 350
-500~0
-1500~0
+ 350 ~ - 500
-700~0
-1500~0
Page-4
CFR200
CFR3WS
3W
5. DERATING CURVE
Rated Load (%)
70℃
100
80
60
40
60
80
100
120
140
155
180
Ambient Temperature (℃)
6. DIMENSIONS
ψd
ψD
L
H
STYLE
DIMENSION
ψD
L
H
ψd
Normal
Miniature
CFR-12
CFR25S
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
CFR-25
CFR50S
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
CFR-50
CFR1WS
9.0±0.5
3.3±0.3
CFR100
CFR2WS
11.5±1.0
4.5±0.5
CFR200
CFR3WS
15.5±1.0
5.0±0.5
26±2.0(T-52 type)
32±2.0(T-63F type)
35±2.0 (T-73 type)
25±2.0 (T-52 type)
33±2.0
0.55±0.05
0.8±0.05
0.8±0.05
7. ENVIRONMENTAL CHARACTERISTICS
(1) Short Time Over Load Test
At 2.5 times of the rated voltage or max. overload voltage for 5 seconds, whichever is less; the resistor
should be free from defects after the resistor is released from load for about 30 minutes
Rated Voltage =
Power Rating ´ Resistance Value
The change of the resistance value should be within ± 0.75 % + 0.05Ω
(2) Voltage Proof
The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage specified
in the “Table I “ between the terminals connected together with the block for about 60 seconds.
The resistor shall be able to withstand without breakdown or flashover.
Page-5
(3) Temperature Coefficient Test
Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the
constant temperature silicon plate for over 5 minutes. Then measure the resistance value.
The Temperature Coefficient is calculated by the following equation and its value should be within the
range of requested.
Re sistor Temperatur e Coefficien t =
R
R0
t
to
R - R0
1
´ 10 6
R0
t - t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= The testing temperature
= Room temperature
(4) Insulation Resistance
Apply "measuring voltage" between protective coating and termination for 1 min.,then measure. The
measuring voltage shall be either 100V±15V d.c. for resistors with an insulation voltage lower than 500V
or 500V±50V d.c. for resistors with an insulatin voltage equal to or greater than 500V.
The test resistance should be high than 1,000M ohm.
(5) Solderability
Immerse the specimen into the solder pot at 245 ± 5 °C for 3 ± 0.5 seconds.
At least 95% solder coverage on the termination.
(6) Solvent Resistance of Marking
The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes.
The specimen is no deterioration of coatings and color code.
(7) Robustness of Terminations
Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the
direction of the longitudinal axis of the resistor unit the applied load reached the requirement.
The load shall be held for 10 seconds. The load of weight shall be ≧ 2.5 kg ( 24.5N ).
(8) Damp Heat Steady State
Place the specimen in a test chamber at 40 ± 2 °C and 90 ~ 95 % relative humidity. Apply the 0.1 times
rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56
days.
The change of the resistance value shall be within ± 3.0 % + 0.05 Ω
(9) Endurance at 70 °C
Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire
at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected
mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90
minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for
1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value.
The change of the resistance value shall be within ± 3.0 % + 0.05 Ω.
There shall be no remarkable change in the appearance and the color code shall be legible after the test.
Page-6
(10) Temperature Cycling Test
The temperature cycle shown in the following table shall be repeated 5 times consecutively. The
measurement of the resistance value is done before the first cycle and after ending the fifth cycle,
leaving in the room temperature for about 1 hour.
Temperature Cycling Conditions:
Step
1
2
3
4
Temperature(°C)
-40 ± 3
25 ± 3
155 ± 3
25 ± 3
Time (minute)
30
10 ~ 15
30
10 ~ 15
The change of the resistance value shall be within ± 1.0 % + 0.05 Ω
After the test the resistor shall be free from the electrical or mechanical damage.
(11) Resistance to Soldering Heat
The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5
mm.
(12) Pulse Overload
Apply 4 times of rated voltage to the specimen at the 1 second on and 25 seconds off cycle, subjected
to voltage application cycles specified in 10,000 time.
