C82683JAE4RLC
C82683JAE4RLC
    SRD(圣融达)
    插件
    薄膜电容 径向
C82683JAE4RLC 数据手册
盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 引用标准 Reference standards GB10190(IEC384-16) ■ 结构 Structure 介质:聚丙烯膜 电极:双面金属化聚酯膜 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: polypropylene film Electrode:double side metallized polyester film Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0 Box: Flame retardant PBT plastic shell, conforming to UL94 V-0 ■ 典型应用 Typical Application 广泛应用于高压高频脉冲电路中 适用于变频器的谐振电路中 适用于 LED 驱动和开关电源高效电路 吸收和 SCR 整流电路中 ■ Widely used in high voltage high frequency pulse circuit. Applicable for resonant circuit of frequency converter. Suitable for LED driver and switching power supply high efficiency circuit Snubber circuit and SCR rectifying circuit 特点 Features 损耗小,内部温升小, 小型化的安装尺寸,优异的阻燃性能(UL94V-0) Low loss and low internal temperature rise, small mounting size, Excellent flame resistance property. ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category 40/105/56 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.25% per ℃ for R.V(DC) (+85℃~+105℃): 额定电压降额使用系数 1.25% per ℃ for R.V(DC) 额定电压 Rated Voltage 630VDC, 1000VDC,1600VDC,2000VDC,3000VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.001μF~1.2μF Capacitance Range 测试条件 Test Condition: 耐电压 1.6UR,5S Withstand Voltage 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.33μF IR≥100000MΩ Insulation Resistance CR>0.33μF IR≥30000S 最大脉冲爬升速率 Max. Pulse Rise Time (dV / dt) (1KHZ ) 20℃, 1KHz, 1Vrms 无击穿或飞弧 No breakdown or electric arcing 测试条件 Test Condition : 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min UR(V) P15 P22.5 P27.5 630V 2500 1600 1000 1000V 3500 2500 1300 1600V 6300 3200 2200 2000V 10000 5000 2500 3000V 10000 8000 --- 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0015(10KHz) dissipation factor rise:≤0.0015(10KHz) 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% ■ 产品编码说明 Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 11 C 4 Digit 1-3 8 2 1 0 4 J 型号代码 Product Name Code 2 J E 12 R 13 14 15 8 * * C82= MMKP82 series Digit 4-6 标称容量 Rated Capacitance Value For example : 104 = 10×104pF = 0.1F Digit 7 容量偏差 Capacitance Tolerance J=±5% Digit 8-9 额定电压 Rated Voltage Code 2J=630V 3A=1000V 3C=1600V 3D=2000V 3E=3000V Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :630Vdc(400Vac) 成品编码 Part No. 容量 系列 Series Capacitance 尺寸 Dimension (mm) (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 C82103J2JD1R6LC MMKP82 0.01 18 5 11 15 0.6 C82123J2JD1R6LC MMKP82 0.012 18 5 11 15 0.6 C82103J2JD2R8LC MMKP82 0.01 18 6 12 15 0.8 C82183J2JD2R8LC MMKP82 0.018 18 6 12 15 0.8 C82223J2JD2R8LC MMKP82 0.022 18 6 12 15 0.8 C82273J2JD2R8LC MMKP82 0.027 18 6 12 15 0.8 C82333J2JD2R8LC MMKP82 0.033 18 6 12 15 0.8 C82393J2JD2R8LC MMKP82 0.039 18 6 12 15 0.8 C82473J2JD2R8LC MMKP82 0.047 18 6 12 15 0.8 C82473J2JD3R8LC MMKP82 0.047 18 7.5 13.5 15 0.8 C82563J2JD3R8LC MMKP82 0.056 18 7.5 13.5 15 0.8 C82683J2JD4R8LC MMKP82 0.068 18 8.4 14.5 15 0.8 C82823J2JD4R8LC MMKP82 0.082 18 8.4 14.5 15 0.8 C82104J2JD6R8LC MMKP82 0.1 18 10 15.8 15 0.8 C82124J2JD6R8LC MMKP82 0.12 18 10 15.8 15 0.8 C82124J2JD8R8LC MMKP82 0.12 18 11.2 19.2 15 0.8 C82333J2JE1R8A0 MMKP82 0.033 26.5 6 15 22.5 0.8 C82393J2JE1R8LC MMKP82 0.039 26.5 6 15 22.5 0.8 C82473J2JE1R8LC MMKP82 0.047 26.5 6 15 22.5 0.8 C82563J2JE1R8LC MMKP82 0.056 26.5 6 15 22.5 0.8 C82683J2JE1R8LC MMKP82 0.068 26.5 6 15 22.5 0.8 C82823J2JE1R8LC MMKP82 0.082 26.5 6 15 22.5 0.8 C82104J2JE1R8LC MMKP82 0.1 26.5 6 15 22.5 0.8 C82683J2JE2R8LC MMKP82 0.068 26.5 7 16.5 22.5 0.8 C82823J2JE2R8LC MMKP82 0.082 26.5 7 16.5 22.5 0.8 C82124J2JE2R8LC MMKP82 0.12 26.5 7 16.5 22.5 0.8 C82124J2JE3R8LC MMKP82 0.12 26.5 8.5 17 22.5 0.8 C82154J2JE3R8LC MMKP82 0.15 26.5 8.5 17 22.5 0.8 C82184J2JE3R8LC MMKP82 0.18 26.5 8.5 17 22.5 0.8 C82154J2JE4R8LC MMKP82 0.15 26.5 10 19 22.5 0.8 C82224J2JE4R8LC MMKP82 0.22 26.5 10 19 22.5 0.8 C82274J2JE5R8LC MMKP82 0.27 26.5 11 20 22.5 0.8 C82224J2JE6R8LC MMKP82 0.22 26 12 21.5 22.5 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series C82284J2JE6R8LC MMKP82 0.28 26 12 21.5 22.5 0.8 C82334J2JE6R8LC MMKP82 0.33 26 12 21.5 22.5 0.8 C82394J2JE6R8LC MMKP82 0.39 26 12 21.5 22.5 0.8 C82334J2JF1R8LC MMKP82 0.33 31.5 10.8 19.5 27.5 0.8 C82394J2JF1R8LC MMKP82 0.39 31.5 10.8 19.5 27.5 0.8 C82474J2JF2R8LC MMKP82 0.47 31.5 13 21.6 27.5 0.8 C82564J2JF2R8LC MMKP82 0.56 31.5 13 21.6 27.5 0.8 C82684J2JF3R8LC MMKP82 0.68 31 14 25 27.5 0.8 C82824J2JF4R8LC MMKP82 0.82 31.5 16 25.5 27.5 0.8 C82105J2JF5R8LC MMKP82 1 31.5 16 30 27.5 0.8 C82125J2JF5R8LC MMKP82 1.2 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 ■ “**”=Internal use. 