The change of the resistance value shall be within ± 1.0% + 0.05 Ω
8. PACKING METHODS
Bandolier for Axial leads
STYLE
Normal
Miniature
a
CFR-12
CFR25S
6 ± 0.5
CFR-25
CFR50S
6 ± 0.5
CFR-50
CFR1WS
6 ± 0.5
CFR100
CFR2WS
6 ± 0.5
CFR200
CFR3WS
6 ± 0.5
DIMENIONS
A
B1-B2
52.4 ± 1.0
1.2
26.0 ± 1.0
1.0
52.4 ± 1.0
1.2
26.0 ± 1.0
1.0
52.4 ± 1.0
1.2
63.0 ± 1.0
73.0 ± 1.5
52.4 ± 1.0
73.0 ± 1.5
52.4 ± 1.0
1.5
1.5
1.2
1.5
1.2
Page-7
Unit::mm
S (spacing) T (max. deviation of spacing)
5
5
5
5
10
1 mm per 10 spacing
0.5 mm per 5 spacing
9. TAPE ON REEL PACKING
STYLE
Normal
Miniature
TAPE ON REEL
ACROSS FLANGE ( A )
B
Qty per reel
CFR-12
CFR25S
66.5
75.5
5,000
CFR-25
CFR50S
66.5
75.5
5,000
CFR-50
CFR1WS
66.5
75.5
2,500
CFR100
CFR2WS
87
96
2,000
CFR200
CFR3WS
87
96
1,000
10. TAPE ON BOX PACKING
STYLE
Standard Lead Length
Short Lead Length
Qty per box
Normal
Miniature
W(A)
H(B)
L(C)
W(A)
H(B)
L(C)
CFR-12
CFR25S
81
70
260
48
102
255
5,000
CFR-25
CFR50S
81
104
260
48
102
255
5,000
CFR-50
CFR1WS
73
45
258
CFR100
CFR2WS
103
78
260
81
91
260
1,000
CFR200
CFR3WS
103
94
260
81
91
260
1,000
Page-8
1,000
11. SPECIAL TYPE ( FORMING DIMENSIONS )
M TYPE
STYLE
DIMENSIONS
UNIT:mm
Normal
Miniature
L
ψD
ψd
P
H
CFR-12
CFR25S
3.4± 0.3
1.9 ± 0.2
0.45 ± 0.05
6.0±1.0
10.0 ±1
CFR-25
CFR50S
6.3 ± 0.5
2.4 ± 0.2
0.55 ± 0.05
10.0 ± 1
10.0 ± 1
CFR-50
CFR1WS
9.0 ± 0.5
3.3± 0.3
0.55 ± 0.05
12.5 ± 1
10.0 ± 1
CFR100
CFR2WS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
15.0 ± 1
12.5 ± 1
CFR200
CFR3WS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
20.0 ± 1
15.0 ± 1
MB TYPE
STYLE
DIMENSIONS
UNIT:mm
Normal
Miniature
L
ψD
ψd
P
H1
H2
t
CFR-25
CFR50S
6.3 ± 0.5
2.4± 0.2
0.55 ± 0.05
10.0 ± 1
6.0 ± 1
5.0 ± 1
1.2 ± 0.2
CFR-50
CFR1WS
9.0 ± 0.5
3.3± 0.3
0.55 ± 0.05
12.5 ± 1
6.0 ± 1
5.0 ± 1
1.2 ± 0.2
CFR100
CFR2WS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
15.0 ± 1
6.0 ± 1
5.0 ± 1
1.4 ± 0.2
CFR200
CFR3WS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
20.0 ± 1
10.0 ± 1
5.0 ± 1
1.4 ± 0.2
Page-9
F TYPE
STYLE
Normal
Miniature
CFR100
CFR2WS
CFR200
CFR3WS
DIMENSIONS
ψd
P
h1
H1 max
E max
11.5 ± 1.0 4.5 ± 0.5
0.8 ± 0.05
6.0 ± 1
5.0 ± 1
15.5 ± 1.0 5.0 ± 0.5
0.8 ± 0.05
8.0 ± 1
5.0 ± 1
25
3.5
L
ψD
UNIT:mm
DIMENSIONS
STYLE
UNIT:mm
Normal
Miniature
L
ψD
ψd
P
h
H max
E max
CFR100
CFR2WS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
6.0 ± 1
8.0 ± 1
25
3.5
CFR200
CFR3WS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
8.0 ± 1
8.0 ± 1
30
3.5
Page-10
MT Type Forming for Taping
( Rated Watts -12 & 25S size only )
PN Type Forming for Taping
AV Type Forming for Taping
Page-11
12. Plant Address
A.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
B.
China Suzhou Plant
No.158, Jinchang Road, No.1 Building of NanBangIND.Zone,
Mu Du New District, Suzhou, China
(江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號)
Tel. 86-512-66518889
Fax. 86-512-66519889
Page-12