料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc(600Vac) 容量 成品编码 Part No. Capacitan 系列 Series ce W±0.5 (μF) 尺寸 Dimension (mm) T±0.5 H±0.5 P±0.5 d±0.05 C82102J3AC2R6LC MMKP82 0.001 13 5 11 10 0.6 C82122J3AC2R6LC MMKP82 0.0012 13 5 11 10 0.6 C82152J3AC2R6LC MMKP82 0.0015 13 5 11 10 0.6 C82182J3AC2R6LC MMKP82 0.0018 13 5 11 10 0.6 C82222J3AC2R6LC MMKP82 0.0022 13 5 11 10 0.6 C82272J3AC2R6LC MMKP82 0.0027 13 5 11 10 0.6 C82332J3AC2R6LC MMKP82 0.0033 13 5 11 10 0.6 C82392J3AC2R6LC MMKP82 0.0039 13 5 11 10 0.6 C82472J3AC2R6LC MMKP82 0.0047 13 5 11 10 0.6 C82562J3AC2R6LC MMKP82 0.0056 13 5 11 10 0.6 C82682J3AC2R6LC MMKP82 0.0068 13 5 11 10 0.6 C82822J3AC2R6LC MMKP82 0.0082 13 5 11 10 0.6 C82103J3AC2R6LC MMKP82 0.01 13 5 11 10 0.6 C82392J3AD1R6LC MMKP82 0.0039 18 5 11 15 0.6 C82562J3AD1R6LC MMKP82 0.0056 18 5 11 15 0.6 C82822J3AD2R8LC MMKP82 0.0082 18 6 12 15 0.8 C82103J3AD2R8LC MMKP82 0.01 18 6 12 15 0.8 C82123J3AD2R8LC MMKP82 0.012 18 6 12 15 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series C82153J3AD2R8LC MMKP82 0.015 18 6 12 15 0.8 C82153J3AD3R8LC MMKP82 0.015 18 7.5 13.5 15 0.8 C82183J3AD3R8LC MMKP82 0.018 18 7.5 13.5 15 0.8 C82223J3AD3R8LC MMKP82 0.022 18 7.5 13.5 15 0.8 C82473J3AD3R8LC MMKP82 0.047 18 7.5 13.5 15 0.8 C82683J3AD3R8LC MMKP82 0.068 18 7.5 13.5 15 0.8 C82273J3AD4R8LC MMKP82 0.027 18 8.4 14.5 15 0.8 C82333J3AD4R8LC MMKP82 0.033 18 8.4 14.5 15 0.8 C82333J3AD6R8LC MMKP82 0.033 18 10 15.8 15 0.8 C82393J3AD6R8LC MMKP82 0.039 18 10 15.8 15 0.8 C82563J3AD7R8LC MMKP82 0.056 18 10.8 19 15 0.8 C82393J3AD8R8LC MMKP82 0.039 18 11.2 19.2 15 0.8 C82473J3AD8R8LC MMKP82 0.047 18 11.2 19.2 15 0.8 说明 Note: “**”表示内部特征码 ■ “**”=Internal use. 料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc(600Vac) 容量 成品编码 Part No. Capacita 系列 Series nce W±0.5 (μF) 尺寸 Dimension (mm) T±0.5 H±0.5 P±0.5 d±0.05 C82273J3AE1R8LC MMKP82 0.027 26.5 6 15 22.5 0.8 C82333J3AE1R8LC MMKP82 0.033 26.5 6 15 22.5 0.8 C82393J3AE1R8LC MMKP82 0.039 26.5 6 15 22.5 0.8 C82273J3AE2R8LC MMKP82 0.027 26.5 7 16.5 22.5 0.8 C82333J3AE2R8LC MMKP82 0.033 26.5 7 16.5 22.5 0.8 C82473J3AE2R8LC MMKP82 0.047 26.5 7 16.5 22.5 0.8 C82563J3AE2R8LC MMKP82 0.056 26.5 7 16.5 22.5 0.8 C825633AE3R8LC MMKP82 0.056 26.5 8.5 17 22.5 0.8 C82683J3AE3R8LC MMKP82 0.068 26.5 8.5 17 22.5 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series C82683J3AE4R8LC MMKP82 0.068 26.5 10 19 22.5 0.8 C82823J3AE4R8LC MMKP82 0.082 26.5 10 19 22.5 0.8 C82104J3AE4R8LC MMKP82 0.1 26.5 10 19 22.5 0.8 C82104J3AE5R8LC MMKP82 0.12 26.5 11 20 22.5 0.8 C82124J3AE5R8LC MMKP82 0.12 26.5 11 20 22.5 0.8 C82154J3AE6R8LC MMKP82 0.15 26 12 21.5 22.5 0.8 C82104J3AF1R8LC MMKP82 0.1 31.5 10.8 19.5 27.5 0.8 C82124J3AF1R8LC MMKP82 0.12 31.5 10.8 19.5 27.5 0.8 C82154J3AF1R8LC MMKP82 0.15 31.5 10.8 19.5 27.5 0.8 C82184J3AF2R8LC MMKP82 0.18 31.5 13 21.6 27.5 0.8 C82224J3AF2R8LC MMKP82 0.22 31.5 13 21.6 27.5 0.8 C82274J3AF3R8LC MMKP82 0.27 31 14 25 27.5 0.8 C82334J3AF4R8LC MMKP82 0.33 31.5 16 25.5 27.5 0.8 C82394J3AF5R8LC MMKP82 0.39 31.5 16 30 27.5 0.8 C82474J3AF9R8LC MMKP82 0.47 31.5 18 28 27.5 0.8 说明 Note: “**”表示内部特征码 ■ “**”=Internal use. 料号明细及尺寸 Part No. List and Dimensions UR :1600Vdc(650Vac) 成品编码 Part No. 容量 系列 Series Capacitance 尺寸 Dimension (mm) (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82122J3CD2R8LC MMKP82 0.0012 18 6 12 15 0.8 C82152J3CD2R8LC MMKP82 0.0015 18 6 12 15 0.8 C82182J3CD2R8LC MMKP82 0.0018 18 6 12 15 0.8 C8222J3CD2R8LC MMKP82 0.0022 18 6 12 15 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series C82272J3CD2R8LC MMKP82 0.0027 18 6 12 15 0.8 C82332J3CD2R8LC MMKP82 0.0033 18 6 12 15 0.8 C82392J3CD2R8LC MMKP82 0.0039 18 6 12 15 0.8 C82472J3CD2R8LC MMKP82 0.0047 18 6 12 15 0.8 C82562J3CD2R8LC MMKP82 0.0056 18 6 12 15 0.8 C82682J3CD2R8LC MMKP82 0.0068 18 6 12 15 0.8 C82822J3CD2R8LC MMKP82 0.0082 18 6 12 15 0.8 C82103J3CD2R8LC MMKP82 0.01 18 6 12 15 0.8 C82123J3CD3R8LC MMKP82 0.012 18 7.5 13.5 15 0.8 C82153J3CD3R8LC MMKP82 0.015 18 7.5 13.5 15 0.8 C82183J3CD4R8LC MMKP82 0.018 18 8.4 14.5 15 0.8 C82223J3CD4R8LC MMKP82 0.022 18 8.4 14.5 15 0.8 C82273J3CD6R8LC MMKP82 0.027 18 10 15.8 15 0.8 C82273J3CDAR8LC MMKP82 0.027 18 10 15.8 15 0.8 C82333J3CD8R8LC MMKP82 0.033 18 11.2 19.2 15 0.8 C82153J3CE1R8LC MMKP82 0.015 26.5 6 15 22.5 0.8 C82103J3CE2R8LC MMKP82 0.01 26.5 7 16.5 22.5 0.8 C82183J3CE1R8LC MMKP82 0.018 26.5 6 15 22.5 0.8 C82223J3CE1R8LC MMKP82 0.022 26.5 6 15 22.5 0.8 C82273J3CE2R8LC MMKP82 0.027 26.5 7 16.5 22.5 0.8 C82333J3CE2R8LC MMKP82 0.033 26.5 7 16.5 22.5 0.8 C82393J3CE3R8LC MMKP82 0.039 26.5 8.5 17 22.5 0.8 C82473J3CE4R8LC MMKP82 0.047 26.5 10 19 22.5 0.8 C82563J3CE4R8LC MMKP82 0.056 26.5 10 19 22.5 0.8 C82683J3CE5R8LC MMKP82 0.068 26.5 11 20 22.5 0.8 C82823J3CE6R8LC MMKP82 0.082 26 12 21.5 22.5 0.8 C82823J3CF1R8LC MMKP82 0.082 31.5 10.8 19.5 27.5 0.8 C82104J3CF1R8LC MMKP82 0.1 31.5 10.8 19.5 27.5 0.8 C82124J3CF2R8LC MMKP82 0.12 31.5 13 21.6 27.5 0.8 C82154J3CF3R8LC MMKP82 0.15 31 14 25 27.5 0.8 C82184J3CF3R8LC MMKP82 0.18 31 14 25 27.5 0.8 C82224J3CF5R8LC MMKP82 0.22 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 料号明细及尺寸 Part No. List “**”=Internal use. and Dimensions 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series UR :2000Vdc(700Vac) 成品编码 Part No. 系列 容量 Serie Capacitance s (μF) 尺寸 Dimension (mm) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82151K3DD2R8LC MMK P82 0.00015 18 6 12 15 0.8 C82331K3DD2R8LC MMK P82 0.00033 18 6 12 15 0.8 C82821K3DD2R8LC MMK P82 0.00082 18 6 12 15 0.8 C82102J3DD2R8LC MMK P82 0.001 18 6 12 15 0.8 C82122J3DD2R8LC MMK P82 0.0012 18 6 12 15 0.8 C82152J3DD2R8LC MMK P82 0.0015 18 6 12 15 0.8 C82182J3DD2R8LC MMK P82 0.0018 18 6 12 15 0.8 C82222J3DD2R8LC MMK P82 0.0022 18 6 12 15 0.8 C82272J3DD2R8LC MMK P82 0.0027 18 6 12 15 0.8 C82332J3DD2R8LC MMK P82 0.0033 18 6 12 15 0.8 C82392J3DD2R8LC MMK P82 0.0039 18 6 12 15 0.8 C82472J3DD2R8LC MMK P82 0.0047 18 6 12 15 0.8 C82562J3DD3R8LC MMK P82 0.0056 18 7.5 13.5 15 0.8 C82682J3DD3R8LC MMK P82 0.0068 18 7.5 13.5 15 0.8 C82822J3DD4R8LC MMK P82 0.0082 18 8.4 14.5 15 0.8 C82103J3DD6R8LC MMK P82 0.01 18 10 15.8 15 0.8 C82123J3DD6R8LC MMK P82 0.012 18 10 15.8 15 0.8 C82123J3DD8R8LC MMK P82 0.012 18 11.2 19.2 15 0.8 C82153J3DD8R8LC MMK P82 0.015 18 11.2 19.2 15 0.8 C82103J3DE1R8LC MMK 0.01 26.5 6 15 22.5 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series P82 C82123J3DE1R8LC MMK P82 0.012 26.5 6 15 22.5 0.8 C82153J3DE2R8LC MMK P82 0.015 26.5 7 16.5 22.5 0.8 C82183J3DE2R8LC MMK P82 0.018 26.5 7 16.5 22.5 0.8 C82223J3DE3R8LC MMK P82 0.022 26.5 8.5 17 22.5 0.8 C82273J3DE4R8LC MMK P82 0.027 26.5 10 19 22.5 0.8 C82333J3DE4R8LC MMK P82 0.033 26.5 10 19 22.5 0.8 C82393J3DE5R8LC MMK P82 0.039 26.5 11 20 22.5 0.8 C82333J3DE6R8LC MMK P82 0.033 26.5 12 21.5 22.5 0.8 C82473J3DE6R8LC MMK P82 0.047 26.5 12 21.5 22.5 0.8 C82393J3DF1R8LC MMK P82 0.039 31.5 10.8 19.5 27.5 0.8 C82473J3DF1R8LC MMK P82 0.047 31.5 10.8 19.5 27.5 0.8 C82563J3DF2R8LC MMK P82 0.056 31.5 13 21.6 27.5 0.8 C82683J3DF2R8LC MMK P82 0.068 31.5 13 21.6 27.5 0.8 C82823J3DF3R8LC MMK P82 0.082 31 14 25 27.5 0.8 C82104J3DF4R8LC MMK P82 0.1 31.5 16 25.5 27.5 0.8 C82124J3DF4R8LC MMK P82 0.12 31.5 16 25.5 27.5 0.8 C82154J3DF5R8LC MMK P82 0.15 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 ■ “**”=Internal use. 料号明细及尺寸 Part No. List and Dimensions UR 3000Vdc(750Vac) 成品编码 Part No. C82102J3FD2R8LC 容量 系列 Series Capacitance MMKP82 尺寸 Dimension (mm) (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 0.001 18.0 6.0 12.0 15.0 0.8 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series C82122J3FD2R8LC MMKP82 0.0012 18.0 6.0 12.0 15.0 0.8 C82152J3FD2R8LC MMKP82 0.0015 18.0 6.0 12.0 15.0 0.8 C82182J3FD2R8LC MMKP82 0.0018 18.0 6.0 12.0 15.0 0.8 C82222J3FD2R8LC MMKP82 0.0022 18.0 6.0 12.0 15.0 0.8 C82272J3FD2R8LC MMKP82 0.0027 18.0 6.0 12.0 15.0 0.8 C82332J3FD3R8LC MMKP82 0.0033 18.0 7.5 13.5 15.0 0.8 C82392J3FD3R8LC MMKP82 0.0039 18.0 7.5 13.5 15.0 0.8 C82472J3FD4R8LC MMKP82 0.0047 18.0 8.4 14.5 15.0 0.8 C82562J3FD5R8LC MMKP82 0.0056 18.0 9.5 15.5 15.0 0.8 C82682J3FD6R8LC MMKP82 0.0068 18.0 9.5 15.5 15.0 0.8 C82822J3FD8R8LC MMKP82 0.0082 18.0 11.2 19.2 15.0 0.8 C82332J3FE1R8LC MMKP82 0.0033 26.5 6 15 22.5 0.8 C82442J3FE2R8LC MMKP82 0.0044 26.5 7.0 16.5 22.5 0.8 C82472J3FE2R8LC MMKP82 0.0047 26.5 7.0 16.5 22.5 0.8 C82562J3FE2R8LC MMKP82 0.0056 26.5 7.0 16.5 22.5 0.8 C82682J3FE2R8LC MMKP82 0.0068 26.5 7.0 16.5 22.5 0.8 C82822J3FE3R8LC MMKP82 0.0082 26.5 8.5 17.0 22.5 0.8 C82103J3FE3R8LC MMKP82 0.01 26.5 8.5 17.0 22.5 0.8 C82123J3FE4R8LC MMKP82 0.012 26.5 10.0 19.0 22.5 0.8 C82153J3FE4R8LC MMKP82 0.015 26.5 10 19 22.5 0.8 C82153J3FE5R8LC MMKP82 0.015 26.5 11.0 20.0 22.5 0.8 C82183J3FE6R8LC MMKP82 0.018 26 12.0 21.5 22.5 0.8 C82223J3FE6R8LC MMKP82 0.022 26.5 12 21.5 22.5 0.8 C82223J3FE7R8LC MMKP82 0.022 26.5 13.0 23.0 22.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use Note: We can customize the capacitors according to customers special requirements.
C82683JAE4RLC
物料型号:MMKP82(C82)系列
器件简介: - 产品名称:盒装型双面金属化聚丙烯膜电容器 - 电介质:聚丙烯膜 - 电极:双面金属化聚酯膜 - 封装:阻燃环氧树脂,符合UL94 V-0标准 - 外壳:阻燃PBT塑壳,符合UL94 V-0标准
引脚分配:未在文档中明确说明,但通常这类电容器会有标识说明引脚分配
参数特性: - 额定温度:85°C - 工作温度范围:-40°C至+105°C - 额定电压:630VDC, 1000VDC, 1600VDC, 2000VDC, 3000VDC - 容量误差:±5% - 容量范围:0.001μF至1.2μF - 耐电压:1.6UR,持续5秒,无击穿或飞弧 - 损耗角:≤0.001 (1KHz) - 绝缘电阻:根据容量不同,阻值不同,例如CR≤0.33μF时IR≥100000MΩ,CR>0.33μF时IR≥30000S
功能详解: - 广泛应用于高压高频脉冲电路 - 适用于变频器的谐振电路 - 适用于LED驱动和开关电源高效电路 - 吸收和SCR整流电路中使用 - 特点包括低损耗、低内部温升、小型化安装尺寸、优异的阻燃性能
应用信息: - 符合RoHS及REACH环保标准
封装信息: - 产品编码说明:15位产品编码,包括型号代码、标称容量、容量偏差、额定电压代码、壳号、塑壳颜色、线径代码、成型或内部识别码 - 例如:104=10×10^4pF=0.1μF,J=±5%,2J=630V,3A=1000V,3C=1600V,3D=2000V,3E=3000V,R=塑壳顶部带有LOGO的灰色
产品尺寸:文档中提供了不同型号的尺寸信息,包括宽度(W)、厚度(T)、高度(H)、引脚间距(P)和中径(d)。
C82683JAE4RLC 价格&库存
很抱歉,暂时无法提供与“C82683JAE4RLC”相匹配的价格&库存,您可以联系我们找货
